Vendors say coming soon, i say now :) I have been working with an az vendor making sure that this is a worthwhile upgrade and is a user friendly mod so i will not be posting all the details yet.But will give you my impressions.
Best part so far is that you do not have to unbolt the coils now to get to the plugs or dont even have to loosen the inlets! Just pop the plug out and you can get to the plug also without removing the adapter.
There is a lot of wiggle room with the adapters im testing with, so i dont see any reason the coils will crack.
**Link to xmoox's writeup where he soldered in everything: http://www.audizine.com/forum/showth...-Solder-method
Now back to finish the wiring so i can test these things out.
Updated schematic :
You can use the existing ground for both ground pins if you like. (No need for separate grounds like the original(rev1,2) schematic, it is fine if PIN2 and 4 are connected together on the new coils.)
Rev 3 schematic:
http://img194.imageshack.us/img194/8...nfinkcrev3.jpg
To break it down easier:
!! NOTE:Both Banks of ICMs have the same color wires, do one at a time so you dont mix them up or your car will not start!
Bank 1 (Cylinder 1,2,3 ICMs)
4 Wire plug - Grey/Yellow (Pin 1) goes to 3 Wire plug Brown/Grey (Pin 3)
4 Wire plug - Pin 2 Brown Unused
4 Wire plug - Green/Grey (Pin 3) goes to 3 Wire plug Brown/Green (Pin 2)
4 Wire plug - White/Green (Pin 4) goes to 3 Wire plug Brown/Blue (Pin 1)
Bank 2 (Cylinder 4,5,6 ICMs)
4 Wire plug - Grey/Brown (Pin 1) goes to 3 Wire plug Brown/Grey (Pin 3)
4 Wire plug - Green/Brown (Pin 3) goes to 3 Wire plug Brown/Green (Pin 2)
4 Wire plug - White/Brown (Pin 4) goes to 3 Wire plug Brown/Blue (Pin 1)
Coils:
New 4 wire plug (Pin1) - Red/Green on s4 harness
New 4 wire plug (Pin2) - Brown/Yellow Ground on s4 harness
New 4 wire plug (Pin3) - brown w/(blue, green, grey,) stripe on s4 harness
New 4 wire plug (Pin4) - Brown Ground on s4 harness
Additional diagrams from Congtatulati0ns:
Rev 2 schematic if you want to use separate grounds:
http://img515.imageshack.us/img515/2...nfinkcrev2.jpg
Here is the parts list that i used.
06E905115E 2.07T coilpacks x6
034 Custom coilpack adapters x6 http://www.034motorsport.com/ignitio...v-p-22336.html
For the Coilpack 4pin connectors you have a few options:
1J0971658L is a complete harness repair for the 1.8t, it has 4 connectors on it so you need x2
also 1J0971658M is the same harness wired a tad different (same or cheaper, price but the other may be out of stock)
http://www.ecstuning.com/Volkswagen-...arness/ES7679/
http://www.ecstuning.com/ES2089862/
Buying the harness above is way cheaper than ordering the pins seperate and the 4 pin connectors. (edit, it is now cheaper to buy the connectors)
Cheapest place so far for 6 connectors ~$53
http://www.onlinewholesaleparts.com/vwicc-004.html
or amazon http://www.amazon.com/2011340-Igniti...ords=1J0998724
4B0906102 is the part number for the boots if you do not want to use your old ones. x6
4B0973724 is the part number for the 4 pin connector housing. x6
00979133A is the pins for the connector with a short pigtail of wire, comes with 2 so you need x12
For the ICM delete harness, why no one could find the male connectors, is cause they are a Volvo part :) Yes it took me awile to find them.
**UPDATE, if you plan on never going back, i suggust just cut and splicing the wires together for a much cleaner install.
978161 is the 4 pin connector x2
978157 is the 3 pin connector x2
978298 are the pins x12
970773 are the insulators if you want to use them x12
*** New information has come out, that you can use adapter plates off a Touareg for the coils instead of the billet adapters.
part 077 905 390 You need Qty 6 and run about ~$5ea
http://www.audizine.com/forum/showth...o-spend-5-FATS
