Results 1 to 13 of 13
    Mar 27 2011
    00 S4 Epl 3
    mn
    2.7t Coil Pack Conversion Hardwire
    Lets get this out of the way, im hardwiring b/c the wiring up to my original plugs is shot + i hvae 1 bad icm and 5 bad coils.
    Sooooo.
    Does anybody know/ have any expierence in hardwiring in, or know of another thread?
    I believe on the original coils, 3-pin, its 2 grounds and a signal. Anybody know which are the grounds and which are signals?
    on new coils 4 pin its, 2 grounds, signal and power.
    Anybody have diagrams?
    Veteran Member Three Rings greg@dubaudi's Avatar
    Feb 05 2005
    2001.5 pearl WB Avant, 2016 SQ5
    Alton Bay, NH
    2001.5 EPL/Tial 770 Pearl WB Avant///2021 SQ7 Nimbus Grey///2021 GMC 3500 Duramax
    Jun 12 2008
    Four Rings
    TX
    edit*: ^^ Greg beat me to to it
    Sep 17 2005
    Fremont, California
    Real quick:
    On OEM 3 wire connector:
    Pin 1 (1)= Signal
    Pin 2 (4a) = Ground
    Pin 3 (15) = +12v
    on 4 wire connector
    Pin 1 = +12v
    Pin 2 = ttl ground
    Pin 3 = signal
    Pin 4 = ground
    Mar 27 2011
    00 S4 Epl 3
    mn
    Thanks guys for the quick reply!!
    I saw tht 2.0t teaser thread but the wiring diagram seemed more complex than it needed to be.
    thanks max, ill follow what you go by and report back and make a DIY
    What is the TTL ground??
    And i did not see numbers above the pin so how do i know which one is 4 and which one is 1?
    Dec 13 2007
    05 Denali, 64 baja bug, 67 beetle, 04 passat W8.
    Eastern CT
    on the S4 harness red/green is 12+ and brown/yellow is ground the other colored wire on each plug is the signal.
    the TTL just gets grounded to the head, i went to a valve cover bolt its the skinny brown/yellow wire coming from each 4 wire connector.
    Mar 27 2011
    00 S4 Epl 3
    mn
    Also what about rewiring the ICM's?
    Mar 27 2011
    00 S4 Epl 3
    mn
    success!!!
    Dec 13 2007
    Eastern CT
    good, i have the wiring on my computer at home i was going to post it later but since you got it good
    Jun 29 2010
    Ottawa
    Quote Originally Posted by calundeen View Post
    Would like to know this also...
    Sent from my SGH-T989D
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    Lots of ICM delete, TSI coil packs for 1.8T out there.
    Same benefits (weak/failing/expensive stock coils and ICM, stronger spart, larger gap (0.040), etc.) applies to 2.7T?
    I plan to start with one of my 1.8T AEB (one is having misfires, even with new plugs), than move on to my 2.7Ts.
    Best source to get the coils (and required - as I understand - spacers)? I saw some good looking Bosch "R" (for red).
    Also, seems there are Hitachi (bold down) and Bosch (plug in) available, and several versions for the TSI. Which one(s) are best and why?
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Sep 11 2009
    NE
    Dealer Bosch coils for 2.0 tfsi are the best. Eldor ones for earlier engines are crap.
    Feb 20 2010
    Brighton, MI
    Bought Bosch coils (red) and spacers (red) from intergrated engineering (not sure about the function of the spacer; only side slots of coils reach into them).
    Also got the ECS harness. Plugs for coils fit, what what are those 2 wire looms with loose pins for? where are they going?
    I thought I need to cut off the ECU to ICM 5 pin connector and hard wire to ECS harness. Not so?
    Need some help.
    05 Golf TDI
