Results 1 to 22 of 22
    Jan 11 2007
    SLC,UT
    Engine assembly specs, tolerances, tips, diagrams and links document
    So I also made an excel spread sheet with all of the consolidated tolerances, specs, and tips that I've accrued throughout my research and over the years. I hope to take a little of the mystery out of the DIY assembly of the rotating assembly/ heads, for anyone that might want to attempt it on their own. This should help with some of the common downfalls of the 2.7l assembly (heads mis-timed, rods installed backwards, etc). If you print it in landscape format, it's 3 pages where you can write the measurements of your engine in. Hope this maybe helps someone!
    LINK PUT ON HOLD WHILE I UPDATE
    Screenshots below, but use the file above to get all of the info
    ** GT2860R-7 S4 Build Log--
    FOR SALE (click me):
    --FIKSE FM10 - 3pc LIGHTWEIGHT WHEELS - 17x9 et55 & 17X8 et57 - 5x130 - WORK ON AUDI W/ ADAPTER**
    --JHM DELRIN SHIFTER STABILIZER BUSHING (LATE STYLE)**
    --RS4 AIRBOX--
    LOOKING FOR:
    --BROKEN SPIDER HOSES
    Jan 11 2007
    SLC,UT
    And if there's any mistakes, feel free to bring them to my attention!
    --RS4 AIRBOX--
    LOOKING FOR:
    Senior Member Four Rings Hyphy's Avatar
    Jan 09 2009
    Ft. Lauderdale
    Cool stuff man..def. Will take a look at it in detail when I'm not at work.
    Nick
    PM me if you need any B5 work done in south Florida.
    I'd rather be flying
    Veteran Member Four Rings A62TURBO's Avatar
    Apr 18 2007
    Perfect timing for my engine build
    6 Speed--RS4 Clutch & Flywheel--Stage 2 APR 93 Oct.--Forge 007 DV's (black)--S-flo ITG Filter--4.2 Door Blades --RNS-E--APR Catback--Gutted DP's-- PSS9's
    Greg
    C5UNION
    Senior Member Four Rings shorterthanrich's Avatar
    May 24 2009
    2000 S4 Nogaro Blue, 1996 Ford Exploder
    Boston
    This is awesome. You are a gentleman and a scholar, and an asset to this community!
    FREE BEER, click: Pintley - Tap Into Your Tastes!
    My iPhone/Android App
    2000 S4 Nogaro Blue VAST/DxC Stage "GT"
    GTX2863 Build Thread
    Active Member Four Rings S4 00 2.7's Avatar
    May 13 2011
    Good info to share.
    Thanks.
    APR | SSAC | UUC SS | JHM Delrin
    2003 Z06 (Sold)
    Wicked
    Senior Member Four Rings bigern45's Avatar
    Sep 28 2009
    B5 S4 stage 3
    ky
    what are you doing?? stop messing around and get the S finished!!!
    stage 3+ dyno-tuned by EPL
    AWE smic, OEM RS6's, CM Fx850 twin
    JHM ss, linkage, DTS, Devils Own Meth
    034 anchors everywhere, custom 4" single
    www.teameurotrash.com
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Mind if I put this on my repair page?
    I'll credit you, of course.
    Really good info.
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - Kevin@socals4.com
    Mar 18 2010
    Ottawa
    Quote Originally Posted by shorterthanrich View Post
    I second the above!! Nice
    Nov 14 2006
    '02 911 C4S, '00 Passat Variant
    Renton, WA
    Informative stuff like this is why I put up with all the retards on forums. LOL
    THANK YOU!
    -Darrick
    No more Audis, but can't leave this place alone.
    Active Member Three Rings MDJ's Avatar
    Jun 29 2010
    '01.5 StgII B5S4 ** '74 Superbeetle ** '60 MGA
    Awesome. Thanks for posting!
    Senior Member Four Rings DiscoPotato's Avatar
    Sep 16 2009
    Parts
    Your Computer Screen
    That handwritten timing picture saved me in the past..
    Given that I know that this will help someone out on here.
    Thanks for sharing!!
    StrictlyEuros ::: Web
    J-Fonz Tuning
    honestly when i was doing timing i tried to use that pic for the chain and mine was off using it.
    also for the more visual diy a shameless plug to my walkthough http://www.cardomain.com/ride/264337...udi-s4/page-14
    i would recommend the wiseco app guide here to determine ring gap http://www.wiseco.com/PDFs/Manuals/RingEndGap.pdf
    you measure ring gap to the bore not the piston and should be measured to at least 1/10 thous, you should never round off until the end of your measurements, as the end result can varry, i do all my measurements on my ti89, i downloaded a free app to do " to mm conversion
    example: bore= 81.5 mm = 3.20866142"
    top = .005" x 3.20866142" (bore of that cylinder, not mike value of piston** do not round off***) = 0.0160433071" round to .016" < rounded value
    call me anal but i'm a perfectionist i cant help it :)
    Senior Member Three Rings B6T's Avatar
    Dec 16 2008
    1982 Honda C70 Passport
    Awesome tool, but I would stick with either mm or inch, not both.
    4 doors, 6 cylinders, 6 gears, 2 turbos, 0-60 in under 4 seconds.
    Jan 11 2007
    SLC,UT
    Quote Originally Posted by bigern45 View Post
    Lol. You're welcome? (ps, I'm writing this from my shop, so work is getting done son)
    Quote Originally Posted by Rated S View Post
    Really good info.
    Go for it, but wait like a week because I might make a couple of updates to it.
    Alot of my info came from other places (I didn't make the drawing or any of the diagrams), and I just credited it to the internet forums.
    Quote Originally Posted by DiscoPotato View Post
    Quote Originally Posted by goohead View Post
    I too was worried about the handwritten picture, because it goes against the Bentley. When I saw all the people that were using it, and who those people were (reputable), I decided to use it. Then, just before doing the install I realized that I had a set of 2.7 heads 5 feet away for reference that had never been disassembled. I personally verified that the picture is correct.
    Awesome! I thought I had seen almost all of the S4 DIY stuff (you should see my bookmarks folders), but I don't think I've ever seen yours. I'll add it to the links.
    I'll add that to the links as well. I hear all different 'rules of thumb' for the ring gap spec, but the one thing that is usually consistent is that in that equation, the top ring factor that you multiply is usually .005" smaller than the bottom. I went with .055" for the top and .060" for the bottom after doing research, but I'll probably change the recommendation on the sheet to reflect Wiseco's recommendation, so that the liability is on
    I did measure using the bore (81mm), not the piston (80.95mm or whatever), and the equation says "bore size", but I'll change the wording in the parenthesis so that no one can confuse that. And as for rounding off, I wasn't too worried for a couple of reasons, the main reason being that we're using relatively loose, general "rule of thumb" formulas in the first place (for example, I choose the factors to be .0055" and .0060", when you and some other people might use .0050" and .0055"). Also, the stock 81mm bore works out to be 3.18897", which is well inside what I'm personally comfortable rounding up to 3.19" for me. Come to think of it though, I think I used my TI calc as well, and I don't think I rounded anything til the last spec (for the final numbers), I think I just wrote 3.19" in the general formula example
    I'm glad for it. It's because of people like you that things can get refined and improve. I'll add those links and change a couple of words.
    Quote Originally Posted by B6T View Post
    If you want to take the time to convert those and send me the updated file, I'll put that in the original post. If not though, if someone is disassembling their engine, I'd hope they're capable of being attentive to the units
    --RS4 AIRBOX--
    LOOKING FOR:
    Jan 11 2007
    SLC,UT
    Quote Originally Posted by jibberjive View Post
    Actually I take that back, I did have your cardomain page bookmarked like 3 times, but for the engine pull stuff. I swear the engine internals stuff wasn't on there a while ago?
    --RS4 AIRBOX--
    LOOKING FOR:
    Ya u know how projects goes lol
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Cool if you want to email me the 'final' I'll post it up when it's ready, in case I miss anything on the forum.
    Thank's again for another helpful contribution to us.
    Sep 11 2009
    NE
    I will use this when starting my own assembly. Thanks man!
    Sep 16 2009
    Parts
    Believe me, Bentley is wrong. Ive been there done that. But to make things clear: Bentley is wrong for the DRIVER side cylinder head. Passenger - follow Bentley/illustration (Illustration is more clear though), Driver - follow illustration. It will make things much easier.
    J-Fonz Tuning
    Jan 11 2007
    SLC,UT
    As you said, the illustration is correct for the driver's side as well, so if you choose to rely on only one, make it the illustration
    --RS4 AIRBOX--
    LOOKING FOR:
    Senior Member Three Rings diabolical1's Avatar
    Mar 24 2009
    New York and Toronto
    very useful information. thanks for posting it.
    The dude that loves cars with character: raw, rambunctious road manners, angry triangles and four devilish rings ...
