Results 1 to 40 of 67
    Veteran Member Four Rings CaSp3r9's Avatar
    Nov 30 2005
    Tools and toys
    Los Angeles, CA
    FINALLY after an hour of searching I found someone with the same problem as me! Did you ever figure out what was making the sound? It's driving me insane.
    I have a 2006 2.0t 6MT, the rotational metallic-like clicking only occurs when decelerating (in all 6 gears) and when the revs are dropping if out of gear. When decelerating in gear, it takes 1.5 - 2 seconds for the noise to start - seemingly when the fuel injectors shut off. It goes away when I get back on the throttle. Could it be related to the low pressure fuel sensor?
    Codes stored:
    P2004 - Intake manifold runner control bank 1, intermittent
    P0642 - Sensor voltage circuit A, low voltage
    - - I'm told to check the manifold pressure/boost sensor(G31), Intake manifold position sensor(G336), Low pressure fuel sensor(G410), and ECM software version.
    TIA
    1998.5 A4 1.8tqms, Sold
    2006 A4 2.0tqm
    I have a VAG-COM if anyone in the Santa Monica area needs it.
    Junior Member One Ring
    May 17 2010
    San Diego
    Does it sound like a bike sprocket? Or a card in spokes?
    Sep 27 2008
    Phoenix
    My problem ended up being a blown DV. I'm not sure if any codes were being thrown but I didn't have a CEL.
    Nov 30 2005
    Tools and toys
    Los Angeles, CA
    Kinda like a card in spokes but higher pitched and more metallic sounding. It's weird. I'm banking on a fuxed dv cause that was woot's problem, our descriptions match and I'm flashed with APR so it makes sense...
    2006 A4 2.0tqm
    May 21 2007
    Florida
    Quote Originally Posted by pdub View Post
    i get the "card in spokes" sound when rolling under 20mph...what is that? 85k miles
    2018 Navarro Blue Q5
    Established Member Two Rings B8-A4's Avatar
    Apr 05 2013
    PA
    lol so you dont have to read the thread, the sound is due to either a bad n75 valve, or the busted diverter, also the DV valve actuator could be getting stuck, which would end up being a turbo replacement.
    Quote Originally Posted by doublezero30 View Post
    Veteran Member Three Rings Homer's Avatar
    Jan 27 2010
    2006 A4 6MT Quattro, 1990 Volvo 240 Turbo
    Bay Area
    Quote Originally Posted by B8-A4 View Post
    Or the wastegate actuator arm being sticky. That's what ended up being the problem on mine. I've put on ~ 50k miles in the past 2 years on the new turbo. No issues since the dealer replaced the turbo.
    -Jacob
    1990 Volvo 240 Turbo-Project Car
    2017 Audi allroad prestige
    Sep 25 2014
    1941%20dodge%20pickup%20prostreet%2C%20100hp%20big%20bore%20kit%20Polaris%20650%20triple%20in%20a%20
    Vermont
    hello, i have a 2005.5 manual.. i have the bike sprocket noise.. what is the problem?! no codes but it drives me crazy!
    Jan 08 2011
    Texas
    Quote Originally Posted by CaSp3r9 View Post
    TIA
    I have the same noise. like a clicking.
