Results 1 to 17 of 17
    Junior Member Two Rings istaygold88's Avatar
    Aug 20 2015
    Panorama city/CA/SoCal
    Problem with cylinder 4. any help would be appreciated
    recently got back from a trip to vegas and while driving back i noticed a slight miss fire nothing crazy so i jumped ahead and assumed coil packs may be bad and spark plugs..changed them today and actually swapped 4 to 5 and then back 5 to 4 and only miss firing cylinder 4 no other cylinder...im assuming the worst and thinking its my valve thats gone bad? anything that you guys would think that could be something else? fuel injectors?
    any help would honestly be appreciated honestly...
    almost forgot i put that solution into my gas tank that cleans up carbon build up so hoping that works?
    what about sea foam? maybe that would help?
    doing the compression test after I'm done with the carbon clean up liquid..almost forgot
    summary
    miss fire cylinder 4
    new coil packs and spark plugs
    still miss firing during WOT after replacement
    only cylinder 4 though
    Established Member Two Rings audis4noob's Avatar
    Nov 21 2015
    oregon
    I had misfire in cylinder #5 I re gaped plug and it fixed my problem.
    Sent from my Z936L using Tapatalk
    Aug 20 2015
    still learning lol.
    you re gapped plug meaning?
    sorry lol
    Jul 07 2009
    Alberta, Canada
    Search spark plug gap.
    Also, these cars get quiiiiite a bit more complex than spark plug gap. Keep that in mind before really diving in.
    Jul 04 2012
    Woodbridge, VA
    Quote Originally Posted by istaygold88 View Post
    summary
    Any codes saved in ecu?
    Veteran Member Four Rings LakeTahoeQuattr's Avatar
    Jan 04 2013
    '07 JHM S6, '21 TTRS, '06 CTT, '20 Supra GR
    Zephyr Cove NV
    This exact thing happened to me last week. It was a ICM. Try swapping ICM cables from one bank to the other and see if the miss goes to cyl 1.
    21 TTRS - track whip 1
    20 Supra GR - track whip 2
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Can try swapping around cyl 4 fuel injector as well if ICM swap doesn't solve it.
    2001 Corvette (C5) Z06
    Veteran Member Four Rings CJ_'s Avatar
    Oct 27 2014
    Flag/Phx, AZ
    Compression test should tell you if a valve is bad.. Literally had the same thing happen on the way out to vegas last weekend. My thread is a few down from yours and has quite a bit of information/things you could try but mine ended up being a bad injector
    2001.5 Silver S4 Avant - 6spd swap + BW K04s (Current)
    2001.5 Santorin S4 Sedan - SRM k24 build (Totaled)
    IG: CJ_s4
    Veteran Member Four Rings 88ninety9's Avatar
    Nov 02 2012
    Four rings and a long roof
    Indianapolis, in
    Great info laid out right here. If you don't already have it, get vagcom. It's a necessity for owning vw cars
    2002 Pearl/onyx S4 Avant
    Veteran Member Four Rings MikeyB3's Avatar
    May 16 2008
    What spark plugs are you running?
    Aug 20 2015
    no codes showed up...was driving with the computer connected and watching the cylinders and 4 was the only one miss firing..then my check engine light would flash for a few seconds then disappear..
    Aug 20 2015
    alright ill definitely try that..driving around right now to try and clean up what ever carbon build up i have and then compression test..if valves come back fine ill try it
    Aug 20 2015
    stock spark plugs believe the ones NGK from ECS
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    Swap coils>ICM>plugs>injectors. After that it's
    compression check and leakdown time. You can
    check exhaust backpressure, cats, and other shit
    but that would more than likely effect a whole bank
    instead of one cylinder.
    Veteran Member Three Rings 2000s4_m's Avatar
    Sep 05 2012
    2005 vw touareg 4.2 V8
    Mcallen, tx
    summary
    You could have a vac leak, there is a vacuum hose near the throttle, check all the hoses near intake manifold
    Aug 20 2015
    Quote Originally Posted by landfill View Post
    gonna be doing the pressure test tomorrow to find out about the cylinders..after that we are doing icm and injectors. did the coil swap and spark plugs and still miss fired on cylinder 4
    Nov 02 2012
    Indianapolis, in
    You could do icm's in a matter of 30 seconds, id do that before the compression test
