Page 6 of 40 FirstFirst ... 4567816 ... LastLast
Results 201 to 240 of 1581
  1. #201
    Veteran Member Four Rings NYEuroTuner's Avatar
    Oct 24 2008
    "Silvaro" B5 S4, 2013 B8 S4, 2018 RS3
    Re: *** OFFICIAL VR6 -12V & 24V FAQ and Info sharing ***
    Any updates on a Harness>?
    -- George
    SEMPER FI
    Build Thread--------------->My VR6 Journey<-Click it, Click it good.
    IABEDINDUSTRIES
  2. #202
    Active Member Four Rings nthusiastt's Avatar
    Oct 27 2008
    B5 S4 Avant
    Is it possible to make 800-900 comfortably with this motor?
    They want you afraid of your neighbors, your community, your family, your ability to support yourself, terrorists, climate change, China, Russia, Covid. As long as you are afraid, and won't unite red or blue, they win.
  3. #203
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Quote Originally Posted by nthusiastt View Post
    Yes.
    http://www.eurotuner.com/videos/6203...008/index.html
    http://www.youtube.com/watch?v=WJZRiCL79rw
    http://www.youtube.com/watch?v=J3g5a0HFeMo
    Jim
    I Do Werk.
  4. #204
    Veteran Member Four Rings Big Boost's Avatar
    Jan 28 2008
    S4VRT
    Milwaukee, WI
    A well built VR6 can support 1000 crank HP, while a stock one should be able to support 500-550 crank HP. Others have produced even more on the stock block. Rods, pistons, ported head with big valves are the foundation for power on the VR6. Expect to spend north of $6K for a built engine.
    2015 Audi A3 Stage 3+
    2001.5 Audi S4 VRT
  5. #205
    Veteran Member Four Rings revhards4's Avatar
    Feb 14 2004
    Michigan
    So what oil pan has to be used with the 24v VR6? Or do you modify the stock one somehow?
  6. #206
    Oct 24 2008
    Quote Originally Posted by revhards4 View Post
    I believe the VW Touareg oil pan.
    -- George
    SEMPER FI
    IABEDINDUSTRIES
  7. #207
    Jan 28 2008
    S4VRT
    Milwaukee, WI
    Quote Originally Posted by NYEuroTuner View Post
    That's the right oil pan, but Dan @ 034 mentioned that it needs to be modified to clear the crossmember with the 12V or 24V. I'm trying to find out what the mod is and will they do it if I buy it from them. I know it involves cutting and rewelding a section out of it and that's all.
    2001.5 Audi S4 VRT
  8. #208
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    We supply the correct oil pan needed and infact we have a pan out there that does NOT require any modification of the subframe.
  9. #209
    Jan 28 2008
    S4VRT
    Milwaukee, WI
    Can you post how much it is or PM me? Thanks. It's getting closer.........
    2001.5 Audi S4 VRT
  10. #210
    Established Member Two Rings 04/01-s4's Avatar
    Jul 28 2009
    01 s4,03 1500hd,2006 FXSTI
    Bloomsburg PA
    Wow, This single post made me finally subscribe to audizine. I love the fact of a timing chain over a belt and an engine bay I can work in.
    Will an adjustable fuel pressure regulator for the 2.67 motor fit on a vr6 rail? if the housing is even built onto the rail? im new to vr6 engines but not new to auto mechanics and doing some really wild shit on motors. I ask the FPR question because I was about to drop a few grand in parts (some allready $$) for my build up that I JUST rented a 20x20 garage for. Now I've gotta cancel a few orders and other things with the machine shop....This forum saved me some major time/$$ allready. With that cramped bay I never even considered an engine like that.
    Im definatly going to be doing a major buildup of this engine and just spent the last 3 hours researching shit. The ecu problem still confuses me but hopefully 034 will save the day on that one. My power/$$ aspirations have completely changed. Btw im located in yuma arizona, feel free to get in contact.
    2006 HD FXSTI
    2003 silverado 1500hd 4x4 (DD)
    2001.5 s4 / 034 STK conversion in process
    TIA certified
  11. #211
    Veteran Member Four Rings will175's Avatar
    Apr 25 2007
    Las Vegas..Hawaii..Nor Cal
    ^^^I am in the same boat as you but I am already Stg3. I have been searching/learning more about the VR, boost the VR, and this swap for the last few nights. I am still trying to figure out about the engine management also.
    Train Hard, Go Hard, But always be Humble.
  12. #212
    Jan 28 2008
    S4VRT
    Milwaukee, WI
    Quote Originally Posted by 04/01-s4 View Post
    I just purchased the 034 stand alone stage IIc ECU, harness, and relay board. 034 will need to know what size injectors you're using, the type of throttlebody you'll install, the location where you plan on installing the ECU, and a few other questions. Pretty much it's a plug and play affair. You just will need to connect power, ground, and a 12V switched source.
    2001.5 Audi S4 VRT
  13. #213
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    This is beginning to appeal to me, for a new project car (not my current one).
  14. #214
    Jan 28 2008
    S4VRT
    Milwaukee, WI
    Here are some pics of the 034 TIme Attack car that features the build up. Christian Miller at 034 sent me this link. I found this very helpful in figuring out what mods need to be done. Every installation will be different, but this can provide some guidelines.
    2001.5 Audi S4 VRT
  15. #215
    Feb 26 2006
    Earth
    Quote Originally Posted by Big Boost View Post
    Glad I could help out
  16. #216
    Oct 24 2008
    Issam, PM
    -- George
    SEMPER FI
    IABEDINDUSTRIES
  17. #217
    Jan 28 2008
    S4VRT
    Milwaukee, WI
    Quote Originally Posted by Issam@034 View Post
    Much appreciated. For those of you who don't know, Issam is the OWNER of the Time Attack car. He would know firsthand what the swap involves and all of its secrets......(hint hint);)!!
    2001.5 Audi S4 VRT
  18. #218
    Feb 26 2006
    Earth
    Issam, PM
    PM replied again
  19. #219
    Oct 24 2008
    PM replied again
    haha I am driving you nuts.
    -- George
    SEMPER FI
    IABEDINDUSTRIES
  20. #220
    Feb 26 2006
    Earth
    Small price to pay
  21. #221
    Senior Member Two Rings Mrsfourrings's Avatar
    Jul 31 2007
    2001.5 E85 STG 3 S4 Avant 1993 Corrado VR6
    How long until an 034 harness is available?
  22. #222
    Jul 30 2009
    1981 Euro URQ, 87 4000vr6
    Vegas
    a lot of good information here Issam. When you said earlier that the 12v v6 guys had it easy, is it that easy to retain the obd2 stuff required to pass emissions and keep tachs/trip computers and such? Care to expand upon that topic a bit more? I will probably call you with a few more questions, but I figured it is good information for the community...
    BTW, this is my first post on audizine. I signed up purely for this thread. For those who dont know me, My name is Hank and I am addicted to fast things.
  23. #223
    Apr 25 2007
    There should be an update on the first page with all the new info on this swap. Thanks again Issam for all the help.
  24. #224
    Feb 26 2006
    Earth
    Quote Originally Posted by will175 View Post
    Ill probably update the first post with packages and pricing in the near future.
    Quote Originally Posted by URHank View Post
    Hey Hank,because the 12V V6 harness is very similar to the 12V VR6 harness in terms of what connectors are on it and such.
  25. #225
    Jan 28 2007
    dallas TX
    has a swap for the b6 chassis been tried before???
  26. #226
    Feb 26 2006
    Earth
    Quote Originally Posted by ImageX View Post
    Yes
    not completed yet
  27. #227
    Jan 28 2007
    dallas TX
    What would be that much different on a b6 chassis compared to the b5??
  28. #228
    Established Member Two Rings biglou's Avatar
    Oct 27 2008
    2001 Audi A6 , 1998 BMW M3 cab
    home
    Yes
    not completed yet
    wuts the difference between the two
  29. #229
    Feb 14 2004
    Michigan
    damn, a B6 or B7 with a 600hp boosted VR would be the ultimate!
  30. #230
    Veteran Member Four Rings dubenvy's Avatar
    Oct 21 2006
    '14 A4 2.0tQ (wifey)
    Odenton
    when my Audi gets retired from daily driver duties, hopefully the B6 solution will be finished and it's game on for the avant.
    USP CLUB MEMBER #41
    <<Insert Clever Signature Here>>
  31. #231
    Veteran Member Four Rings s2the4's Avatar
    Nov 02 2006
    01 Stage 3 S4 Silvaro, 01 S4 Avant Nogaro
    Western Mass
    6K? I just checked Schimmel's built 3.0 VR6 motor price and it was $4000. 6K is a HUGEEEEEEE stretch. I call b/s!!!!! break that 6 K down if you don't mind.
    |MRC-Tuned Stage 3| | RS4 K04 Turbos | | RS4 Y-Pipe | | RS4 Airbox | | RS4 Fuel Pump | | 60lb Siemens injectors | | ER SMIC | | APR Bi-Pipe | | All JHM Goodies | Vogtland GT | | Porsche 993 TT Brakes | | 034 Motor & Trans Mounts|
    ...For now
    417whp @ KTR Ayer, MA 110 octane with open dumps
    clicky
  32. #232
    Veteran Member Three Rings mys4.org's Avatar
    Dec 18 2007
    2013 S4 | 2013 Q5 3.0T
    PNW | Monroe, WA
    The fact that the 12v VR6 still has timing chains vs. a belt I would not recommend for any one to swap from something with a belt to chains. The timing chain problem has been notorious in the 12v VR6 world. Unlike a belt which you can easily take a look and see how the belt looks... timing chain (and guides) is nearly a half day of just to see if they are ok or not. No thanks. That's main reason I traded my MK3 97 Jetta VR6 for a B5 2001 S4.
    Yes I love the sound of the VR6 and I miss it bad but really how often are you going to need the extra room to swap your turbos out? To do all the work for a more space seems like a waste even if it slightly cheaper for the amount of power... We also need to keep in mind most emission standard make it illegal to swap in a older engine in a newer car. I know it is here in Washington state. Correct me if I'm wrong but I'm sure most people are just going to be doing this for a track only car.
    I love seeing people trying new things but this might be going in the wrong direction.... that's just my $0.02
    MyS4.org | B8.5 2013 Audi S4: EPL Stage 2, Solo-Werks Coilovers | B8.5 2013 Audi Q5 3.0T: EPL Stage 1 & ZF Tune | Instagram: mys4dotorg
  33. #233
    Nov 02 2006
    Western Mass
    Yes
    not completed yet
    So Issam, is the b5 cluster integration with the 034 EFI system something of the near future? Wouldn't you need to run a MK3 cluster to get it to work? or has anyone figured out the wiring to integrate the existing cluster?
    ...For now
    clicky
  34. #234
    Active Member Four Rings NYCVR6's Avatar
    Queens, NYC
    Quote Originally Posted by mys4.org View Post
    Ive seen vr timing chaine go for over 200k no problem. I had a jetta with 178k on it with original timing chain.. If you're swapping in a motor, might as well do the chains and guides anyway, save yourself the headache.
    Justin- 01.5' Pearl S4 24V VR6 Turbo Pow Pow
    034 Motorsport
    FFE Racing
    MoTec
    Tuned By Shane T
    Boost Factory!
    Drive your car, not your dyno sheet
  35. #235
    Feb 26 2006
    Earth
    Quote Originally Posted by s2the4 View Post
    A MKIII cluster in a B5? No
    you would only need to convert to DBC and keep the stock S4 in there to keep the cluster happy
    all engine control is done with Stage IIc.This is how most of the 034 builds are done...the only reason people are not throwing themselves at this is due to emissions - if your state does OBD scans vs sniffer then you cant have standalone.
    Quote Originally Posted by NYCVR6 View Post
    fuck ....Got a 300K here still running
    Its a VR - treat it like shit and it will treat you like shit but NO WORSE than a 2.7TT.
  36. #236
    Oct 24 2008
    ^ lol
    I am currently doing this swap in my Daily Driven S4, and it will stay a Daily driven S4 when its finished.
    Other than that, please don't turn this thread into a 2.7tt vs Vr6.
    This is the Vr6 Swap FAQ Thread, not "state your opinion why this swap is bad thread"
    ;) Thanks.
    -- George
    SEMPER FI
    IABEDINDUSTRIES
  37. #237
    Jan 28 2008
    S4VRT
    Milwaukee, WI
    Whoa. You're calling B/S based on what? Please send me the link showing where $4K buys a built VR6.
    2001.5 Audi S4 VRT
  38. #238
    Queens, NYC
    ^ lol
    How far along with this swap are you since you're currently doing it?
    034 Motorsport
    FFE Racing
    MoTec
    Tuned By Shane T
    Boost Factory!
  39. #239
    Veteran Member Four Rings wdbdy2000s4's Avatar
    Oct 08 2008
    1998 pathfinder, 2000 s4
    MA
    I agree. Parts alone are going to cost you 3-4k. Plus the labor to balance everything, port the heads...it ads up quick with a VR6, just like any other motor.
    Frimmel: i only speak when i have something negative to say.
    Grah4m: i lost to a giraffe. be careful out there.
    ThirdStrike:leave your feelings at the keyboard
  40. #240
    Jan 28 2008
    S4VRT
    Milwaukee, WI
    Yeah, I was going to show him just how fast Ti retainers, valve springs, ported head, head studs, cams, larger valves, machining and other parts in the head alone adds up fast. I haven't even started on the block yet. You can have at least $2-3K in the head alone. What are you getting for $4K, just the shortblock or the longblock?
    2001.5 Audi S4 VRT
