The car: 1999 facelift A4 B5 1.8T (ANB engine) quattro. The car is planned to be a frequent track participant, but also used in town (I know, I know I can't have it all... but I will try).
The story: began in 2008 when I upgraded my car with APR Stage III kit, Racetec FMIC, APR 2,5" turboback exaust, street density package, some gauges and all the rest of supporting mods to make it happen. The car was dynoed at 262 bhp on pump gas.
The car was fun, but as usually - I got bored, and wanted more. With more power in my mind I decided to upgrade the power transmission to the wheels. This summer I bought from a 2000 S4 B5 transmission (DSY), drive shaft, rear differential, axles, hubs and brakes. All of this is already mounted on the car, but more upgrades are to happen soon.
The aim: 480 hp tuned for mid-range power. I hope to have your support around here.
The plan:
Engine upgrades (2.0L stroker):
Short block
- ABF crank - PURCHASED;
- Mahle 83 mm stroker pistons - PURCHASED
- IE Tuscan 144 x 20 mm (unfortunately I bought regular H-beam IE and now I need to sell them first) - PURCHASED, NEED UPGRADE, Update - Scrach IE, there will be PAUTER rods in the engine, no rifle drilling! - PURCHASED;
- New audi oil pump - PURCHASED;
- Rosten performance girdle kit with new ARP smaain studs for 058 girdles - PURCHASED.
- New crank, main and rod bearings Calico, ACL??? - Decision was made for Vandervell/Mahle Motorsport sets - ordered +0.25 main and + 0.5 mm rod bearings - 5 grooved/ 5 plain shells.
- Head gasket for ALT - PURCHASED;
- IM shaft seal and bearings - PURCHASED;
- Front and rear seals - will be sourced by the shop;
- Full set of gaskets - will be sourced by the shop;
AEB head:
- IECVA2 cams - PURCHASED;
- IE cam gear - PURCHASED;
- New Audi hydraulic lifters - PURCHASED;
- New Ferrea intake and exhaust valves PURCHASED;
- Supertech springs and Ti retainers kit - PURCHASED;
- New Supertech valve guides - PURCHASED;
- New chain tensioner - PURCHASED;
- ARP head studs - PURCHASED;
Other:
- Timing Belt - NEEDED;
- IE dowel pin kit - PURCHASED;
- Rollers and tensioners, serpentine belt, water Pump, thermostat - will be sourced by the shop;
Forced induction:
- S4 B6 V8 4.2L MAF;
- Log T25 manifold - PURCHASED; I have two - APR which will be my first option, if not - SPA TMA01;
- BW EFR 7163 - PURCHASED; Upgraded recirculation valve and IWG actuator - Turbosmart TS-0620-1143 with set of springs for up to 26 psi spring pressure, TS-0203-1261 - PURCHASED
- ER competition FMIC kit - PURCHASED;
- IE large plenum intake manifold big port - PURCHASED;
- 3'' turboback exhaust system - NEEDED, decided to stay with custom 3" downpipe and the 2.5 APR to the back, but + open exhasut valve after the downpipe.
Clutch and flywheel (+ bolts):
Single mass flywheel new (refurbished) from old school I4 audis - PN 026105269L(X)
Upgraded pressure plate for 2.2L turbo 3B engine - Sachs PN 3082999707
Custom ceramic 6 puck friction plate made from 23 spline 240 mm core
Very happy I did not go into extremely expensive clutches. This one is reasly well priced and ofthe used in projects north of 500 hp in Europe
As for the clutch I will leave the part numbers above for refference for other builds, but I found it may be a problem to fit a sprung friction disc.
I will probably go with custom steel flywheel for RS4 B7 cluch with 8-puck ceramic disc.
Ignition:
- 2.0TFSI coil conversion kit and coils - PURCHASED;
Fueling:
- Bosch 044 + 034 adaptor - PURCHASED;
- ID1000 w/ P&P adapters PURCHSED;
- Adjustable FPR - initial idea fro Bosch was now substituted for Tubosmart FPR 1200 (TS-0401-1004) - NEEDED;
Water/Methanol injection system ??? - NEEDED, may be give up on this system for now.
Brakes:
- New S4 321 x 30 mm front and 256 x 25 rear rotors (Audi) - PURCHASED;
- Stoptech street performance front and rear pads - PURCHASED;
- Stoptech braided lines - PURCHASED;
- Brake repair kits and caliper paint - PURCHASED.
Although this set up is on the car I will upgrade to B6 S4 set up.
Suspension:
- Sturn adjustable upper control arms - PURCHASED;
- CPP adjustable rear links - PURCHASED
- TRW/Lemforder control arm kit and tie end rods - PURCHASED;
- RS4 front and rear sway bars - PURCHASED;
- Front and rear Wiechers strut bars - PURCHASED;
- DGR coilovers - street version - PURCHASED;
Drivetrain:
- RS4 transmission (FDP) - PURCHASED; but decided to stay DSY wuith the T3.
- Center T3 torsen differential (RS4 B7) 40:60 bias - PURCHASED;
- Adapters for T3 differential to fit in 01E - NEEDED;
- Wavetrac rear TBD/LSD - NEEDED;
We are starting with Brakes/Suspension work. A teaser pic:
[IMG]
