Page 1 of 3 123 LastLast
Results 1 to 40 of 98
    Oct 29 2005
    10speed
    San Francisco, CA
    The 1.8T Wiring Harness Explained
    Hey guys, thought I’d document this for people always trying to figure this stuff out. This should also help for my 2.7T swap. This is for a 2002 harness and I am missing a few connectors like SAI and MAF.
    MAP Sensor
    Connector: Black (4 pin)
    1: Black
    2: Empty
    3: White with black stripe
    4: Grey with blue stripe
    Oil Level
    Connector: Black (3 pin)
    1: Black with red stripe
    2: Brown
    3: Red with green stripe
    Thermostat (possibly wrong)
    Connector: Black (2 pin)
    1: Brown
    2: Blue with brown stripe
    Lower Coolant Temp Sensor
    1: Yellow with black stripe
    2: Blue with black stripe
    Throttle Body
    Connector: Black (6 pin)
    1: Purple with red stripe
    2: Green with purple stripe
    3: Red with purple stripe
    4: Purple with red stripe
    5: Brown with purple stripe
    6: Grey with brown stripe
    A/C Compressor (possibly wrong)
    1: Blue
    2: Blue
    IAT
    2: Black
    Alternator (possibly wrong)
    1: Green with blue stripe
    2: White with green stripe
    N112
    Connector: Brown (2 pin)
    1: Green with yellow stripe
    2: Brown with black stripe
    N249
    2: Yellow with green stripe
    Wideband 02
    1: White
    2: Black with white stripe
    3: Green with yellow stripe
    4: Red with white stripe
    5: Brown
    6: Grey with green stripe
    Rear 02 Sensor
    Connector: Brown (4 pin)
    2: White with grey stripe
    3: Purple
    4: Red
    Crank Position
    Connector: Grey (3 pin)
    1: Black
    2: Blue
    3: Grey
    Knock Sensor (Rear)
    Connector: Blue (3 pin)
    1: Yellow
    2: Green
    3: Black
    Knock Sensor (Front)
    Connector: Green (3 pin)
    1: White
    2: Brown
    3: Black
    1: Blue with yellow stripe
    2: Empty
    3: Brown with yellow stripe
    Oil Pressure
    Connector: Black (1 pin)
    1: Yellow
    Speed Sensor (Trans)
    1: Empty
    2: Brown
    3: Brown with red stripe
    Other Trans Sensor (??)
    Connector: Black (5 pin)
    1: Empty
    2: Blue with red stripe
    3: Black with blue stripe
    4: Empty
    5: Empty
    1: Red with black stripe
    VVT Tensioner
    2: Yellow with grey stripe
    Coolant Temp (Top)
    1: Blue with brown stripe
    2: Brown with yellow stripe
    3: Black
    4: Brown with grey stripe
    Cam Position Sensor
    1: White with black stripe
    2: Green with grey stripe
    3: Black
    Injector 1 (Front)
    1: Red with blue stripe
    2: Black with green stripe
    Injector 2
    2: Brown with blue stripe
    Injector 3
    2: Grey with green stripe
    Injector 4
    2: Grey with purple stripe
    N75
    1: Black with purple stripe
    2: Yellow with white stripe
    EVAP
    2: Purple
    Coilpack 4 (Rear)
    1: Red with green stripe
    2: Brown
    3: Brown with black stripe
    4: Brown with yellow stripe
    Coilpack 3
    2: Brown
    3: Grey with black stripe
    Coilpack 2
    2: Brown
    3: Grey with brown
    Coilpack 1 (Front)
    2: Brown
    3: Grey
    Coilpack Grounds: Brown with yellow stripe
    2000 Audi S4 Body Harness Plugs:
    - T10, Brown, 10 pin
    1. green/red - K-line diag wire into ECU pin 43
    2. green/brown - to pin 47 on ECU from ?
    3. white/blue - vehicle speed signal to pin 54 on ECU
    4. red/black - from park/neutral position relay to ignition/starter switch
    5. black/blue - to pin 3 on back-up light switch
    6. unused
    7. unused
    8. black/red - to pin 1 on oil level thermal sensor
    9. red/grey - to pin 3 on oil level thermal sensor
    10. yellow - to pin 81 on ECU from ?
    - T10m, Black, 10 pin
    1. blue - goes to the voltage regulator (D+/61)/generator
    2. green/blue - rpm signal to pin 37 on ECU
    3. white/grey - from cluster to oil pressure switch
    4. red - from positive wire 30 to ECU pin 62
    5. brown/yellow, pin 3 on engine coolant temp sensor
    6. unused
    7. blue/green - from cluster to pin 1 on Engine Coolant Level Warning Switch
    8. red/blue - power pin 15 to fuel pump relay and then ECU
    9. blue/brown - from cluster to ground connection 2?
    10. brown/red - from cluster to to pin 2 on speedometer vehicle speed sensor (VSS)
    - T10ar, Orange, 10 pin
    1. red/green - from 20A fuse in fuse holder to power output stage pin 1 connector T5d
    2. red/brown - to pin 48 on ECU from ?
    3.
    4. unused
    5. black/blue - pin 1 on injector 1 to 20amp fuse in fuse holder
    6. white/yellow - to pin 1 on leak detection pump
    7. yellow/red - to pin 2 on leak detection pump
    8. green/yellow - to 15A fuse in fuse holder
    9.
    10. blue/lilac - engine overhead warning light
    - T15m, Red, 15 pin
    1. green/brown - From ABS control module to ECU pin 74
    2. unused (only for FWD)
    3. black/green - A/C control head to ECU pin 41
    4.
    5. black/lilac - to pin 30 on ECU from ?
    6.
    7.
    8.
    9.
    10.
    11.
    12.
    13.
    14. orange/brown - connection (low-bus)
    15. orange/black - connection (high-bus)
    - T15, White, 15 pin
    1. yellow/blue - to pin 1 (4 on 2001) on throttle body
    2. yellow/lilac - to pin 2 on throttle body
    3. brown/red - to pin 3 on throttle body
    4. green/yellow - to pin 4 (5 on 2001) on throttle body
    5. green - to pin 5 (1 on 2001) on throttle body
    6. brown/green - to pin 6 on throttle body
    7. red/grey - to pin 1 on connector T6y
    8. blue - to pin 2 on connector T6y
    9. red/yellow - to pin 3 on connector T6y
    10. black/white - to pin 6 on connector T6y
    11. red/black - to pin 2 on brake light switch
    12. white/red - to pin 4 on brake light switch
    13. red/green - to pin 1 on clutch vacuum vent valve switch
    14.
    15.
    2003 B6 A4 1.8T harness
    T10, Black, 10 pin
    1. blue - generator
    2. unused
    3. white/grey - Oil pressure switch
    4. unused
    5. red/green - from pin 121 on ECU to ?
    6. brown/yellow - pin 3 from engine coolant level warning light
    7. blue/yellow - Engine coolant level warning switch
    8. unused
    9. blue/brown - Engine coolant temp sensor
    10. brown/red - Speedometer vehicle speed sensor pin 2 (unused in 03)
    T10a, Brown, 10 pin
    1. red/blue - from injector harness to... ?
    2. black/red - Oil level thermal sensor pin 1
    3. unused
    4. red/black - Ignition/starter switch to ground
    5. black/blue - Back up light switch pin 3
    6. green/red - control module with indicator unit in instrument panel insert
    7. unused
    8. green/yellow - connector for fuse 234, connects MAF, N112, N80, N249
    9. red/grey - Oil level thermal sensor pin 3 (red/green for 03)
    10. unused
    T17e, White, 17 pin
    1. brown/green - to pin 1 on throttle body
    4. yellow/blue - to pin 4 on throttle body
    5. grey/yellow - to pin 5 on Throttle Body
    6. brown - to pin 6 on throttle body
    7. unused
    8. unused
    9. unused
    10. blue/green - from pin 38 ECU to steering column electronics module
    11. red/black - to pin 4 on brake light switch from ECU
    12. white/red - to pin 2 on brake light switch from ECU
    13. red/green - to pin 2 clutch vacuum vent valve switch
    14. grey/white - from pin 1 on locking relay for starter (clutch pedal switch) to pin 2 on clutch vent vacuum valve switch
    15. black/lilac - from ? to ECU
    16. red/grey - from power supply relay to fuse S229 (20A)
    17. unused
    T17d, Red, 17 pin
    1. white/yellow - pin 1 leak detection pump to ECU
    2. grey/red - pin 2 leak detection pump to ECU
    3. unused
    4. unused
    5. blue/brown - ? (03)
    6. lilac/blue - to airbag control module from pin 67 ECU
    7. unused
    8. unused
    9. unused
    10. red/blue - to pin 5 on fuel pump relay
    11. red/white - to ECU pin 24 to coolant fan control module
    12. unused
    13. orange/brown - Wire connection (low-bus)
    14. orange/black - Wire connection (high-bus)
    15. blue/red - reverse lamp connector
    16. unused
    17. unused
    2004 B6 S4 4.2 harness
    T10, Black, 10 pin
    1. blue – generator ???
    2.
    3. white/green – from instrument panel to F1 (oil pressure switch)
    4.
    5.
    6. brown/yellow – from pin 3 on F66 (Engine Coolant Level Warning Switch) to ground 269
    7. blue/yellow – from J285 (dash) to pin 1 on F66 (Engine Coolant Level Warning Switch)
    8.
    9. blue/brown – from J285 (dash) to pin 1 on G2 (Engine Coolant Temperature Sensor)
    10.
    T10a, Brown, 10 pin
    1. red/blue – from 25 to D95 ground for injector 1-6 ???
    2. black/red – from 21 to pin 1 on G266 (Oil Level Thermal Sensor) ???
    3.
    4. red/black - to the 50 pin on the starter
    5. black/blue – from connector A70 to F4 (Back-up light switch)
    6. for auto cars
    7.
    8. green/yellow – from 26 to D22 ground
    9. red/green – from instrument panel to pin 3 on G266 (Oil Level Thermal Sensor)
    10.
    T17e, White, 17 pin
    1. brown/green – from throttle body pin 1 to ECU pin 72
    2. yellow/lilac - from throttle body pin 2 to ECU pin 73
    3. brown/red - from throttle body pin 3 to ECU pin 36
    4. yellow/blue - from throttle body pin 4 to ECU pin 35
    5. green/yellow - from throttle body pin 5 to ECU pin 33
    6. brown - from throttle body pin 6 to ECU pin 34
    7.
    8.
    9.
    10. blue/green – from dash to ECU
    11. red/black – pin 4 on brake light switch to ECU pin 56
    12. white/red – pin 2 on brake light switch to ECU pin 55
    13. green/grey – pin 2 on clutch vacuum vent valve switch to ECU pin 39
    14.
    15. black/lilac – from 20 to pin 21 on ECU
    16. red/grey – from ECM power supply relay to fuse 229 (20A) to 229???
    17.
    T17d, Red, 17 pin
    1. yellow - from pin 1 on leak detection pump to ECU pin 80
    2. green/red – from pin 2 on leak detection pump to ECU pin 25
    3. red/yellow – from coolant fan control module 2 to ECU pin 104
    4.
    5.
    6. lilac/blue (possibly not there) – from fuse 234 to ECU pin 61???
    7. green/black – from pin 1 on N220 valve for exhaust flap to ECU pin 22
    8.
    9.
    10. red/blue – pin 4 on fuel pump relay to pin 65 on ECU
    11. red/white – from coolant fan control module 1 to ECU pin 66
    12.
    13. orange/brown – CanBus (low) from instrument panel to pin 58 on ECU
    14. orange/black – CanBus (high) from instrument panel to pin 60 on ECU
    15. blue/red – from J393 (Central Control Module for Comfort System) to 220???
    16.
    17.
    - Clint
    New: 2011 B8 S4 Prestige - broken
    Current: 05 B5.5 Passat 4motion 1.8T - Jfonz Tune, 034 HFC, Samco TIP, TR18 FMIC, meth. waiting to go on: K04, H&R Coils
    totaled: 04 DG B6 Cabby 1.8T - stock forever
    Gone: White '04 S4 2.7T - Stage 2+
    Gone : 05 DG B7 2.0TQ - Stage 1
    Veteran Member Four Rings Staz's Avatar
    Jul 03 2010
    QUEENS, NY
    i hate that youre missing the maf one !!!!!!!!!!!!!!!
    nice writeup though
    Oct 29 2005
    10speed
    San Francisco, CA
    lol someone will fill it in.
    - Clint
    Veteran Member Four Rings a4darkness's Avatar
    Dec 01 2007
    Pasadena, CA
    I can't even. This. Seriously. Wow. Just wow.
    Really great idea.
    Thomas
    | Chronicles | Threads | IG
    // A U B A
    Veteran Member Four Rings alexza4's Avatar
    Apr 23 2007
    15-S5||18-X5||14-RAM1500Hemi
    real nice Clint! virtual rep to you man.
    2015 S5 3.0T
    2003 A4 QM EFR 6758 on meth - SOLD :((
    Oct 29 2005
    10speed
    San Francisco, CA
    It's getting better when I trace every wire around the harness down to the pin
    - Clint
    Veteran Member Four Rings Dolphin18T's Avatar
    May 17 2007
    You know the Bentley manual has all of this, right?
    Let me know if you need any diagrams and I'll post them up.
    -Ryan
    Maestro Tuned
    Now with slushbox-delete mod!
    Apr 23 2007
    are you doin this shit now? you must be bored ;)
    how are you doin with those PSS9's? still want them!
    2015 S5 3.0T
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by Dolphin18T View Post
    I've seen the bentley though and it's rather confusing. I gotta find my disc I know its somewhere. YGPM
    - Clint
    May 17 2007
    Here's an example of what's in the manual. You have to practice using the guide it has leading in to the wiring diagram section to be able to read it easily, but it's worth it. My trans swap would have been a nightmare without it, or I probably would have just bypassed the starter interlock relay, which I really didn't want to do.
    -Ryan
    Maestro Tuned
    Veteran Member Four Rings Bische's Avatar
    Jun 03 2009
    2002 Big Block Avant
    Sweden, north
    great idea!
    -Bische
    Tuning related questions? Please visit my Facebook page!
    <Bische's Wagon - The thread>
    <Bische's Wintermode - The thread>
    Dec 03 2005
    2 pedals 1FG
    connecticut
    It's not that confusing. Took me five minutes to read the diagram and figure out the clutch switch. It took Jake... well. it didn't as he couldt figure it out even after I laid out the steps and such.
    Go to Raritan Valley and take a quick electronics course in reading diagrams.
    The key information not posted yet are the pin outs for the ECU. again... in the bentley.
    -Doug
    '02 A4 Avant 2.7T 6spd
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Anyone know how much a new harness is?
    2005.5 A4 2.0t quattro
    Borg Warner EFR 6758
    Pag Parts rods/inlet pipe/FMIC/manifold/downpipe
    Eurodyne Maestro
    Eurodyne Boost Manager Plus
    StopTech 332mm BBK
    Stasis Touring suspension
    Misc. JHM and 034
    Oct 29 2005
    10speed
    San Francisco, CA
    none of that makes sense to me lol
    - Clint
    May 17 2007
    Did you finally get both of Vince's clutch switches wired correctly? I thought you just jumped the relay.
    It would take me quite a long time to to post up the images required to pinout the entire ECU... Hah.
    -Ryan
    Maestro Tuned
    Jul 03 2010
    QUEENS, NY
    could u possibly post up the diagram of the maf ? please !
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by Staz View Post
    someone can yank the plug. I know its a 4 pin but idk the colors. My MAF wires are gone so idk lol
    - Clint
    Jul 03 2010
    QUEENS, NY
    i meant to quote dolphin18t.. i know its the 4 pin i just changed out my connector along with splicing and adding a few wires that i bought from the dealer but its still giving me low voltage on the maf (so im thinking somethings wrong with the wiring somewhere down the line of it) .. was wondering is i buy a used harness and take the maf harness from it, if i could just run it behind the engine as the other wires do and if it plus directly/ near the ecu ?
    Oct 29 2005
    10speed
    San Francisco, CA
    yes you could pin one in but it'd be a nightmare. It was giving you low voltage so you replaced the whole MAF harness?
    - Clint
    Jul 03 2010
    QUEENS, NY
    heres the thread i posted on it
    the techs at the dealer said it was my connecter having issues thats why my maf would keep blowing. so i wanted to order a whole harness for the maf but they said they didnt sell them. said id have to buy 4 wires and a new connector, splice the old ones, solder the new ones in and it would solve the problem. i did research and research and couldnt find a solution for it so i ended up doing what the dealer said and bought the stuff. replaced it, and was still giving me random low voltage.
    so now im thinking im i just buy a used engine harness and take the maf harness out of it and run it behind where all the other wires are. Then just heat wrap them all since id have to take the oem wrap off to get the old maf harness out
    heres what it looked like after i installed it
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Good info here. Nice to see it all laid out.
    So that whole mass plugs into the ECU/ECM.... +ve rep
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Oct 29 2005
    10speed
    San Francisco, CA
    adding more about the B5 S4 harness connectors
    - Clint
    Oct 29 2005
    10speed
    San Francisco, CA
    stuff added at the bottom of the first post
    - Clint
    Veteran Member Four Rings IVRINGS's Avatar
    Mar 27 2009
    2007 Audi A4 Ti S-line Avant
    Audi Columbus Sales
    I hope you enjoy that package I sent you the other day. They said it should be there by Monday like I said. I'm going to finish up my timing stuff and pick a clutch this week and get things ready for wiring. I miss driving my car.
    Audi Enthusiast and Audi Columbus Brand Specialist
    Oct 29 2005
    10speed
    San Francisco, CA
    started adding 2002 B6 wiring to it
    - Clint
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    Aprilia SXV 550, BMW F800GS, Honda CRF450X Timbersled, Ram EcoDiesel, 1989 Bronco
    Lander, Wyoming
    Nice Clint! Thanks!
    I too find the Bentley manual annoying to read, particularly because the colors are written in German abbreviations on the diagrams which is a tad confusing (and I even speak german!).
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Oct 29 2005
    10speed
    San Francisco, CA
    I started getting better at it but i have an actual harness coming too which should help
    Aug 26 2005
    Thanks for your efforts posting this valuable reference! I recommend you add this to the AZ Wiki. Included in the AZ Wiki, anyone can add to the content of this reference, a lot easier than as a single post/thread.
    Vorsprung durch Technik
    Aug 26 2005
    The main features to understand to read the wiring diagrams, is that the top of the diagram is the +BAT, "30", and the bottom is Chassis Ground, "31". The current flows in the diagram from the top "+BAT, 30" to the bottom, "31, Chassis Ground". The numbers in the square boxes at the circuit traces, refer to the numbers along the bottom of the diagram, and indicate where the circuit trace continues in the diagram. Where a circuit trace continues, a box with the origination reference number corresponds to the destination reference number for that circuit.
    Oct 29 2005
    10speed
    San Francisco, CA
    John I'm not done yet but this will be part of the 2.7T swap DIY
    Mar 27 2009
    Audi Columbus Sales
    Your welcome... I hope that I'm the next one to have mine up and running. I just wished my 6-speed swap would have been done a long time ago. Looks like 5-speed for now and maybe do FT's or K04's during the 6-speed so I can get out of the FORD
    Oct 29 2005
    10speed
    San Francisco, CA
    well that's all I can get for now until I figure this thing out better.
    - Clint
    Veteran Member Four Rings nefkntym's Avatar
    Jan 30 2007
    a bunch of tools
    Monument, CO
    Good info Clint, I am looking for pin out info for the 1.8t harness.
    2018 TTRS Nardo Grey |IROZ CC ECU/TCU Tune | Sports Exhaust | Dynamic Plus Package | Design Selection Interior | Carbon Inlays | Tech Package | Black Optic
    2018 SQ5 Prestige Azores Green | Loaded like a Baked Potato
    2018 S5 SB Navarra Blue/Magma
    2003 A4 Avant Polar White | 2.7T swapped |Tial 605.2
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by nefkntym View Post
    PM me with what you need I've been working on the side with it for awhile
    - Clint
    Veteran Member Three Rings daghstdrummer's Avatar
    Feb 09 2007
    2012, Honda CRV - 99 Ford E-150 Conversion van
    Astoria, N.Y.
    WOW! sticky....
    2002 A4QM 1.8t Frankenturbo Tuned by SSP... R.I.P.
    135
    24R
    Veteran Member Four Rings Haenszel20v's Avatar
    Oct 05 2008
    B6 A4 USP - B5 VR6T Avant
    Buffalo, NY
    '90 CQ - S8 4.0t swap in progress
    B5 Avant VR6T - 10.201@143.42mph
    Established Member Two Rings Scubasteeve's Avatar
    Aug 28 2009
    Audi A4
    Mnneapolis
    That's cool.
    I are an engineer. I like make cars. i speak to english good. engineer don't need to good be talk. because race car.
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by Haenszel20v View Post
    Yea that's what I've been using. It makes sense after awhile but some of them are still very confusing
    - Clint
    Veteran Member Three Rings SpeedWorksAuto's Avatar
    Sep 23 2008
    2001 A4 TQM
    Renton, WA
    Borrowed some info and reposted it here: http://www.audizine.com/forum/showth...42#post7054042
    Sep 10 2011
    Oregon
    Excellent write-up. Definite STICKY??????
    ~Calvin
    2004 Audi A4 1.8T /// 6-Speed /// quattro /// Moro Blue Pearl
    || motoza tuned gt2871r elim || b7 thermal r&d exhaust || ns sport w/ b5 seats || v718 sunken treasure
