Results 1 to 28 of 28
    Senior Member Two Rings lorge1989's Avatar
    Jan 27 2012
    Buffalo
    Swapping B5 S4 seats into an B5 A4 (pictures and install)
    This topic seems to come up a lot and I've yet to see a complete write-up on it. So here it goes.
    Vehicle Info:
    2000 Audi A4 1.8T Quattro
    Non power, but heated seats
    WHAT I NEEDED TO BUY:
    Seats (complete)
    Connector and wiring (for each seat) to get power to the seat motors
    Hardware
    My original drivers seat was busted up pretty good from the owner before me, so I found a set of S4 leathers for a fair price and jumped on them.
    First things first, removing the old seats.
    Both the passenger and drivers are the same. Remove this 'pin' type thing:
    IMGP5313 by lorge1989, on Flickr
    And then slide the seat all the way back on the track. Or to the right in this picture:
    IMGP5314 by lorge1989, on Flickr
    The side closest to the center console for each should pop out first then wiggle the other side out, be careful of the carpet. The seat can easily get caught up.
    NOTE: I undid my battery before starting. I didn't want any funny business with the airbags or anything so I would suggest whenever either of the seats have the connectors disconnected that you also have the battery disconnected.
    Here's a quick comparison, S4 seat bottom:
    IMGP5319 by lorge1989, on Flickr
    My A4 seats, with heat and manual adjustments:
    IMGP5320 by lorge1989, on Flickr
    So clearly we see how the mounting points differ. The S4 seats have two fixed points up front and then sliders in the back. Your A4 will have holes in the floor where the S4 seats go, but the will not have the threaded portion that is directly under the hold that the seat bolts into. After ripping up some carpet you can see the mounting holes:
    IMGP5318 by lorge1989, on Flickr
    IMGP5317 by lorge1989, on Flickr
    I have solution for this that doesn't involve welding or putting a hole through the floor. We will get back to that later.
    In order to wire these up all you need is a power and ground for each seat along with pins to add them to the existing connector in the car. For my car there were three connectors. Yellow, green and red. The red was the only one that changed (this is for the new to my car power seat function). On the passenger side there was no red connector to start and on the drivers I was missing two wires.
    Here's what the passenger should look like when finished. (hard to see, but the top right in this pic is ground and the bottom left is power)
    IMGP5328 by lorge1989, on Flickr
    This is what the drivers side looks like. (note pins 1 and 2 were existing, I added 3 and 4)
    IMGP5327 by lorge1989, on Flickr
    Now make sure you have enough slack in the connector wiring so when you move the seat you don't rip stuff up. At least as much as shown below:
    IMGP5322 by lorge1989, on Flickr
    Next after you get the wiring out of the way is to start mounting up the seats.
    I don't really have any efficient way of getting the nuts welded in but I think I have come up with a decent solution. On the S4s there are two allen bolts holding each seat in. I went to the store and picked up some high grade ones that look exactly the same.
    Then some fender washers, regular washers and nuts. What I plan to do is cut a small slit in the floor crossmember allowing me to feed in a 13mm wrench and the associated nut onto the bolt. I believe this will give me enough strength in any type of car accident or the like.
    The minimum tensile strength of Class 12.9 Metric bolts is around 1220 MPa. A good estimate of shear strength, since not tested in bolts directly is about 60% of the tensile strength.
    Therefore multiplying a few things out we get a max tensile strength on a M8 bolt like this is 61300 N. The shear strength is then 36800 N. Converting that to lbs we get 8300 lb capability in shear. Considering that I have two of these per side I believe they should be okay.
    For example to shear one of these bolts you would need:
    F=ma
    Where F = 36800 and m = 250 lb = 115 kg (a little less but you get it)
    36800 N = 115 kg * a
    a = 320 m/s^2
    or a deceleration of 40 m/s to 0 m/s in .125 seconds.
    That's a crash speed of 90 mph. And that is for one bolt. For two bolts you get double the strength so the acceleration would be double resulting in a crash speed of near 180 mph, coming to rest in .125 seconds. Also a 250 lb mass working only horizontally on the bolt is very unlikely. If I had to guess for me, weighing about 150 lbs the lateral force during a crash would be right around my body weight. This is because you have other supports for yourself and the seat other than the two bolts. (Airbag, you hands on the steering wheel, your feet on the floor, the sliders in the rear of the seat, friction everywhere etc. )
    That being said I am confident the bolts will not fail. The steel you are putting the bolts through is also to be questioned. But with the amount of material present and the fact that the S4 uses nearly the same design that should be fine. The calculations for such strength is bit more than I want to do right now.
    At first I was going to what I said above.
    But soon realized it was easier to cut out the part of the floor that had the hole for the S4 seats, shown above, weld a nut on the bottom, and re-install.
    It was kind of a pain but IMO there is no great way of doing this. A nutsert will work IMO, and will hold up to any load it will see. Or at least you will have much larger issues before you make that fastening point fail. Most people don't realize that the force in a crash in not 100% horizontal and much of the for impacts other fastening points, AKA the rails in the back first.
    Anyways....
    Another thing to be done before you can mount your seats, is the front pin support (for manual seats) will need to be chopped off in order for the seats to mount in properly. This will prevent you from going back to your stock seats!
    I think the switches on my seats are broken, WTF. I don't get all functions working on both seats.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    How are you going to slide the seat back and forth with the slider mount in the way in the front? Many others including myself have had to cut off that center mount for the seat to slide.
    Also, please specify what year/model your car is.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings revolution337's Avatar
    Apr 03 2009
    4.2 A4, 82 Vanagon, Mk7 Sportwagen
    Pennsylvania
    Quote Originally Posted by biketsai View Post
    count me as one of those people
    Life is too short to drive ugly cars.
    Forum Moderator Four Rings Gumby's Avatar
    Sep 06 2008
    Bellingham, WA
    i still need to cut the brackets out on mine, thankfully i'm tall enough to reach the clutch peddle.
    i'm also curious what year your car is. when i installed mine everything was plug and play.
    -Matt-
    B5 S4, B5 A4 Moderator
    2871r'd 2001 A4 1.8t Build thread
    You may think I'm not online. But I'm always here. Even if I'm not posting. I'm always here. Scrolling. Judging.
    Veteran Member Four Rings NeedingAnAudi's Avatar
    Mar 16 2009
    99.5 A4 4.2QM, 01 Nogaro RSFaux Avant, 15 Q7 TDI Sport Edition
    Valparaiso, IN
    Quote Originally Posted by Gumby View Post
    You have the wiring already?? Damn 01s
    Brilliant Black 99.5 A4 Project V8
    Nogaro Blue 01.5 S4 B5 RSFaux
    Glacier White 15 Q7 TDI Sport Edition
    Poopoo Brown 80 5000s Diesel
    Audi R8 certified technician - PM for work local to Chicago/Northwest IN
    Alex
    Senior Member Three Rings SIMPLXA4's Avatar
    Aug 09 2009
    97 Audi A4 1.8T
    Utah
    Subscribed as I will be doing this very soon.
    Sep 06 2008
    Bellingham, WA
    Quote Originally Posted by NeedingAnAudi View Post
    i had heated sport cloth seats originally, so everything plugged right in. the only thing i had to do was make the mounting holes for bolting them in.
    -Matt-
    Jun 04 2007
    Austin/DFW, TX
    X2. IIRC, it should definitely be plug and play for 2000's as well.
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Three Rings SS92's Avatar
    Jul 11 2011
    2012 2.0T GTI
    Charlotte, NC
    They are. Just had my seats out to put sport cloth in.
    2000 B5 A4 1.8T ATW GT2871r, Unitronic/Maestro tune, RaceTec FMIC, etc... - > FOR SALE
    Veteran Member Three Rings Brrman's Avatar
    Indianapolis
    where the heck do you guys find the seats, ebay and classifieds I guess? My 2000 a4 seats are torn to shit and I would like to replace them as well.
    2019 S4 Prestige
    RIP... 2013 A4 Allroad
    SOLD 2007 A4 2.0T S-Line Ti (APR stg1, Koni Coilovers, LED Tails)
    SOLD. 2000 A4 avant 1.8T (GIAC stg1, Bilstein/H&R)
    RIP... 1998 A4 1.8T (GIAC stg1, Bilstein/Neuspeed)
    Jul 11 2011
    2012 2.0T GTI
    Charlotte, NC
    Quote Originally Posted by Brrman View Post
    Tons of classifieds. Lurk the shit out of them. Vortex, local, audizine
    Jan 27 2012
    Buffalo
    Post updated with some more information, getting back at this shortly.
    I most likely will have to cut the original slider bracket
    And I found these for sale locally (Buffalo, NY). I believe there is another set floating around as well.
    Mar 16 2009
    Valparaiso, IN
    Wait. Did you have the wiring for power seats also? I have all the other wiring already.
    Alex
    Sep 06 2008
    Bellingham, WA
    Yep, I didn't touch a single wire, just plugged it in and everything worked.
    -Matt-
    May 16 2008
    South Texas
    The nut plate for the front seat mounts in cars with power seats is reinforced, so I would try and mimic that structure in the event your involved in an accident. Don't want a seat occupant plus 80 pounds of seat flying forward into the steering wheel or windshield.
    Jan 27 2012
    Buffalo
    I agree, I haven't made any final decisions yet.
    Jul 04 2012
    Opel Corsa C
    Cluj-Napoca, Romania
    lorge1989, I have just bought a nice set of fully electrically opperated and heated leather seats for my audi A4. And the problem I came upon is the same you had. My seats are manuals, and the seats I bought are automatic. So I find myself in the same situation you were. I also have the 2 holes needed in the chassis, nut I am missing the threaded portion for the bolts. So one idea, just like you mentioned, would be to weld a nut and than install them. By the way, I would really appreciate it if you could post couple of pics about how you did that, and how it finaly came in place. Another idea that came into my mind is: What if I use a bolt having a bigger diameter(maybe equal to the hole's), that would force its way through the seat and through the hole in the chassis.
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    I made a thread on this as well in case anything in here wasnt covered.
    http://www.audizine.com/forum/showth...-seats-into-A4
    Active Member Two Rings RyanMedina's Avatar
    Jul 05 2014
    Boston
    Does anyone know what size bolt to use? I'm planning on trying a nutsert so I don't need to cut a hole.
    Oct 30 2009
    Miami, FL
    Quote Originally Posted by RyanMedina View Post
    Don't use a nutsert and don't cut a hole. From the factory there's a just a threaded steel plate on top of the bump in the floor. I don't know where this whole "it has to be flush with the floor" thing started because it's not even like that from the factory.
    2018 S5 Coupe - stock for now
    Jun 04 2007
    Austin/DFW, TX
    It is not threaded if you have a 1.8t. I used nutserts. Hammered the sharp edges in after drilling tiny holes for those and then welded.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    yeah, 1.8's are not threaded. I just used nuts that I welded on. Kinda sucked because I had to spray a bunch of water on the carpet, but I managed to get it done without starting a fire.
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Sep 07 2010
    NC
    Great write up... but no one gets into the airbag plugs. I have a preface a4 and my airbag plug has 2 wires and the s4 has 3. and the harness is different.. please help.. i don't wanna blow shit up... everything else is done.
    Nov 30 2013
    United States
    Can anyone with an s4 confirm that the seats work without the ignition turned on?
    I'm swapping seats into a 98.5. Apart from the airbag wiring, 12v line needs to be run to the seats. I'm hesitant to run a direct 12v line in case it drains the battery
    Nov 30 2013
    United States
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Yes, the seats have constant power. I do not have an s4, but the 01 a4 wires are the same.
    The seats will only drain when the power seats are operated. I let my car sit all week and it fires right up
    2000 S4- Working?
    Nov 30 2013
    United States
    'Preciate it. I'll post up what I've done for wiring for the pre-facelift
    Nov 30 2013
    United States
    Here is a much better explanation of the wiring for the red connector on the s4 seats
    and a decent explanation of wiring the s4 airbag connector
