Page 13 of 20 FirstFirst ... 31112131415 ... LastLast
Results 481 to 520 of 765
  1. #481
    Veteran Member Three Rings SpeedWorksAuto's Avatar
    Sep 23 2008
    2001 A4 TQM
    Renton, WA
    New compressor wheel for the he351VE and a few others:
    I think once I am up and running I will toss one of these suckers in.
  2. #482
    Veteran Member Four Rings ZimbutheMonkey's Avatar
    Mar 27 2010
    solar system
    OK, do you have any more info on the compressor wheel on the left? I've seen them on the Bullseye Power site but couldn't figure out if they were for real or if it was some kind of April Fool's gag. Assuming they're for real, has anyone ran them back to back vs an equivalent straight edged billet compressor to see if they actually work any better? I've read the technical posts that Bullseye has put up, and they seem like an interesting design. However without any real testing, it's just speculation to me at this point.
    Also, mad respect for what you're doing man. Not very many people here that are actually doing their own fabrication work and all. I had a similar scenario this summer with my build. It's a LOT of friggin' work when you're doing all the fabrication. I know the last bits when you're tired, frustrated and worn out can suck, but just push through it. You look like you're going to have a wicked setup man, it'll be worth it all in the end. Looking forward to seeing it done
  3. #483
    Sep 23 2008
    2001 A4 TQM
    Renton, WA
    Its called the BatMoWheel.
    Dynos are there for back to back. I think I saw that people are seeing arpound 40hp on gas motors, and since these are made for Holset too (diesel) they are seeing like 2 billion ft pound of torque and like 6hp in those applications too...J/K.
    I think this is where I am going to be buying mine from:
    http://www.cumminsperformanceparts.c...rhebaishe.html
    Supra guy went from high 792whp to 941whp with one of these wheels.
    http://www.supraforums.com/forum/sho...tmowheel/page3
  4. #484
    Mar 27 2010
    solar system
    OK, but in the Supra thread, it was compared to a non extended tip GT series turbo (GT 42?). I'd really like to see a test against a billet extended tip turbo. i.e. 366 ETT billet w a straight leading edge vs a 366 ETT w the Batmowheel edge.
    No harm in getting one I guess, but I have to wonder how much power it adds above and beyond a similar compressor.
  5. #485
    Sep 23 2008
    2001 A4 TQM
    Renton, WA
    I don even think BW sells the wheel separate for their turbos. Dude said it comes on the new turbos only IIRC. I kind of recall him telling a few people that in either that thread or somewhere else. The only one I found that was wheel only was for the holsets. In the supra guys thread there was a story about the sucess of the wheel in a diesel app. in post#32
    "Congrats to Aron Nick from Blacks Diesel for winning the Super Stock Quick 16 in Bradenton. After months of dyno testing we decided to switch from our standard billet wheel to the new "BatMoWheel" right there at the track during test and tune. This immediately picked him up a tenth and 2 mph on the very next run. Then we installed our race cover for eliminations which put this truck in the 10's for the first time. All in all this truck picked up 3 tenths in the quarter mile which put him in the finals and ultimately won the race. "
    *ADD...I guess, after reading the quote, they might do the wheel seperately.
  6. #486
    Mar 27 2010
    solar system
    In any case, I'll be stoked to see your setup run, batmowheel or not. If you do get one, take some detailed pics though.
  7. #487
    Veteran Member Three Rings Sigma 3's Avatar
    May 23 2005
    Tricities Wa
    Way to keep pushin!
    Originally Posted by FNK re getting more power from a 2.8 a4
    "Paint the exhaust and intake with Ceramic paint (heat repellent), thus increasing the exhaust velocity, thus less striction = more Power"
  8. #488
    Sep 23 2008
    2001 A4 TQM
    Renton, WA
    Still at it.
  9. #489
    Senior Member Two Rings bmx_a4's Avatar
    Aug 19 2008
    Sheridan, WY
    Oh that looks like fun!
    2006 Jetta TDI
    2000 Brilliant Black S4
  10. #490
    Sep 23 2008
    2001 A4 TQM
    Renton, WA
    One more:
  11. #491
    Sep 23 2008
    2001 A4 TQM
    Renton, WA
    Anybody have wiring diagrams for the late b5 1.8 body from ecm connectors, and the s4 ? I been looking for days and only found the s4
  12. #492
    Sep 23 2008
    2001 A4 TQM
    Renton, WA
    Ok, Guess thats a no. I have them both from the Bentley. They arent what I am used to looking at. I guess I will start by tracing the wires to see what needs to be changed around and what goes where. Feel free to chime in.
    SO, HERE GOES:
  13. #493
    Sep 23 2008
    2001 A4 TQM
    Renton, WA
    Starting with the 10 pin black connector = T10M (1.8T) T10M(2.7TT)
    some stuff stolen from :http://www.audizine.com/forum/showth...wiring+diagram
    1. blue: from the voltage regulator (D+/61)/generator to T32a/12 on J218(instrument cluster processor)
    2. green/blue: rpm signal from pin 37 on ECU to A45(wire connection RPM signal, in instrument panel wiring harness) to T32/11 on J218(instrument cluster processor)
    3. white/grey
    4. red (large gauge): power to pin 62 ECM ( splits to 9 and pin 2 on J271 - motronic engine control module power supply relay)
    5. brown/yellow: from pin 2 on G2(engine coolant sensor) to sensor ground, shared ground with coolant level sensor
    6.
    7. blue/yellow: from T32/22 on instrument cluster combination processor to pin 1 on Engine Coolant Level Warning Switch
    8. red/blue: power to pin 15 fuel pump relay to pin 65 on ECM
    9. blue/brown: from pin 1 engine coolant temperature to T32/22 on instrument cluster combination processor
    10. brown/red: from pin T32/28 instrument cluster combination processor to to pin 2 on speedometer vehicle speed sensor (VSS)
    3. white/grey: from cluster to oil pressure switchto pin 116 on ECU
    4. red: from positive wire 30 to ECU pin 62
    5. brown/yellow: pin 4 on engine coolant temp sensor to ground, shared ground with coolant level sensor
    6.
    7. blue/green(blue/yellow): from T32/22 on instrument cluster combination processor to pin 1 on Engine Coolant Level Warning Switch
    8. red/blue: power to pin 15 to fuel pump relay and then to pin 65 on ECU
    9. blue/brown: from pin 2 on G2(engine coolant sensor) to T32/8 on J218(instrument cluster combination processor)
  14. #494
    Sep 23 2008
    2001 A4 TQM
    Renton, WA
    10 pin brown connector = T10 (1.8T) T10(2.7TT)
    1. green/red
    2.
    3. white/blue
    4. red/black (large gauge): from J433(locking relay for starter(anti theft immobilizer) to 50? at starter
    5. black/blue
    6.
    7.
    8. black/red: mini fuse 10a #5 pin 1/15? on G266(oil level thermal sensor)
    9. red/grey
    10.
    - T10, Brown, 10 pin
    1. green/red - K-line diag wire into ECU pin 43
    2. green/brown - to pin 47 on ECU from instrument cluster combination processor
    3. white/blue - vehicle speed signal to pin 54 on ECU
    4. red/black (large gauge) - from park/neutral position relay to ignition/starter switch
    5. black/blue - to pin 3 on back-up light switch
    6.
    7.
    8. black/red - to pin 1 on oil level thermal sensor
    9. red/grey - to pin 3 on oil level thermal sensor
    10. yellow - to pin 81 on ECU from ?
  15. #495
    Sep 23 2008
    2001 A4 TQM
    Renton, WA
    10 pin orange connector = T10ar (1.8T) T10ar(2.7TT)
    1. red/green (large gauge): (red and gray)from pin 6 on J271(motoronic power suppy relay) 20a fuse #29 to A151(to pin 1 on all four injectors - chiltons) to t10ar1 to D23 to pin 121 on ECU
    2.
    3.
    4. black/blue (large gauge): 20a fuse #7 to: pin 6 on cruise control switch, pin 3 on brake vacuum vent switch, pin 2 on clutch vent valve switch, PIN 3 ON J220
    5. black/blue (large gauge): from 87f/DTI (green wire) on fuel pump relay to 10a fuse #32 to D95(wire connection injectors in engine comaprtment wiring harness)
    6. white/yellow: pin 80 on ECU to t10ar/6 to t6aa/1 to pin 1 on V144(leak down detection pump)
    7. yellow/red: pin 25 on ECU to t10ar/7 to t6aa/2 to pin 2 on V144(leak down detection pump)
    8.green/yellow (large gauge): from s3/87a on fuel pump relay to 10a fuse #34 to A20(wire connection 15a in wiring panel harness) to t10ar8 to D22(connector over fuse 234)
    9.
    10.
    - T10ar, Orange, 10 pin
    1. red/green (large gauge): from 87f/DTI (green wire) on fuel pump relay to 20a fuse #29 to A151 (connector -4- (87), in instrument panel wiring harness) to t10ar/1 to 15 on all 6 coils.
    2. red/brown - to pin 48 on ECU from instrument cluster processor
    3.red/yellow
    4.
    5. black/blue (large gauge) - from t32/1(32 pin blue connector on instrument panel processor) to A2(plus connection (15), in instrument panel wiring harness) to 20a fuse #32 to A20(wire connection (15a), in instrument panel wiring harness) to t10ar/5 to pin 1 on all six injectors
    6. white/yellow : pin 80 on ECU to t10ar/6 to t6aa/1 to pin 1 on V144(leak down detection pump)
    7. yellow/red : pin 25 on ECU to t10ar/7 to t6aa/2 to pin 2 on V144(leak down detection pump)
    8. green/yellow (large gauge) - from s3/87a on fuel pump realy to 10a fuse 34 to A152(connector -5- (87), in instrument panel wiring harness) to t10ar/8 to D22(connector over fuse 234)
    9. brown/red
    10. blue/violet - engine overhead warning light PIN 19 ON ECU
    Wires I moved:
    pin 1 red/green to pin 5 to power all six coils and correct termial on FPR
  16. #496
    Sep 23 2008
    2001 A4 TQM
    Renton, WA
    15 PIN ORANGE/3 PIN RED connector = T15? (1.8T) T15M(2.7TT)
    ORANGE
    1. green/brown
    2.
    3. black/grey
    4.
    5.
    6.
    7.
    8.
    9.
    10.
    11.
    12.
    13.
    14. orange/brown - connection (low-bus)
    15. orange/black - connection (high-bus)
    RED
    1. blue/red
    2. blue/violet
    3.
    - T15m, Red, 15 pin
    1. green/brown - From ABS control module to ECU pin 74
    2.
    3. black/grey - A/C control head to ECU pin 41
    4.
    5. black/violet - to pin 30 on ECU from instrment cluster
    6.
    7.
    8.
    9.
    10.
    11.
    12.
    13.
    RED
    1.
    2. blue/violet
    3.
  17. #497
    Sep 23 2008
    2001 A4 TQM
    Renton, WA
    15/3 pin white connector = T15/T3aa (1.8T) T15/T3aa(2.7TT)
    1. yellow/blue
    2. yellow/lilac
    3. brown/red
    4. grey/yellow
    5. grey
    6. brown/green
    7. red/grey - PIN 1 ON T6Y
    8. blue - PIN 2 ON T6Y
    9. red/yellow - PIN 3 ON T6Y
    10. black/white - PIN 6 ON T6Y
    11. red/black - PIN 2 BRAKE LIGHT SWITCH
    12. white/red - PIN 4 BRAKE LIGHT SWITCH
    13. red/green
    14.
    15.
    T3aa
    1.
    2. red (large gauge)
    3. red/grey (large gauge)
    - T15, White, 15 pin
    1. yellow/blue - to pin 1 (4 on 2001) on throttle body
    2. yellow/lilac - to pin 2 on throttle body
    3. brown/red - to pin 3 on throttle body
    4. green(grey)/yellow - to pin 4 (5 on 2001) on throttle body
    5. green(grey) - to pin 5 (1 on 2001) on throttle body
    6. brown/green - to pin 6 on throttle body
    7. red/grey - to pin 1 on connector T6y
    8. blue - to pin 2 on connector T6y
    9. red/yellow - to pin 3 on connector T6y
    10. black/white - to pin 6 on connector T6y
    11. red/black - to pin 2 on brake light switch
    12. white/red - to pin 4 on brake light switch
    13. red/green - to pin 1 on clutch vacuum vent valve switch
    14.
    15.
    T3aa
    1.
    2.
    3. red (large gauge)
  18. #498
    Sep 23 2008
    2001 A4 TQM
    Renton, WA
    Fuses and relays
  19. #499
    Sep 23 2008
    2001 A4 TQM
    Renton, WA
    Anything I missed
  20. #500
    Sep 23 2008
    2001 A4 TQM
    Renton, WA
    Been at most of the day was wondering why the a4 wiring just didnt make sense. It appears I have the 2002 mY infront of me which is different than the 2001.....b6 vs. b5. Makes sense why the connector names on the 1.8t side are a bit awkward. Back to Google to see if I can pull up the info, Chiltons isnt cutting it
  21. #501
    Sep 23 2008
    2001 A4 TQM
    Renton, WA
    Gotta switch the valve covers to make room for intake Amd intercooler piping.
  22. #502
    May 23 2005
    Tricities Wa
    Cellus whats the third bung whole in the the elbow off the turbo? Are you sure you want those sensors that closet to the fire place!?
    good progress.
  23. #503
    Oct 29 2005
    10speed
    San Francisco, CA
    What year S4 is it? Are you using my wiring descriptions? I'll try and help if I can
  24. #504
    Sep 23 2008
    2001 A4 TQM
    Renton, WA
    I am using your wiring descriptions as a start point. I believe its a 2001 motor. I got the s4 bentley wiring diagrams, I just ordered the bentley for my a4. I need to figure out the body harness section. There doesn't seem to be much of a difference.
    I am also having a hard time figuring out which plug is for the left/right knock sensors and the four o2 plugs.
    I was hoping to delete the icm, but I don't have the adapters yet. I might have to wait and do it later, which means I will need to order some icm.
    I am kinda throwed off as to which injectors are stock. I have two fuel rails and the injectors are a different color. I haven't had the time to go looking for that info yet.
    I was hoping to start it up this weekend.....not looking good as this list keeps growing. Hell, I still haven't nailed down a good maf to turbo solution. I wish I could get it to run blow through.
    For now, I wanna start it up with as many stock components as possible to help isolate problems. Also, in my tune I had the Egt, rear o2 and a bunch of other stuff coded out. He said I could remove the plugs. I will have to wait and see.
  25. #505
    Sep 23 2008
    2001 A4 TQM
    Renton, WA
    I agree the o2s are close. I might deal with that later. The third is for my wbo2
  26. #506
    Sep 23 2008
    2001 A4 TQM
    Renton, WA
    I have these on their way now:
    Since I am doing wiring now, I figured I might as well upgrade to the coils, and ditch the ignition control modules.
    Link to DIY:
    http://www.audizine.com/forum/showth....0T-Coil-packs...
  27. #507
    Sep 23 2008
    2001 A4 TQM
    Renton, WA
    So pissed that the Bentley Dvd only works with XP. My laptop is running 7 home premium so I can't do a virtual p.c with xp in it. You need 7 professional for that. That's really dumb that the software hasn't been upgraded to be compatible with the newer OS. I don't really feel like paying to.upgrading my Windows just to run xp, so I can use some stupid software.
    Wish I would have known beforehand.
  28. #508
    Veteran Member Four Rings onemoremile's Avatar
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    That sucks. Where did you get the wiring bits from? I like the look of those. I just picked up a set of the bolt down 4 wire packs. It gets me new wiring and packs and makes any future changes to the push down packs really easy.
    I love this project. Dunno if I've said that yet. Love it.
    Jim
    We cannot achieve the future by being timid. It requires aggressive imagination.
    I Do Werk.
  29. #509
    Apr 27 2010
    seattle/WA
    there was a b5 bentley on seattle craigslist for 40bucks a few days ago! the builds coming along nicely though. Cant wait for you to get this thing done!(or for mine to get finished for that matter...)
    2001.5 A4 TQM
    Unitronic Stage 2/APR exhaust/2.5" test pipe/Intake
    JHM Shifter/solid linkage/AWE DTS/034 Weighted Delrin knob/Apikol Rear diff mount
    ST's/Keskin KT1 18x10ET25 18x8.5 ET30 and some stretch
    2.1L 9.5:1 Stroker/Built AEB head/PAG 5857 kit... under construction.
  30. #510
    Sep 23 2008
    2001 A4 TQM
    Renton, WA
    Text me your number again. Got my phone replaced and lost it
  31. #511
    Sep 23 2008
    2001 A4 TQM
    Renton, WA
    Quote Originally Posted by onemoremile View Post
    The connectors I was going with above were actually going to be more expensive than ordering the 4cyl repair harness x2. They were 35.00 each x 6 = 210.00. The 4cyl harness was around 50.00 each.
  32. #512
    Nov 21 2006
    san francisco, ca
    Quote Originally Posted by SpeedWorksAuto View Post
    http://www.034motorsport.com/engine-...s-p-22156.html
    1998.5 A4 2.0TQM ADR/058, Custom ME5 tune by 034, ABA 92.8 stroke forged crank, Scat rods, JE Pistons (83mm/8.5:1), Schrick cams, Supertech springs and retainers, inconel exhaust valves (+1mm), Spa T3 mani with a Precision 5557E-B, 034 3inch exhaust, etc, etc, etc. 034 featured user
    2012 S4 Prestige, Titanium, Monsoon gray metallic, DSG. 034 ECU and TCU tunes and other bits.
  33. #513
    Sep 23 2008
    2001 A4 TQM
    Renton, WA
    @565.00 I will piece mine together. If you can't tell by this thread, I am more of DIY kind of guy.
  34. #514
    Veteran Member Three Rings A4DRIVR's Avatar
    Sep 08 2009
    2001 Golf GLS 1.8T
    Loveland, OH
    I think the b5 A4 and S4 manuals are one in the same. Let me know why you need... I had to by win 7 pro for that exact reason! Virtual xp to read my repair manuals.
    It's SOLD!... 2001 B5A4 QMT BAT: Used to be... My BAT Build
    "When life gives you lemons, paint that shit gold!"
  35. #515
    May 23 2005
    Tricities Wa
    Is any of what you need in the haynes?
  36. #516
    Sep 23 2008
    2001 A4 TQM
    Renton, WA
    Quote Originally Posted by A4DRIVR View Post
    I only had the part of the manual that was someone put into Adobe format from the socals4 link. I need the wiring for the A4.
    I am going to try to install XP on my virtual PC, I was told that was going to work.
  37. #517
    Sep 23 2008
    2001 A4 TQM
    Renton, WA
    Quote Originally Posted by Sigma 3 View Post
    I dont know whats in the Haynes. I only have a Chiltons. from my experience they are pretty similar.
  38. #518
    Sep 23 2008
    2001 A4 TQM
    Renton, WA
    Too cold to really get much done:
    Bracket to mount Coolant res. on passengers side, along with swapped valve covers to give mroe room for piping:
  39. #519
    Sep 23 2008
    2001 A4 TQM
    Renton, WA
    A little sheet metal to clean it up
  40. #520
    Sep 23 2008
    2001 A4 TQM
    Renton, WA
    A buddy of mine, on his way up to his house stopped by and took me for a spin in his stg 3 s4. Ya, I see now Imma have to start saving up for a 6 speed and some tires. That thing was rediculous. Then he launched it....!
