Results 1 to 8 of 8
    Veteran Member Four Rings Staz's Avatar
    Jul 03 2010
    QUEENS, NY
    problems problems problems - codes
    yes ive done months of searching.
    ..so my car has been acting very weird for a while now.. a few months back my maf blew, i replaced it, about 1000 miles later it blew again.
    there was a nice cut on the wire by the maf connector, so i spliced the wires, went to the dealer and picked up a new wiring harness, re-wired everything and im still pulling these codes. esp light and cel stay on at all times. i know if i change the maf out again its going to blow and i dont feel like spending 100$ every week for a new maf.
    any ideas on what to do guys ?
    Address 01: Engine Labels: 06B-909-518-AMB.lb
    Part No SW: 8E0 909 518 AK HW: 8E0 909 018 A
    Component: 1.8L R4/5VT G 0004
    Coding: 0016751
    Shop #: WSC 78129 665 427558
    VCID: 79F2E0C2495F
    1 Fault Found:
    16486 - Mass Air Flow Sensor (G70): Signal too Low
    P0102 - 002 - Lower Limit Exceeded
    Readiness: 0000 1100
    Address 02: Auto Trans Labels: 01V-927-156.lbl
    Part No: 8E0 927 156 S
    Component: AG5 01V 1.8l5VT USA 1212
    Coding: 0001002
    Shop #: WSC 63351 000 00000
    VCID: 3E7833DE10F1
    1 Fault Found:
    18265 - Load Signal: Error Message from ECU
    P1857 - 003 - Mechanical Failure
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517 A
    Component: ABS/ESP allrad 3429
    Coding: 04277
    Shop #: WSC 01234
    VCID: 2648FBBEE861
    1 Fault Found:
    P1857 - 35-00 - -
    thanks in advance
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    What kind of intake filter are u running to protect that MAF?
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    03 A4 Avant, 85 ABA Golf
    Palo Alto, Ca
    I'd try putting the intake back to stock and go from there.
    Senior Member Three Rings Ori0n's Avatar
    Sep 26 2010
    Saskatoon, SK
    Your Carbonio is fine, it's a dry filter.
    You said...
    Quote Originally Posted by Staz View Post
    So in this order? Your MAF Fried, you replaced it, it fried again, you replaced the wiring harness, but didn't replace the MAF again?
    Bad wires will fry the MAF, once it's fried, you need a new one. Double check your wiring harness and replace the MAF once more.
    EDIT: I'll add that all of your codes can be caused by a bad MAF.
    2004 Audi A4 Avant 1.8TQM - Stage 2+ [ SOLD :( ]
    2007 Audi A4 Avant 2.0TQM - OEM+
    Jul 03 2010
    QUEENS, NY
    Quote Originally Posted by Ori0n View Post
    You said...
    didnt even see this reply ! ill buy another maf, give it another shot and let u know how it goes
