Issam,
Since we have to use the S4 ECU to run the dash, is there any way to program the stock ecu so the dash board doesn't look like a Christmas tree?. And also, is there a way to program the ECU so that we go for inspection, it passes?
Meaning..
I've heard of some software tuning out the O2's, but is there a way to tune out the sensors that would normally fail in inspection being that were swapping in the Vr6 and no longer running the 2.7tt
Like I'll run the stand alone for the motor, but is there a way to trick the ECU into thinking there's a perfectly running S4 motor running that can pass inspection computer?
Again, thank you for your time. Its very much appreciated.
