Originally Posted by
Dan[FN]5857
If you're going to go through all the trouble of swapping transmissions, fucking do it right and get a standard. just trust me. and I'm sure many, many others will agree.
EDIT: reads more harsh than I actually mean it. but I wanted to get my point across.
well thats what im trying to figure out .. what the difference in electrical and whats needed to get everything running is between a tip and stick.
as much as i do want to swap in a 6 speed manual, i just as much want to swap in a 6 speed tip just to do something different and test the power of it at the same time - if a b6 s4 tip tranny bolts right in and no change in electrical, wiring, and so on is needed then id swap it in asap (assuming they dont cost an arm and a leg)
Kittrell
Do not quote me on this, but I am pretty sure the A/S/RS all use a Getrag 466 transmission, and the only difference is the clutch. So you just need a B6/B7 six speed, doesn't really matter what it's out of. Someone feel free to correct me if I am wrong.
As far as the TIP is concerned, the B6 S4 uses a 6HP19. You'll want a first gen box, which came in the B6 S (not a B7 S) so there is no incompatibility with the controllers. Other than that, I could not tell you, I have yet to see it done. The 5HP19 Tip can handle 450 or more with upgrades, so it might not be worth the hassle of the swap.
so my 5 speed tip right now is capable of 450 or more ?! jeeeeez everybody always used to say these trannys sucked
anybody else with more info on this feel free to chime in !
