Page 58 of 66 FirstFirst ... 8485657585960 ... LastLast
Results 2,281 to 2,320 of 2610
  1. #2281
    Junior Member One Ring
    Aug 24 2021
    Portland, OR
    Every car I've had has a headlight indicator in the dash. My used 2017 RS7 doesn't. Is there supposed to be a light that comes on when the headlights are on, and maybe it's just not working on my car?
  2. #2282
    Jan 07 2011
    2013 C300 4Matic
    Quote Originally Posted by igxqrrl View Post
    I don’t think there’s an actual indicator besides that your dash lights up i.e The cluster is illuminated
    Present:
    2009 Audi S5 Phantom Black
    IG: bknewtype
  3. #2283
    Jan 02 2019
    Park Ridge Illinois
    What causes this noise?
    Here’s a ‘dumb question’ (o.k., two dumb questions): What causes this noise??? I have a 2018 A7 Prestige. There are no problems with the car. This is just something that I am curious about. I have noticed that when I drive the car and accelerate, as soon as the car gets to the speed of 50 MPH, I hear something, maybe some sort of actuator, do its thing. It’s a brief sound, about 1 second in duration. The sound seems to come from under the center console area. I don’t notice anything different about how the car rides or accelerates after I hear this actuator. And, if I then slow the car down to a stop, without turning the car off, then accelerate again up to 50 MPH, I don’t hear the actuator a second time. Does anyone know what this noise is? And why does it only occur once per drive?
  4. #2284
    Junior Member One Ring kennelm's Avatar
    Oct 12 2019
    2008 A6 3.2; 2017 Honda Pilot Elite
    va
    I have a related question on my 2017 S6...
    I could swear that the "Passenger Airbag Off" light was never illuminated, even when I drive alone. And then recently I had my battery replaced. After that, and perhaps completely coincidentally, I noticed that the light is on all the time when I drive alone. I assumed that it was a glitch following a power interruption or spike when the battery was replaced. And then I read the owner's manual and it says it SHOULD be on when no one is seated there. So I test it out, and sure enough, if I sit in the passenger seat, the light goes out.
    Is it possible that the light was off before the battery was replaced, and now it's on (as intended)?
    Things that make you go "hmmmm"
    2017 S6 Prestige
    Sepang Blue Pearl / Black interior
    Sport Package
    Black Optic Package
    Cold Weather Package
    Driver Assistance Package
  5. #2285
    Aug 14 2019
    Tampa
    There's a sensor in passenger seat, PODS... Is there anything in your seat or is it empty? Reset the error code and see if it comes back on.
    18 S6
  6. #2286
    Veteran Member Three Rings Speedooooo's Avatar
    Sep 13 2015
    Cincinnati, OH
    Did you get your PODS sensor replaced during the recall? Depending on what I place on the passenger seat the light also goes on and off.
    2018 Glacier White A6 3.0T | Driver Assistance | Sport | Black Optics
    2016 Mythos Black Q5 3.0T SOLD
  7. #2287
    Veteran Member Four Rings hunter_killer's Avatar
    Mar 25 2020
    Mandan, North Dakota
    Being a new C7 owner (2013 S6) with three days under my belt I’ve gotten two questions already.
    First; The Bose systems seems to be lacking in bass and depth even at full volume. My S4 with Audi’s concert system was a lot better. I don’t know if the subwoofer is shot or if something is up with the system. I’ve adjusted the bass to max and messed with the treble. No middle adjustment although. Our 2014 Acadia with a Bose systems is miles ahead. Anyone have some insight for me?
    Second question; I’ve noticed atleast twice every time I start the car I can hear what seems to be a ticking sound behind the driver’s side rear seat. I assume it’s the air pump? It doesn’t do it but once for about 20 seconds and it’s done. Is this normal or an indication of something? No faults for the air suspension.
    2013 Quartz Gray S6: APR Stage 1 and CTS intakes.
    Gone: 2013 S4 Stage 2. RIP.
  8. #2288
    Veteran Member Three Rings MBM6F's Avatar
    Oct 10 2012
    Va
    Stupid question time (and not worth a new thread):
    1) From what I’ve read, it sounds like the APR tune is a bit more conservative than some of the other options. Has anyone heard any horror stories about it causing issues? I’m cool with a more conservative tune, would just like to wake it up more. Would I need a transmission tune as well?
    2) I’d love to slap a catback on this car, it’s the first car I haven’t changed the exhaust on. My hearing is starting to go a little bit so I try to be careful with that. Has anyone managed to only swap the tips and make it look clean and not trashy? I feel like I usually see that on lousy rebadged cars, I’d just like quad tips for aesthetics and a new diffuser. Any input is appreciated.
    AWE Tuning
    Current: 2016 A6 3.0T S-Line - H&R Sport Springs - Carbon Imports Low Kick CF Lip Spoiler - Hartmann FF-003-CG 19”x8.5” ET38 - 15/18mm Spacers - RS6 Grille - 20% Ceramic Tint - Hardwired Max360c -
    Sold: 2007 S4 DTM - AWE Touring Exhaust - H&R Springs & Coilovers - 18" Gunmetal VMR V708 RS4's - Nexon Motors Custom Spec Flat Bottom CF Steering Wheel - Fly V4 LED's - RS4 Grille - Hardwired V1 w/ Concealed Display - Laser Interceptor Dual Setup -
    @mattbmclean6f
  9. #2289
    Veteran Member Three Rings WatchMeSpend's Avatar
    Mar 19 2019
    2016 A6 3.0T Technik S-Line
    Toronto/Ontario
    Quote Originally Posted by hunter_killer View Post
    Regarding the stereo, I don't know it is exactly the same as my Bose in my 2016 A6, but I can barely see out the rear view mirror when the bass hits. I think it moves all the mirrors. The only comparison I have is my buddies 2017 A4 Bang and Olufsen and mine murders his. It actually seems like someone stole his woofer.
  10. #2290
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    I can't help directly, but there are several AZ members such as OlyS6 who have great knowledge of the sound systems. In general their criticism of the Bose seems to be more about the amplifier, not so much the speakers. Like WatchMeSpend, I get decent bass volume from my Bose system so maybe your subwoofer is indeed disconnected or shot. Others will have to offer suggestions on how to test the system.
  11. #2291
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Quote Originally Posted by MBM6F View Post
    From what I've read, all the off-the-shelf stage 1 tunes from all the tuners perform about the same, so cost and convenience may be more important deciding factors. Most people encourage a TCU tune as well, although that seems to be more important for the DSG transmission even at Stage 1, not as much for the tiptronic.
  12. #2292
    Mar 19 2019
    Toronto/Ontario
    If you don't have access to anything higher than 93 octane, it seems the difference is price and flash from home options for a dual pulley tune. it looks like APRs competitors have more aggressive "Stage one" tunes" that produce more oomph than APR, but when they go to a Stage 2 dual pulley the difference doesn't seem to be as great as with APR. This doesn't mean the others are worse, in Stage 2 builds, it just looks like the difference is less between competitor's stage 1 vs stage 2 tunes of EQUAL octane and stock exhaust. Remember you have a CREC engine that limits your tuner options.
    There are enough guys running APR stage 2 DP on stock exhaust pulling in some of the best 1/4 mile times that nobody should worry about APR.
  13. #2293
    Oct 10 2012
    Va
    Quote Originally Posted by Alabama View Post
    I guess that’s an upside of not having DSG hahaha
  14. #2294
    Mar 25 2020
    Thanks to you guys for the insight. If I have time today I’ll check out fuses and what not. Maybe see if I’ll get to physically looking at the sub and amp to see if anything looks “off”. I’m not a very big audio guy as far as technical stuff. I’m just an enjoyer of good audio quality.
  15. #2295
    Senior Member Two Rings jeff351's Avatar
    Dec 16 2020
    2015 Q5 Prestige TDI, 2016 RS7 Performance
    oklahoma
    i run apr's black diamond exhaust tips on mine and i think it looks clean but i only have dual tips not quad
  16. #2296
    Sep 13 2015
    Cincinnati, OH
    I did quad tips and got an S6 diffuser. I did chop off the mufflers so it’s a bit loud and drones. You probably won’t like it if you’re already sensitive to that.
  17. #2297
    Nov 08 2017
    Chicago
    For awhile I thought my high beams weren't working then finally realized the indicator would come on occasionally when they auto-engaged.
  18. #2298
    Nov 08 2017
    Chicago
    I bookmarked this a while ago: https://www.youtube.com/watch?v=x8YGujHDLVM
    Have not done it though.
  19. #2299
    Oct 10 2012
    Va
    Quote Originally Posted by Speedooooo View Post
    That looks amazing. Did you just take it to an exhaust shop?
    I think more accurately the issue is that I’m not sensitive enough to it haha. I keep toying with the idea of exhaust but any extra noise for a long period of time is something I’d like to avoid.
    AWE Tuning
    @mattbmclean6f
  20. #2300
    Sep 13 2015
    Cincinnati, OH
    TY! Yes I had an exhaust shop cut the mufflers and weld on the new tips. I told them I wanted it pretty flush. If I had to do it again I might not have deleted the mufflers and straight piped the center x-section instead. However, that won't give you that quad exhaust look.
  21. #2301
    Established Member Two Rings reighnman's Avatar
    Apr 30 2017
    8S TTRS
    MN
    Is the oem rs7 diffuser always carbon fiber? Just noticed mine on my c7.5p is painted black so wondering if it got damaged at some point and they painted it.
  22. #2302
    Jan 31 2009
    2016 RS7-P
    Not always carbon, there is a gloss black lower section with the trim pieces coming in various colors like silver, black and titanium.
  23. #2303
    Apr 30 2017
    8S TTRS
    MN
    Ops meant specifically the rear unless that applies as well.
  24. #2304
    Jan 31 2009
    2016 RS7-P
    Yep, was talking about the rear as far as the trim pieces along the top of the bumper. The front center and side pieces come in those 3 colors plus carbon no real trim piece to add to the front.
    Example of a titanium edition RS7, gloss black lower with titanium trim. This car would've needed the carbon pack to get the mirrors, front and rear pieces in carbon. The carbon rear diffuser is one piece, unsure if the other options are all one piece or not, have just seen the variations.
  25. #2305
    Apr 30 2017
    8S TTRS
    MN
    Cool thanks!
  26. #2306
    Mar 25 2020
    Anyone here cut open this closed off spot in the grille to allow for air to go straight the intake scoop?
    Also side note, I just did the passenger side spark plugs and I was pretty surprised to see number 2 (?)/ second cylinder from the front had nearly no carbon on the piston face. The other three had some carbon build up. Little surprised to see that on one cylinder only.
  27. #2307
    Oct 18 2017
    NW Philly
    Something to consider is that the airflow has been optimized by engineers for a reason. I would not mess with it, as cutting things without a sense could lead to turbulence in the airflow or a certain resistance we can't evaluate properly.
    Better off leaving well enough alone there.
    It's like driving without the hood on for better cooling. Seems like a great idea, right? Except you'll have no cooling through your radiator where you really need it.
  28. #2308
    Mar 25 2020
    Quote Originally Posted by Spitfire007 View Post
    Yeah I get it, hence the question. It’s a small spot up top directly in front of the ram scoop, and while you’d think it wouldn’t affect air flow, I didn’t want to cut it without having some opinions on it. I didn’t think it would affect things that much being as it’s three of the “diamonds” in the grille, but if anyone else may of done it I was curious. Probably wouldn’t gain anything noticeable anyways…
    Removing the hood for cooling is a bit of a stretch as a comparison for my question lol
  29. #2309
    Senior Member Four Rings THCarpenter's Avatar
    Jun 26 2021
    C7.5 S6 Prestige
    East Coast
    Q found it counter productive to remove the inserts in the ACC area in his thread for cooling in 4.0TT. May queue into that for engineered air passage for the engine
    2016 S6 Mythos Black / B&O, Cold Weather, Drivers Assistance, Black Optics
    2016 S6 Mythos Black / Sport, Cold Weather, Drivers Assistance, Black Optics, Night Vision
    "How to spend a shitload of money and still be slow, the THCarpenter story." - sepheroth86
  30. #2310
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Quote Originally Posted by THCarpenter View Post
    Presumably the manufacturer does extensive wind tunnel testing to study airflow. I imagine there are compromises though between the function engineers and the aesthetics marketing folk.
  31. #2311
    Aug 14 2019
    Tampa
    Well, passenger side is blocked there on my S6, but it is open on RS6 as they have an additional cooler that gets air from there. German engineers are pretty good..
    18 S6
  32. #2312
    Jun 26 2021
    C7.5 S6 Prestige
    East Coast
    maybe
  33. #2313
    Aug 14 2019
    Tampa
    maybe
    And thats a SIM... reality is almost always different... how different is another story... (btw im waiting to hear about your crash bar cover)
    18 S6
  34. #2314
    Jun 26 2021
    C7.5 S6 Prestige
    East Coast
    Quote Originally Posted by Audisthesia View Post
    I thought I told you I received it!
    lol
    cant install until I get back to the states....Im still floating off the coast of Italy, and wont be home for.......4 more months? maybe.....
  35. #2315
    Aug 14 2019
    Tampa
    you did, i waiting patiently for install pics
    18 S6
  36. #2316
    Mar 25 2020
    I was thinking of just opening up a section by the scoop, I wouldn’t remove the whole blockade. I could see the whole thing being removed causing a negative effect. I don’t have any images or results of how the air flow exactly moves up under the hood/ top of the radiator and intake scoop. Good intentions I suppose.
  37. #2317
    Oct 18 2017
    NW Philly
    Those are things I REALLY wouldn't touch.
    Its would be like adding additional ducts for brake cooling. Think the engineers didn't think it through?
    Or a huge wing on a Honda...mmmm. Not gonna help you stick like an F1 car. And that ricer pipe doesn't make you faster, just more obnoxious....
  38. #2318
    Mar 25 2020
    Well brake ducting can be argued, but no need to get into that. Engineers aren’t always out for the best performance in every aspect… I’m glad for the discussion on this and getting opinions on them. I’ll just leave the idea alone.
  39. #2319
    Apr 26 2022
    Enon, OH
    I just got my first Audi, a 2016 A6 Premium Plus 2.0t. When I bought it the backup camera was not working but the parking sensors work fine. I have searched and read multiple forums and seen tons of pictures of where the reverse camera control module is located. Almost all say it's in the right rear qtr in the trunk but when I pulled that panel the only things back there are the fuse block, the Emergency Parking Brake and the Comfort control modules...nothing else. Now most if not all of my previous searches were from prior model years. Can anyone tell me exactly where the Reverse Camera Control Module for a 2016 A6 is located? Is it possible its under the front passenger seat?
    Thanks in advance!
  40. #2320
    Jun 12 2019
    MK5 Rabbit 2.5 5spd
    Natick, MA
    Quote Originally Posted by anarchy1970 View Post
    Thanks in advance!
    From erwin manual (note page numbers at bottom as they attached out of order):
    72BEEAD6-F6F2-46F7-91F8-BAF371C44B99.jpgC7FBDCAF-930A-44F0-B956-2B3BB53709BF.jpg13324062-8FFC-4420-ACA8-813BFF6D8EAF.jpg
    2016 A6 P+ 3.0T / Aviator Blue Metallic / APR Stage II Single Pulley 93 Octane / BG_SQ5 tcu / MercRacing hx v3 / Hartmann Rotor Reps 20x9 ET40 w/ 265/35-20 PS4S / 0-60 3.56 sec
