Results 1 to 40 of 43
    Senior Member Three Rings Borg54's Avatar
    Nov 07 2005
    Sprinter Van, Too many motorcycles
    Marin, CA
    Remove Center Console and Center Trim for Audi A7 C7
    Like many folks on here I wanted to change my center trim piece but unfortunately, this job requires the entire center console be removed. Since I was unable to find detailed instructions on removing the center console I decided to take some pics as I went and hopefully help the next person. I am not an expert so if I missed a step or someone has a suggestion please post on here as well. Hope this helps!
    1. Start in the back seat by removing the rear AC vents
    2. I used a trim removal tool slid into the side of the vent. You can also use a Audi/Merc pull tool (looks like a hook) that you pull from the inside of the vent. It slots into a hole in the side, you can see it in the pic
    You should be done with the back of the console and now we need to move to the front of the car.
    1. Make sure your car is on a level surface
    2. Block your wheels with a wheel chock in case your parking brake is worn
    3. Start your car and engage the parking brake. Then shift the car into Neutral
    4. Turn the car off. (I then took the key out of range of the car so I did not mistakenly turn the car on while any of the electrical components are disconnected). DO NOT START THE CAR WITH CABLES DISCONNECTED. This will cause fault codes that you will have to remove.
    Established Member Two Rings cooncified's Avatar
    Oct 16 2013
    Orange County
    Great write up, thanks for taking the time to post!
    Senior Member Three Rings 2wookies's Avatar
    Jun 03 2016
    Omaha NE
    Why did you do this? I've missed a mod
    Veteran Member Three Rings tenspeed's Avatar
    Dec 12 2011
    Honeoye NY
    Quote Originally Posted by 2wookies View Post
    He installed a black center console.
    2012 A7 3.0T Prestige, Ibis white/Nougat/Ash, 20" Sport, ACC, LED, HUD, Ferrada FR2 wheels, AWE Touring exhaust, Adam's Drag II rotors, BlackVue dash cams
    As I've grown older, I've learned that pleasing everyone is impossible,
    but pissing everyone off is a piece of cake
    Nov 07 2005
    Marin, CA
    Quote Originally Posted by tenspeed View Post
    Correct, I also re-wrapped my carbon vinyl. I originally wrapped the center trim in place and wanted to make it a little cleaner.
    Mar 21 2016
    Columbia South Carolina
    that looks superb.
    is the trim piece on the passenger side dashboard the regular aluminum? Or did you wrap that a color to match the interior? It looks different...in a good way.
    Nov 07 2005
    Marin, CA
    Quote Originally Posted by jpru2001 View Post
    that looks superb.
    The dash trim is the original aluminum but I am going to pull that off soon and wrap in carbon vinyl as well.
    Mar 11 2007
    Colorado Springs
    Great write up, nicer looking center console. Congrats.
    2022 Q8 S line Prestige Stock
    2012 A7Plus APR Stage II+ UC
    2012 A8L 4.2
    Still own them all...
    Established Member Two Rings Roadwarrior's Avatar
    Oct 01 2016
    Atlanta, GA
    Excellent and incredibly helpful. Thanks for the detailed instructions.
    2015 Audi S6- Phantom Black Pearl Effect, Black Interior, Black Alcantara Headliner, Driver Assistance, Night Vision Assistant, Carbon Atlas Inlays, Cold Weather Package, 20" OEM Wheels. Mods- AWE Touring Exhaust, Bel STI R+, ALP Laser Shifter, RS6 Intake. On the way but not installed: Alu Kruez, Sways, End Links and Mounts.
    Established Member Two Rings BEEZER's Avatar
    Feb 13 2016
    FJ Cruiser
    Ontario Canada
    Wow! I owe you a few this will help many people 🏻
    Jun 14 2009
    GA
    Excellent write-up! Swapped out the Dark Walnut trim for Piano Black last night. Very straight forward, took just shy of 2 hours from start to finish. Would've been quicker, but I was doing it in between cooking dinner. ;)
    Thank you!
    2018 IA6 3.0T Sport | Glacier White Metallic | Black Optics | Carbon Atlas | XPEL PPF | Gyeon Quartz
    Gone, but not forgotten:
    2014 A6 P+ Quattro, Quartz Grey Metallic
    2010 A4 P- 2.0T Quattro 6MT, Quartz Grey Metallic
    2007 A4 S line 2.0T 6MT, Phantom Black Pearl
    Sep 22 2016
    WA
    Took me a few hours to complete. Took my time with the console panel removal. I had trouble removing the center console. Would not just slide out. Eventually something gave and it came out. Couldn't tell you how. Then putting it back in took some force to get the back bracket into the proper place.
    Additional small note: to release the MMI port door you will need to release a tab under it. You can see it in the picture above on the bottom left. Reach through the small area from the back and press it to the right with a finger while you slide the door off.
    Thanks again for the walkthrough.
    Junior Member Two Rings
    Jul 12 2017
    Hungary
    So I followed these steps, and after putting everything together I have quite a few problems:
    - AC doesn't work
    - Speedometer doesn't work
    - Steering wheel buttons and handles around it don't work
    - Windows only work when holding their handle
    - Parking sensors don't work
    I've checked all 3 fuse boxes and they seem to be alright. Any ideas?
    Jul 12 2017
    Hungary
    Managed to fix the problems. Turns out if you tighten these bolts too much it causes numerous errors with the car.
    Quote Originally Posted by Borg54 View Post
    Sep 05 2017
    Exeter
    Hi
    Do I have to go through every step above just to remove the silver trim to wrap it or can I follow just part 2 as I don't want to remove the entire centre console. How easy does it all go back as worried once I remove it all that it wont go back and then I will be buggered. Also don't want to put it back together to find warnings like above and then have to remove it all again. thanks
    Deactivated Three Rings
    Apr 30 2014
    Stockholm/Sweden
    Quote Originally Posted by AndrewS81 View Post
    Hi
    You have to follow every step and remove whole center console
    - - - Updated - - -
    oh me again, does this work for the A6 c7 model or is it different
    This works with A6 C7 and A7
    Sep 05 2017
    Exeter
    Established Member Two Rings David3's Avatar
    Jan 23 2012
    Slovenia
    Just what i need
    Few coins fell into cup holder lid, now i have noises in my head
    Jun 03 2016
    Omaha NE
    This will be so helpful when my CarPlay box arrives!!!
    Established Member Two Rings tutone's Avatar
    Sep 02 2010
    2018 MB C300 Cabriolet
    North Carolina
    How do I disconnect the rear A/C wiring harness with the red bar? It's #5 on the circled pictures. I'm totally stuck!!!
    Current: 2013 Porsche Cayenne Diesel and 1995 Porsche 911 C4
    Former: 2014 A6 TDI Prestige | Daytona Gray | Black Optics | Sport Package | CQuartz | Expel
    Sep 02 2010
    North Carolina
    Finally!!! This was a challenge. Thanks for the instructions!
    Apr 21 2017
    To be determined...
    MI
    I need to replace the silver trim around the shift boot on my 2011 a6, need to take center console apart or an easy fix? ty
    -Anthony
    2006 A4 2.0T 6MT APR Stage 2, Full Exhaust, and some other stuff...
    Dec 05 2016
    Chicagoland
    Quote Originally Posted by GearHead7 View Post
    For a C7 this is very easy and you just have to pop up the shift boot. If you have a 2011 your car is actually a C6 though (at least in the US).
    2012 A6 Ice Silver on Black // Rohana RFX10 // Gloss Black vinyl wrapped roof and mirrors // RS Grille and Diffuser // 35% tint including windshield // Audison Bit One, Focal KRX2, JL 300/4 and 1200/1, JL 12W6 // EPL Stage II // Vag-Com // Injen // Chrome Delete
    Veteran Member Four Rings 97B518TQM's Avatar
    May 31 2009
    CA. USA
    Great write up. Really appreciated. Took me exactly 45 minutes from start to finish to swap my center trim piece. All other trim pieces took a total of 10 minutes. This one.... 45 minutes thanks to this write up. Otherwise it would have taken me 2-3 hours to figure out all the steps on my own. Thanks Borg54.
    SOLD: B5 S4 Tial 770s with meth @652hp
    Current: C7 S6 - SRM +4mm RS turbos, SRM inlets, SRM fuel lines, DS1 stage 4 custom tune, HPFPs, X-pipe, H&R lowered
    Registered Member One Ring geramibrown's Avatar
    Dec 03 2017
    Florida
    Thanks for this! Helped me clean under my console. Sonic ocean water leaked through the cup into the cupholder :(
    May 14 2019
    Serbia
    hello
    is it in this location the Airbag Module on Audi A6 C7 2011??
    Nov 08 2018
    Fishkill, NY
    I used these directions on Saturday to run the retrofit Carplay USB cable to my center console. Worked perfectly! Thanks!
    Nov 05 2019
    Colorado
    Does anyone know if there is a fan or dampener in this center console that could restrict air flow? I’m only getting partial air flow for rear climate control. Looking through this thread cannot confirm I see a fan unit. When the car is off, I kind of hear a struggling fan. So I keep thinking that’s my issue.
    Nov 05 2019
    Colorado
    Quote Originally Posted by 2016_A6 View Post
    Did you see a fan unit in there?
    Sep 22 2016
    WA
    Quote Originally Posted by Generator5150 View Post
    If I recall correctly, there is only a snorkel that goes below the tunnel up to the vents. Don’t think there’s a fan.
    Jan 24 2020
    Bracknell Berkshire UK
    A6 C7 Front Armrest Stuck upright
    Big thanks to Borg54. The great write up allowed me to quickly dismantle my A6 front central armrest after I left my Viagra in it and it got stuck in the full up position :-) I all seriousness if you find your armrest gets stuck upright the attached photo's might show you the problem. The paul has torn the ratchet in half. Overloaded. I could not see a way to fix the problem but was able to find an Ebay replacement for £40.
    Jan 31 2009
    2016 RS7-P
    Thanks for this removal guide! German engineering is always impressive. Genius, simple and mfing aggravating at the same time.
    Junior Member One Ring Bird67's Avatar
    Mar 30 2019
    New England
    Just posting that this was a lifesaver for me. I had the console-lid-stuck-in-up-position problem and needed access to the spring-loaded tab that would release it. So glad I found this. Thank you.
    May 13 2019
    Southern California
    This is super helpful! I really appreciate the time and huge effort you put in to share this with us. I
    Veteran Member Three Rings eurospek's Avatar
    Mar 15 2008
    Chicago
    Quote Originally Posted by GripenX View Post
    I agree. I need to replace my rear HVAC vent and this makes it easier.
    Sep 12 2019
    Avalon, C10
    San Antonio, TX
    Thank you, great write up. Found this and really helped me get things apart without any damages.
    Mar 17 2014
    Texas
    THANK YOU!!!! your very detailed instructions kept me from going insane. I followed your guide to remove the rear of the console to find one of my kids had dropped a paperclip inside one of the vent holes, that kept making a metal to plastic noise every time I took a turn :)
    yay problem solved :):)
    Established Member Two Rings chydog's Avatar
    Jan 29 2017
    1996%20Impala%20SS
    Barrie, Ontario, Canada
    Hmmm So that's all you have to do 'eh ? Here I thought you'd have to take it all apart! LOL, great write up, I have had the viagra armrest twice now, dealer put it back twice but refused any further service saying its my fault for opening it to harshly, that's not the case so I don't open it in winter anymore when its happened previously, if I do I'm like a kid peeking into a shoebox to see a mouse
    2016 A6 S-Line Oolong Grey, Carbon Fiber wrapped roof/Mirrors - EBC Brakes slotted + yellowstuff pads, Renntech Monolite wheels 19x9 et39, debadged Stonecarbon RS6 grille and APR stage 2
    1996 Impala SS BBB - 383 forged stroker LT1, GM 846 cam, Advanced induction 200 cc heads + valvetrain, 3.73 rear, denny's driveshaft
    Apr 12 2021
    Columbus, OH
    Great write up. This is going to help immensely when I get my new MMI center console controller in a few days (dog puked on my current one and half the buttons/knobs wig out when I try to use them ). I'm assuming if I'm not replacing the entire center console setup and just the MMI controller, I'd just stop after the the controller comes out, set the new one in and reconnect everything? No need to take bolts out of the ashtray and all that noise, right?
    Feb 12 2022
    UK
    Yes, it did help, thank you!
    I had to remove my centre console as the cup holder lid had snapped on one side, so had to replace the cup holder itself!
