Originally Posted by
animportant
So to sum up this thread.. Max understands that I'm an average consumer and it would be an absolutely ridiculous proposition to swap a vr6t into my audi to try and get 100 extra whp when i should rebuild my engine with rods and throw a set of duals or do a single conversion, be happy with 500 whp and stop trying to be a spoiled asshole with a 9 second luxury vehicle. Angular understands the little kid side of me that wants to have a crazy fast b5 s4 and that a vr6t might make the extra power more possible, which I'd probably find some way to blow up eventually, anyway. Maybe we are taking the frustrations we have against our b5 s4s on fellow b5 owners? hahaha
That was my main point; that it is not viable unless you are going for something ridiculous. And I stand by my statement that even if you are going for something ridiculous, it will likely be easier, cheaper, and almost as fast with a built to the hilt 2.7T.
Angular, I think first off you misunderstood what I was saying about disadvantages. I am specifically talking about advantages and disadvantages of a VR6 motor IN A B5 CHASSIS. If there were no disadvantages to running a VR6 in a B5 (and there are many disadvantages, such as weight distribution, engine management, exhaust components, A/C, cruise control, etc), then I would run a 24v VR6 in my B5. I love the VR6, especially the 3.2L; it's a great motor, there's a lot of aftermarket, and it sounds totally bad ass. But besides the VR6's ability to hold some extra power stock, there are no obvious and apparent advantages over the 2.7T beyond an extra 0.2L of displacement (which once again, is not worth the huge inconvenience of the VR6 in a B5). I'm promoting the idea that 100-200whp more on a stock motor is NOT worth the thousands of dollars and hours of extra work to get to where the OP wants to get. Even if he was 100% set on building a 9 second car, I would still recommend the 2.7T and tell you that there simply hasn't been enough development.
A 3.0L APB motor has no trouble pushing 800-900whp when built correctly. You said you would show me a cracked block for any 2.7T over 800whp. I'll say that I have a +900whp 2.7T 30 feet away from me right now. Only reason we didn't push it more is because we need a chassis dyno; too much tire spin at +850whp.
In the end, once again, my primary point is to illustrate that building a motor is easy and you can pay someone to do it and you know what it will cost, etc. Paying someone to install your VR6 motor into your B5, is a whole different head ache and in the end, said and done, dollar to dollar, I would venture as far as to say a stock VR6 in a B5 would be much more expensive than a fully built 3.0L. Unless you want something different, I still will say that a VR6 is not ideal or efficient in a B5 from start to finish cost to performance.
Also, while I'm well aware of the "capability" of a stock VR6 motor, but let's make sure we don't confuse reliability with capability. Please also take into consideration that I think differently then a lot of people on the forum, and I illustrated that with the fact that we do not even like to tune a stock 2.7T motor beyond 450whp (even if it can go more). We are safe, extra safe, and not too interested in taking the risk of blowing up a customers motor. Our Stage 3 K04 tune even illustrates that; we run 20psi, low timing, etc. There is no reason to skate the limits when you can make a small sacrifice in performance and enhance reliability exponentially. Show me an 800whp stock VR6 motor that runs 800whp everyday at the track? For every example you can produce, it is likely I can produce 10x more examples of VR6 engines that have blown up with turbos.
If the VR6 really was the wonder engine you make it out to be, I don't think I would be personally selling so many VR6 build parts. There is capability, and then there is reliability and safety. Motor to motor, a 3.2L 24 VR6 is a better motor than the 2.7T V6. But, in a B5, it changes everything. A simple check of past records of all the past people who have purchased VR6 conversion parts from us shows me that a large majority of them also purchased, at a minimum, rods and pistons.
I'm not trying to offend you Angular; I'm trying to give the OP a realistic idea of what is involved and what the advantages or disadvantages are of going VR6 in a B5 chassis. I'm sorry if I made it out to seem like the VR6 is only marginally better then a 2.7T. Considering we are the ONLY company who makes all the parts for a VR6 swap, this isn't something I am against by any means. But for all intensive purposes in this thread, I stand by my main points and I do not feel 800whp on a stock motor is example that has been repeated many times and shown to be as reliable as a stock S4 motor under 500whp.
/ultra mega rant over
