Results 1 to 33 of 33
Thread: Phantom A4 (UK)
    Active Member Two Rings Golfedd's Avatar
    Nov 19 2012
    UK
    Phantom A4 (UK)
    Since the UK invasion seems to be high with Olethalb and D2NY G thought jump above the invading ship too haha.
    Anyhow, the progress and how it stands/history (warning, it's a diesel ):
    So with the Air'd MK4 all stripped down and gone and the
    MK1 TT abused and sold
    I was on the lookout for a V6 TDi A4 and with commuting and need for decent mpg the 3.0TDi Quattro (much to the daily banter) was ruled out leaving the 2.5 and 2.7. and finally the one I wanted came up...
    - Phantom Black
    - S-Line
    - Sunroof
    - Bose
    -2.7TDi V6
    Picked it up and order some AP coils straight up. The S-line suspension is ok, but unusually 'bouncy'. The AP's ride very well, much more comfortable that OEM suspension and make driving the car more fun and planted! was a long process to fit, thanks to Olly for help on the installation- the rears are a TIGHT fit to get out and HARD as hell!...
    - 'joey modded' the lights and de-tango'd them alongside some 5point LED side lights and white fogs
    - slid in some white LED for interior lighting
    - round one of detailing too
    - Remaping it began with Bobby on here Bobby-Singh (details below) But 100% recommended!
    - DPF and Pre-Cat delete again with the magical hands of Olly to help! [Y]
    Pics Old to newest
    Nov 19 2012
    UK
    Then time for bluetooth XCarlink connection device for my A4. I ran one in the TT and I like how simple and effective they are for the money and this evening while everyone was alseep from overfeeding and drinking I got to it and whipped the car apart.
    The install
    First thing was to hide the microphone... I had wanted to put it in the light housing BUT the cable was too short, and I didn't want it on display so I set about a small hole in a blank to tuck it away. Sound quality is still good and clear! thin layer of silicon to stop splits. Blue tack to hold in place while glue set. I left a bit in to absorb bumps and support the mic.
    Took a trip this weekend to Olly for a swearing, painful weekend of De-Cat and DPF removal...
    Fist the Pre-Cat which was ok to undo, only snapping one stud, welded a new on in and new nut but cut it out and piped it, the EGT sensor was fiddly to get out and had to bend back the clip for the expansion tank. which bent back fine
    Then the BEAST of a DPF... didn't take long to drop it off the car thanks to olly for giant strength, snapped two studs as they were seized up corroded. two new nuts and bolts for them. They measured up and olly got his weld on, almost artistic
    Big shout to olethalb again for his help. Time to address the straw like intake system and I'll get some pipes to fabricate a new induction route. Should free up some throttle response and noise from the V6
    waiting on my mapper to sort out the DPF removal, we ran two options but it still goes into limp mode, throwing up two errors... he's working on it but for now I'm 0-60 NEVER and 55-60mpg... no boost will do that, forced to cruise at 50mph BORING and annoying. sorted soon though
    - on another note, I meant to do the Clear Corner mod, so set about that and decided to run some regular 5 light LED's for brighter sidelights. Looks good, I'll get some more photos' up soon.
    Nov 19 2012
    UK
    further to the magic work at ollys of DPF delete and pre-cat Delete I've been having the car mapped by bobby who's been fettling and tweaking it as I go through the performance stage...
    1st - Basic custom map, to get a feel for the potential and asses the possibilities, pulled much better and free'd up the rev range
    2nd - Custom map tweaked and assessed smoke (no smoke at all), heat and fuel + EGR delete, pulled harder and smoother
    3rd - Revision after DPF delete and Pre-Cat Delete and tweaking = amazing torque in the low and mid, carrying through into the high RPM + constant and relentless pull and delivery of power. no horrid short spikes
    Also - no smoke AT ALL, like some generic maps 'can' give. Chatting to Bobby he takes into account what you want and demand from the car and how you drive, tailors the map to you give him a shout! really knows his stuff.... This was good as the car isn't 'maxed' out there still more to go, but I didn't want to kill the clutch off too quickly - I get NO slip at all through the gears and it's on 67,000m with original clutch. I will be upgrading to a beefier one in the next few months out of personal choice. but very very impressed.
    Off to rolling road ASAP - will through up the graph and results but they should be very good over the stock power of 177bhp and 280lb-ft.
    Nov 19 2012
    UK
    Next Stages
    -Wheels! and it's got to be 19" by 9.5's really... or maybe a staggered set so shall see whats around as these 18" looks a little lost and have had curb rash from previous owner!
    - Full snow foam, wash and detail this week! get the paint back up to scratch after the rubbish weather
    Veteran Member Four Rings papadelogan's Avatar
    Jul 31 2011
    1999 F250 7.3 Powerstroke
    Gulf Coast of Florida
    I am so jealous that you have a diesel!! Well done and a beautiful car!
    2013 Phantom Black A5 P+ Cabriolet (2.0T quattro) mods4cars, mesh grill, gunmetal VMR 701, HFC "Boudica"
    2007 Ibis White B7 A4 Ti Avant 6MT quattro JHM Stage 2, HFC, Milltek CatBack, GFB DV+ "the YETI" sold
    2005.5 Black B7 A4 6MT quattro sold
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    2.7L TDI? Is that UK only? You learn something new everyday lol..
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
    Veteran Member Three Rings A4TQS's Avatar
    Feb 17 2013
    B7 2.0T Quattro Sline
    Europe
    looking good
    Feb 25 2011
    Seacoast NH
    Very nice, sir.
    Nov 19 2012
    UK
    Quote Originally Posted by papadelogan View Post
    thanks man, really? jealous? I thought it'd be all out petrol love over here. my bad.
    Quote Originally Posted by BenMTL View Post
    I think it's a Europe thing, but didn't know you guys didn't get the 2.7TDi
    Quote Originally Posted by A4TQS View Post
    looking good
    cheers!
    Quote Originally Posted by wildcat333 View Post
    Very nice, sir.
    Thanks kind sir... more updates to come soon! and rolling road print out
    Nov 19 2012
    UK
    So, went to Surrey Rolling Road this evening along with a few other cars and Bobby to see what she was pushing. Went with the hope of 230-240bhp and 400-430ftlb
    Stock: 177bhp and 280ftlb
    Mods: Pre-Cat Deleted and DPF deleted + Bobby-Singh Custom Map
    Results: 265bhp and 448lbft
    Huge shout to Bobby who worked on the map very hard and produced a smooth, SMOKE FREE map with very very nice figures! car drives like a whole new machine!
    Veteran Member Four Rings Jay-Bee's Avatar
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    448 ft-lb with a chip and a straight pipe, fuck me sideways i'm jealous!
    Nice ride man, we didn't get ANY TDI options in north america for the B7.
    2008 Audi A4 Avant 2.0T Tip - Stage 2 94 octane Digitek Tuned
    [AEM Intake, CTS FMIC, B8 IHI Turbo, CTS test pipe, 2.5" Custom stainless exhaust, Rev J DV, H&R Springs, Bilstein shocks, S4 rear sway bar, B8 S-line seats]
    Nov 19 2012
    UK
    Quote Originally Posted by Jay-Bee View Post
    Yeh a custom remap and straight pipe all it was... not bad output. Damn sucks you had no options for TDi's the 3.0l TDi will do 500ftlb+ and 320bhp+ and the turbo from that engine BOLTS onto this one. so those figures are nearly reachable for mine too...
    Mar 07 2013
    Holy torque. Great progress
    Nov 19 2012
    UK
    There are things in the pipe work for this, full rear box delete and DTM tips to unleash some of the V6 noise and a few other bits.
    recent photos
    Lurking
    Nov 19 2012
    UK
    Forgot to add in the new clutch info! and some other bits that went on!
    Wheels,
    Interior,
    Clutch (new flywheel, friction plate + Supper Clamp Stage 3 RS4) + (old burnt clutch photos)
    wheels being done
    Rolling
    Alcantara section with USB charge port installed
    Senior Member Two Rings imajeanius's Avatar
    Jan 30 2012
    2004.5 Blue Lagoon GLI
    York, PA
    Quote Originally Posted by Golfedd View Post
    Woah! Call me stupid but that's my favorite part! DIY? Write up? More pics?
    Established Member Two Rings Whats4dinner's Avatar
    Feb 26 2012
    2009%20328I%20Coupe%2C%202017%20S550%2C%202017%20Audi%20A4%2C%202001%20BMW%20525i
    Bay Area
    Wow, very nice. Those are some crazy numbers you put up as well.
    Love me some European cars. My year old lab Bodie is my avatar.
    Nov 19 2012
    UK
    Quote Originally Posted by imajeanius View Post
    Um some alcantara, thin MDF + USB charging port. cut a hole and trim.... Then wire up the charger to cigarette lighter or as I did, use the interior lighting to activate a relay so the USB socket is only live IF the lights are on (I always drive with Side lights on)
    Quote Originally Posted by Whats4dinner View Post
    Thanks :-) not bad power, for now
    Finally got around to sorting out the chrome fails...
    Side trims all done
    Front Grill all done + (S-line badge, which makes it a little more subtle) Waiting till I get an RS4 grill though really
    Boot Trim - to be done
    (sorry iPhone photos)
    Veteran Member Three Rings Adub-Drew's Avatar
    Feb 07 2010
    Wilton, CT
    Cool car man, I really wish we had the TDI's here in the states!
    B7 A4 tip (daily) Mk6 Gti Drivers Edition (toy) Soon to come Mk4 R32
    Nov 19 2012
    UK
    Quote Originally Posted by Adub-Drew View Post
    Thanks bud, did you not get the V6 TDi's out there... damn :-/
    After seeing some full black and some half matte headlights on B7s at the E38 weekend... I finally had an idea of what I wanted to achieve with mine. Had got hold of Bi-Xenon projectors, bulbs, ballasts and all bits needed to make my Halogen lights into Bi-Xenon projectors, missed the output from the ones I had on the TT and Golf. So with clear lenses on these projectors I'm hoping for a very good light output.
    Stripped lights out
    Took lights completely apart
    Sprayed them
    Installed Projectors
    Finished shots to come. and a before/after light output.
    slim pack mounted against the chassis out of the way, wires tucked away too - no annoying 'aftermarket' loom hanging about
    More to come tomorrow when they're in and running / night comparison shots too.
    Established Member Two Rings la modz's Avatar
    Mar 16 2011
    birmingham uk
    nice mods mate
    Aug 09 2007
    Mount Airy, MD
    frickin love everything so far. I am so jealous of the engine offerings too. projector retrofit looks good. I'm glad you went with oem shrouds, anything else just gives it a bug eyed look.
    - Will
    06_Avant . DTM K0R-Gt. etc...
    The Avants Timeline
    Veteran Member Four Rings LoKisSpYdR's Avatar
    Jun 26 2012
    Brilliant Red B7 A4 2.0T Titanium quattro Tip - 2015 Q7 PP
    Reading, PA Area
    ^agreed. Love the car. Envy the options offered in Europe (engines and interior). Love the passenger airbag off switch! Has anyone ever retrofitted one in to a NA spec while doing Recaros as opposed for the pressure plate?
    Sick car though. Look forward to seeing more.
    B6 A4 1.8T Dolphin Gray qM
    4L Q7 3.0T Glacier White PP
    Nov 19 2012
    UK
    Quote Originally Posted by la modz View Post
    nice mods mate
    Thanks man, I like your B8 was looking at the thread the other day!
    Quote Originally Posted by SykoraA4 View Post
    Thanks SykoraA4, ah looks like we got some good engines then haha. Yeh, saw some odd looking options for shrouds makes them look off.
    Quote Originally Posted by LoKisSpYdR View Post
    not sure on the retrofit for NA never even new you guys couldn't turn it off :-/ can't you disable via vag-com?
    Thanks, more to come - see below
    Nov 19 2012
    UK
    Lights are done, back together and leveled up which took some fine tuning to ensure both beams where straight and aligned, still need some minor side to side adjustment at night.
    Here's some finished photos
    1 - Just Bi-Xenons
    2 - Bi-Xenons and Fogs
    3 - Fogs
    4 - Off
    Those interested they are 5000k bulbs for white light.
    Apr 05 2010
    impressive. u got the right mods/skills !
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    i like everything except the all black motif, i can understand why people like it, its just not my cup of joe.
    everything is tastefully done, love the passion, and i can only imagine what 450lbs of torque feels like on a 3,000 lb car, in my 5k lb touareg it was pretty awesome.
    [CENTER]Scott
    2011 S4
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
    Nov 19 2012
    UK
    Quote Originally Posted by djpaw View Post
    Thanks djpaw, it's all coming together. More power next maybe. Haha.
    Quote Originally Posted by mr shickadance View Post
    Cheers man. I actually been weighing up the badge and going back to silver to tie in With the badge... Yeh she's not sluggish however the 3.0l turbo would produce a stronger curve and a little more power :)
    Nov 19 2012
    UK
    Finally got some dark shots of the light out put. Dipped and Full Beam. The tunnel photo shows the increase of full beam very well.
    Oct 14 2009
    Okinawa Japan
    What components did you use for the bi-xenon conversion?
    -Shane Drake-
    2006 A4 Avant Dolphin Grey
    2007 GT3071R A4 Moro Blue-RIP
    >DRAKLOREs Build<
    Formerly DRAKES-PERFORMANCE
    Senior Member Three Rings olethalb's Avatar
    Feb 22 2013
    london ish
    Hi Edd :P
    Active Member One Ring Caleebra's Avatar
    Mar 07 2013
    Norway
    Nice mod on the head lights!
    that is a much better solution then the aftermarket headlights tbo :) *thumbs up*
    - Arne
    2008 A4 B7 2.0TDI
    Nov 19 2012
    UK
    Quote Originally Posted by DRAKLORE View Post
    They are Iris surrounds with Mini Morimoto lenses and slim ballasts running 5000k pure white. I was going to do the FX-R install, however the install and lining them up is significantly harder, so stuck with the Morimoto to ensure a good finished item.
    Quote Originally Posted by olethalb View Post
    Hi Edd :P
    Hi Olly!
    Quote Originally Posted by Caleebra View Post
    Thanks man, I was going to go OEM... but after the units, wiring, components it was around £500-£600 so this is a much better result for the money and looks OEM!
