I would recommend reading through this thread before you get started.
This will be an explanation of what I did for the 2.0 FSI conversions on my car.
I am in no way responsible if you mess up your car, but if you follow this you shouldn’t!
My goal for this is to make the install easy and answer any questions that I had. I will try to keep this up to date with answers to people’s questions. Expect to spend 6 to 8 hours on this. (Based on my own experience. Your time might vary)
If you see anything incorrect or have suggestions please let me know so I can correct it.
Tools
Soldering iron: this doesn’t matter, but I recommend over 35 watts. I soldered all mine about 650 degrees.
I would recommend watching this video, it's very informative.
Solder: I got .032 inch in diameter 60/40 Rosin-core Solder from radio shack. When selecting solder, make sure you get solder with Rosin core or get a separate container of flux. (This helps the solder adhere to the wire.) (Sorry couldn’t find a link to the solder all the ones on radio shacks website are missing led)
Heat shrink: Best stuff I found was from harbor freight for the price. It will do the job and can withstand around 230 degrees F. Found it for about 4.99 a box. I bought regular heat shrink and then marine grade heat shrink with adhesive lining for a watertight seal.
http://www.harborfreight.com/120-pie...set-67530.html
http://www.harborfreight.com/42-piec...ing-67598.html
Wire cutters: Big enough to cut through 4 strands of wire at once and insulation.
Wire strippers: Wire strippers are extremely important so I recommend that you get them or you will go insane! There are a couple options here and I used these. The only problem with them is the wire has to be a certain length for them to work. In my case the wire was too short and they didn’t work very well on the original wires. Worked great though on the new coil plugs wires. Radio Shack wire Strippers
If I did it again I would probably get some designed like the ones from harbor freight. The reason these would be better is because you can strip the wire from end without needed a lot of extra wire to grip. I read the reviews about the harbor freight version so it’s possible that these are bad now. I used to have some but they broke because they were made out of plastic. These should last the life of the install and will make your life so much easier (its only 5 bucks). This is what took a lot of my time was having to strip the original wire with a knife and made me a little insane.
http://www.harborfreight.com/6-1-2-h...ent-66690.html
Heat gun: I got this at harbor freight a while ago very useful tool I use it all the time. This is for the heat shrink (if you choose to use a lighter don’t! I don’t recommend it go buy a heat gun it has many uses.) I set it to about 450 to melt the heat shrink.
http://www.harborfreight.com/12-inte...9343-9184.html
Step 1 Get supplies!
Coil connectors 6x http://www.ebay.com/itm/Ignition-Coi...d28e8f&vxp=mtr
You can get this version as well http://www.amazon.com/2011340-Igniti...vglnk-c1005-20
6x adaptor plates - I got mine from a member here for $65 but the Touareg adaptor plates will work (part 077 905 390).
06E905115E 2.07T coil packs x6 http://www.amazon.com/Standard-Motor...rds=06e905115e
Bought from amazon because of amazon prime free shipping ftw
Step 2 Now comes the good part
Now that you read through the tools and parts now comes the fun part.
Take a deep breath and get ready for some cutting. Just tell yourself your car will start again. Don’t freak out!!!
############################# ICM #####################################
I decided to cut and directly solder the ICM instead of buying the $35 dollar connector and building it.
!!!IMPORTANT ONLY CUT ONE ICM OFF AT A TIME!!!!
Only cut the other ICM after you have soldered and shrink wrapped the other one.
I started with the ICM take the wire cutters and cut one off! I cut it off maybe half an inch from the rubber boot. The length that you cut off can vary depending on how clean you want to make it. Use your wire stripper and strip about a ¼ inch of the insulation. Follow these colors from infinkc.
[IMG]
This is an example of how much I cut off from the ICM
[IMG]
Bank 1 (Cylinder 1,2,3 ICMs)
4 Wire plug - Grey/Yellow (Pin 1) goes to 3 Wire plug Brown/Grey (Pin 3)
4 Wire plug - Pin 2 Brown Unused
4 Wire plug - Green/Grey (Pin 3) goes to 3 Wire plug Brown/Green (Pin 2)
4 Wire plug - White/Green (Pin 4) goes to 3 Wire plug Brown/Blue (Pin 1)
Bank 2 (Cylinder 4,5,6 ICMs)
4 Wire plug - Grey/Brown (Pin 1) goes to 3 Wire plug Brown/Grey (Pin 3)
4 Wire plug - Green/Brown (Pin 3) goes to 3 Wire plug Brown/Green (Pin 2)
4 Wire plug - White/Brown (Pin 4) goes to 3 Wire plug Brown/Blue (Pin 1)
Follow the color chart above and solder and shrink wrap and then repeat for the next one
[IMG]
This is what it should look like when done. Yes the large brown wire is to be left alone!
Personal note: I ran into a problem with bank 2. Grey/Brown looks an awful lot like White/Brown so make sure when soldering bank 2 that you pay attention! Use a very bright light so you can get a clear view of the colors.
Once done pat yourself on the back and don’t try to start your car!
######################### COIL PACKS ###################################
Time to cut the coil packs! I recommend that you finish soldering and heat shrinking the solder joints before moving to the next one.
As for where to cut the wire, it all depends on the location of the wire. With solder the wire will become very stiff at the joint. We also don’t want any stress on it so I would cut the wire at an area where there won’t be a bend and the wire would lay flat. See picture.
[IMG]
[IMG]
[IMG]
These are examples of how much I cut off.
First put on the heat shrink as far away from the solder join as possible (it is possible that you can heat the wire up enough that it will activate the heat shrink). I placed a larger heat shrink over both pin 2 and 4 for the grounds. Next connect the wires as shown below
Coils:
New 4 wire plug (Pin1) - Red/Green on s4 harness
New 4 wire plug (Pin2) - Brown/Yellow Ground on s4 harness
New 4 wire plug (Pin3) - brown w/(blue, green, grey,) stripe on s4 harness
New 4 wire plug (Pin4) – Brown/Yellow Ground on s4 harness
Here are some pictures of the process.
Before shrink wrap
[IMG]
I was surprised that cylinder 1 and cylinder 4 only had 3 wires each. For soldering those just connect pin 2 and 4 together and solder to the Brown and yellow wire. On all the other cylinders there are 4 wires. I ended up soldering both brown/yellow wires to pin 2 and 4 together in a bundle. (Not sure if you can solder brown/yellow to pin 2 and the other to pin4 and keep them separate.)
Example of the two ground wires soldered together.
[IMG]
Once soldered place the heat shrink over the solder and shrink it using the heat gun taking care not to heat up other components in your engine bay.
[IMG]
Repeat this for the other 5 coils.
Double check your wiring
Check it again!
Now start your car and profit!!!!
If you have any problems then there is probably a problem with connections or wiring is backwards.
Once done pat yourself on the back but you’re not quite done!
######################### MAKING IT CLEAN ###################################
So I recommend heat shrinking all the connections and wires that you just added. This will protect everything from the high heat as well as make it look stock.
I will include diameter of the heat shrink I currently don’t have it.
I reused the boots from my old terminals.
I had to take the connector apart and pull all the pins out. (I ended up modifying a paperclip to push down the tab. (I will expand on this)
Once all the pins are out of the connector slide over the heat shrink and then the boot.
Put the pins back into the appropriate holes.
The reason for the other heat shrink was I had to cut the boot to fit the pins into the boot. I then placed the heat shrink over the boot. The heat shrink that I use has adhesive that melts when heated and seals the connection.
This is what the final product will look like:
[IMG]
Now you can pat yourself on the back!! Congrats you did it!!
I’m still expanding on this DIY and I will continue to update it with corrections.
Questions/Comments
Let me know if you have any suggestions or comments. I hope this helps and answers some questions people have.
If anything is wrong let me know! I don't want to spread misinformation
