Results 1 to 40 of 64
    Senior Member Two Rings arankaspar1's Avatar
    Feb 20 2018
    Oakland CA
    I was hoping to not have to buy a cooler. This giac tune is stage 3 but it's stills just a daily driver.
    1. Do you think the stock oil switch port would be big enough to use for the accusump?
    I went with the electric valve option.
    2. Do you know of a way to wire this to something that only happens before startup? I.e. fuel pump priming or maybe the check engine like hahaha.
    3. I installed that glow shift gauge but I used this banjo bolt adapter on the turbo feed line for the gauge sensor. I'm reading 12psi warmed up. Do you think it could be due to the location not being closer to the oil filter? Should I Tee into where the stock oil switch is?
    https://www.ecstuning.com/b-new-sout...o-port/con017/
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    Quote Originally Posted by arankaspar1 View Post
    Assuming its 12psi at idle.? What do ya have it 2k/3k rpms? Is it hitting 60psi by 3k? If so, and its only low at idle, could be bad piston cooling jets. If 2 or 3 check valves are shot(stuck open), it'll cause your idle pressure to drop.
    EDIT- didn't realise you did the 1.8t conv, when I commented. So many not be your issue..
    Sent from my LM-V600 using Audizine Forum mobile app
    Feb 20 2018
    Oakland CA
    No I never converted to 1.8. seems like way too much money. I'll just buy a new engine if this one goes. I would like to pre-oil before starting and so I got the accusump valve and about to buy a 2qt accusump piston.
    Feb 10 2012
    parts
    Napanee, ON
    Piston squirters need more pressure then accusump can output to spray the pistons. Don’t waste your money unless you’re going to a fully external cooler/oil filter change out to one that will allow the oil to flow into correct veins inside the motor.
    To pre oil buy one of the fuse plug ins that allows you to install a switch and fuse after the factory fuse. Kill the ignition fuse, turn the key and viola pressurized pre oiling for under $20.00
    https://www.amazon.com/General-Techn.../dp/B001TCXOTW
    Jan 21 2018
    frackville, pa US
    Quote Originally Posted by canadianA4B7 View Post
    How much pressure does the accusump put out? Don't think he's worried about having enough to open the cooling jets(1.6-1.9bar), just to get oil flowing. But could be wrong.
    Feb 10 2012
    parts
    Napanee, ON
    Quote Originally Posted by Jayz691 View Post
    It’s how the oil gets to the squirters through the galleries and how Audi balance shaft makes the pressure engine likes. The accusump “should” be set up to be just below operating pressure at idle 19 psi maybe it’s not there to oil the engine it’s only there to add a bit when needed (heavy turns, hard launches). It will not give you 5 min extra drive time, more like 30 seconds to a minute of oiling while the oil pump continues to push fragments of destroyed bearing through the engine.
    I’ve got a dry sump for the 2.5 swap. Gives me option to lower motor in engine bay, fabricated low profile oil pan and guaranteed oiling all the time. Few things audi missed with the balance shaft disaster in the 2.0
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    This.
    An accusump pre-oiler will do the job, and pressure can be set to 40+ psi, but it’s not really needed. They’re really meant for what Canadian highlights (starvation for whatever reason). Dry sump is the way to go though. Cough cough.
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
