Page 1 of 3 123 LastLast
Results 1 to 40 of 114
    Veteran Member Four Rings freaksavior's Avatar
    Jul 06 2010
    Houston
    emergency! Hole in my cam follower !
    Want to see? Sure you do, posts are useless without pictures.
    So question for you guru's and mechanics.
    Do I replace it, drive it and keep going, or do I put the car back together and have it towed into audi to check into this. Im really not sure what to do.. called an audi dealer in Cali since in Texas they are closed and he suggested i tow it in but I would like your feedback.
    Im at 77,107 miles
    Veteran Member Four Rings Coderedpl's Avatar
    Jul 27 2007
    Orange County, NY
    Are you under CPO?
    Might be just the pic but the HPFP looks damaged? how are the cam lobes?
    Current: F80 M3 | 2018 Q7
    Past:2018 VW Golf R | 2014 S4 | 2016 Nardo Gray SQ5 | 2012 VW Golf R | 2006 Audi S4 | 2006 A4 2.0T |
    Veteran Member Four Rings viziers's Avatar
    Jan 27 2007
    2005.5 A4 2.0T, 07 A4 Sprint Blue
    NC
    If your under CPO bolt it back up and drive it to the dealer... If your are not warrantied then you need to replace the HPFP, Cam an CF...... Or you can put a new CF in and have EXCESSIVE wear on the new and then on CF's..
    vizi
    05.5 B7 A4 longest running with no motor issues at 373whp
    Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
    Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
    Jul 06 2010
    Houston
    i bought it under cpo, id have to check if it's still under cpo though.
    Since the cam follower failed, wouldn't audi replace it free anyway??
    Jul 27 2007
    Orange County, NY
    Quote Originally Posted by freaksavior View Post
    They should with your deductible offcourse.
    I hate to say it but i would wait till dealer is open, check if you are under CPO and explain to them what happened.
    I would honestly be shitless scared to put that back in and turn on the car even lol.
    Talk to the dealer and ask them wtf
    Jul 06 2010
    Houston
    i have another cam follower, I was going to replace it if it wasn't that bad.
    So what im not sure if I should replace it with the new one, drive it back to Houston and then go to a dealer Monday or if I should have it towed back to Houston. I'm in Byran which is about 65 miles from where I live.
    Jan 27 2007
    NC
    Tow it back if you can swing it money wise unless you have AAA...
    vizi
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    Audi extended the warranty on the cam followers, intake camshafts, and the high pressure fuel pump to like 10 years/120K miles. So I would bolt it back up and take it to the dealership. Tell them that you took the high pressure pump off to check the camshaft follower and noticed it was badly damaged. See if you can get them to replace the cam follower, intake camshaft, and high pressure fuel pump. I see that you have a tune but I don't think the scan tool and pick that up on your car yet for the TD1 label.
    Jul 06 2010
    Houston
    its not a tdi...
    Veteran Member Four Rings bman005's Avatar
    Sep 06 2011
    2015 Silverado, 2012 A4 Avant. Former; 90 Corrado, 97 Golf, 05.5 A4, 2010 Tiguan
    Harrisburg, Pa
    Im gonna second the 10/120k extension. Just picked my car up yesterday, all covered and I have 114k
    And I'm also gonna second Vizi on just towing it
    New Build, 2010 Tiguan. Details to com
    Veteran Member Four Rings groundround's Avatar
    Jun 19 2009
    17 ram 1500
    Hartford CT
    put the cam follower back in drive it till everything f's up and let them replace everything!
    Feb 25 2011
    Seacoast NH
    if it's under cpo still, call audi roadside assistance (free).
    Oct 14 2009
    Okinawa Japan
    Quote Originally Posted by groundround View Post
    ^this...
    But I'm sure there are better ways of screwing over the dealers earned money..
    I would set things back to stock as much as possible, including tune, and then tow it back to the dealer for a warranty repair. The worst being you spent the money on towing for them to tell you it's not covered. The best being thy cover towing and replace most everything
    -Shane Drake-
    2006 A4 Avant Dolphin Grey
    2007 GT3071R A4 Moro Blue-RIP
    >DRAKLOREs Build<
    Formerly DRAKES-PERFORMANCE
    Sep 02 2008
    Boonies VA
    Looks just like my first one did. This is what you need to do, put it back in the car, make an appointment with the dealer. Tell the service adviser that you have been experiencing some hesitation while driving, that you would like for them to check the cam follower. They will tell you that with no codes they can't do anything blah blah blah. Tell them specifically that you would like for them to check the cam follower, if it turns out that its fine, then you will pay the hours labor to have them replace it.
    They will take it off, find it trashed, your HPFP lobe is worn, and it will all be covered under the 120k extended warranty. Your HPFP looks identical to how mine did, if you look up the TSB it categorically states that when the follower is worn through, that they must replace HPFP, camshaft and follower etc.
    If they try to give you crap about the tune, point out to them that if it was the tune that caused it, then how come Audi issued an extended warranty and there are thousands of documented owners with stock engines experiencing the same problem.
    You will be fine driving it like that. I was probably driving for at least a month on my cam follower like that with no issues, and I was beating on it trying to get a CEL to come on. Who knows how long I was driving it before I even discovered it punched through.
    White Wagon
    Senior Member Three Rings audisline08's Avatar
    Jul 20 2011
    Alabama/Ft. Benning, GA
    Quote Originally Posted by naiku View Post
    ^^^Good stuff man, thanks for the knowledge!! Im always worried now with a tune they will hold that in my face.....but like you said! Never thought of that, little piece of mine...just a little haha
    Brilliant Black Quattro 6MT
    May 21 2007
    Florida
    mine was a little worse than yours. audi ended up replacing the pump, cam, lifter, and follower along with all gaskets etc. thank you baby jesus for having been a CPO! $1600 covered fo $free.99
    im 95% sure its covered up to 110,000 miles. but you need a "symptom" or CEL. i luckily work for a company that owns an audi dealer so im pretty sure they just made up a symptom for me, since i discovered the wear myself when i inspected it. converstation went like this:
    Me: (emailed pictures) I inspected my cam follower for wear and found this. There is no tension left on the pump either..can this be covered under the extended warranty on the cam followers? i replaced the follower already.
    Audi service: since you replaced the cam follower already we cant do anything.
    Me: .....what if i put the old one back in?....
    Audi Service: Thats probably a good idea, i would get it towed up here.
    Me: Done.
    hahah i was shocked they said that...but hey, cant complain!!
    2018 Navarro Blue Q5
    Sep 06 2011
    Harrisburg, Pa
    always an option. I drove mine until it threw a fault. Got the cam, follower, hpfp, cam chain, exhaust cam adjuster, chain housing cover, cam adjustment valve all replaced. Mine really did some damage!
    Oct 20 2008
    Denver
    wow you must have worn completely through the follower for some time. look how worn down the fuel pump piston is. if you're still covered best bet is to have Audi replace the follower, pump, and possible camshaft as well.
    Feb 06 2009
    328d, Tacoma
    Woodland Park, Colorado
    its not a tdi...
    TD1 is a new thing Audi has in place to track tuned/modified cars.
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
    Veteran Member Four Rings shiro1745's Avatar
    Jul 26 2009
    DMV Area
    It doesn't have to be CPO, audi extended the warranty for this issue up to 120k miles. So you can either get it towed to audi or put everything back and drive it there since all cam, follower and hpfp need replacing. I'm not sure if audi covers the towing with this extended warranty.
    If you're still CPO they will pay for towing but you have to make sure you call audi of america and get the towing through them not through you audi dealership. I made this mistake and I had to pay for towing.
    Now there's another big issue you need to take care of, the missing piece of the follower. It should be around the cam chain tensioner and it can do some damage if not removed. It's possible some damage was already done.
    I had the same problem a few years ago. They most likely won't look at it if there's no CEL, but you can do what I did. I told them I want it checked for the piece of mind and pay for the labor. When they will see it they won't charge you anything, Audi will cover everything. So they cannot say no. Read this my thread for more details.
    http://www.audizine.com/forum/showth...DATE-NEW-PICS-!!!
    Good luck.
    - Chip
    K0R-GT -- S3 injectors -- Maestro tune -- IE Drop-in rods
    "It took 4 bad crankshaft seals and lots of cursing to build my avatar"
    Oct 14 2009
    Okinawa Japan
    Hey, regardless of any of that
    Good luck, I hope it all works out in your favor
    -Shane Drake-
    >DRAKLOREs Build<
    Jan 03 2007
    VW/Audi/Ducati
    Houston
    Quote Originally Posted by Coderedpl View Post
    Are you under CPO?
    No CPO warranty required because...
    Quote Originally Posted by JimmyBones View Post
    +1
    B8.5 Audi SQ5 | APR Stage 1
    Jul 26 2009
    DMV Area
    OP, don't tell them that, don't give them reasons to void your warranty cause an unauthorized person worked on the car.
    See my post above.
    - Chip
    Jul 27 2007
    Orange County, NY
    its not a tdi...
    An example:
    http://www.audizine.com/forum/showth...=1#post7403623
    Jul 06 2010
    Houston
    I put in the new follower. It threw a cell a while back but honestly, I never checked it because it's thrown a few cels at me before after the tune. I should have checked it.
    So partially my fault, BUT! it shouldn't have worn through regardless. I'm going to drive it home make an appointment, and just show them the freaking hole in the follower. I was told to talk to a specific person at the dealer im going as he is more mod friendly.
    So i'll update this Tomorrow.
    Veteran Member Three Rings ignus99's Avatar
    Nov 08 2009
    Calgary/Alberta/Canada
    I'm sure this has been said already, but if its not under warranty chances are you will need a new cam, follower, and fuel pump as all will be quite damaged.
    - Karl
    Engine: GT28RS by ATP / Turbosmart 38mm dual BOV/Recirc / Carbonio CAI / APR TBE / APR Testpipe / REVO St2+ / Snow Performance ST2 / APR HPFP
    Body/Suspension: KW V2 / DPE ST-10 19x8.5 et35 / Thor Skid Plate
    Pretty Stuff: AWE Vent Boost Gauge / OEM Bixenon + V4 LED / Supertones / Votex SS / CF Hood & Mirrors / RS4 Grille & Fogs
    Sep 06 2011
    Harrisburg, Pa
    Good luck!
    Veteran Member Four Rings Ed Gein's Avatar
    Sep 21 2011
    '10 GTI, '08 Scion tC, '01 CBR 600
    Maine
    am i just seeing things or did this thread really get 21k views in under 24 hours?
    Sep 06 2011
    Harrisburg, Pa
    Quote Originally Posted by Ed Gein View Post
    Craziness! Has to be a glitch, after all a worn through follower isn't exactly a new thing
    Jul 06 2010
    Houston
    Yeah, probably a glitch.
    Established Member Two Rings sleeper's Avatar
    Dec 23 2009
    salt lake city UT
    was it still running like that? Were you just doing routine maintenance and that's what it looked like? The last three i've replaced on cars had basically no real signs of wear but i figured better safe than sorry. Also i thought all cars were covered not just CPO?
    Jul 06 2010
    Houston
    ^ yup, just routine maintenance on the car. I was changing the timing belt, water pump, thermostat, oil, cam follower, brake light fix (bulb was out) filters, etc. So just normal things, the car isn't going to be driven much anymore so just wanted to take care of the essentials coming up.
    Nov 08 2009
    People love gore. Schadenfreude at its best!
    - Karl
    Jul 06 2010
    Houston
    No update, just wanted to post better pictures
    Jul 06 2010
    Houston
    Called all three dealers.
    Audi West
    Momentium Audi
    And Sewell Audi
    Audi West and Momentium didn't act like the knew what I was talking about, or that they cared. Sewell Audi (yet again) knew what I was talking about and said tomorrow morning. I asked if it was possible to get this looked into today, he said "my loaners will be back in around 5, if you want to come then, that's fine" so he not only gave me the options but knew what I was referring to.
    So it's getting dropped off in a couple hours.
    Senior Member Two Rings co_pa's Avatar
    Apr 13 2009
    detroit[ish]
    so this took place after a new follower was installed and *only* having a stage I tune? did you have an upgraded HPFP or internals?
    just wondering aloud on why this happened @ this point and if the lobe and pump were already damaged before the new follower was installed.
    good luck, man. hope it turns out OK.
    .: APR Stage 2+ : Autotech HPFP : 034 HFC + TIP : Rev D DV : [custom] AWE Exhaust : Stasis SS : RS4 R Sway : H&R Trak+ Spacers : BBS CH 19x8.5 [spaced]: Zimmerman Slotted Rotors: Hawk HPS Pads : CC.d : Ibis White Markers : VAG.d : Audi Sport Stuff [Matts, Valve Stem Covers, Pedals] : Audi iPod Adapter : Etc :.
    Jul 06 2010
    Houston
    No, this was the original cam follower in the car, replaced it at 77k miles only.
    So the original has a hole. i replaced it so I could drive home. The plunger of the HPFP is damaged with an angle on it, I didn't get a chance to look at the cam, but I imagine it's scared a little.
    Jul 06 2010
    Houston
    Update: They are going to overnight the parts and have it fixed by late tomorrow, so i'll get my car back Thursday afternoon.
    They also said I was throwing a code for an evap line, so i need to look in to that.
    Jun 27 2011
    This thread is making me nervous about my Cam Follower. 70k here and likely on the original. 2006 too...
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Veteran Member Four Rings Kubus's Avatar
    Aug 10 2009
    2017 Audi S3
    Montreal, QC
    How exactly was it driving? Mine is going into the dealer tomorrow.
    Car won't accelerate past 2000 rpm. Surges and stuff. Runs normal under 2000 rpm. Throwing check engine lights when I try to accelerate past 2000. Dealer told me I can drive it until it flashes. Said sounds like PCV and maybe follower.
    Were you able to accelerate? Or did you just feel like checking your follower?
