Results 1 to 8 of 8
    Jan 28 2014
    Fargo, ND
    RS7 - VAG COM Air Ride Height Adjustment
    I was reading in the A6/S6 forum that you can adjust the ride height through the VAG COM. Does anyone know if this will work on a 2014 RS7? I would prefer not to purchase a after market ride height adjustment module.
    Thanks for any help.
    Established Member Two Rings ChrisR14's Avatar
    Sep 08 2015
    2009 VW MK6
    Germany
    Yes, it will work.
    2014 Audi S5 3.0T STronic // Estorilblue
    VAG Coding and retrofit expert
    Jan 28 2014
    Fargo, ND
    Great!! Thanks for the reply.
    Established Member Two Rings JS300's Avatar
    Apr 01 2015
    NYC to Seoul
    As noted, it'll work. But for my 2014 RS7, the most I could lower before hitting the maximum setting was about 14mm, not 17mm as noted in the VAG COM thread. I'm guessing this is because the RS7 rides lower than the A/S6/7 stock.
    Before (Dynamic mode):
    After (Dynamic mode):
    Established Member Two Rings jrod80's Avatar
    Dec 18 2011
    SLC, UT
    I was able to lower mine 15mm with no issues. I haven't tried to go any lower but the current stance is great.
    Aug 09 2020
    Warsaw Indiana
    Which thread did you see this on? I can’t find it
    Jan 31 2009
    2016 RS7-P
    Feb 03 2016
    Cleveland
    I was able to get my S7 much lower, but I already had lowering links installed, so not 100% sure on the ability to lower on straight stock setup. There is a limit you are able to adjust through VCDS which is kind of annoying. I have found you can set it at 399 when 400 isn't acceptable, then just reenter 401 and it will take it.
