Results 1 to 40 of 50
    Veteran Member Four Rings bananas's Avatar
    Jun 13 2005
    1999 A4 Avant 1.8TQM
    Minnesota
    A tale of two turbos -- OR -- Sneak peak HTA2868 vs GTX2867
    -- OR --
    The "Little Big Turbo" faceoff
    -- OR --
    How I learned To Stop Worrying and Love the Boost.
    On the left, a HTA2868 (47lb/min) with a chipped turbine blade.
    On the right, a GTX2867 (47lb/min) freshly shipped to my door.
    GTX2867 nameplate
    GTX2867 Exducer, at base (67.82mm)
    GTX2867 Exducer, widest point (69.53mm)
    HTA2868 Exducer, at base (67.96mm)
    GTX2867 Inducer (49.56mm)
    HTA2868 Inducer Measurement 1 (48.00mm) (7 blades; no way to measure exactly)
    HTA2868 Inducer Measurement 2 (48.80mm) (7 blades; no way to measure exactly)
    GTX2868 Compressor Height
    Assembly Height (12.58mm)
    Highest point (37.67mm)
    HTA2868 Compressor Height
    Assembly height (12.64mm)
    Lowest point (35.89mm minus 12.64mm)
    Highest point (approx 41.59mm minus 12.64mm)
    GTX2867 Detail
    HTA2868 Detail
    '03 A4 1.8TQM 337WHP/355WTQ (93+meth) | My car's Mods | Fancy Pants™ Turbo Club Member #001
    Jun 13 2005
    Minnesota
    Side By Side (HTA2868 on left, GTX2867 on right)
    GTX2867 ported compressor cover fitted over HTA2868 compressor.
    The GTX2867 fit over the HTA2868 wheel. The HTA wheel spun freely.
    There was an obvious small gap between the wheel and the compressor cover.
    HTA2868 wheel spinning under the GTX2867 cover.
    GTX2867 Anti-Surge Compressor cover
    Pictures from inside the cover looking out towards the inlet
    Pictures from the inlet looking down towards where the compressor would be
    Picture from inlet to GTX2867 compressor
    GTX2867 cover and compressor from above
    GTX2867 cover and compressor close-up
    GTX2867 cover on HTA2868 from inlet to compressor for comparison
    Showing gap when GTX2867 cover is put on HTA2868
    Blurry pic showing gap when GTX2867 cover is put on HTA2868
    HTA2868 with HTA2868 cover with 2.5" inlet (non-standard)
    HTA2868 cover and compressor closeup
    HTA2868 and GTX2867 side-by-side
    The entire IMGUR album this post is based on
    Veteran Member Four Rings Turbwhistle's Avatar
    Jan 02 2011
    That gtx2867 looks beautiful.
    Chris|1999.5 B5 A4 Avant 1.8TQM Brilliant black|Flickr
    PSS9 | StopTech | Fikse | Challenge Motorwerks | EPL
    Veteran Member Four Rings jeffrey146's Avatar
    Feb 19 2012
    04 S4 nogaro avant MTQ, 2013 CT200H F sport, 93 EG hatch
    Draper, Utah
    Damn can you say picture heavy? Very good job on the pictures. Wish everyone would take such a load of pictures.
    CHECK OUT MY BUILD THREAD!!!
    Noggy S4 Avant MT B6
    OZ superleggera 3, Pilot SS , 034 (Trio, adjustable uppers, Zero gap snub, rear sway with endlinks) APR full exhaust with drilled cats, H&R Coilovers, Red rear diff mount, JHM (NO2,Center diff, rear LSD and stage 4 kevlar clutch with LWFW)
    ...BBK coming soon
    Senior Member Three Rings bedes's Avatar
    Mar 19 2010
    Alameda, Ca
    does that turbo require built bottom end? at least pistons?
    Veteran Member Four Rings Bische's Avatar
    Jun 03 2009
    2002 Big Block Avant
    Sweden, north
    Nice!
    very interesting thread
    Veteran Member Four Rings mrbacardi35's Avatar
    Sep 18 2006
    Fresno/Los Angeles, CA
    Quote Originally Posted by bedes View Post
    i would say at least drop-in rods.
    Veteran Member Four Rings EErie B6's Avatar
    May 30 2008
    Honda HRX
    Penna.
    Drop in rods, yes. Pistons, no. Rods are the weak point. Pistons aren't really needed unless the user intends to change displacement or compression ratio. As for sizing, this turbo is going to be larger than a GT2871 but not as large as a GT3076.
    Bananas,
    What claimed the turbine wheel of the HTA?
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Nice pics I personally know how hard it is to take pics of shiny metal parts.
    U probably took 3 times the number of pics u posted.
    Would like to see what the car does on the dyno with the new components installed. Keep up the good work sharing ur progress.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Jun 21 2005
    Milton, Ontario
    Chris, finally you get to put that new GTX turbo on!
    John, last year Chris' motor ate a spark plug ceramic and chewed through the turbine of the HTA.
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
    2014 Dodge Grand Caravan
    Oct 29 2005
    10speed
    San Francisco, CA
    GTX are the bomb
    - Clint
    May 30 2008
    Honda HRX
    Penna.
    Thanks for the background Steve.
    ...somehow I missed that. That sucks to hear.
    On the bright side, this is going to be an awesome back-to-back comparison. Its about as perfect of an HTA vs GTX as you can get.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    -Doug
    Jun 22 2009
    Dundalk, MD
    I can't wait to see how this turns out
    Jun 13 2005
    Minnesota
    A few notes:
    The GTX 2867 exducer blades are much taller than the HTA 2868 blades. They are also slightly wider.
    I'm a little surprised that the 2867 compressor is marginally larger overall than the 2868 considering the stated exducer sizes in their product names (2867mm and 2868mm).
    The machining work on the 2867 is much finer than that on the 2868. It feels much smoother to the touch compared to the machining ridges on the 2868.
    I'll be getting the 2868 rebuilt by FP and hope to do back-to-back dyno comparisons of the two turbos to compare spool and power.
    I put the 2867 cover on the 2868 just to see if it would fit or if it would be an option for 2868 owners. The gap is less than a millimeter, but obviously tolerances here are very important. If I'm REALLY bored, I might try running the 2868 with the 2867 anti-surge cover at some point.
    Thanks Doug, for getting the reference
    Mar 19 2010
    Alameda, Ca
    looking forward to seeing results
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by bananas View Post
    No problem. Was stoked to see the reference so I had to provide.
    Will you be tweaking your softwere for each turbo on back-to-back dyno runs or keep the software alone but switch turbos? I prefer the later. Less variables the better story the data tells...
    -Doug
    Jun 13 2005
    Minnesota
    I plan to run the same software, but there will probably be at least a day between dyno runs to allow time to swap the turbo correctly. I suspect the two dynos will be very similar.
    Jun 21 2005
    Milton, Ontario
    How much boost are you planning to run?
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
    Jun 22 2009
    Dundalk, MD
    All the boost.
    Jun 22 2009
    Dundalk, MD
    Stanley Kubrick films kill it.
    Jun 13 2005
    Minnesota
    I'll probably dyno each turbo at each of: 20, 25, 30psi
    Oct 29 2005
    10speed
    San Francisco, CA
    You old sailor you! That info will be passed around on a bunch of forums, it's going to be extremely useful
    - Clint
    Dec 03 2005
    2 pedals 1FG
    connecticut
    What manifold are you using now-a-days?
    -Doug
    Jun 13 2005
    Minnesota
    Still running the cast iron T25 Treadstone (unfortunately still M8 too)
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Oh
    Yeah, that T25 is not quick to swap. I can probably swap my Treadstone T3 within an hour (once cool) because you don't have to remove the T3 from the car.
    -Doug
    Veteran Member Four Rings MmmBoost's Avatar
    Nov 29 2005
    10 A4 Avant S-line, 07 Suzuki GSX-R600, '69 VW Beetle w/ 1.9L aircooled turbo
    Edmonton, AB
    M10 that shit! ASAP!
    ~Chris
    I sold my Audis and bought a Touareg... Catch me over at Club Touareg
    My B6 Avant GT2871R build
    Tumblr
    "Robert Bosch don't fuck around"
    Veteran Member Four Rings nein-reis's Avatar
    Feb 01 2008
    MK6 GTI, MK1 GTI 1.8T, B7 A4 TE Avant
    SLC, Utah
    Quote Originally Posted by MmmBoost View Post
    This.
    -Tyler-
    Built 06A/IE Cams/IE 2.0 stroker/GT3076/6MTQ
    Dan Shank Super Tuned
    It was a fun run, but the time has gone.
    Established Member Two Rings RudeJude518's Avatar
    Oct 10 2010
    Albany, NY
    In for results!!!!
    Xbox Gamertag: Ya uraHERB soi
    Call of Duty when I can find time between work and taking care of the new baby.
    Jun 13 2005
    Minnesota
    I failed miserably. Don't have a press, so I tried using a hand drill. I ended up drilling each hole at a slight angle (maybe 3 degrees off). I suspect this will stress the studs enough that they'll break off.
    I ordered a Treadstone Stainless Steel T3 flange, which are pre-tapped for M10. I'll be porting my T25 exhaust housing a bit to better match the T3 manifold outlet. Sigh, more money down the drain.
    On a side note, I was shocked at how easy it was to tap cast iron.
    Jun 21 2005
    Milton, Ontario
    Damn, hand drill?
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
    Jun 13 2005
    Minnesota
    Also, got an email from FP today. The HTA2868 is rebuilt and on its way back to me with a new turbine wheel. Total charge $500.
    Sep 05 2010
    2001 A4 TQMS / 1993 RX-7 R1
    Have you set a dyno date yet? I'm really looking forward to seeing the data.... The question of HTA2868 vs. GTX2867R has been on my mind for a long time!
    Jun 03 2009
    Sweden, north
    Im also very interesting in your comparation, I would LOVE to see a log from the dyno pull(s).
    These two turbos are in my opinion the best matches to the 1.8t(along with the smaller framed EFR's, but those arent really attainable).
    Active Member Two Rings DCarver75's Avatar
    May 20 2012
    2001 Vw New Beetle
    Henderson, Nevada, 89015
    Im planning on running bigger turbo eventually i have the ko4 upgrade from the k03 what else would be necessary besides rods?
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by DCarver75 View Post
    Everything else?
    - Clint
    Sep 05 2010
    Quote Originally Posted by Bische View Post
    +1 Data logs would be fantastic. EGT, mass airflow, charge air temp, etc. (all data normalized to Dyno RPM would also be a huge plus) kind of a lot for us to ask for, but it would be damn interesting to see.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Have a machine shop face the T3 flange and the exhaust manifold flange.
    Then do something like this: http://www.audizine.com/forum/showthread.php/422519
    and if you have a 38mm MVS w/g then weld on this adapter: http://www.atpturbo.com/mm5/merchant...egory_Code=WGT
    -Doug
    Mar 27 2005
    The Cold North
    A deep checkbook.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Jun 10 2010
    Nicosia
    If you interesting on anti-surge housing for 2868 let me know ! is a company in uk that can do it for you ! ! i manage and take one :)
