Page 1 of 37 1 2311 ... LastLast
Results 1 to 40 of 1461
    Feb 11 2009
    2011 S4 6MT
    Cool VAG-COM codes
    Removing Seatbelt Chime
    [Select]
    [17 - Instruments]
    [Coding - 07]
    [Long Coding Helper]
    Click on each of the Byte numbers in step 3) and you'll see the selectable options below.
    Uncheck the box for "Seatbelt Warning active"
    [Do It!]
    Enabling Gauge Test/Needle Sweep
    This will sweep the gauge needles through their full range automatically when you start the engine.
    [Select]
    [17 - Instruments]
    [Coding - 07]
    Check the box for "Gauge Test/Needle Sweep active"
    [Do It!]
    Enabling Lap Timer
    [Select]
    [17 - Instruments]
    [Coding - 07]
    Check the box for "Lap Timer active"
    [Do It!]
    Operating Windows and Sunroof with Remote
    (Note, the sunroof cannot be opened with the remote)
    You need to continuously hold the remote button for the function to operate.
    [Select]
    [46 - Cent. Conv.]
    [Coding - 07]
    Click on each of the Byte numbers in line 3) and you'll see the selectable options below.
    Check the box for "Comfort Operation: Remote Control active"
    [Transfer Coding]
    [Do It!]
    Senior Member Four Rings ApexIt's Avatar
    May 28 2008
    2005 A4
    Re: Cool VAG-COM codes
    I wonder if any of these would work with a b6. I guess thats on my to do list this weekend.
    AKA: numer24
    18'' R8 replicas :: RS4 Rear Sway :: Eibach dampers and springs :: 30% black tint :: S4 Door Blades :: B5S4 Calipers :: Dimpled and Slotted rotors
    Senior Member Four Rings Smiley's Avatar
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    Quote Originally Posted by numer24 View Post
    Dude, theres a whole thread for codes like these in the B6 section...
    New Member Three Rings sc_flaw's Avatar
    Dec 18 2008
    2008 Ibis White a3 Sline
    toronto
    i wonder if it works on the a3. That sweeping needle would be pretty cool
    Oct 24 2008
    N/A
    Did you just copy that from Ross-tech's website??
    Feb 11 2009
    2011 S4 6MT
    Quote Originally Posted by akaisuzu View Post
    yes
    Senior Member Three Rings xileh's Avatar
    Nov 06 2008
    Audi A4 B8 and Audi 100 20vt q
    Norway
    Where is the cheapest place to buy VAG-Com that works on B8?
    Active Member Two Rings D.NGUYEN's Avatar
    Feb 17 2009
    2009 Audi A4 2.0T 6MT
    My dealership did it all for me for free =D
    Senior Member Four Rings rlarsen's Avatar
    Mar 20 2009
    Sweden (south)
    Let expand the list
    Hidden menu in MMI high:
    STG 07 - Control Head
    STG Adaptation -> Channel 8
    change 0 to 1
    Use this hidden menu at your own risk.
    Caution: Keep away from the "Bootloader".
    STG 09 – Cent. Elect.
    STG Coding -> Long Coding Helper -> Byte 3
    Bit 2 - LEDs remain at full brightness with parking lights (1 = active)
    Bit 7 - Turn off LED-strip DRLs with indicators (1 = active)
    STG 17 - Instruments
    STG Coding -> Long Coding Helper -> Byte 1
    Bit 0 – Gauge Test/Needle Sweep (1 = active)
    Bit 3 – LAP-Timer (1 = active)
    Consumption in DIS:
    STG Adaptation -> Channel 3
    change 100 to 104
    Sample 1:
    DIS: 9,3 l/100 km.
    Real: 9,8 l/100 km. (100/9,3*9,8 = 105,38)
    Channel 3 will be changed from 100 to 105
    Sample 2 :
    DIS: 7,8 l/100 km.
    Real: 6,9 l/100 km. (100/7,8*6,9 = 88,46)
    Channel 3 will be changed from 100 to 88
    DVD navigation eject lock:
    STG 37 - Navigation
    STG Adaptation -> Channel 68
    0 = button active
    1 = button inactive (anti-theft)
    http://wiki.ross-tech.com/index.php/Audi_A4_(8K)_Navigation
    STG 46 - Comfort System
    STG Coding -> Long Coding Helper -> Byte 8
    Bit 0 – Emergency Brake Flashing via Turn Lights active (1 = active)
    Bit 1 – Emergency Brake Flashing via Brake Lights active (1 = active)
    Phone voice control:
    STG 77 - Telephone
    STG Coding
    00x0x?0 - The 2nd to last digit should be changed to 2 (English (UK))
    http://forums.audiworld.com/showthread.php?p=23587701
    http://wiki.ross-tech.com/index.php/Audi_A4_(8K)_Telephone_Preparation_(MOST)
    Rene Larsen
    A4 Avant 3.0 TDI quattro tiptronic MY2009
    VCDS
    11.11.2 - Beta xx.xx.x (HEX-USB+CAN)
    Dropbox Invite - use this link and we'll both get extra space!
    Senior Member Three Rings blkb7's Avatar
    Dec 12 2006
    Jerzey
    Quote Originally Posted by rlarsen View Post
    Bit 0 – Emergency Brake Flashlight - with Turn Signal active (1 = active)
    Bit 1 – Emergency Brake Flashlight - with Brake Light active (1 = active)
    what does this do??
    The question is, when you turn on your car, does it return the favor?
    Mar 20 2009
    Sweden (south)
    Quote Originally Posted by blkb7 View Post
    what does this do??
    Adaptive brake lights
    http://www.youtube.com/watch?v=17l9ZUwdvZY
    Rene Larsen
    VCDS
    Dec 12 2006
    Jerzey
    please tell me it doesn't strobe like that car in the vid and which lights blink??
    is it possible to make only the middle blink like this
    http://www.youtube.com/watch?v=Xmxj4...eature=related
    Mar 20 2009
    Sweden (south)
    The system on the A4 (B8) is almost the same as the one used by Mercedes in there "Pre Safe" safety system.
    The system can be configured in two ways (as the coding also show)
    1) the warning Lights (Turn Signals) enables automatic.
    2) the Brake Light begin to flash.
    the two options can be enabled at the same time.
    If you can read German - or can translate it to a language you can read - you can read about the Adaptive brake lights in more detail
    Rene Larsen
    VCDS
    Nov 06 2008
    Norway
    The thing with the turningligts is on by standard with me. I came in about 80-90 km/t and wanted to really test the brakes. So i braked as hard as possible untill it stopped. Then i saw the turninglights was on, and thought something was wrong with my car
    Anyone know a place to order VAGCOM att a good price. Need one that works with the B8 for both faultcodes and theese codes.
    Mar 20 2009
    Sweden (south)
    Quote Originally Posted by xileh View Post
    I don't know if it is a good price, but I think you will be more happy in the long run with an original VagCom cable from Ross Tech. This cable can be bought at VagCom in Sweden - with this cable you can use the Norwegian/Swedish and English version of the VagCom software.
    It is however possible to buy a Chinese build VagCom cable (works only with old VagCom software) on e.g. eBuy, but I will not recommend the buy of such a cable.
    Rene Larsen
    VCDS
    Active Member Three Rings maka's Avatar
    May 01 2009
    2006 Audi A4 2.0T Q Auto
    West Vancouver Canada
    will the break lights and gauge thing work for a b7.
    New Member Two Rings
    May 19 2009
    MIAMI
    Bit 7 - Turn off LED-strip DRLs with indicators (1 = active) When is this suppose to work when the day light driving lights on (when LED strip on when driving in day) they don't turn off when turning signal on??? Or at Night??
    Mar 20 2009
    Sweden (south)
    Quote Originally Posted by JAM-FL View Post
    They don't turn completely off.
    Normally with no modification done - the LED-strip will get less bright in the side where the indicator is on (when ONLY the LED-strip is active - as with DRL). This behavior can be changed, when Bit 7 is unchecked (or changed from 1 to 0)
    Rene Larsen
    VCDS
    May 19 2009
    MIAMI
    Ok....I go outside right now my led are on when I put the turning signal they turn off....is that the way they are suppose to be after you chabge the code?Its daytime here now. Or what your talking about allpies at night
    Mar 20 2009
    Sweden (south)
    If they turn off (or get less bright) - they work as they did when you got your A4/A5 (default configuration) - this behavior can then be changed, so they don't turn off.
    The brightness when they normally 'turn off', is the same as when head light is on (xenon) - where both LEDs get less bright.
    Rene Larsen
    VCDS
    May 19 2009
    MIAMI
    Rene Sorry to bother you soooo much on this. With my headlights on the led stay on with the same strength when i put the turning signal. During the DAY I put my turning signal on with no headlight ON and the LED turns off....So I suppose the function only works with headlights on. Meaning that with headlights OFF and LED light on only daytime driving the led still turns off when turning signal turned on. Right????
    May 19 2009
    MIAMI
    Basically daytime driving with NO headlights ON LED still turns OFF at night driving with headlights on LED stay on same strenght with turning signal on......
    Mar 20 2009
    Sweden (south)
    Yes, it is only working with the LEDs on - because it is them you are configuring
    If they still 'turn off' after you have changed Bit 7 - then the change was not done successfully - try to check the current configuration.
    When only LEDs are on (and NO headlights are on) - they should be very bright, and it should be very clear to see that the LED get less bright, in the side where turning signal turned on.
    When you say "headlights OFF and LED light on" - how do you turn the LEDs on??
    If you have turned the LEDs on as "Parking lights" - the LEDs are not on at full brightness by default - here you need to set "Bit 2 - LEDs remain at full brightness with parking lights"
    Rene Larsen
    VCDS
    May 19 2009
    MIAMI
    Ohhhhhhh I got it now!!!!!! Thnkas for all your help :)
    Mar 20 2009
    Sweden (south)
    The LED-strip is meant to be used as DRL - and with DRL the LEDs are on with full brightness on both "0" and "AUTO"
    Rene Larsen
    VCDS
    May 19 2009
    MIAMI
    What is meant by DRL...????
    Mar 20 2009
    Sweden (south)
    DRL = "Daytime Running Light"
    This means that there is always lights on in the front (on A4/A5 with LED-strip), and maybe also the tail lights (in some Countries you need lights on both front and rear - like where I live).
    Rene Larsen
    VCDS
    Apr 24 2009
    2010 S4, '07 Gti
    Oakville, Ont.
    Quote Originally Posted by D.NGUYEN View Post
    Which Dealer is that?
    _____________________________
    2010 S4 Phantom Black. Ordered.
    May 19 2009
    MIAMI
    Yes Mines are on full brightness in "O" and "Auto" but when I put my turning signal....the DRL turn off. The function of BIT 7 only work when you have your DRL on along with the parking light this is when BIT 7 works
    Mar 20 2009
    Sweden (south)
    No, this is not correct.
    It should work with both "0" and "AUTO" too.
    When you say "the DRL turn off" - is this then just in the side where the turning signal is on??
    Bit 7 has after the change a value of 0 - right?? or the whole Byte 3 has a value of 00010101 - in Hex it is 15 (if you have changed Bit 2 as well)
    Rene Larsen
    VCDS
    May 19 2009
    MIAMI
    yes the drl turns off on the side where the turning signal is on.....
    Mar 20 2009
    Sweden (south)
    You did click on the "Do It!" button after the modification??
    Have you tried to turn all off - vagcom disconnected and ignition off - and then back on, and see if Byte 3 still has the expected value??
    00010101 from left to right Bit 7 - Bit 0
    Rene Larsen
    VCDS
    May 19 2009
    MIAMI
    I'm going back to the shop right now with the printout of how the bit should look have them check it out and get back to you ...TY
    Senior Member Three Rings Toecutter's Avatar
    Dec 31 2007
    Oregon
    The Ross-Tech site no longer shows the DRL-stays-on-with-turn-signal modification. Why come?
    http://www.ross-tech.com/vag-com/cars/audiB8.html
    Or did I simply overlook it?
    Mar 20 2009
    Sweden (south)
    Quote Originally Posted by Toecutter View Post
    This is not a complete list - what counts is the options in the VCDS (Vagcom) interface - and there is the DRL-stays-on-with-turn-signal option still. (I use the 805.3 and 904.0 Beta)
    The label-files are impossible to read for the B8-platform - so you need to connect the cable to your car to see which options VCDS offers.
    Rene Larsen
    VCDS
    May 19 2009
    MIAMI
    Rene Thankyou so much just got back from the shop and FINALLY the DRL and turning signals are working it seems Bit 7 didn't show "0" and 00010101 from left to right Bit 7 - Bit 0 so he took care of it. Thank you once again for your time spent in helping me.
    Mar 20 2009
    Sweden (south)
    Glad I could help
    Rene Larsen
    VCDS
    Mar 20 2009
    Sweden (south)
    ohhh - I just forgot to tell you that from now on, you have to remember to tell your workshop that there have been made manual changes to the coding, each time you you are there.
    If the workshop receive a software update from Audi and the workshop don't remember or know about the changes, the coding will be overwritten with the default coding, which Audi have registered for your car. The default coding can not be changed/overwritten with your new coding.
    I don't know whether you've got the latest software updates from Audi "23D6 Kit 14" - I'll have it next time my A4 is at the shop.
    Rene Larsen
    VCDS
    May 19 2009
    MIAMI
    Well this shop is located in Miami, Fl GERMAN MOTORING they are the one that installed my APR and they keep records of all theire customers cars on file for everything they perform to the vehicle so I guess I'll be ok. But thanks for the info.
    Mar 20 2009
    Sweden (south)
    And they also do the Service on your car (oil change, inspection, ...)??
    Rene Larsen
    VCDS
