I tired to remove the coils and plugs yesterday to see if everything was okey, first thing I saw was all the plugs had some carbon fouling.
This can indicate wrong mixture so I hooked the A/F meter to bank one and two. The mixture was around 14,7/15:1 on idle which should not be a problem? Maybe a little to lean but nothing to worry about I guess.
Vagcom dont show anything abnormal either.
I also saw that I have abit carbon buildup on the pistons after just idling the far for a total of 60 min maybe.
After checking all the connections to each coil, I swapped the coils around and installed new plugs bot got the same coeds, only this time the Cylinder 5 didnt have the "intermittent" word in the code.
Any ideas? Maybe I just need some load on the engine to burn of the carbon on the pistons?
