Results 1 to 13 of 13
    Established Member Two Rings jacobaudi's Avatar
    Dec 07 2013
    Audi A4 2.8Q 00 Audi S4
    Ny
    S4 seats into a A4 need help with airbag wiring
    I picked up some 2000 s4 seat to put into my 98 Audi A4 but the wiring coming out of my car is 2 wire airbag hornet now the s4 seats are 3 wires hornet blue,black,brown with white stripe. I really want my air bag working back so do any body out there knows how to wire up the 2 pin into the 3 pin for my airbags to work
    May 20 2010
    By "hornet", do you mean "harness"?
    Dec 07 2013
    Ny
    Harness sorry
    Dec 07 2013
    Ny
    Ok the wire coming out from my car is yellow with blue stripe and the other one is yellow with purple stripe I believe
    I traced the 3 wires coming out of the S4 seats and the brown and white lead to a ground to the Seat airbag Metal the other two wires are blue and brown wires leading to the air bag so which 2 wires join together to the yellow and blue and yellow and purple
    May 20 2010
    Sorry--It just really bothers me when I see simple automotive terms that are spelled incorrectly. Break instead of brake is the biggest offender.
    Anyway try sorting through these and PM some of the folks that have information. One knows the wiring, and others say to get the harness from the S4 that will hook in below the steering column.
    http://www.audizine.com/forum/showth...-seats-into-A4
    http://www.audizine.com/forum/showth...otorized-seats
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    haha. you know what bothers me and its not misspelled? when ppl call dampers shocks/shock absorbers. I know thats what most ppl were taught, but its wrong. dampers dont absorb any shock, the springs do
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    May 20 2010
    Agreed. I mean, dampers do exactly that--damp. Without them, you'd be continuing to bounce crazily your whole time driving.
    Nov 07 2010
    South of Heaven
    I am running mine the other way, I have the 1998/1999 sport seats in my 2000 A4 which had 3 wire connectors and the earlier seats which had 2. Look at the wiring diagrams for both cars and you will find the later cars have a shield and then the exciter wire and the ground for the air bag. All you need to do is to use a different connector on the car or the body or you need to splice the wires from the seat to body.
    When there is a problem in the connector and the air bag is on for the seat air bag the factory repair is to cut the connector out and crimp it with high quality crimps so you can do it this way. I bought the seat side air bag connector from the newer cars and then swapped this out with the old style plug that was currently on the seat. I just moved the two air bag wires over to the new style plug and ignored the shielded wire which is not used. On your car you would do the opposite, transfer over the air bag wires and just ignore the shield wire and either cut it off or seal it up and zap-strap it aside. You can buy the connector from ECS like I did or find a used one to make it plug and play or you can go the crimp route.
    This is my new style plug on the other seats....
    - 2000 Audi A4 QTM
    - 1994 Corrado VR6
    - 1991 Jetta G60 Coupe Syncro
    Dec 07 2013
    Ny
    Quote Originally Posted by Corrado_Guy View Post
    I wish it was that easy.. Now forget the shield wire..... The two airbag wires that are coming out of the car are different colors than the s4 seats
    Nov 07 2010
    South of Heaven
    I used the wiring diagrams to identify each of the wires from both cars and then matched them that way because my wire colours did not match either.
    - 2000 Audi A4 QTM
    - 1994 Corrado VR6
    Dec 07 2013
    Ny
    Is It possible that you can match my wiring for me? I will be greatly Appreciated if you can do so
    Dec 07 2013
    Ny
    Bump
    Dec 07 2013
    Ny
    Ok just an update I got my both s4 seat wired up meaning the airbag and most of all no airbag light :.)
