Results 1 to 40 of 1065
    Veteran Member Four Rings absolutegtr's Avatar
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Re: DIY - B6 1.8t - Vacuum line and Check Valve removal/simplification
    Quote Originally Posted by 7speed View Post
    Hopefully my block off plate will be here in a couple of days. Shawn you wanna do another write up with your DSLR ?
    Aww come on now, the pics seriously arent that bad.
    Plus a DSLR wouldnt fit in some places!
    -Sami-
    Saint Cloud, Fl
    Quote Originally Posted by absolutegtr View Post
    it's just a ploy to get some help
    instagram ------------> low_enforcement
    Feb 19 2007
    Charleston, SC
    It really is very easy.
    In all honesty, I really didnt know 100% what I was doing when I started but, as I went along it all started to make sense, on what each system does and what to take off and what to leave.
    Those two links are crucial for you to read and then it all comes together!
    -Sami-
    Veteran Member Three Rings nihil's Avatar
    Oct 01 2007
    Too small
    N/A
    I've been reading this thread every couple weeks, and so far the only thing that has kept me from yanking all that crap out of my engine bay is the SAI CEL issue. The ECU has to get input from something to determine if SAI is operating correctly. I'd like to address this outside of the ECU firmware, as not everybody is in a position to go that route.
    I'm guessing this is not the case, but a resistor should work to convince the ECU that the blower motor is still in place (if it's using that as input). Otherwise it needs to rely on a sensor, or combination of data from other sensors, to trigger that CEL/code. What is the input that the ECU is using for the SAI system?
    2002 A4 1.8TQMS (sold)
    1982 MB Geländewagen 300GD
    1968 Charger R/T
    1987 Porsche 944 (sold)
    2015 Tacoma TRD/OR
    2007 4Runner
    2022 Tenere700
    2009 TW200
