Page 59 of 66 FirstFirst ... 9495758596061 ... LastLast
Results 2,321 to 2,360 of 2610
  1. #2321
    Established Member Two Rings reighnman's Avatar
    Apr 30 2017
    8S TTRS
    MN
    Quote Originally Posted by THCarpenter View Post
    maybe
    Funny I was just about to ask if there was supposed to be a splash guard in the center of the car since I was recently under mine and it looked like maybe something should have been there, but looking at this appears not.
  2. #2322
    Apr 26 2022
    Enon, OH
    Thank you 2k16A6. I am not sure which region that info is for but it doesn't match mine. If you look at this photo https://photos.app.goo.gl/TYuKgA7ue53kN5An8 you can see, all I have is what I previously posted...no reverse camera control module. So I have to assume it's located somewhere else.
    Any suggestions?
  3. #2323
    Jun 12 2019
    MK5 Rabbit 2.5 5spd
    Natick, MA
    Quote Originally Posted by anarchy1970 View Post
    Any suggestions?
    Unfortunately I don’t have any other suggestions as I’ve never been and deeper than pulling the small cover to access the emergency release for the fuel door actuator. I’m in MA so same region as you. You sure your car is 2016 not 2017? The manual on the last page I posted said that 2017+ the module is integrated into the camera itself and not independently replaceable.
    2016 A6 P+ 3.0T / Aviator Blue Metallic / APR Stage II Single Pulley 93 Octane / BG_SQ5 tcu / MercRacing hx v3 / Hartmann Rotor Reps 20x9 ET40 w/ 265/35-20 PS4S / 0-60 3.56 sec
  4. #2324
    Apr 26 2022
    Enon, OH
    Quote Originally Posted by 2k16A6 View Post
    The production date on the front door says 11/2015...at least I assumed that is the production date. I have seen very little info on the C7.5, most is C7 or earlier.
  5. #2325
    Veteran Member Four Rings hunter_killer's Avatar
    Mar 25 2020
    Mandan, North Dakota
    A thought came across my mind yesterday; does anyone here run filter socks on their air filters? I work in a pretty dusty environment at work and it’s fine dust. Having a CTS intake system, I don’t know how good the filters really are and I was wondering if the filter socks that modded euro has for these exact filters is worth getting?
    2013 Quartz Gray S6: APR Stage 1 and CTS intakes.
    Gone: 2013 S4 Stage 2. RIP.
  6. #2326
    Senior Member Four Rings THCarpenter's Avatar
    Jun 26 2021
    C7.5 S6 Prestige
    East Coast
    people are all up in arms over the K&N Filters not providing 100% protection.....you could up the filter membrane with a sock to have some more protection if you wanted to.
    2016 S6 Mythos Black / B&O, Cold Weather, Drivers Assistance, Black Optics
    2016 S6 Mythos Black / Sport, Cold Weather, Drivers Assistance, Black Optics, Night Vision
    "How to spend a shitload of money and still be slow, the THCarpenter story." - sepheroth86
  7. #2327
    Jun 19 2018
    21 Jeep Gladiator / 05 Tahoe Z71
    NH
    Quote Originally Posted by hunter_killer View Post
    I personally would 100% run a filter sock on any open-air filter, even if you didn't work in a dusty environment. OEM filters are slightly more restrictive and filter out smaller particles, with the assistance of the airbox to keep out as much dirt as possible, for a reason. I stuck with the upgraded OEM inlets and airbox for a reason and this was a big one for me (other being; keeping the OEM look)
    I'll gladly miss out on a little cooler sound and maybe 10-15hp any day of the week for the protection benefits
    2013 Q7 / Prestige / Mugello Blue Pearl
    2014 S7 Phantom Black on Black / B&O / DS1 ECU Stage 2 / SRM TCU tune / RS7 Inlets & Airbox / JXB Carrier / 034 Drivetrain Inserts / Cooling mods coming - SOLD
    2016 A6 3.0T / Premium + / Glacier White on Black / S-line / Sport Package w/ 20" wheels / No Mods - TOTALED
  8. #2328
    Mar 25 2020
    Quote Originally Posted by MattyMarkey View Post
    Never ran one before so wasn’t sure what it affected aside from help keeping out particles. I’ll be looking at getting a set of them then.
  9. #2329
    Jun 19 2018
    NH
    I would think they do limit some airflow compared to just the K&N, closer to a stock filter, but other than maybe a few horsepower, I think there would be only positive benefits IMO
  10. #2330
    Feb 21 2017
    St Louis
    Do I need to unplug my negative battery cable when installing new HPFPs? Seemed unnecessary to me
    2016 Mythos Black S6 | 20% Tint | APR Exhaust | DS1 Stage 1
  11. #2331
    Established Member Two Rings Johndep7's Avatar
    Mar 23 2013
    Suffolk, NY
    Is there any way to remove the rear side marker and replace with just a piece that's the same color as the body? My left marker went bad about a year ago, my mechanic switched it out for me while doing other work on the car and it seemed to be a nightmare..well more effort than there should need to be...it just went bad again and I really don't want to keep dealing with that. I assume removing it would probably throw codes but I assume I can disable that
  12. #2332
    Aug 14 2019
    Tampa
    Quote Originally Posted by Johndep7 View Post
    Yes you can disable those with vcds/obd11. I know you can buy painted ones to match body color, i think TAG sells them, not sure who else.
    18 S6
  13. #2333
    Mar 25 2020
    What’s a good way for the C7 chassis to crank the engine over without firing, just removing the fuel pump relay/ and or fuse? I’d like to crank the engine over a few times in hopes of oiling the turbos better than I did before firing up. (Thought the oil would drain down from the top to bottom, but it just sat there instead of draining when I filled up the cavity.)
  14. #2334
    Mar 23 2013
    Suffolk, NY
    Do a6 seats fit in an A7 (both front and rear)? (Same gen)
  15. #2335
    Sep 08 2021
    2013 Chevy Tahoe
    Philadelphia, PA
    Do the a6/a7 share the same shape door panels?
    …..lowkey like the a6 panels better and really like the rear shade for the kiddos
    Daily -2015 Audi A7 Prestige| 20% rear & 35% front 3M Ceramic IR tints|Custom Alcantara Starlight Headliner|
    Music, Real Estate, and Audi
  16. #2336
    Jan 31 2009
    2016 RS7-P
    6 and 7 seats physically fit in either model. 2 seat rear config needs to code out or resistor the buckle if it had 3 to begin with. A caveat with putting the 6 3 seat in the back of a 7 is child seat upper harness point won’t be there since the 6 mount points are on the rear deck and the 7 mount points are on the seat backs.
    Door cards for 6 and 7 are different in shape and mounting points. 6 rear door sunshade is supported by the window frame but the 7 is frameless.
  17. #2337
    Sep 08 2021
    2013 Chevy Tahoe
    Philadelphia, PA
    Quote Originally Posted by widebodyfx View Post
    So what you’re saying is i have to modify the rear panels and add em myself, got it
  18. #2338
    Jan 31 2009
    2016 RS7-P
    Yeah not a direct swap, I don't think the glass is anywhere near the same shape either so the assembly from a 6 may not do you much good. On my RS6 door cards the rear doors didn't have shades so have flush deck, but still have the catch at the top of the window frame.
  19. #2339
    Mar 23 2013
    Suffolk, NY
    Awesome response, thanks
  20. #2340
    Mar 01 2014
    1965 GTO conv, 05 Outback XT stage2ish
    Pa
    Built in radar w/ RS honeycomb grill. Anyone have a built in radar system and RS style grill? I have 2 sensors mounted on the original grill. They are unobstructed but with a honeycomb grill the sensors will have to be mounted behind the grill somehow. I would guess that the RS grill is going to block some of ability of the sensors. The cheap chrome plastic on my grill is bubbling and looks terrible.
    Sent from my SM-G990U1 using Audizine Forum mobile app
  21. #2341
    Aug 14 2019
    Tampa
    Quote Originally Posted by Maustin View Post
    Would plastic affect them at all I think is a good question to have answered. The RS grill would put relatively thin plastic bars in front of it, so I have to wonder would that even matter.
    18 S6
  22. #2342
    Mar 23 2013
    Suffolk, NY
    Does a b8 steering wheel work on a c7?
  23. #2343
    Jan 31 2009
    2016 RS7-P
    I don't know the specifics and there's a ton of hits when searching. B8 wheels are addressed a little in europrice's thread. https://www.audizine.com/forum/showt...ighlight=wheel
  24. #2344
    Stage 2 Banner Advertiser Four Rings
    Aug 07 2008
    Dallas, TX
    Unfortunately no. The B8 controls won't work on the C7 models.
    Thanks for the link and there's lots of info there and on the site itself. Just follow the links to the year/model range that works best.
    Cheers,
    Alexander van Gerbig
    www.europrice.us
    [email protected]
  25. #2345
    Mar 23 2013
    Suffolk, NY
    Quote Originally Posted by [email protected] View Post
    Cheers,
    Awesome, thanks for your help!
  26. #2346
    Mar 25 2020
    I noticed this the other day when cleaning my wheels that my drivers front brake rotor has a small crack in it but it’s seems to of come from an inside impact pushing outward. TBH I’ve never seen that before and wondering if anyone else has come across it.
    Sent from the howitzer using Audizine Forum
  27. #2347
    Jul 10 2021
    Nashville, TN
    2017 A7 -- steering wheel does not include seek forward/back buttons.
    With vcds/obd11, is it possible to re-program the gear paddler shifters to perform seek forward/back?
  28. #2348
    Aug 14 2019
    Tampa
    Quote Originally Posted by bosseternal View Post
    It is not.
    18 S6
  29. #2349
    Junior Member Two Rings regulartalldude's Avatar
    Jun 02 2021
    Philadelphia PA
    I'm getting a check engine code (P013C; 02 Sensor Slow Response - Rich to Lean Bank 2 Sensor 2)
    This is right after installing my test pipes and O2 spacers, one of which had threads that were kind of bunged up and couldn't get super tight because it would keep spinning. Tried to use gasket paste as the car was on a lift that needed to be used the next morning but I'm guessing it wasn't enough.
    Before I go pulling apart the entire bottom side of the car to pull the test pipe and replace (what I'm assuming) is the bad O2 spacer throwing the code, can anyone confirm which side of the engine is bank 2?
    Note: there's a chance I can reach in from the top of the engine and get the O2 spacer out, but I need to find someone strong enough with skinny arms to reach in lol
    2016 Audi A7 Prestige - Glacier White Metallic - Airlift 3P - IE S2+ DP welded clutch E45, HVF ZF8 TCU Tune - BC Forged 20x10 2-Piece wheels - JHM Race Pipes - AWE Touring Edition Exhaust Diamond Black - AWE Tuning S-Flo Intake - Garage Auto Sport Coolant Divorce Kit - Xpel XR Ceramic 5% rear, 20% front
  30. #2350
    Junior Member One Ring
    Mar 07 2021
    Pcola
    Alright, I've used the search function and I have the answer to this question for the Q7, B4, B6, A4, and a host of other vehicles, but I can't find this for ours.
    I bought these rims:
    https://momo.com/en-us/momo-rf-serie...zio-black.html (pretty insane deal and I'll believe it if they really show up next week)
    I need to get a Conical Bolt set. I get that our lug nuts are 14x1.5, but I have no idea what depth I need to be running. 28mm? 30mm? I'm probably going to buy one-offs from a website I found and then figure out which is the proper fit.
  31. #2351
    Jun 26 2021
    C7.5 S6 Prestige
    East Coast
    Quote Originally Posted by oreopride View Post
    If you are NOT running a spacer, the OEM length is 27mm
    you can find good grade OE style and Conical Style wheel bolts
    Cone/Conical Seat
    https://blackforestindustries.com/co...audi-cone-seat
    OE/Ball Seat
    https://blackforestindustries.com/co...audi-ball-seat
    I am running +10mm spacers so I am using 35mm wheel bolts.....
  32. #2352
    Veteran Member Three Rings GID's Avatar
    Nov 02 2017
    Virginia/USA
    Alright guys, be easy on me as I haven't switch my tunes in several years. Going from EPL stage 2 to stage 1, do I have to do rsa off first or just go straight to 1?
    Is this flash one of the 30 second flashes or a 10 minute flash?
    Thanks guys!
    Sent from my SM-A526U using Tapatalk
    SQ5 Sportback
  33. #2353
    Mar 11 2007
    Colorado Springs
    From the looks of what you've done, your car is pretty damn fast, so why, is the question?
    And what is RSA?
    2022 Q8 S line Prestige Stock
    2012 A7Plus APR Stage II+ UC
    2012 A8L 4.2
    Still own them all...
  34. #2354
    Nov 02 2017
    Virginia/USA
    Quote Originally Posted by A6sport View Post
    And what is RSA?
    I have emissions in my state so I was removing some mods. Now I'm thinking about removing most of my mods and going back to stock. Haven't decided yet.
    SQ5 Sportback
  35. #2355
    Junior Member Two Rings DrewZee's Avatar
    Aug 25 2022
    2004 SRT Viper; 2008 Lamborghini Gallardo Spyder
    Gilbert, AZ
    Here’s a really dumb question-
    I just got my 2018 S7 Prestige delivered today. While sitting in it, with doors closed and engine off, I hear a faint humming noise…like a little motor or something…coming from the central dashboard area… very faint. Is this normal? Am wondering about that, and also if that will eventually drain the battery?
    Told you this question was stupid…lol.
  36. #2356
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Quote Originally Posted by DrewZee View Post
    I don't know the exact answer, but the car has many systems that monitor the car even when the engine is off. Some will activate when opening the driver door to prepare the car for driving. The systems are relatively sensitive to variations in voltage, so if you plan to leave the car sitting for more than several days, the use of a battery tender is generally a good idea. I believe there is an AZ thread where folk recommend specific battery tenders.
  37. #2357
    Aug 25 2022
    Gilbert, AZ
    Thanks Alabama!
  38. #2358
    Veteran Member Three Rings Vinng86's Avatar
    Jul 20 2018
    Toronto, ON
    That sound is most likely the car priming the fuel pump. It basically warms it up and gets it lubricated when you open the driver door because the Audi engineers figured you're probably about to start driving soon.
    2014 Audi A6 3.0T Technik(Prestige) S-line w/ Black Optics
  39. #2359
    Aug 25 2022
    Gilbert, AZ
    Makes sense - thanks!
  40. #2360
    Sep 08 2021
    2013 Chevy Tahoe
    Philadelphia, PA
    Is there any options in the VCDs to adjust the auto dimming mirrors? I put tints on my rear window and now none of my mirrors dim and I would kind of like to either change the sensitivity or just make them permanently dim
