Page 60 of 66 FirstFirst ... 10505859606162 ... LastLast
Results 2,361 to 2,400 of 2610
  1. #2361
    Veteran Member Three Rings Botbasher's Avatar
    Jul 26 2018
    2014 S6 "Elsa" - Mk 6 JSW - Scratch Built Lotus 7 Replica
    Humidity, NC
    Quote Originally Posted by DrewZee View Post
    Here’s a really dumb question-
    I just got my 2018 S7 Prestige delivered today. While sitting in it, with doors closed and engine off, I hear a faint humming noise…like a little motor or something…coming from the central dashboard area… very faint. Is this normal? Am wondering about that, and also if that will eventually drain the battery?
    Told you this question was stupid…lol.
    Not a stupid question... just a unique reason!
    Mid-Dash... bet the HDD for the MMI was spinning up (fuel pump sounds distinctly under car). As mentioned, several system get the car ready, but several other systems KEEP the car ready. There are down timers for things like the Jukebox and such that keep the car "aktiv" for a return.
    Ever notice how sometimes the MMI is near instant and others it takes a few minutes to settle? Those times can be set. My brother had a problem with his keeping his Bluetooth active when he went in the house. We adjusted the times so that it turned off within minutes and POOF... problem solved.
    I've heard my HDD spool up when I was just sitting reading emails. You bump the wheel, adj the seat or anything that lets the car know you are still present, it lights up!
    Hope this helps,
    KS
  2. #2362
    Veteran Member Four Rings Audisthesia's Avatar
    Aug 14 2019
    Tampa
    Quote Originally Posted by AudiInMyA7 View Post
    Is there any options in the VCDs to adjust the auto dimming mirrors? I put tints on my rear window and now none of my mirrors dim and I would kind of like to either change the sensitivity or just make them permanently dim
    Very good question, not one I have the answer too. However, the sensors for auto dimming all 3 mirrors are located in your rear view mirror. Ill have to see if mine dim next time I drive in the dark, as I have 5% tint on my car..
    18 S6
  3. #2363
    Aug 14 2019
    Tampa
    Quote Originally Posted by Botbasher View Post
    Hope this helps,
    KS
    Great theory, except there is no HDD in his car. He has a 2018 S7. The MMI got rid of that mechanical ticking time bomb with C7.5 MMI update.
    18 S6
  4. #2364
    Veteran Member Three Rings Speedooooo's Avatar
    Sep 13 2015
    Cincinnati, OH
    Where are you guys getting your jack pad adapters? I was using this before https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1, but it fell apart and is no longer available.
    I just got this https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1 and it is too large to fit in the jack pad area.
    2018 Glacier White A6 3.0T | Driver Assistance | Sport | Black Optics
    2016 Mythos Black Q5 3.0T SOLD
  5. #2365
    Aug 14 2019
    Tampa
    Quote Originally Posted by Speedooooo View Post
    Interesting, glad I bought a 4 pack before they went poof.
    18 S6
  6. #2366
    Veteran Member Three Rings Burkeomatic's Avatar
    Feb 22 2021
    14 A8L 4.0T, 96 Corolla Wagon
    San Antonio
    Quote Originally Posted by Audisthesia View Post
    I wonder if they would completely implode if you 3d printed one with 100 percent infill.I know in the miata world, they often fashion some out of hockey pucks. Those cars also weight 2000lb.
    2014 A8L 4.0T - DS1 Stage 4/JHM TCU, FE Axlebreakers, E85
  7. #2367
    Sep 13 2015
    Cincinnati, OH
    I did read before that these things fall apart. I had just used it and when I lowered the car the adapter just crumpled.
    I ordered another adapter on Amazon and same issue. It's too large.
  8. #2368
    Senior Member Four Rings THCarpenter's Avatar
    Jun 26 2021
    C7.5 S6 Prestige
    East Coast
    I checked mine.....seems I bought the same grey one as you....I got 2 two packs.....just checked over on ECS, and they only have powerflex ones that pinch the framerail
    https://www.ecstuning.com/b-powerfle...pf99-1000~pbs/
    https://www.ecstuning.com/b-powerfle...pf99-1001~pbs/
    https://www.ecstuning.com/b-powerfle...pf99-1002~pbs/
    2016 S6 Mythos Black / B&O, Cold Weather, Drivers Assistance, Black Optics
    2016 S6 Mythos Black / Sport, Cold Weather, Drivers Assistance, Black Optics, Night Vision
    "How to spend a shitload of money and still be slow, the THCarpenter story." - sepheroth86
  9. #2369
    Sep 08 2021
    2013 Chevy Tahoe
    Philadelphia, PA
    Yeah I noticed that when I put my phone up to it and i thought I might be able to trick it but I can’t drive with my phone up to my rearview mirror lol
    Daily -2015 Audi A7 Prestige| 20% rear & 35% front 3M Ceramic IR tints|Custom Alcantara Starlight Headliner|
    Music, Real Estate, and Audi
  10. #2370
    Jul 26 2018
    Humidity, NC
    Well damn... didn't know that one.
    But one thing I do know... mid dash isn't a fuel pump priming!
    Cheers!
    KS
    Sent from my SM-S906U using Audizine Forum mobile app
  11. #2371
    Aug 14 2019
    Tampa
    Cheers!
    KS
    Yeah fuel pump sound is very noticeable as coming from rear seat area.
    18 S6
  12. #2372
    Veteran Member Three Rings WatchMeSpend's Avatar
    Mar 19 2019
    2016 A6 3.0T Technik S-Line
    Toronto/Ontario
    Maybe the car is opening vents to the outside world and running a fan. I know that in the 1998 A6 when fully loaded would do that to keep the inside of the car cool. It may have been only an option on the sunroof cars that had solar panels in the sunroof glass. In both of my late 80s Fords, the car knew you were sitting on the seat via sensors and I would imagine the Audi is the same. Just guessing.
  13. #2373
    Mar 19 2019
    Toronto/Ontario
    You have to block the light going into the little square on the front of the mirror. This way the front is darker than the back and the mirror will tint to balance it out. If I have my sunshade up, auto dimming works like crap if at all during the night. I don't need it for the rear view with the sunshade up, but the sides dim with the rearview and so then none of them dim. I can only imagine that tint would make the auto dimming less effective.
  14. #2374
    Sep 08 2021
    2013 Chevy Tahoe
    Philadelphia, PA
    Quote Originally Posted by WatchMeSpend View Post
    This is the way holy shit and now whenever i want them dimmed i can just turn them on thanks so much
  15. #2375
    Aug 14 2019
    Tampa
    Well, unless you gonna drive around with your finger over the sensor on the mirror, they're not going to stay dimmed...
    18 S6
  16. #2376
    Sep 08 2021
    2013 Chevy Tahoe
    Philadelphia, PA
    I put a piece of black tape over it. I have black trim pieces so thats gonna work for me
  17. #2377
    Senior Member Two Rings Akakios's Avatar
    Feb 05 2022
    2014 Audi S7 | 2018 Audi S4
    DE
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Deutsche Auto Garage - Website // YouTube // Instagram
    2014 Audi S7 (Audi Exclusive Interior)
    2018 Audi S4
  18. #2378
    Aug 14 2019
    Tampa
    EPIC. simple solutions are great. Although got me thinking, there is a way to test auto dim in vcds, now I wonder if there’s a way to just set it to be always on.
    - - - Updated - - -
    Love those things, I have a sheet of them.
    18 S6
  19. #2379
    Sep 08 2021
    2013 Chevy Tahoe
    Philadelphia, PA
    I have been looking to replace my tires and i can get 275's about 80$ cheaper than 265's.... IDK how but im not asking questions lol. if i go with the 275's would i run into any issues? i currently have 265/35/20's on what i think are 9" wheels
  20. #2380
    Sep 13 2015
    Cincinnati, OH
    You can check out some charts online but 275 is not recommended on a 9” wide wheel.
  21. #2381
    Feb 05 2022
    DE
    I can't sleep with any LEDs on in my room and this completely conflicts with the design language of everything I own or work on for a living. Those little covers have been a savior. I never thought about sticking one on my rear view mirror until this thread so that's a win (I noticed my auto dimming wasn't as effective as before but I have a tint waiver so I kind of expected it).
    2018 Audi S4
  22. #2382
    Aug 14 2019
    Tampa
    It’s not that simple. People run 275 on 9 inch wheel quite a lot. It really depends on the tire brand, sidewall spec, wheel offset, etc. It can be done perfectly fine with no issues, and it can be a bad idea. You don’t want too much sidewall or bulge as that will create to much lateral movement making steering feel sloppy. Several manufacturers also list 9inch wheel as the minimum for a 275, which tells you it is approved for that setup. Others will say 9.5 or 10.
    18 S6
  23. #2383
    Jan 31 2009
    2016 RS7-P
    275/35 is Audi selection for RS7 20", 275/30 is Audi selection for RS7 21", 275/30 is Audi selection for RS5 20"
  24. #2384
    Sep 13 2015
    Cincinnati, OH
    Now that you mention it I just saw this post https://www.audizine.com/forum/showt...1#post14682036. 275/35/20 on a 9" wheel.
    So I've been trying to get an answer to this. I bought some 20x10 et30 wheels recently and it came with 285/30/20 tires. I have no rubbing issues on my A6 and I am on stock height. I need some all seasons and I need some extra sidewall in my area so I would like to run 275/35/20 DSW06. The tire rep advised me against it because of the 30 offset. He thought it would rub. Any advice?
  25. #2385
    Feb 15 2011
    Northern VA
    All B8 and B9 RS5s came with 20x9" wide wheels and 275 tires straight from the factory
  26. #2386
    Sep 08 2021
    2013 Chevy Tahoe
    Philadelphia, PA
    I was gonna say when i look it up i see people with 8” tires running 275’s. I’m honestly not 100% sure my rims are 9” but they’re wide. I have the sport suspension option from audi and that came with its own set of rims which lead me to believe they’re at least 20x9” rims. Ill have to pull out a tape measure and find out for myself I’m such a noob with cars i cant believe myself sometimes lol
  27. #2387
    Jun 12 2019
    MK5 Rabbit 2.5 5spd
    Natick, MA
    If you take a wheel off the car, the width will be stamped. It should say something like "9.0Jx20H2 ET37" where in this example the 9.0 indicates a 9" width.
    2016 A6 P+ 3.0T / Aviator Blue Metallic / APR Stage II Single Pulley 93 Octane / BG_SQ5 tcu / MercRacing hx v3 / Hartmann Rotor Reps 20x9 ET40 w/ 265/35-20 PS4S / 0-60 3.56 sec
  28. #2388
    Sep 08 2021
    2013 Chevy Tahoe
    Philadelphia, PA
    Quote Originally Posted by 2k16A6 View Post
    Dont really have the means to take the tire off but I just took a tape measure and it measured 10" for an A7? am I just being dumb here?
  29. #2389
    Jan 31 2009
    2016 RS7-P
    You can find your wheels here. https://www.original-felgen.com/audi/a7/4g/
  30. #2390
    Sep 16 2020
    West Michigan
    I run a 285/30/21 on factory RS7 wheels.
    Standard suspension on my A6. I get some occasional rubbing on the rear over large bumps/dips/woops in the road.
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
  31. #2391
    Sep 08 2021
    2013 Chevy Tahoe
    Philadelphia, PA
    So sounds like ima do 275/35/20 cuz honestly they’re 80$ cheaper somehow. Doesnt seem like ill have any crazy issues
  32. #2392
    Junior Member Two Rings DrewZee's Avatar
    Aug 25 2022
    2004 SRT Viper; 2008 Lamborghini Gallardo Spyder
    Gilbert, AZ
    Here's a really dumb question!
    How do I disconnect the connector on the front left strut of my 2018 S7? Is the below pic correct?
    Kind regards,
    A dumb S7 owner
  33. #2393
    Aug 14 2019
    Tampa
    I discovered same thing recently, looking for new tires. 265 is stupid prices. Get 255 or 275 and save a ton.
    18 S6
  34. #2394
    Sep 08 2021
    2013 Chevy Tahoe
    Philadelphia, PA
    Quote Originally Posted by [email protected] View Post
    The sweeping front turn signal does come with the matrix headlights. So far no one to my knowledge has fitted these to a North American model. The sweeping turn signal dynamic signal is however the same as used in the taillights. The conversion would run in the $7k range on the low end.
    Cheers,
    $7k to make my lights move.. FUCKING MADDENING
  35. #2395
    Feb 21 2019
    JKU with LS motor, 2016 3.0 TDI ,2017 Q7 Prestige, '04 CC Magna 42' '84 streached CJ7 with a 6.0ls
    Wellington Nevada
    Question on the outdoor temp sensor on my 2016 A6, whats is the range?
    I was driving through a area and it regestered 0*, so wondering just how low the sensor will display.
    Thanks
    2016 3.0 TDI Tornado Gray Metallic Prestige Black Optic Package S Line Sport Package.
    2017 3.0T Argus Brown Metallic Prestige Adaptive suspension Driver assistance 21's
  36. #2396
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Quote Originally Posted by Caryt View Post
    The display can show a negative number but I don't know how low it goes. Try resetting to Celsius to more quickly show a negative number.
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
  37. #2397
    Veteran Member Three Rings Gunmeister's Avatar
    Feb 03 2019
    Spokane, WA
    So I cleaned the interior of an Audi A6 2012 C7 the other day and now the MMi buttons will not light up and nothing is working related to MMI (entertainment, phone, navigation all say being initialized please wait). The screen also doesn't pop up anymore. Hitting menu or car buttons also does nothing. I detailed the car and I found several items in the compartment behind the cubby in the trunk on the driver's side too and I pulled all that stuff out. I already checked fuses and I'm a little lost on where to start. I'm thinking maybe I sprayed to much detailer spray near mmi controls or maybe I pressure washed near the windshield to hard I don't know but it's the only thing not working after the detail and it worked before. Any thoughts on what I could do to isolate what my problem is?20221120_134107.jpg
    Sent from my SM-S908U1 using Audizine Forum mobile app
    2016 A6 TDI | Mugello Blue, Pearl Effect Exterior | Alabastar White Interior | Audi Exclusive Line | Eucalyptus Natural Wood Decorative Inlays | Prestige Package | Comfort Seating Package | Driver Assistance Package | S Line Sport Package | 20" Black Optic Package | Cold Weather Package | 18% Ceramic Film Windows | 70% Ceramic Film Windshield | Thinkware Q800 Pro Dash Cam | Audi All Weather Mats |1 of 1 for 2016|
  38. #2398
    Aug 14 2019
    Tampa
    Sounds like too much moisture to mmi controls. error codes would help pinpoint the issue.
    18 S6
  39. #2399
    Feb 03 2019
    Spokane, WA
    When I scanned several modules could not be reached
    56-Radio
    47-Sound System
    5f-Information Electr
    17-Instruments
    Not getting any error codes just no connection except for this code
    0267 - Optical data bus open circuit
  40. #2400
    Feb 03 2019
    Spokane, WA
    Removing the negative battery cable and reconnecting fixed my issue. MMI now works fine now. What is irritating now though is I was stupid and removed the wrong fuse and now I have a transmission error and parking error and the car won't shift out of park. I tried resetting codes for these issues with no luck.
