Page 64 of 66 FirstFirst ... 14546263646566 LastLast
Results 2,521 to 2,560 of 2610
  1. #2521
    Senior Member Three Rings ItsCAvalos's Avatar
    Aug 04 2018
    Rockford, Illinois
    Quote Originally Posted by st33zus View Post
    Saw this on here earlier(2019) but there was not a clear solution(besides full console replacement under warranty): my volume knob in my RS7 behaves erratically sometimes. I’ll turn 2 clicks and it’ll jump way up, or go way down, in a random direction. Also the mute/power off function doesn’t work if I push on it. It’s just stiff. Is there any replacement part numbers people might know of? I’m guessing I might need the knob as well as the piece the knob fits into. - SV
    I heard that if you take off the knob and spray electrical connector cleaner it can bring it back. If not I might have a spare knob
    ‘14 A6 TDI
  2. #2522
    Veteran Member Three Rings Gunmeister's Avatar
    Feb 03 2019
    Spokane, WA
    Quote Originally Posted by ItsCAvalos View Post
    ‘14 A6 TDI
    Mine was really bad volume would drop to zero when trying to turn the volume up. I removed it and cleaned it with electrical cleaner and this completely solved the issue is my A6 last year as well. Still working good worth a shot.
    2016 A6 TDI | Mugello Blue, Pearl Effect Exterior | Alabastar White Interior | Audi Exclusive Line | Eucalyptus Natural Wood Decorative Inlays | Prestige Package | Comfort Seating Package | Driver Assistance Package | S Line Sport Package | 20" Black Optic Package | Cold Weather Package | 18% Ceramic Film Windows | 70% Ceramic Film Windshield | Thinkware Q800 Pro Dash Cam | Audi All Weather Mats |1 of 1 for 2016|
  3. #2523
    Senior Member Two Rings st33zus's Avatar
    Apr 06 2014
    2023 F150 Platinum Black Pack
    CO USA
    ‘14 A6 TDI
    Awesome, I will try this. Thank you
  4. #2524
    Apr 06 2014
    CO USA
    Quote Originally Posted by Gunmeister View Post
    This sums up is behavior, I’ll give it a shot. Many thanks.
  5. #2525
    Active Member One Ring cwells777's Avatar
    Dec 25 2019
    Hamilton, NJ
    Grill question here- Is the front camera mount on a c7.5 able to be removed and put on another grill that didn't have a camera from the factory. Both grills are OEM with the slats/bars, thinking about swapping black optics grills between an a6 and an s6. TIA!
  6. #2526
    Established Member Two Rings Nolzie's Avatar
    Mar 18 2023
    Porsche Cayenne Turbo, Audi A4 (Stage 1), Benz E350
    Clarkston, MI
    I have an exhaust question. I don’t know much about the OEM parts market but here it is. Is there value in OEM exhaust systems? I am replacing my system on my C8 RS7 and want to sell the original parts and not just discard them. Thank you.
  7. #2527
    Jan 31 2009
    2016 RS7-P
    Probably better to look in the C8 section to see if there's a market for them, the rear assembly is definitely not a C7 compatible thing.
  8. #2528
    Oct 31 2006
    San Antonio, TX
    https://www.audizine.com/forum/showt...9-Faulty-radio
    Current: 2016 S6 Previous: 2015 A6, 2012 Q7 Prestige SLine, 2005 S4, 2007 Avant 2.0T, 2002 A4 1.8T
  9. #2529
    Apr 06 2014
    CO USA
    You rock bro, many thanks
  10. #2530
    Established Member Two Rings Mister Mike's Avatar
    Dec 05 2023
    Oregon
    Make sure the product used is PLASTIC SAFE, for example CRC QD Electronic Cleaner. A regular contact cleaner that is not plastic safe may melt the plastic!
  11. #2531
    Apr 06 2014
    CO USA
    Quote Originally Posted by Mister Mike View Post
    Thank you for the tip, oddly, that was the exact product I ordered. Appreciate everyone’s input.
  12. #2532
    Apr 06 2014
    CO USA
    Reporting back, the Plastic Safe Electronic Connector Cleaner worked! Pleased, thanks team.
  13. #2533
    Senior Member Two Rings tnjed's Avatar
    Jan 29 2018
    2023 Infiniti QX80
    Knoxville, TN
    ‘14 A6 TDI
    If your volume knob-and-stem is available, I might be interested. Dealership has told me that cleaning it isn’t the issue and that I need a replacement. The quoted amount was $2100. Ha!
    Sent from my iPad using Audizine Forum
    2017 RS7 Performance / Prism Silver / Titanium Edition / KW H.A.S.
    2016 A7 Prestige / Tornado Grey Metallic - SOLD
  14. #2534
    Established Member Two Rings caelric's Avatar
    Jun 10 2023
    Colorado Springs, CO
    Quote Originally Posted by tnjed View Post
    dealership is wrong. just clean it.
    2016 RS7 Performance - Prism Silver Crystal - Comfort/Bang & Olufsen - DS1 Stage Custom 1 w/ BTRes- TGK Intake - 034 Suspension/Transmission/Differential Inserts
  15. #2535
    Aug 04 2018
    Rockford, Illinois
    Sure I still got it. I do recommend just trying to clean it though. If not I’ll ship it to you
    ‘14 A6 TDI
  16. #2536
    Apr 06 2014
    CO USA
    The $11 spray worked for me. Just used a rag to keep it contained.
  17. #2537
    Junior Member One Ring
    Mar 09 2023
    Gloucester MA
    OK. New to me 2018 A7 competition pkg. I just noticed the little LEDs on the exteriot door handles that shine down. The one on the driver's door is out. The other 3 work fine, and the audi ring lights on both front doors work. Is this normal or is the little door handle led nfg?
    2018 A7 Competition
    2006 A3 3.2Q.
    1990 CQ
    1985 4KQ
  18. #2538
    Jan 31 2009
    2016 RS7-P
    It's a replaceable part, need to pull the handle out to access it. https://parts.audiusa.com/p/Audi__/C...H0947134B.html
  19. #2539
    Mar 09 2023
    Gloucester MA
    Quote Originally Posted by widebodyfx View Post
    Thank you! Found a youtube of the handle removal and led replacement. Simple enough. All that plastic, it can wait till springtime. 26* F. and dropping to the teens this weekend.
    Also found the vcds lighting output test to check it.
    2018 A7 Competition
    2006 A3 3.2Q.
    1990 CQ
    1985 4KQ
  20. #2540
    Established Member Two Rings schonc's Avatar
    Aug 21 2021
    Alberta
    What is this?
    Sent from my SM-S911W using Tapatalk
  21. #2541
    Junior Member Two Rings
    Mar 15 2020
    Carrollton, GA
    Can you post the VCDS code, please...
    Larry in Georgia
  22. #2542
    Veteran Member Four Rings MyDimeIsUp's Avatar
    Dec 04 2019
    West Chester, PA
    Quote Originally Posted by schonc View Post
    What is this?
    Breather tube/vent for the headlights. Helps with built-up gasses in headlight housing.
    2020 BMW M340i xDrive - Mineral Grey
    2012 Audi A6 3.0T Prestige - 034 Stage 1 ECU and TCU | CTS Turbo Intake | 034 Street Density Motor Mounts w/ JHM Trans Insert | ECS X-Pipe
    2013 Audi allroad - RIP
    2007 Toyota corolla
  23. #2543
    Aug 21 2021
    Alberta
    Quote Originally Posted by MyDimeIsUp View Post
    Ah yes. Makes sense now.
  24. #2544
    Senior Member Three Rings mrdouble99's Avatar
    Mar 31 2018
    Montreal
    2017 S6 stall 30-90 sec after a start when it's cold, full of fault code and the start normaly ...
    If the engine is hot, no probleme
    Mythos Black Metallic 2018 Audi S6 current
    Moonlight blue 2015 Audi S6 sold
  25. #2545
    Oct 31 2006
    San Antonio, TX
    C7.5 S6....
    How do you remove the lower side grills.
    I did a quick search but didn't find anything. Has anybody done this, seen a step by step, or a video?
    thx
  26. #2546
    Jan 31 2009
    2016 RS7-P
    Yank them, they snap into place. You're in Texas so probably not cold enough or old enough plastic to worry about brittleness
  27. #2547
    Senior Member Four Rings THCarpenter's Avatar
    Jun 26 2021
    C7.5 S6 Prestige
    East Coast
    What Viet said.....pull from the inner side, it has two slip tabs on the outer sides of the grills. They pull out and away from the car. Its all pressure tabbed in
    you WILL feel like you are breaking them the first time removing them
    2016 S6 Mythos Black / B&O, Cold Weather, Drivers Assistance, Black Optics
    2016 S6 Mythos Black / Sport, Cold Weather, Drivers Assistance, Black Optics, Night Vision
    "How to spend a shitload of money and still be slow, the THCarpenter story." - sepheroth86
  28. #2548
    Established Member Two Rings poloshirt's Avatar
    Apr 06 2022
    Oregon
    Outer tie rods shouldn't be clunking like this when rotating, right?
    https://youtu.be/W85PpCb1cz4
    2013 Audi TTRS - Daytona Gray Pearl
    2014 Audi S6 - Ibis White - JHM Stage 2
    2013 Audi S4 - Phantom Black
  29. #2549
    Veteran Member Four Rings ericw.'s Avatar
    Apr 23 2011
    C7 S7 4.0TT, Jeep JKU, MB GLB
    Sac Area, CA
    Quote Originally Posted by poloshirt View Post
    I'm not sure that's a concern. The only way to test tie rod ends (when not obviously broken) is to put someone in the driver seat with the car running. Watch closely while you have them turn the steering wheel a quarter turn left to right and observe for any odd or uneven movement with the joint.
    IG @lolzhax
    //AGILITYDRIVES.US
    C7 S7 4.0tt faster than kaploww and passed smog | LX7U | JHM STG3 ECU+TCU | JHM DP + CATBACK + Oil Screen Relocation + LW Crank Pulley + Heat Exchanger | SRM +4MM Turbos | S-FloV2 | EUROCODE SWAYS | CETE ASC | RFX7 | PS4S | RS7 FR+R | PD700R Splitter | Maxton Skirt+Spoiler Extensions | Indicator Delete | Hardwired
    b7 a4 2.0t | Stage 2+ | DTM Body [sold]
  30. #2550
    Apr 06 2022
    Oregon
    Quote Originally Posted by ericw. View Post
    Thanks for your input. I've been chasing a low-speed clunk on the driver side recently. This was the only clunk I could reproduce, but it doesn't necessarily match known tie rod failures. 12 and 6 o'clock shake felt solid, 6 and 3 o'clock had minimal play. Lower ball joints held up against the crowbar test. The boot on the outer tie rod has a small tear so I have replacements from 034 on the way. It will be a cheap fix if the noise goes away, otherwise I can cross them off the preventative maintenance list
  31. #2551
    Apr 23 2011
    Sac Area, CA
    Hope that solves the problem. If not, I'd look at control arm bushings, front sway bar, subframe, motor mounts.. and if all else fails, just turn the music up until the problem gets big enough to find. lol
    IG @lolzhax
    //AGILITYDRIVES.US
  32. #2552
    Apr 06 2022
    Oregon
    They did not fix the original clunk concern, however the steering response and ride quality has much improved! A lot of vibration and harshness was being transmitted through the bad ball joints on the tie rods to the suspension & steering.
    New sway bar bushings and 034 adjustable end links on the way. Plan to replace the bushings first to see if they are to blame for the low speed clunk.
  33. #2553
    Mar 18 2023
    Clarkston, MI
    Is there any real resale value in OEM exhaust systems after removed for an upgrade. Namely, just took the system off my C8 RS7 and not sure if I should just scrap it or try and continue to sell it. Thank you for any constructive recommendations.
  34. #2554
    Jan 31 2009
    2016 RS7-P
    The C8 RS assembly in the back is way different from C7, I was chatting with a C8 S owner about the RS counterparts and he didn't really make it seem like the A/S owners were really after the RS exhaust parts. S and RS being different engines entirely is different to the C7 scenario where it was a lot closer relation.
  35. #2555
    Mar 18 2023
    Clarkston, MI
    Thank you. I figured it was a small niche market for it and it would probably only be a coincidence to find someone that wants one at the same time one is available. Just seems a shame with how expensive Audi parts are new, to just scrap it. Just too cumbersome to store it and wait for interest. I’d give it away free if someone came and got it. Just so I know I wasn’t wasting something so potentially valuable to someone.
  36. #2556
    Jun 15 2016
    2017 S7
    Louisville, KY
    My 2017 S7 needs air filter replaced (87k miles and last replaced around 40k?). I have ordered a K&N E-1983. I am totally mechanically inept. I have searched all over YouTube and cannot find a video that shows how to change the air filter on my car. I know where it is located, but it is not clear to me what all I need to disconnect and anything to watch out for when I do this. I only found a video that appeared to be V6 A6.
    Any pictures, videos, list of tools, advice, etc would be greatly appreciated. Also, the K&N is coming on my Amazon subscription March 5, so let me know if others have had any bad experience with that filter and I can get a different filter.
    I had all my fluids done yesterday at my Independent, but skipped the air filter because I wanted to try K&N. They didn't mention plugs until I was leaving, so I could have them drop it in as plugs are due, but I would like to do the air filter and even cabin filter myself.
    Thanks in advance for your assistance!
  37. #2557
    Apr 18 2016
    2016 RS7 Prestige
    Boston Area
    Quote Originally Posted by KingMota View Post
    This pretty much covers it. https://www.youtube.com/watch?v=a-QE...heManleyGarage
    2016 RS7 / Mythos Black / Comfort Seats / B&O / Layered Alum Trim
    Also in the stable:
    - 2018 GMC Sierra (Daily)
    - 2020 Kia Telluride SX-P (Daily)
    Past: S7, A7, A8, Multiple A6's
  38. #2558
    Jun 15 2016
    2017 S7
    Louisville, KY
    Thank you BasicBlack! That looks simple enough that even I should be able to do it!
  39. #2559
    Aug 04 2018
    Rockford, Illinois
    Questions you thought were too dumb to ask
    I have a 2014 A6 that I retrofitted power closing trunk. At first I used the old button from my B8 Avant but now I got one from a 2018 S6. The lock button won’t do anything. Is there a wiring difference or coding somewhere? The trunk close still works just fine. IMG_8522.JPGIMG_8521.JPG
  40. #2560
    Apr 18 2016
    2016 RS7 Prestige
    Boston Area
    IIRC, the lock button was not available on pre facelift C7's. I owned a 2012 C7 A7 which only had the single "close" button inside the hatch. My 2016 C7.5 S7 and subsequent C7.5 RS7 both had the combined close and lock button. Your 2014 pre facelift C7 A6 may not be wired for the lock button.
    Also in the stable:
