Page 1 of 9 123 ... LastLast
Results 1 to 40 of 321
    Veteran Member Four Rings Tjtalan's Avatar
    Jul 19 2014
    Tulsa
    Just picked up an 01 F21 car.
    Just picked this car up, basically same story as my B6 S4. Previous owner put a lot of money into it, but started with performance and looks. Doesn't look like any maintenance has been performed in years. Leaking oil from everywhere. All the mounts and control arms are shot. Plus side, lots of pricey parts.
    I'm going to start tearing into it, first call 034 and get all track mounts. Get all the oil leaks sorted and go from there. I don't even have a list of everything that's been done, i'll find out as I get to it.
    Update, how it sits today.
    This car has come so far in a small amount of time. Basically replaced every maintenance item from wheel bearings to timing belt.Here is a list of mods:
    Engine stock 2.7T
    Daz tuned, 91 and E85
    Frankenturbo F21's
    Modified Frankenturbo inlets
    SSAC down pipes, modefied with flex and 2 bolt flange
    Fast intentions stage I and III, no cats, I switch out the center sections
    044 pump
    550 EV14 injectors
    3bar map
    034 85mm Hitachi maf
    034 bi-pipes
    034 carbon intake
    034 spider hose
    AWE side mounts with carbon shrouds
    VagAutoWorks aka Daz 2.0T coil conversion
    Transmission
    JHM 1-2 collar
    JHM carbon synchronizers
    JHM centering spring
    JHM Trio package
    JHM cross rod
    Fidanza flywheel
    Ringer racing stage 4 clutch
    Mounts
    034 billet engine
    034 snub and cage
    034 billet trans
    Apikol diff mount track
    034 billet diff carrier with track bushings
    JHM drive train stabilizer
    Suspension/wheels
    PSS9 Coilovers
    034 front fully spherical upper control arms
    034 rear fully spherical upper control arms
    034 fully spherical rear tie rods
    034 rear sway bar
    034 subframe reinforcement kit
    034 rear sway bar links
    18in OZ superleggera lll
    Brakes
    Brembo 17Z up front
    Jul 20 2011
    Providence - RI
    Interior looks exceptionally clean.
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    is that 217xxx miles ?
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Jul 19 2014
    Tulsa
    Quote Originally Posted by AudiTechS4 View Post
    Yes it is, I know I know it's a lot. But I'm planning on going over everything. So I'm not all that worried about the mileage. Full stage 3 was done at 207000, funny right.
    First parts orde
    Aug 24 2014
    Newport Beach, CA
    Very nice, where did you pick this up from? My car had the same sort of previous owner, lots of money spent on high dollar parts but stupid basic maintenance things or repairs were not done. Kind of opposite of what the natural order of things should be.
    2024 M3 Comp xDrive
    Jul 19 2014
    Tulsa
    Quote Originally Posted by christianb5s4 View Post
    I'm in Los Angeles, I found it in Redlands. I'm excited, all in all it's a great starting point. I've wanted a b5 S4 since the first time I laid eyes on one. It's funny I always wound up in something different. This car will be with me for the long-haul.
    Aug 24 2014
    Newport Beach, CA
    Exactly how I ended up with mine, drove a few back in high school and always wanted one since.
    2024 M3 Comp xDrive
    Veteran Member Four Rings JKnight41's Avatar
    Oct 11 2012
    Southern Illinois
    I drove my first one in high school, then bought it, and haven't owned anything other than an s4 since. My car market is very narrow and extremely biased.
    -00 Hibiscus S4 Sedan (FOR SALE)
    -09 Audi S5 / SOLD
    -01 Audi S4 Avant / SOLD
    -04 Audi S4 / SOLD
    -00 Audi S4 Stage 2 / SOLD
    Veteran Member Four Rings Meow's Avatar
    Mar 08 2012
    MI
    OZ IIIs! Awesome! Look like 18s? I bought a set of 19s and thought they were very rare and now 3 or 4 cars have popped up this year with them on... lol. MOAR PICS!
    RIP Daz, you will be missed.
    Jul 19 2014
    Tulsa
    Yep 18-8 OZ IIIs, I can't find the ET stamp? Fk coil overs, what Looks like a 034 carbon intake, AWE intercoolers with carbon shrouds. I know it has an epic tune, any thoughts on them? It is spiking at about 27, holding 25 on the AWE gage. The camber is all wrong it has some Adjustable uppers I've never seen before. The exhaust, what I believe to be a Milltek is cut on and welded and leaking. This car has some good and some bad, I have my work definitely cut out for myself.
    Nice car, i have been looking to get one, but the prices on them are crazy high
    Senior Member Two Rings omakayd's Avatar
    Mar 08 2014
    V10 B5 S4, 4.0t widebody B5 sedan, 01 India Red Avant
    Waterloo, IA
    Looking at that order list it seems you like to feel every vibration.
    It will make you paranoid, trust me!
    Project B5.2 (v10 swapped B5 S4)
    2000 Black S4 5.2L/6mt
    2001 India Red A4 Avant 2.7t/5mt
    2004 A8L 2.7t/6mt
    2014 A8L 4.0t
    1997 A4 Widebody sedan
    Instagram: @harp_attack
    Veteran Member Four Rings sherbet's Avatar
    Jun 26 2010
    '63 Thunderbird
    Walnut Creek, CA
    ^psh, its not that bad. With the amount of weight that those little tranny and motor mounts support, you really need delrin and billet on everything if you want it to feel locked down. The NVH is noticeable but not horrible...but the difference in feel is incredible!
    B5S4 Sedan/ Stg lll/6MT/ Trouble
    B5S4 Avant/ Stg ll/6MT/Daily
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Play with one that has sterns on the motor, 034 motorsport on the tranny, and poly dts.
    Might just be the combo, but Im tempted to start throwing another set of tranny mounts in every time I see it and swapping them back out before it goes home.
    Seems like you are fine running whatever mounts you want elsewhere, but keep the tranny mounts a little softer as these are right under your ass.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Jul 19 2014
    Tulsa
    I went with the same basic set up on my B6 S4. Even going from good stock monts, The feel just improved drastically. I love The driving experience you get from having the drive train completely locked down. My Basic idea for this car is road course with interior. Next major mod Will be getting rid of all of the bushings for spherical bearings. Not worried about sound, or comfort, just feel.
    Mar 08 2014
    Waterloo, IA
    I'm not saying the driving experience won't be improved, it definitely will. I run almost the same setup and honestly, I agree with zillarob. Don't regret anything else but those tranny mounts, those made every loose thing in the cabin annoyingly obvious.
    ECS engine mounts
    ECS rear diff mount
    034 billet trans mounts
    034 snub mount with bracket and extended bolts
    apikol "race" rear diff carrier bushings
    powerflex rear lower control arm bushings
    2004 A8L 2.7t/6mt
    2014 A8L 4.0t
    Jul 19 2014
    Tulsa
    Quote Originally Posted by omakayd View Post
    Thanks for the tip omakayd. Every bit of info helps, that's why I'm here, take experiences of many. Hopefully come out the other end with a better machine.
    Nov 16 2010
    WetSide, WA
    Ya, just go easy on the trans mounts (like stern or 034 street density) and you will be better off.
    I put a set of solid ones in my car once. I only had to back up 4' before I knew they were coming back out
    Odd thing was, I put them in another car to diag some drivetrain slop and it wasnt that bad. Ymmv I guess.
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    Those 3pc superleggera's would definitely have been
    as selling point for me. Nice wheels! Also don't listen to
    everyone on here. The car feels so much better with solid
    mounts. The nvh increases a little bit but keep in mind
    your turning your heavy & comfy luxury sedan or what
    once was into a more performance orientated ride.
    Oct 11 2012
    Southern Illinois
    Quote Originally Posted by zillarob View Post
    I am gonna be running stern motor mounts, and I already have 034 street trans mounts, as well as an ECS diff mount, were you saying this setup is optimal? Or garbage. Maybe I am a yard, but your phrasing threw me off. Haha
    -09 Audi S5 / SOLD
    -04 Audi S4 / SOLD
    Veteran Member Four Rings hibiscusS4's Avatar
    Sep 09 2013
    2000 hibiscus s4 , 2000 allroad
    Ill be running all stern mounts as well they were the best in my opinion
    01 s4 f21 on meth sold
    00 s4 hibiscus six speed swap pj ko4
    00 allroad pj ko4
    Rip mike aka Daz Dillenger
    Jul 19 2014
    Tulsa
    Quote Originally Posted by hibiscusS4 View Post
    I personally have never run Stern anything, not to say they're not good. I've had a passion for VAG products for a very long time, always run 034. Everything from suspension components to mounts, even engine parts. I've never been let down with the quality. I think especially in regards to the B5 chassis, they know what they're doing.
    Oct 11 2012
    Southern Illinois
    Quote Originally Posted by Tjtalan View Post
    Not here to shit on 034, I love them and their products. BUT my first trans mount I received from them looked like this after a few months with no launches... Stage 2.
    They promptly sent me a new one. (Made me shell out 15 bucks to ship the little thing) Still happy with my mounts though.
    -09 Audi S5 / SOLD
    -04 Audi S4 / SOLD
    Jul 19 2014
    Tulsa
    Quote Originally Posted by JKnight41 View Post
    I have known of people having experiences like yours. Thay must have had some bad batches, I beat the snot out of my B6 S4 and my A3 on the track and the street. Suspension components mounts, never had any issues.
    Nov 16 2010
    WetSide, WA
    I think it is rough, but I drive like a girl most of the time and always seem to be in the rpm range it is most prevalent.
    If you get it wound up a little it smooths right out.
    I think you have a nice list there and it will be an excellent driver.
    I babysit one with stern motor/trans/snub and it is by far my favorite setup.
    Firms it up nicely and adds just enough rumble to know you are sitting on something.
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    Just curious as to why you got the whole diff carrier instead of just the bushings
    Jul 19 2014
    Tulsa
    Quote Originally Posted by Zba View Post
    Well I can't say I've seen one brake, or even Heard of one breaking. But this is where I put my faith in a company I trust. I'm going to track this car eventually and want to know that I've done everything right. It may be overkill but that's what gives me peace of mind.
    Jul 19 2014
    Tulsa
    PARTS! I'm going to tear into it tomorrow.
    Veteran Member Four Rings jpurre's Avatar
    Jun 11 2013
    2004 BMW 325i
    South Florida
    Isn't it fun when you get a box full of new parts! Congrats on the new acquisition!
    2001 Silver F21 TIP (SOLD)
    Build thread--> http://www.audizine.com/forum/showth...ally-Happening
    Senior Member Two Rings Jay_Soprano's Avatar
    Nov 15 2010
    Audi A6 C6
    Orlando, FL
    Congrats... I love getting parts of new stuff just got my Capra R lip and I feel excited... Lol
    Jul 19 2014
    Tulsa
    Ordering and receiving parts is the greatest thing ever. It's an addiction, I consider it my one vice. Looking at all the parts and the fact this thing has 217000 miles on the clock, I'm pulling the engine. Whoever had worked on previously, The turbo install and such, was just a hack. I'm going to do it right the first time and be done with the engine at least. I'll start pulling it tomorrow.
    Jul 19 2014
    Tulsa
    Put the S up on jack stands on my lunch break. I'm hoping to have it finished in a week. I'm going to pull the engine apart and replace all the bearing, rings and the oil pump. Send the heads and block to the machine shop to be gone over. Just a basic refresh. This thing is a mess. I'm also going to replace all of the front suspension components, and all the wheelbearings. Hoping everything will take me about a week. Wish me luck!
    Jul 19 2014
    Tulsa
    Nov 16 2010
    WetSide, WA
    I would seriously reconsider tearing into the motor unless youre doing rods or something.
    These things are pretty shout and wear very well. A few people have stg3 cars with well over 300k on the original motor.
    Id just reseal it and save the money for all the little bs that you will find along the way.
    Just replacing the hoses that are swollen up from oil and psteering fluid leaks adds up pretty quickly.
    Jul 19 2014
    Tulsa
    My last car was a B6 S4, so everything scares me. It runs great, compression is good. Think I should be alright with just a reseal, that was my original intention. Then I let a Chevy guy friend talk me into tearing it apart.
    Veteran Member Three Rings Audimilo's Avatar
    Apr 19 2014
    CO
    do. not. listen to chevy truck guy.
    Oct 11 2012
    Southern Illinois
    Quote Originally Posted by Audimilo View Post
    -09 Audi S5 / SOLD
    -04 Audi S4 / SOLD
    Apr 19 2014
    CO
    just laughed out loud.
    Like a Rock.
    Jul 19 2014
    Tulsa
    Standing Arrow straight, lol...
    Jul 19 2014
    Tulsa
    Another box came today, PSS9!
