All,
A month or so ago I swapped over to 2.0T Coils using the "solder" method posted within Audizine.
Everything went as per the plan, and the car was running perfectly once I changed out the plugs for sidefires.
In the last week I started getting obvious misfires, so I scanned for codes (please note that I was keeping an eye on codes after going to 2.0t coils, and I wasn't getting any previous to this).
Upon reading the codes, I cleared them to ensure none were from me f-ing around pulling coils etc, took it for a drive which has resulted consistently in the following.
Please note that I've added the "standard" go-to causes for each code group, just for clarity to those of varying experience.
P1358 - Cylinder 2 Ignition Circuit: Open Circuit
P1364 - Cylinder 4 Ignition Circuit: Open Circuit
P1367 - Cylinder 5 Ignition Circuit Open Circuit
P1370 - Cylinder 6 Ignition Circuit: Open Circuit
- Faulty Ignition Coil
- Ignition Coil harness is open or shorted
- Ignition Coil circuit poor electrical connection
P0300 - Random Cylinder Misfire Detected
- Faulty spark plug (s)
- Faulty ignition coil (s)
- Clogged or faulty fuel injector (s)
- Intake air leak
- Fuel injectors harness is open or shorted
- Fuel Injectors circuit poor electrical connection
- Ignition coils harness is open or shorted
- Ignition coils circuit poor electrical connection
- Insufficient cylinders compression
- Incorrect fuel pressure
P0301 - Cylinder 1 Misfire Condition
P0302 - Cylinder 2 Misfire Condition
P0306 - Cylinder 6 Misfire Detected
- Faulty spark plug X
- Clogged or faulty fuel injector X
- Faulty ignition coil X
- Fuel injector X harness is open or shorted
- Fuel injector X circuit poor electrical connection
- Ignition coil X harness is open or shorted
- Ignition coil X circuit poor electrical connection
- Insufficient cylinder X compression
- Intake air leak
I've gone back and traced all spliced wires, and everything appears OK. Given that this appears to be ALL cylinders, I was leaning towards it being an issue with the ICM splices rather than the individual cylinder splices.
I've pulled everything apart and it all appears to be fine. I've rolled each connection while the engine is running, and there is no discernable deviation to indicate a potentially poor solder.
I doubt the coils (genuine BOSCH) or plugs are failing, as they're only 1-1200kms old, if even.
A poor ground somewhere?
