Results 41 to 80 of 109
Threaded View
    Oct 29 2005
    10speed
    San Francisco, CA
    The 1.8T Wiring Harness Explained
    Hey guys, thought I’d document this for people always trying to figure this stuff out. This should also help for my 2.7T swap. This is for a 2002 harness and I am missing a few connectors like SAI and MAF.
    MAP Sensor
    Connector: Black (4 pin)
    1: Black
    2: Empty
    3: White with black stripe
    4: Grey with blue stripe
    Oil Level
    Connector: Black (3 pin)
    1: Black with red stripe
    2: Brown
    3: Red with green stripe
    Thermostat (possibly wrong)
    Connector: Black (2 pin)
    1: Brown
    2: Blue with brown stripe
    Lower Coolant Temp Sensor
    1: Yellow with black stripe
    2: Blue with black stripe
    Throttle Body
    Connector: Black (6 pin)
    1: Purple with red stripe
    2: Green with purple stripe
    3: Red with purple stripe
    4: Purple with red stripe
    5: Brown with purple stripe
    6: Grey with brown stripe
    A/C Compressor (possibly wrong)
    1: Blue
    2: Blue
    IAT
    2: Black
    Alternator (possibly wrong)
    1: Green with blue stripe
    2: White with green stripe
    N112
    Connector: Brown (2 pin)
    1: Green with yellow stripe
    2: Brown with black stripe
    N249
    2: Yellow with green stripe
    Wideband 02
    1: White
    2: Black with white stripe
    3: Green with yellow stripe
    4: Red with white stripe
    5: Brown
    6: Grey with green stripe
    Rear 02 Sensor
    Connector: Brown (4 pin)
    2: White with grey stripe
    3: Purple
    4: Red
    Crank Position
    Connector: Grey (3 pin)
    1: Black
    2: Blue
    3: Grey
    Knock Sensor (Rear)
    Connector: Blue (3 pin)
    1: Yellow
    2: Green
    3: Black
    Knock Sensor (Front)
    Connector: Green (3 pin)
    1: White
    2: Brown
    3: Black
    1: Blue with yellow stripe
    2: Empty
    3: Brown with yellow stripe
    Oil Pressure
    Connector: Black (1 pin)
    1: Yellow
    Speed Sensor (Trans)
    1: Empty
    2: Brown
    3: Brown with red stripe
    Other Trans Sensor (??)
    Connector: Black (5 pin)
    1: Empty
    2: Blue with red stripe
    3: Black with blue stripe
    4: Empty
    5: Empty
    1: Red with black stripe
    VVT Tensioner
    2: Yellow with grey stripe
    Coolant Temp (Top)
    1: Blue with brown stripe
    2: Brown with yellow stripe
    3: Black
    4: Brown with grey stripe
    Cam Position Sensor
    1: White with black stripe
    2: Green with grey stripe
    3: Black
    Injector 1 (Front)
    1: Red with blue stripe
    2: Black with green stripe
    Injector 2
    2: Brown with blue stripe
    Injector 3
    2: Grey with green stripe
    Injector 4
    2: Grey with purple stripe
    N75
    1: Black with purple stripe
    2: Yellow with white stripe
    EVAP
    2: Purple
    Coilpack 4 (Rear)
    1: Red with green stripe
    2: Brown
    3: Brown with black stripe
    4: Brown with yellow stripe
    Coilpack 3
    2: Brown
    3: Grey with black stripe
    Coilpack 2
    2: Brown
    3: Grey with brown
    Coilpack 1 (Front)
    2: Brown
    3: Grey
    Coilpack Grounds: Brown with yellow stripe
    2000 Audi S4 Body Harness Plugs:
    - T10, Brown, 10 pin
    1. green/red - K-line diag wire into ECU pin 43
    2. green/brown - to pin 47 on ECU from ?
    3. white/blue - vehicle speed signal to pin 54 on ECU
    4. red/black - from park/neutral position relay to ignition/starter switch
    5. black/blue - to pin 3 on back-up light switch
    6. unused
    7. unused
    8. black/red - to pin 1 on oil level thermal sensor
    9. red/grey - to pin 3 on oil level thermal sensor
    10. yellow - to pin 81 on ECU from ?
    - T10m, Black, 10 pin
    1. blue - goes to the voltage regulator (D+/61)/generator
    2. green/blue - rpm signal to pin 37 on ECU
    3. white/grey - from cluster to oil pressure switch
    4. red - from positive wire 30 to ECU pin 62
    5. brown/yellow, pin 3 on engine coolant temp sensor
    6. unused
    7. blue/green - from cluster to pin 1 on Engine Coolant Level Warning Switch
    8. red/blue - power pin 15 to fuel pump relay and then ECU
    9. blue/brown - from cluster to ground connection 2?
    10. brown/red - from cluster to to pin 2 on speedometer vehicle speed sensor (VSS)
    - T10ar, Orange, 10 pin
    1. red/green - from 20A fuse in fuse holder to power output stage pin 1 connector T5d
    2. red/brown - to pin 48 on ECU from ?
    3.
    4. unused
    5. black/blue - pin 1 on injector 1 to 20amp fuse in fuse holder
    6. white/yellow - to pin 1 on leak detection pump
    7. yellow/red - to pin 2 on leak detection pump
    8. green/yellow - to 15A fuse in fuse holder
    9.
    10. blue/lilac - engine overhead warning light
    - T15m, Red, 15 pin
    1. green/brown - From ABS control module to ECU pin 74
    2. unused (only for FWD)
    3. black/green - A/C control head to ECU pin 41
    4.
    5. black/lilac - to pin 30 on ECU from ?
    6.
    7.
    8.
    9.
    10.
    11.
    12.
    13.
    14. orange/brown - connection (low-bus)
    15. orange/black - connection (high-bus)
    - T15, White, 15 pin
    1. yellow/blue - to pin 1 (4 on 2001) on throttle body
    2. yellow/lilac - to pin 2 on throttle body
    3. brown/red - to pin 3 on throttle body
    4. green/yellow - to pin 4 (5 on 2001) on throttle body
    5. green - to pin 5 (1 on 2001) on throttle body
    6. brown/green - to pin 6 on throttle body
    7. red/grey - to pin 1 on connector T6y
    8. blue - to pin 2 on connector T6y
    9. red/yellow - to pin 3 on connector T6y
    10. black/white - to pin 6 on connector T6y
    11. red/black - to pin 2 on brake light switch
    12. white/red - to pin 4 on brake light switch
    13. red/green - to pin 1 on clutch vacuum vent valve switch
    14.
    15.
    2003 B6 A4 1.8T harness
    T10, Black, 10 pin
    1. blue - generator
    2. unused
    3. white/grey - Oil pressure switch
    4. unused
    5. red/green - from pin 121 on ECU to ?
    6. brown/yellow - pin 3 from engine coolant level warning light
    7. blue/yellow - Engine coolant level warning switch
    8. unused
    9. blue/brown - Engine coolant temp sensor
    10. brown/red - Speedometer vehicle speed sensor pin 2 (unused in 03)
    T10a, Brown, 10 pin
    1. red/blue - from injector harness to... ?
    2. black/red - Oil level thermal sensor pin 1
    3. unused
    4. red/black - Ignition/starter switch to ground
    5. black/blue - Back up light switch pin 3
    6. green/red - control module with indicator unit in instrument panel insert
    7. unused
    8. green/yellow - connector for fuse 234, connects MAF, N112, N80, N249
    9. red/grey - Oil level thermal sensor pin 3 (red/green for 03)
    10. unused
    T17e, White, 17 pin
    1. brown/green - to pin 1 on throttle body
    4. yellow/blue - to pin 4 on throttle body
    5. grey/yellow - to pin 5 on Throttle Body
    6. brown - to pin 6 on throttle body
    7. unused
    8. unused
    9. unused
    10. blue/green - from pin 38 ECU to steering column electronics module
    11. red/black - to pin 4 on brake light switch from ECU
    12. white/red - to pin 2 on brake light switch from ECU
    13. red/green - to pin 2 clutch vacuum vent valve switch
    14. grey/white - from pin 1 on locking relay for starter (clutch pedal switch) to pin 2 on clutch vent vacuum valve switch
    15. black/lilac - from ? to ECU
    16. red/grey - from power supply relay to fuse S229 (20A)
    17. unused
    T17d, Red, 17 pin
    1. white/yellow - pin 1 leak detection pump to ECU
    2. grey/red - pin 2 leak detection pump to ECU
    3. unused
    4. unused
    5. blue/brown - ? (03)
    6. lilac/blue - to airbag control module from pin 67 ECU
    7. unused
    8. unused
    9. unused
    10. red/blue - to pin 5 on fuel pump relay
    11. red/white - to ECU pin 24 to coolant fan control module
    12. unused
    13. orange/brown - Wire connection (low-bus)
    14. orange/black - Wire connection (high-bus)
    15. blue/red - reverse lamp connector
    16. unused
    17. unused
    2004 B6 S4 4.2 harness
    T10, Black, 10 pin
    1. blue – generator ???
    2.
    3. white/green – from instrument panel to F1 (oil pressure switch)
    4.
    5.
    6. brown/yellow – from pin 3 on F66 (Engine Coolant Level Warning Switch) to ground 269
    7. blue/yellow – from J285 (dash) to pin 1 on F66 (Engine Coolant Level Warning Switch)
    8.
    9. blue/brown – from J285 (dash) to pin 1 on G2 (Engine Coolant Temperature Sensor)
    10.
    T10a, Brown, 10 pin
    1. red/blue – from 25 to D95 ground for injector 1-6 ???
    2. black/red – from 21 to pin 1 on G266 (Oil Level Thermal Sensor) ???
    3.
    4. red/black - to the 50 pin on the starter
    5. black/blue – from connector A70 to F4 (Back-up light switch)
    6. for auto cars
    7.
    8. green/yellow – from 26 to D22 ground
    9. red/green – from instrument panel to pin 3 on G266 (Oil Level Thermal Sensor)
    10.
    T17e, White, 17 pin
    1. brown/green – from throttle body pin 1 to ECU pin 72
    2. yellow/lilac - from throttle body pin 2 to ECU pin 73
    3. brown/red - from throttle body pin 3 to ECU pin 36
    4. yellow/blue - from throttle body pin 4 to ECU pin 35
    5. green/yellow - from throttle body pin 5 to ECU pin 33
    6. brown - from throttle body pin 6 to ECU pin 34
    7.
    8.
    9.
    10. blue/green – from dash to ECU
    11. red/black – pin 4 on brake light switch to ECU pin 56
    12. white/red – pin 2 on brake light switch to ECU pin 55
    13. green/grey – pin 2 on clutch vacuum vent valve switch to ECU pin 39
    14.
    15. black/lilac – from 20 to pin 21 on ECU
    16. red/grey – from ECM power supply relay to fuse 229 (20A) to 229???
    17.
    T17d, Red, 17 pin
    1. yellow - from pin 1 on leak detection pump to ECU pin 80
    2. green/red – from pin 2 on leak detection pump to ECU pin 25
    3. red/yellow – from coolant fan control module 2 to ECU pin 104
    4.
    5.
    6. lilac/blue (possibly not there) – from fuse 234 to ECU pin 61???
    7. green/black – from pin 1 on N220 valve for exhaust flap to ECU pin 22
    8.
    9.
    10. red/blue – pin 4 on fuel pump relay to pin 65 on ECU
    11. red/white – from coolant fan control module 1 to ECU pin 66
    12.
    13. orange/brown – CanBus (low) from instrument panel to pin 58 on ECU
    14. orange/black – CanBus (high) from instrument panel to pin 60 on ECU
    15. blue/red – from J393 (Central Control Module for Comfort System) to 220???
    16.
    17.
    - Clint
