Results 1 to 34 of 34
    Established Member Two Rings Linksman72's Avatar
    Jun 23 2015
    Orland Park IL
    Operating Windows and Sunroof with Remote, vcds
    I programmed the window remote function through vcds vag com , but I am only able close Windows and sunroof. Any one know why I can't open all windows with remote?
    I used the following instructions:
    (Note, the sunroof cannot be opened with the remote)
    You need to continuously hold the remote button for the function to operate.
    [Select]
    [46 - Cent. Conv.]
    [Coding - 07]
    [Long Coding Helper]
    Click on each of the Byte numbers in line 3) and you'll see the selectable options below.
    Check the box for "Comfort Operation: Remote Control active"
    Close the Long Coding Helper by clicking the Windows X box on the top right of the screen or clicking the Exit button on the top left of the screen) will send your new Coding value back to the Coding screen.
    [Do It!]
    2010 Audi A5 Prestige 2.0t, Brilliant Black, APR Ko4, AWE Touring catback exhaust, AWE downpipe, 034 HFC, Kohlefaser Luft-Technik Intake System, Wagner competition intercooler, RS5 Grille, H&R Coilovers, Vorstiener vff 104 20x10, interior LED upgrade, 034 drivetrain mount inserts, Basslink subwoofer, VAG-COM mods
    Veteran Member Four Rings namvar's Avatar
    Jul 10 2014
    2024 SQ8 Prestige, 2018 A4
    SF Bay Area
    [46 - Cent. Conv.] [Coding - 07] -> [Long Coding Helper] Byte 2
    Bit 2 - Set to 1
    This is what I did.
    Holding the unlock button down on the remote after unlocking the car lowers my windows
    2015 RS5: Mythos Black, Tech Package , Dynamic steering, Black Optics, Folding side mirror upgrade, internal LED lights, Eventuri Intake, Akrapovič exhaust, KW DDC ECU, lots of CF
    2013 3.0T Prestige Q7: Sport pedals, LED interior lights
    Jul 05 2015
    West TX
    You have to go into your car's setting to enable it too I think.
    Press the "car" button and then navigate from there to find unlocking features with the key fob.
    Mar 21 2015
    ^ What he said
    Deactivated Three Rings
    Jul 09 2016
    Can someone add some more info on how and where to make these programming changes? Thanks!
    Mar 21 2015
    Quote Originally Posted by 0000_S5 View Post
    You need a cable from Ross tech and a laptop
    http://www.a5oc.com/forums/attachmen...0&d=1271274388
    http://www.audizine.com/forum/showth...ft-2013-B8-5-s
    http://www.audizine.com/forum/showth...-complete-list
    Jul 10 2014
    SF Bay Area
    Nope. In my MMI it only has an enable/disable selection. It dies mot distinguish between up and down
    Mar 21 2015
    Quote Originally Posted by namvar View Post
    It doesn't distinguish up or down. It just needs to be enabled in the mmi after coding it.
    Jul 09 2016
    Many thanks!!!! Those links are quite impressive and intimidating! Will require some study.... Appreciate the consolidated links.
    Veteran Member Four Rings HazeMyth's Avatar
    Jul 17 2015
    Colorado
    If you can close the windows with your remote, that means you've programmed it correctly. As someone already stated, you need to hold the unlock button for a bit after you've unlocked the car. Sometimes mine fails, likely because of an interruption in the wireless signal. It works pretty consistently when I'm close to the vehicle.
    2013 Audi S5 - EPL Stg 2 E40 ECU/TCU, AWE Track 102mm, RocEuro intake, etc.
    2014 Audi Q5 S Line
    2011 Toyota Tacoma TRD Sport - Lifted, reinforced, and slow
    2003 Evolution VIII - HKS280, FBO
    2004 Subaru STI - Stg. 2 (Sold)
    IG: @MrHazeMyth
    Jun 23 2015
    Orland Park IL
    I programmed it correctly, just forgot to go into the mmi and find the newly added window option and enable it correctly. It all works now
    Aug 04 2010
    Queenz/Westchester
    for the record, it's under the door lock settings in the mmi
    Mar 21 2015
    ^ Central locking for FL models and it's something else for pre FL models
    Nov 10 2014
    Apex, NC
    there is another option with less features but easier more user friendly interface
    http://www.caristaapp.com/
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Mar 21 2015
    ^ I forgot to mention that one, it's very easy to use and does some good stuff.
    Jul 09 2016
    Quote Originally Posted by doug97gxe View Post
    That looks really easy. The pricing for write capability is a bummer, but I'm guessing I'll make some changes and leave them forever. Appreciate the post; this is the route I'll take.
    Nov 10 2014
    Apex, NC
    Yeah they came up with a new pricing model most of us here are grandfathered into a lifetime subscription
    Sent from my iPhone8s using Tapatalk
    Present:
    Mar 21 2015
    It's worth having for codes on fly, keep in the glovebox. There was still a backdoor open for the full purchase a week ago, not sure if it's still up though.
    Jul 09 2016
    Now they have two subscription options: 1 week for $9.99 or 1 year for $39.99. No back door visible...
    Mar 21 2015
    ^ Post 1054, it was a few weeks ago, didn't realize it was that long ago, sorry.
    http://www.audizine.com/forum/showth...-wrench/page27
    Jul 09 2016
    ^^ Thanks!!
    Nov 10 2014
    Apex, NC
    Also if u go that route you will need an ODBC Wireless Adapter .. Bluetooth for Android OS and Wifi for iOS
    Present:
    Jul 09 2016
    There are lots of fake or questionable reviews on most of the ELM327 units on Amazon, so I think I'm going to keep it simple and get the Carista hardware module. I guess I'll spend a few extra bucks for some peace of mind.
    Nov 10 2014
    Apex, NC
    Yeah the elm ones aren't created equal my first one was super fast and connected no problems .. My second one I have to start the car.. Connect it then shut the car off and start the car again before my phone will connect
    Present:
    Veteran Member Three Rings JayCar's Avatar
    Dec 13 2015
    2023 Tesla Model Y Performance, 2022 MINI Cooper S Countryman, Specialized Tarmac SL4 Sport :-)
    Houston, TX
    That's stupid. It used to be $39 one time and you're good for life. Now it's per year? Seems greedy to me.
    Aside from all that, it's an awesome device for customizing. I've used mine many times on several diff vehicles.
    2014 SQ5/Monsoon Gray
    Go: APR Stage 2+ w/ SC pulley, Airbox mod w/ aFe hi-flow filter
    Ride: H&R Street Performance Coils, RS6 reps in Gunmetal 21x9.5 w/ Michelin PSS 285/35/21
    Look: P3 vent gauge, HID fogs, E-code heads and tails, Many VCDS mods
    Rebuild Thread
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by JayCar View Post
    They are going with the Microsoft Office 365 model .. I think since they added the service reset and the parking brake release.. 2 big money makers for users of the product they didn't want ppl making money off the product
    Present:
    Jul 09 2016
    What's the Parking Break Release setting?
    Mar 21 2015
    That's for changing the rear break pads.
    Nov 10 2014
    Apex, NC
    The way how Audi has the electronic parking brake u can't change your rear brakes unless u release the parking brake
    Present:
    Jul 09 2016
    Ahh. Good to know. Thanks!
    Senior Member Three Rings ProfileX's Avatar
    Mar 12 2009
    S5 2011
    Denver, CO, USA
    Watch out, some have reported coming outside to find snow or rain inside the car because the windows are down. This setting is the primary suspect, if you're inside and bending over or squatting, asleep on the couch, etc. and the button gets held down, this could be bad. The car won't won't wait for a door to open and reverse the action like the door unlock does.
    Oct 27 2009
    Miami, FL | Boone, NC
    Quote Originally Posted by ProfileX View Post
    Watch out, some have reported coming outside to find snow or rain inside the car because the windows are down. This setting is the primary suspect, if you're inside and bending over or squatting, asleep on the couch, etc. and the button gets held down, this could be bad. The car won't won't wait for a door to unlock and reverse the action like the door unlock does.
    Happened to my 4, minus the elements getting in thankfully.
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Jul 17 2015
    Colorado
    I'm actually paranoid of this happening, so I usually try to make sure my keys are out of range. One time I opened the windows on my M3 without knowing. Had I not run outside to grab something before going to bed I would have left my windows wide open that night.
    2014 Audi Q5 S Line
    IG: @MrHazeMyth
    Senior Member Two Rings Jfonse81's Avatar
    Apr 15 2019
    coming soon RS4
    Nyc
    Does anyone know how to disable the brake lights from flashing with the turn signals ?
    The picture shows just the turn signal flashing without the brakelight , just the way I want them . I believe this is standard in Europe not in US I guess .Screenshot_20190921-102906_1.jpeg
    Sent from my HTC One M9 using Audizine mobile app
