Page 5 of 20 FirstFirst ... 3456715 ... LastLast
Results 161 to 200 of 790
  1. #161
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    Quote Originally Posted by The Infiltrator View Post
    Okay, so I did some coding a while back and it all worked before. I even went back in with VCDS to make sure the box is checked and everything is set right. I just tried to open my windows with my key FOB like I do once in a while and only the sun roof opened. When I have the windows already open the windows will close, so that works. I can't remember if I've tried opening them or not since I did the 3G retrofit but I'm stuck. Thoughts?
    http://www.audizine.com/forum/showth...-VAG-COM-codes
    Operating Windows and Sunroof with Remote
    (Note, the sunroof cannot be opened with the remote)
    You need to continuously hold the remote button for the function to operate.
    [Select]
    [46 - Cent. Conv.]
    [Coding - 07]
    [Long Coding Helper]
    Click on each of the Byte numbers in line 3) and you'll see the selectable options below.
    Check the box for "Comfort Operation: Remote Control active"
    [Transfer Coding]
    [Do It!]
    Edit:
    I just tried my other FOB and it locks and unlocks like it should but it doesn't do anything with the windows. I think the key FOB's are the issue.
    Quote Originally Posted by hyperunion View Post
    You have to go in screen I think convenience and activate in mmi screen
    ^ This is where I'd start. The sunroof, front windows, and rear windows are individual check boxes in MMI.
    Sent from my iPhone 6 using Tapatalk
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
  2. #162
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by ProjectBlackout View Post
    Sweet, thanks guys! I'll have to play with it tomorrow, sounds like an easy fix.
  3. #163
    Veteran Member Four Rings hyperunion's Avatar
    Sep 03 2012
    07 Xterra 4X4 , 02 20V Passat variant.
    Lehigh Valley, PA
    Quote Originally Posted by adamazing View Post
    Those pre-cut kits don't fit to the edges. You'll be left with a couple millimeters of non-coverage around the edges of the panels. The rounded curvatures are also relief cut which makes installation easier, but are eyesores.
    You'll eventually have build-up around the edges of the film that will be pretty noticeable. I'd advise against it.
    I've had a custom fit clear-bra on my other car for few years now and, in all honesty, I don't think I'd do it again. When I weigh the cost incurred vs. the longevity and life spanof the product, you might as well just repaint the bumper every 3-5 years.
    You haven't tried xpel ultimate!!!
    B8.5 A4 Premium +, ZF8, APR Stg II+ E85, APR HFC Downpipe, APR Carbon Intake, APR Intercooler, APR T.M. Delete, AWE Quad Exaust, ECS turbo inlet hose, H&R coilovers , H&R F&R Sway Bars, Q5 4 Piston Brembo upgrade, ECS Slotted rotors and stainless lines, OZ Ultraleggeras, Piaa, 3M Crystalline, Xpel Ultimate. IG: "Veritech1"
    RIP: B6 A4 Sport, AWE GIAC rSK04, Bilstein PSS9, OZ SL.
  4. #164
    Sep 09 2010
    Destin, FL
    Well I checked and can't find where it would be in the green screen. Everything is already checked off in there. I'll figure it out one day when I have time. Now I need to work on getting an AMI cable to work with the Kufatec wire block in the back of the MMI.
  5. #165
    Feb 24 2013
    CA
    Its not in the green screen. Its in the orange screen. The one that has how much oil you have or things like that. Its under the conveinence option
  6. #166
    Mar 24 2014
    Quote Originally Posted by Ulisses03hd View Post
    Yup, in the Car menu there should be a "Convenience Windows" setting that allows you to set which windows open and close with the key.
  7. #167
    Aug 04 2010
    Queenz/Westchester
    Convenience Windows is located in the door lock menu of the mmi.
    Sent from my VS985 4G using Tapatalk
  8. #168
    Sep 09 2010
    Destin, FL
    Well I found it and fixed it, thanks again guys! Sometimes we over complicate things when they are easy and right in front of you.
  9. #169
    Feb 24 2013
    CA
    You should be ashamed. You are able to completely retrofit an mmi system and such but you cant figure out minimal things out. SMH
    :P
  10. #170
    Apr 22 2014
    2018 Q5, 2018 X1
    Sacramento
    Great build!! Finally took the time to read all of this, awesome work~
    Next up is the Color DIS/ new cluster right??? I saw you poke around in that thread, a write up like you did with the 3G retro would be awesome!
    2018 Q5 Tech Premium Plus
    2011 A4 JHM K04-R : JH MOTORSPORTS TUNED : CTS : 034 : ECS TUNING : SNOW PERFORMANCE
  11. #171
    Sep 09 2010
    Destin, FL
    :P
    lol, I know. I should have asked the question in the "Questions you thought were too dumb to ask" thread.
    http://www.audizine.com/forum/showth...oo-dumb-to-ask
    Quote Originally Posted by shaunm82 View Post
    Thanks!! Yeah I am still looking at changing out the temp panel and cluster. I think I might just order them and try it out. The cluster looks like I would run into issues since it saves the miles I guess. But I read you can change it some how as long as it's under 80k, then it locks out.
  12. #172
    Apr 22 2014
    2018 Q5, 2018 X1
    Sacramento
    Yeah that was my concern too, the miles. I was even considering finding one that was slightly higher than mine and once I reached that point, swap it out then lol.
  13. #173
    Sep 09 2010
    Destin, FL
    lol, that might work. But a dealer would go nuts if you sold or traded it with miles not matching.
  14. #174
    Veteran Member Four Rings Cloudg8's Avatar
    Oct 10 2012
    Jeep
    Chicago/IL/USA
    Hey brother. Question. Do you by chance if the facelift rear bumper cover will fit the B8. Or is it better to just get the regular 2010-2013 S4 one?
  15. #175
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by Cloudg8 View Post
    That is a good question. I would say yes, it would fit.
    Can anyone else comment on this please!?!?
  16. #176
    May 07 2014
    Did you ever end up getting the ECS boost gauge?
    I ordered one and finally installed it a couple of days ago. It's a very easy install, the product is quality, and functions very well. I would recommend it.
    2010 A4 2.0t quattro 6mt
  17. #177
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by zokissima View Post
    Na, I haven't really been looking at a gauge since I'm waiting to upgrade the turbo at the same time. I think ECS is the only company selling a boost gauge now and wish AWE still had theirs. I liked where AWE installed theirs a little more than ECS. Now that you have told me your review I might just go with them and buy it now, I might as well.
  18. #178
    Apr 22 2014
    2018 Q5, 2018 X1
    Sacramento
    And here you said that the EFR kit and S-line seats were your last mod~! Then little things like this pop up here and there. You are running out of things to do though!
  19. #179
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    Podi sells a few different boost gauge options for our cars.
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
  20. #180
    Sep 09 2010
    Destin, FL
    lol yeah I know, I have a final list of things I will do to my car and be done.
    Next And Final Upgrades:
    S-Line Seats: Still Looking For A Set
    Boost Gauge: Looking For A Better One
    http://www.ecstuning.com/Audi-B8_A4-...ges/ES2723973/
    CTS Turbo Kit: Still Looking Around
    http://www.ctsturbo.com/cart/product...it-3639-1.html
    Integrated Engineering Intake Manifold: Maybe
    http://www.performancebyie.com/ie-2-...a888-gen1-gen2
    Rims: 19x9.5 Rims Color Options: Silver
    http://n4sm.com/products/wheels/forgestar-wheels-f14
    http://www.getyourwheels.com/view-wh...lors-available
    Tires: 255/35/19 Or 265/35/19....Maybe 275's
    http://www.tirerack.com/tires/tires....omCompare1=yes
  21. #181
    Oct 26 2012
    St. Louis, MO
    CTS Turbo Kit: Later
    Integrated Engineering Intake Manifold: Later
    Rims: 19x9.5 Rims Color Options: Silver, Gunmetal Or Brushed Titanium?
    Podi website
    http://www.podi.ca/p1packages.aspx?CarID=11
  22. #182
    Apr 22 2014
    2018 Q5, 2018 X1
    Sacramento
    You can grab these guys!
    They have the set listed in pieces, but all best offer. I bet that'd sell at a good price if you bought em all.
    http://www.ebay.com/itm/09-10-11-12-...item43e22a3c1c
  23. #183
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by blbroo View Post
    Nice, I've seen these but not sure if I like the location of it. I will add this to my next mods and keep an open mind on this!
    Thanks man!!!
    I've been watching eBay and to be honest, I don't like the S4 seats. They have a lot of S4 seats but it's very rare to see S-Line seats.
    Looking for black full leather S-Line seats (front & rear).
  24. #184
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    About $1600 asking for all the pieces. Plus shipping. Why doesn't the rear seat split fold!
    My 2009 A4 Prem+ Build thread
  25. #185
    Apr 22 2014
    2018 Q5, 2018 X1
    Sacramento
    Yeah, I think I've seen one set and the price was just nuts for the S-Line seats.
    I'll keep an eye out as well. I'm also always watching ebay lol. 'Window' shopping you can call it.
  26. #186
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by Lambda13 View Post
    Yeah, damn good price for those seats!
    lol, I love eBay. I went through them for my 3G MMI retrofit and it worked out.
  27. #187
    Apr 22 2014
    2018 Q5, 2018 X1
    Sacramento
    Yeah, great price! Plus they are local to me, so I'm always on their page! I made an offer on a couple of items (set) for $200 less and they accepted because I made up the set. I'd bet they would do the same.
  28. #188
    Sep 09 2010
    Destin, FL
    Dooooo iiiiiiit
  29. #189
    Apr 22 2014
    2018 Q5, 2018 X1
    Sacramento
    Couple pallets of seats shipped from my work to SC is about $200!! Just sayyyiin!
  30. #190
    Sep 09 2010
    Destin, FL
    lol, now that's a damn good deal!
  31. #191
    Veteran Member Four Rings B G 8er's Avatar
    Sep 28 2011
    2011 A4 Quattro Premium 6MT, 2016 VW Golf Sportwagen SEL Gone: 2013 Q5 2.0 Prem.
    Valencia, CA
    Why not the P3Cars digital vent gauge?
    How about the power folding mirrors? No real need for them on my car but I do think they are quite cool.
    The rear folding seats would be nice. Wish I had those.
    Your car will be truly transformed with the S-Line sport seats. What's the difference with rear S-line seats? Are those different than what comes stock with the front non-S-Line leather front sport package seats?
  32. #192
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by B G 8er View Post
    I don't want a digital gauge.
    I have thought about the folding mirrors and might add that to my list.
    All of us have rear folding seats...
    Yes, they are nice and the rear is just a different design just like the front with S-Line seats.
  33. #193
    Mar 24 2014
    After a certain model year, I want to say 11+ but I'm not sure, folding rear seats were an option on B8s except on higher trim levels. I think they reverted back to standard with the B8.5.
  34. #194
    Sep 09 2010
    Destin, FL
    I have a 2010 and anyone I've ever known to own one of these, their seats fold.
  35. #195
    Oct 26 2012
    St. Louis, MO
    I have a 2010 and both back seats fold.
  36. #196
    Mar 24 2014
    It was mentioned when I got my car... I literally laughed in the salesman's face and called it a blatant cash grab by Audi. Believe it or not he agreed with me. The Premiums didn't get it after 2010.
    http://www.audizine.com/forum/showth...old-down-in-A4
  37. #197
    Sep 09 2010
    Destin, FL
    Oh damn, so base models don't fold. Ha, that sucks!
  38. #198
    Apr 22 2014
    2018 Q5, 2018 X1
    Sacramento
    Yup, 2011 here and mine don't fold either
  39. #199
    Sep 09 2010
    Destin, FL
    Madness I tell ya, madness.
  40. #200
    Oct 26 2012
    St. Louis, MO
    I know where you can get an APR style K04 for $1000 delivered with a warranty. It's rebuilt, but, you could get two for less than the price of the CTS kit and not have to change out your HFC, or one and use the difference for the IE intake manifold. I'm either going this route or the $1400 one like Carlos74 has.
