Page 1 of 52 1231151 ... LastLast
Results 1 to 40 of 2042
    Veteran Member Three Rings vincent9993's Avatar
    Apr 02 2007
    Dune Buggy
    St-Leonard
    B8/B8.5 VCDS & Hidden Menu: The Complete List
    I've been trying to compile a complete list of VCDS mods specific for our S4 cars. I started going through the B8 A4 Cool VAG-COM codes thread but the info is spread over 30 pages and repeats or is trivial. AudiEnthousiasts has also started to put a list together organized by category for the A4. I like his idea but I think there's a need for a straight list of cool VAG-COM mods specific to our S4 and a detail how-to consice in one document.
    Please note, I'm not trying to steal or take credit for these mods, I've simply used the information available throughout the web and tried to bring them in a central place. Your help in filling in a few blanks and validating my info would be appreciated.
    *Suggestion: Print this and check off the mods you've activated and store it with your owner's manual - Will come handy when you need to re-do the coding after an ECU flash.
    Here's the list I've compiled so far:
    • Disable After-wipe of windscreen wipers
    • Disable amber corner lights
    • Disable amber side markers
    • Disable Key warning (keyless models)
    • Disable LED 'wink' on turn signal
    • Disable "Lights are on" warning
    • Disable NAV & Phone warning messages while entering data at speed
    • Disable Seatbelt Chime
    • Enable Adaptive brake lights
    • Enable Ambient Interior Lighting Control
    • Enable Automatic Gear selection shown in DIS
    • Enable Automatic Hill Hold Assist 'lite'
    • Enable Auxiliary ventilation
    • Enable Battery meter
    • Enable DIS with Efficiency Program
    • Enable Double Disarm Beep
    • Enable DRL Selectable via MMI
    • Enable DRL
    • Enable Euro parking lights that turn on signal at night
    • Enable fog lamp to come on for the same side as that turn signal
    • Enable Front Turn Signals as Parking lights
    • Enable Gauge Test/Needle Sweep
    • Enable Hidden menu in MMI
    • Enable Import CDs to MMI's HD
    • Enable Independent Fogs control with high beams
    • Enable Lap Timer
    • Enable LEDs remain bright for parking lights
    • Enable Rear Tail Lights on with DRLs
    • Enable Release Parking Brake without putting foot on Brake
    • Enable Release Parking Brake without putting seatbelt
    • Enable Remote Operation windows&sunroof
    • Enable Reverse mirror tilt
    • Enable Speed through MMI
    • Enable TPMS
    • Enable VIM on MMI
    • Set Audi parking system - Switch OFF Speed
    • Set Custom ADS settings
    • Set Headlight washer - cycles
    • Set Headlight washer - duration
    • Adjust Consumption in DIS
    • Adjust LED Brightness
    Audi A4/S4 B8
    VCDS (VAG-COM) codes
    [09 – Cent. Elect.] [Coding - 07] -> [Dropdown] -> "x ** 8K1 955 119 ** WWS xxxx" -> Long Coding Helper -> Byte 1
    Bit 3 - Remove check mark (1 = active)
    ________________________________________
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 10
    Submodule 0
    Bit 3 - Set to 0 to disable amber side markers (U.S. vehicles)
    [46 – Central Conv.] [Coding - 07] -> Long Coding Helper -> Byte 9
    Bit 7 set to 0 (Uncheck)
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 3
    Bit 2 - LEDs remain at full brightness with parking lights (1 = active)
    Bit 7 - Turn off LED-strip DRLs with indicators (1 = active)
    Disable "Lights are on" Warning
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 5
    Bit 3 - Set to 0 to disable "lights are on" warning when you open the door.
    [5F - Information Electr.] -> Adaptation -> Set channel 2 & 3 to 250
    [17 - Instruments] [Coding - 07] -> Long Coding Helper -> Byte 0
    Bit 2-4 – Seat Belt Warning inactive
    [46 - Comfort System] [Coding - 07] -> Long Coding Helper -> Byte 8
    Bit 0 – Emergency Brake Flashing via Turn Lights active (1 = active)
    Bit 1 – Emergency Brake Flashing via Brake Lights active (1 = active)
    [Hidden menu] [car] [carmenuoperation] [interior light] Set to 5
    [Hidden menu] [car] [cardevicelist] [interior light] Enable
    Reset MMI
    [02 – Auto Trans] [Adaptation – 10]
    Select “Single Gear Display” from top channel drop down menu
    Select “D on/S on” from New value drop down menu
    Enable Automatic Hill Hold Assist ‘lite’
    [03 - ABS brakes][Security Access - 16] (Enter code presented by program)
    [Coding – 07] -> Long Coding Helper -> Byte 1
    Bit 6 set to 1 to enable hill hold assist.
    http://www.audizine.com/forum/showth...r-the-A4/page2
    [5F - Information Electr.] [Coding - 07] -> Long Coding Helper -> Byte 6
    Bit 1 – Set to 1
    [Hidden menu] [car] [cardevicelist] [Auxiliary heating] Enable
    [08 - Auto HVAC] [Coding - 07] -> Long Coding Helper -> Byte 1
    Bit 3 – Set to 1
    Bit 4 – Set to 1
    [Hidden menu] [car] [cardevextdevicelist] [Battery] Enable
    [Hidden menu] [car] [carmenuoperation] [Battery] Set to 5
    Reset MMI
    or
    [56 - Radio] -> Adaption -> Channel 39, add 16 to your value
    Enable DIS with Efficiency Program for MY2010+ (Not a complete Program without the Start/Stop System)
    [17 - Instruments] [Adaptation - 10] -> Channel 77
    change 0 to 255
    [46 - Central Conv.] [Adaptation - 10] -> Channel 63
    Add 4
    [09 – Cent. Elect.] -> [Coding – 07] -> Long Coding Helper -> Byte 3
    Bit 5 set to 1
    Enable DRL
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 2
    Bit 1 = DRL via Front Side markers
    Bit 2 = DRL via High Beams
    Bit 3 = DRL via Fogs
    Bit 4 = DRL via LEDs
    Bit 6 = DRL via Side markers
    Bit 7 = DRL via Tail lights
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 9
    Bit 0 - Set to 1
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 4
    Bit 0 - Check the box or change :Bit 0 set to 1
    Bit 0- Check the box or change :Bit 0 to 1
    Once the change has been made you can enable the front turn signals as DRL's by making the following change:
    Bit 6 - Check the box or change :Bit 0 set to 1
    [17 - Instruments] [Coding - 07] -> Long Coding Helper -> Byte 1
    Bit 0 - Check the box for "Gauge Test/Needle Sweep active"
    Enable Headlights on all the time
    Bit 5 - Check the box or change :(Bit 5 Set to 1)
    change 0 to 1
    Use this hidden menu at your own risk.
    Caution: Keep away from the "Bootloader"
    [Hidden menu]
    Main/Diagnose/Settings
    Import Media
    Set to 4 of 4 "Copy/Ripping"
    Bit 1 – (Front) Uncheck the box or change :Bit 1 to 0
    Bit 2 – (Rear) Uncheck the box or change :Bit 2 to 0
    Enable Lap Timer
    Bit 3 - Check the box for "Lap Timer active"
    Enable Remote Operation Windows and Sunroof
    [46 - Cent. Conv.] [Coding - 07] -> [Long Coding Helper] Byte 2
    Bit 2 - Set to 1
    Bit 7 - DRL's via Tail Lets Active (1 = Active)
    [53 - Parking Brake][Security Access - 16] (Enter code presented by program)
    [Adaptation - 10] -> Channel 4 Set to 0
    [Adaptation - 10] -> Channel 7 Set to 0
    [52 Door Elect, Pass.] -> [Coding - 07] -> [Long Coding Helper] -> Byte 4
    Bit 4 and Bit 2 set to 1
    [56 - Radio] [Adaptation - 10] -> Channel 02, Set to 1
    Does not work if NAV equiped
    Enable TPMS
    * You need the 1AT ABS unit – check your stickers (1AS does not work)
    [Hidden menu] [car] [cardevicelist] [RDK] Enable
    [Hidden menu] [car] [carmenuoperation] [Tires Air Pressure Control] Set to 5
    [03 - ABS Brakes]
    [Security Access - 16] (probably with login code: 61378)
    Bit 3 - Tire Pressure Monitoring (PR-7K6) active (1 = active)
    The TPMS need to be enabled in the Instrument Cluster:
    [17 - Instruments]
    Bit 0 - Tire Pressure Monitoring (TPMS) installed (1 = active)
    Reset MMI
    Enable VIM on MMI
    [5F - Information Electr.] [Advanced ID - 1A] Note 1st Serial number
    [Security Access] Enter Digits 6, 13, 10, 14, 11 of the 1st Serial number
    [Adaptation - 10] -> Channel 48
    Set to 255
    Reset MMI
    [10 - Park/Steer Assist] [Adaptation - 10] -> Channel 23
    Set to 20 (max value in km/h)
    Set ADS to specific preset Comfort, Auto, Dynamic or Individual
    [09 – Cent. Elect.][Security Access - 16]
    Set to 01 - Comfort, 02 - Auto, 03 - Dynamic or 04 - Individual
    [Adaptation - 10] -> Channel 64
    [Adaptation - 10] -> Channel 65
    [Adaptation - 10] -> Channel 66
    *Note all four channels needs to be set to the same value.
    Set Headlight washer - Duration
    [09 – Cent. Elect.]
    [Security Access - 16] [Adaptation - 10] -> Channel 6
    change to e.g. 500
    Set Headlight washer - Cycles
    [09 – Cent. Elect.]
    [Security Access - 16] [Adaptation - 10] -> Channel 26
    change to e.g. 10
    [17 - Instruments]
    [Adaptation - 10] -> Channel 3
    change 100 to xxx (see samples below)
    Sample 1 - Calculation based on volume per distance (e.g. l/100km):
    DIS: 9,3 l/100 km.
    Real: 9,8 l/100 km. (100 * 9,8 / 9,3 = 105,38)
    Channel 3 will be changed from 100 to 105
    Sample 2 - Calculation based on distance per volume (e.g. MPG):
    DIS: 23 MPG.
    Real: 24 MPG. (100 * 23 / 24 = 95,83)
    Channel 3 will be changed from 100 to 96
    Adjust LED brightness
    [09 – Cent. Elect.] [Security Access - 16] (enter security code. One of the default codes is- 20113)
    Set between 5 and 100
    Set Automatic Transmission Start Mode to D or S
    [09 - Cent. Elect.] [Security Access - 10]
    [Adaptation 10] -> Channel 64 - Stored Value = 218 = Starting mode is always D
    Channel 64 - New Value = 00; Starting mode is determined by ADS selection at engine shutdown (Comfort and Auto=D, Dynamic=S, Individual=whatever you pick)
    Channel 64 - New Value = 03; Starting mode is always S regardless of ADS selection at engine shutdown (opposite of stock)
    Channel 64 - New Value = 11; Starting mode is S with all ADS settings at shutdown except Comfort where it's D
    Channel 64 - New Value = 19; Starting mode is S with all ADS settings at shutdown except Auto where it's D
    Again, I take no credit for this information, most of the above is available on these forums and specialty websites as well as Ross-Tech's support pages. I only wanted to group all the info of the pertinant VCDS mods to our S4.
    Not all the above has been verified, I'll be happy to re-edit this post to correct any info.
    Oh and I'm not responsible for any screw ups this causes, good luck.
    Can I get a few volunteers to nominate this post as a sticky?
    Now:2015 Phantom Black / Magma Red S4 Prem, MT6, ADS, Nav, Carbon trim
    - WeatherTech DigitalFit mats
    - Winter wheesl: 18x8 RS4 reps 245/40R18 Gislaved NordFrost
    I have Vag-Com
    Past: B5 A4 2.8, B6 A4 3.0, B7 A4 3.2, B8 S4
    Veteran Member Four Rings NWS4Guy's Avatar
    Sep 29 2009
    2015 Range Rover Evoque 2010 Audi S4
    I have on my car:
    And I also know of some others off the top of my head:
    Change "Auto" settings to mirrow "Individual" so that you start the car in whatever mode you want
    Enable fog lamp to come on for the same side as that turn signal (sort of like an extra light on that corner when turning)
    Like a surgeon with a scalpel, my S4 is a precision instrument, with which I carve and dissect my way through traffic.
    2010 S4 Prem+, Quartz Gray, S-tronic, Sport Diff, B&O, Nav, Gray Birch
    StopTech ST-60 BBK - Stratmosphere intake - APR v2.2 Stage 2 w/pulley + exhaust, v2 Coolant System
    Alu-Kreuz, Apikol rear diff mount, 034 transmission mount
    Nov 11 2010
    Minnesota
    There is also a way via mmi that you can burn cd's to your hard drive directly. There is a thread somewhere on how to do it.
    Veteran Member Three Rings vwong's Avatar
    Apr 03 2006
    '10 S4, '09 335i, '98 Prelude
    I believe there is also the A/C ventilation so that you can set the fan to come on before you enter the car. It's great for hot summer days. I have this in my BMW, and I love it.
    2010 Audi S4 6MT
    2009 BMW 335i Coupe 6MT
    YouTube Channel
    Established Member Two Rings asm777's Avatar
    Sep 25 2010
    Quote Originally Posted by vincent9993 View Post
    [*]Enabling Gauge Test/Needle Sweep [*]Enable TPMS [*]Seat Memory [*]DIS with Efficiency Program [*]Disable Key Warning
    Few questions and comments:
    Aren't these already enabled from the factory on the S4?[*]Enabling Gauge Test/Needle Sweep[*]Enable TPMS [*]DIS with Efficiency Program
    I understood that this mod only works on the A5/S5 (w/o seat mem) because the control module is already there that allows the seat to move forward to let passengers into the back seats. No go for our S4s unless you have Prestige trim:[*]Seat Memory
    I don't suppose this is the "LIGHTS ON" warning that buzzes incessantly when you have the key in and the door open? If so, can you share the coding?[*]Disable Key Warning
    Apr 02 2007
    Dune Buggy
    St-Leonard
    Quote Originally Posted by asm777 View Post
    • Enabling Gauge Test/Needle Sweep - Yes mine was, I assume not all had it
    • Enable TPMS - Not mine as I did not order TPMS
    • DIS with Efficiency Program - Yes mine was, I assume not all had it
    Not sure about the rest...
    I have Vag-Com
    Sep 29 2009
    TPMS is only standard on US cars, as it's required. Canada used to be SOL because it was a sensor in the vavle stem, now it uses the ABS system to monitor wheel rotations and changes in them at speed to determine differences in circumference due to pressure drops - and VCDS can enable it.
    Efficiency is standard on 2011, it's there and hidden on 2010, but several had gotten MMI updates at their service interval which added this.
    The LIGHTS ON has not been found yet, but you CAN tap the reset button that you use to toggle the DIS between screens and it will immediately silence this alarm.
    Sep 25 2010
    Quote Originally Posted by NWS4Guy View Post
    Oh, thanks! At least a temporary solution until someone figures it out!
    Veteran Member Three Rings Deep Sea S4's Avatar
    Nov 06 2009
    I am not sure what enable speed via MMI is?
    Does that show your speed on the LCD screen?
    Senior Member Three Rings iceboss23's Avatar
    Jul 18 2009
    2010 S4, 2001 allroad
    Silver Spring MD
    Items for Sale
    Can you pls explain what reset button you are talking about here?
    Veteran Member Four Rings A5MD's Avatar
    May 21 2009
    2009 Acura MDX Tech, 2015 X5, 2014 Police Interceptor, 2018 Civic Sport Hatchback
    MD
    Senior Member Two Rings dr bryan's Avatar
    Apr 12 2010
    Tualatin, OR
    Anyone know if you can change (increase) the sensitivity of the automatic wipers via mmi? That would be GREAT!
    '11 S4 #2. Ibis/Black alcantara, DSG, Prestige, SD, Brake stuff, Suspension stuff, etc.
    Veteran Member Three Rings 2010S4's Avatar
    Jun 09 2010
    2010 Audi TTS, 2011 Audi Q7 S-Line Prestige
    Virginia Beach
    Quote Originally Posted by dr bryan View Post
    Can't they be adjusted via the little button on top of the wiper stalk. I always thought that is what that thing did.
    DD: 2010 S4 Prestige, Brilliant Black, DSG, ADS, Black Alcantara, Side assist, Carbon inserts
    Mods: APR 93 tune, APR pulley, Strat Intake, StopTech ST-60 BBK, H&R OE Sport springs, H&R rear sway, VAG-COM, tint, LED plate lights, under door LED, lamin-x on tails, Black-optics grill, R8 GT Alcantara steering wheel, Milltek Non-Res exhaust w/ black tips, JL 10" W7, black 19" factory wheels, BFI 10 & 5mm spacers, rear valance in matte black, RS6 shift knob, oCarbon MMI dash surround
    Sep 29 2009
    Well it's a switch with several stopping points, but yes :)
    Senior Member Three Rings Dave-B8S4's Avatar
    Sep 30 2010
    2014 Triumph Daytona 675R, 2016 Aprilia Tuono Factory
    Somewhere in Ontario....
    i definately need to get rid of the "Lights are on" warning sound. when you open the door with your headlights on. its BLOODY ANNOYING!!
    Estoril Blue Crystal 2013 S4
    AWE S-Flo Intake, Black Dipped Grill and Rear Valence
    Ibis White 2010 S4 Prestige R.I.P
    Apr 02 2007
    Dune Buggy
    St-Leonard
    Updated my post, what do you think?
    I have Vag-Com
    Veteran Member Four Rings Leor604's Avatar
    May 25 2010
    Vancouver
    Great work, Vincent. Thread subscribed. Now all I need is the S4 (April delivery )
    Veteran Member Three Rings scottyuk's Avatar
    Sep 20 2006
    Honda CBR1100XX
    Essex, UK
    Great thread - good work.
    Regarding "Set ADS to Individual"
    You could include in the list setting them all to 01, 02 or 03 i.e. Comfort, Auto, Dynamic
    There's also Rear Lights on with DRLs :
    Enable Import CDs to MMI's HDGo into Hidden Menu
    Import Media
    Sep 29 2009
    Here's a combination of some I mentioned you couldn't find, one makes the DRL's 100% bright always, the other disables the amber sidemarker lights, allowing full bright DRL's with no front lights on while Parking lights are on:
    Enable DRL full bright
    - Module 9 - Central Electric
    - Secure Access (use access code 20113 to unlock this module for modification)
    - Choose Adaptation
    - Channel 3, change this value to 100 (which is percentage of the brightness for the DRL's, anything under 5 turns the LED's off and will generate an error code on the DIS)
    Disable amber sidemarker with parking lights
    [09 – Cent. Elect.]
    [Coding - 07] -> [Long Coding Helper] -> Byte 10 Bit 3 - Change 1 to 0
    Apr 02 2007
    Dune Buggy
    St-Leonard
    - Choose Adaptation
    [09 – Cent. Elect.]
    These are listed as:
    * Adjust LED brightness
    * Disable amber corner lights
    I've named them slightly differently but they achieve the same result.
    I have Vag-Com
    Apr 02 2007
    Dune Buggy
    St-Leonard
    Quote Originally Posted by scottyuk View Post
    Import Media
    Thanks for the info, I've added it to the post.
    I have Vag-Com
    Sep 29 2009
    Then you can remove the "LED's remain bright with Parking Lights" as could not find.
    What is this one?
    Enable DRL via LEDs active
    Could not find this one
    Apr 02 2007
    Dune Buggy
    St-Leonard
    What is this one?
    Thanks, I'll remove the "LED's remain bright with Parking Lights" then. The "Enable DRL via LEDs" is to customize which lights (ie: LEDs, fog, etc) are used as DRL IIRC. The title is a little off and this is probably why I could not find my notes on this. I'll vag my car this week end and I update it.
    I have Vag-Com
    Senior Member Two Rings HAWKiS5's Avatar
    Jan 08 2011
    EU
    Great list, thx! I already did most of it last week on my car, and I am still checking if all works.
    This one you can add which is very convenient for peope who have Adaptive Cruise:
    From the Auto distance regulation module 13, Adaptation, Channel 7, change 0 to 1
    This gives you extra entry in MMI/ACC where you can change the default distance.
    BTW: a question about some default settings when starting the car:
    - anybody knows how to get the AHA (hill hold) automatically ON (now you have to put it on every times again)?
    - same for high-beam assist?
    - same for showing preset Memory Radio (and TV) stations first (now it always starts with a list of available channels, but I want to use the memory presets always)
    TIA!
    RS5 Cabrio
    Phantom Black|Waxoil|Cognac Brown leather|Neck-heating|Comfort&Memory seats/mirrors|Black Headlining|Piano black Inlay|B&O|MMI 3G Online|Nav+|AMI|Freecom XXS 5000Gb HDD|DVD|TV/DAB+|Bluetooth+|Adaptive Light|High-Beam assist|Light Pack|Parking Advanced|Advanced Key|Adaptive Cruise|Side Assist|20" wheels (PQI)|TPM|All ADS options|Hold assist|HomeLink|
    Senior Member Two Rings S4Tokyo's Avatar
    Jun 16 2010
    Tokyo
    Quote Originally Posted by HAWKiS5 View Post
    TIA!
    'high beam assist...' = auto hi-lo beam?? If so, that requires separate HW/SW, which by sound of things you don't already have. It uses CMOS Sensor & special algorithms - 'separate' option of Interior Mirror sub-assy - for detecting fwd (opposite lane) and rear (same lane) vehicle source lighting, also sensing for street lights, neon signs, you name it so as not to false adjust and adjusting beam height accordingly. It cannot be VAG'd, at least not in the true definition of intelligent headlamp control.
    Jan 08 2011
    EU
    Quote Originally Posted by S4Tokyo View Post
    Sorry if my question was not clear: if already have high-beam assist (= auto-high beam) so all the hw is there and it work. The only question is: is it possible to have it on ALWAYS (now it is OFF by default, just like the AHA function and the list of radio stations is NOT on Memory view by default.....)
    TIA
    RS5 Cabrio
    Jun 16 2010
    Tokyo
    TIA
    My misunderstanding, however I don't have answer that you can act on:-(
    Technically it's possible, I guess the 12V line to this high beam assist would need to be altered electronically from ON/OFF switch to constant on i.e. VAG control;-) or physically by modifying power line to 12V IGN line. You need smarter person than myself to advise - good hunting though:-)
    Veteran Member Four Rings FINA4's Avatar
    Jun 15 2004
    2010 Audi S4, 2010 Mazda5
    Tampere, Finland
    [09  Cent. Elect.] -> [Coding  07] -> Long Coding Helper -> Byte 3
    Bit 5 set to 1
    What is it supposed to do? I tried this but didn't see anything different in MMI.
    Jul 27 2010
    Singapore
    It would be great if we could set the wiper sensitivity more than the max that the wiper stalk adjuster can offer. I'm always at max setting as it is, and it would be nice to move the whole range up, so that my daily setting is in the middle. Can the sensitivity be adjusted by vagcom?
    Quote Originally Posted by 2010S4 View Post
    Veteran Member Four Rings rlarsen's Avatar
    Mar 20 2009
    Copenhagen, Denmark
    Quote Originally Posted by FINA4 View Post
    Bit 5 set to 1
    Bit 5 should enable/disable the MMI menu item for "Daytime running lights" under "Car->Exterior lighting"
    Rene Larsen
    Audi A4 Avant 3.0 TDI quattro tiptronic MY2009 - sold
    VCDS 18.2.0 (HEX-V2)
    Senior Member Two Rings B8SlineNate's Avatar
    Mar 15 2010
    Northern California
    nice
    2010 B8 S-Line Avant Prestige w/Driver Assist
    Sep 29 2009
    Enable DSG gear displayed when in D or S in the DIS (thanks to kmjmrq - http://www.audizine.com/forum/showth...=1#post6093594)
    [02 - Auto Transmission]
    [10 - Adaptation]
    Use the drop down menu and scroll way down near the bottom and select Single Gear Display
    In the lower drop down labeled "new," select D on/S on
    Do it! - you will get a popup saying this is not a standard change and the would you like to use the generic Shop Code and the string is shown - accept this and it will rescan the module.
    The DIS will now show Dx and Sx where "x" is the current gear you are in just like it should!
    Veteran Member Four Rings Voltrons_Head's Avatar
    Sep 14 2009
    Philly
    ^^I saw this today. How great is this? Have you done it yet?
    Sep 29 2009
    Quote Originally Posted by Voltrons_Head View Post
    I love it, worked great, I literally went right out to my car and tried it immediately. I put in the extra parts about the Shop Code, as that was what I was prompted. Stupid that they made the default to hide it in the car, and it's still there. I even remember someone saying the talked to a guy from Audi AG, who said they knew the new DSG code removed this when they flashed the A3's back before the S4 came out in B8 flavor - he said they would not be making it change back, there was no way to easily in the code - hah!
    This removes one of the small gripes I had about the DSG.
    Veteran Member Four Rings zee007's Avatar
    Jan 12 2010
    2016 RS7; 2017 X5M
    RVA
    Items for Sale
    [10 - Adaptation]
    Fantastic find. I wonder if this works for the S-tronic B8 (like the S5)?
    - Zee
    Gone: MY16 RS7 | Nardo | Diamond | Carbon Optic | Sport Exhaust | Eurocode | 034M | H&R | TAG | K&N
    Past: MY09 TT | MY10 S5 | MY13 AllRoad | MY15 S6
    Current: MY17 BMW X5M | Loaded | Quick | Brute | Not an Audi
    Mar 20 2009
    Copenhagen, Denmark
    Quote Originally Posted by zee007 View Post
    Tiptronic, S-Tronic (or DSG which is the name VW use) and Multitronic can all be coded - so it should work on your S5.
    Rene Larsen
    Jan 08 2011
    EU
    It works on my S5. It shows Dx and Sx. It is not showing the "gear advice" however, that was shown in my S5 coupe before (then it showed for instance D4->5, meaning it is advisable to change gear from 4 to 5).
    RS5 Cabrio
    Sep 29 2009
    I have the B8 with S-tronic...
    Veteran Member Three Rings MeteorS4Ti's Avatar
    Sep 24 2008
    Florida
    So if I put each of the settings into 04- Individual I can go back to my car and change the settings from then on? Looking to do this within the next couple days so I'd appreciate any help.
    2016 S3 S-Tronic Sepang Blue/Black Sport Seats
    APR Tune|TAG Motorsports Gloss Black Rear Logos
    Previous:
    2013 S4 6MT Brilliant Black/Black Alcantara, Prestige, Sport Diff, B&O
    Stratmosphere Intake|Black Edition S4 Grille|Eurocode Meisterwerk STS|Hoen H8
    2011 S4 S-Tronic Meteor Grey/Black Alcantara, Titanium Package, Prestige, B&O
    Stratmosphere Intake|Hoen H8
    Jan 10 2011
    Boston, MA
    Quote Originally Posted by RedAudiaA408 View Post
    Yes, the hardware buttons will still work to change to whatever ADS setting you like.
    Incidentally, I think "Set ADS to Individual" is mislabeled since this code can be used to set the default ADS to any of those four settings, not just Individual. For example, I used code 03 - Dynamic to set Dynamic as the default setting.
