Page 61 of 115 FirstFirst ... 1151596061626371111 ... LastLast
Results 2,401 to 2,440 of 4571
  1. #2401
    Veteran Member Four Rings AllroadCorbin's Avatar
    Jan 15 2014
    B5 S4 (sold) | Saab 9-3 | B8.5 Allroad (sold) |B9 Allroad (totaled) | LB7 Duramax
    Boston, MA
    Quote Originally Posted by AUDacIouS4 View Post
    I forgot to mention that I'm only running 19 psi peak boost tapering to 13.5. Requested is 22.5 tapering to 16.5......damn ginormous FMIC!!
    A custom tuned k03 E85 on meth would push another 20whp/30wtq
    Good numbers on the IHI
    B8.5 Allroad | APR | CTS K04 - SOLD
    B9 Allroad
    B5 S4 | GermanElite | SRM K24
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
  2. #2402
    Jan 15 2014
    Boston, MA
    I don’t think you’d gain 20whp but they’d likely be able to find places in the powerband where they can push it further depending on hardware and such. Regardless, nearly 300whp on the stock turbo is excellent
    B9 Allroad
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
  3. #2403
    Veteran Member Four Rings AUDacIouS4's Avatar
    Mar 11 2016
    981 Cayman GTS/ 2018 Ford F150 FX4 2.7
    Orange County CA
    Quote Originally Posted by AllroadCorbin View Post
    You need some meth.....11's are in the Allroads future
  4. #2404
    Jan 15 2014
    Boston, MA
    Kinda strange how the fastest B8 K04 cars are all the heavier Allroads. if a flex fuel A4 got in the business with us he’d prob get better times
    B9 Allroad
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
  5. #2405
    Established Member Two Rings Coldcarnival's Avatar
    Sep 25 2016
    Fairfax,VA
    What's "the business" lol? my sedan weights 3940 with me and half a tank. And I weight 170.
    Sent from my SM-G930U using Audizine mobile app
    B8.5+E85=
  6. #2406
    Jan 15 2014
    Boston, MA
    Quote Originally Posted by Coldcarnival View Post
    By that I mean was on this thread gunning for the lowest 1/4 time. it seems like all the lowest times/ people trying are in Allroads
    B9 Allroad
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
  7. #2407
    Veteran Member Four Rings Perry01's Avatar
    Jan 22 2016
    Touareg V8 FSI 8V A3 - B8.5 Q5 - MKVI GTI
    Hawaii and Utah
    And on a Mustang Dyno nonetheless....
    CPMA / CTS K04-0064 / IE custom tune / Wagner FMIC / Custom ZF8 TCU tune
  8. #2408
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    I don't even acknowledge E85 dynos as being part of the group. As great as E85 is, because it isnt available at the pump all over the nation, it's not something most people will ever see. I live in the tristate around philly, i know of ONE E85 station near the atco raceway, and not a single other in my area. Dunno why the stuff isnt more regularly available to be honest.
  9. #2409
    Registered User Three Rings MagnaFlow's Avatar
    Jan 26 2015
    Oceanside, CA
    Solid power numbers! This car looks like a ton of fun!
  10. #2410
    Veteran Member Four Rings earhythmic's Avatar
    Sep 17 2006
    ‘17 F450, ‘24 Street Triple RS
    San Francisco Bay Area
    Anyone have experience with the Killer Chiller? I’m wondering if running one and bypassing my big ass intercooler (and swapping out the big ol 20s) will get me in 11s.
    https://killerchiller.com/products/2...-turbo-kc-kits
    2013 Allroad - 12.18s 1/4 mile
    CTS K04| APR | IE | Magnaflow | AirLift 3H | Hotchkis | Vorsteiner
    clicky for build thread
    past: B6 S4, B5 A4
  11. #2411
    Mar 11 2016
    Orange County CA
    I think it's possible. The easy way is to run lightweight wheels, that will get me over 300whp on tbe dyno easy. If I'm currently only hitting 19psi peak boost and the k03 can make 22, then usually 1 psi if boost = 10whp. I need to turn the boost up and richen up the fueling. I made the most power in 5th gear which I noticed on the track is the most powerful. If you look at the lambda in 5th gear, it runs almost a whole point richer than 4th gear and makes 9whp/13wtq more power. Giac has gears 1-4 too lean and underboosted.
    I think E85 +meth + lightweight wheels +k04 = 11's.
    Somone get @Allroadcorbin and @Earythmic some lightweight wheels already!!!!!
  12. #2412
    Jan 15 2014
    Boston, MA
    That, some meth, strip the car, and try 104 octane file
    B9 Allroad
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
  13. #2413
    Sep 17 2006
    Accepting donations
    past: B6 S4, B5 A4
  14. #2414
    Jan 22 2016
    Hawaii and Utah
    Are you attributing 3+ PSI under requested due to your IC?
    After installing an IE intercooler I didn’t see much of a drop in pressure. Whatever drop in psi was made up by the cooler, denser air going into the motor.
  15. #2415
    Veteran Member Three Rings majerrahim's Avatar
    May 31 2013
    Miami FL
    It ain't gonna happen, unless you remove at least 500lb and lighter wheels , then maybe you can get close to that
    Sent from my SM-N950U using Tapatalk
    AWE EXHAUST, Downpipe, AWE FMIC , Carbonio Intake, AEM water/methanol kit, CTS BorgWagner K04 turbo kit+Test Pipe, APR K04 software E85 24/7, alu kreuz drivetrain stabilizer, KW V1 , AWE boost gauge, CTS catch can kit, Sline steering wheel with shift paddles, inlet hose, intercooler hose kit, rear diff mount, transmission mount, enkei19in with michelin pilot super sport 255/35/19, ECs slotted rotors with stainless steel lines and hawk hps 5.0, rs5 grill, SPC adjustable control arm
  16. #2416
    Mar 11 2016
    Orange County CA
    Quote Originally Posted by Perry01 View Post
    That was my thinking. The turbo is probably generating the correct amount of boost pressure but it gets reduced by the larger volume of the intercooler. Its like you said, slightly less boost pressure but it's colder/denser so it generates more power. On a k04 or bigger turbo, the bigger FMIC wouldn't affect boost pressure but with the smaller JH5 it does.
    I just sent GIAC some logs and my dyno. They think I can run about 10* more timing and likely make another 20whp mid range and up top. They said the JH5 (k03) isn't going to move any more air than it already is, so that's tapped out. The only way to make any more power is timing advance, and lots of it.
  17. #2417
    Jan 22 2016
    Hawaii and Utah
    Your lucky to have access to E85. With the higher octane, your tuner can really advance the timing to generate more power without knock.
    I’m still wondering if you have a boost leak somewhere. My stage 1 with a stock IC produced 23 PSI peak tapering to 15 psi at 6k RPM but only 3.5° of timing advance up top using 92 octance pump gas.
    https://datazap.me/u/perry01/q5-stag...37&tmax=108.56
    How much timing advance are you seeing up top?
  18. #2418
    Mar 11 2016
    Orange County CA
    14* advance up top. GIAC said I could probably run 20* or more
  19. #2419
    Jan 15 2014
    Boston, MA
    Quote Originally Posted by majerrahim View Post
    Yea you’d have to basically strip the car to the frame to go under 12. The amount of incremental power/ weight loss needed to go lower on time after a certain point starts becoming exponential
    B9 Allroad
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
  20. #2420
    Mar 11 2016
    Orange County CA
    So what are you waiting for? Who doesn't want a gutted Allroad? So much more practical. Im sure the drone wont be that much worse? Might be a little uncomfortable for passengers, "hey, you might not want to sit on those exposed bolts!!" but they'll get over it once you hit the throttle. Sarcasm off.
  21. #2421
    Veteran Member Four Rings hyperunion's Avatar
    Sep 03 2012
    07 Xterra 4X4 , 02 20V Passat variant.
    Lehigh Valley, PA
    I'm really considering cts's kit !. With apr's tune!.. especially running my light weight 18lb wheels.. and my easy access to over 75% ethanol!...
    Sent from my Nexus 7 using Tapatalk
    B8.5 A4 Premium +, ZF8, APR Stg II+ E85, APR HFC Downpipe, APR Carbon Intake, APR Intercooler, APR T.M. Delete, AWE Quad Exaust, ECS turbo inlet hose, H&R coilovers , H&R F&R Sway Bars, Q5 4 Piston Brembo upgrade, ECS Slotted rotors and stainless lines, OZ Ultraleggeras, Piaa, 3M Crystalline, Xpel Ultimate. IG: "Veritech1"
    RIP: B6 A4 Sport, AWE GIAC rSK04, Bilstein PSS9, OZ SL.
  22. #2422
    Sep 03 2012
    Lehigh Valley, PA
    I believe apr's tune's timing for the st2 is set Higher!. Remember Boomtime.. he ran similar power to you at 290 something.. but much more awtq like around 385lbs!. At around 50% ethanol!. And 0 meth kit , stock airbox... Stock exaust...
  23. #2423
    Aug 04 2010
    Queenz/Westchester
  24. #2424
    Veteran Member Four Rings lettuce's Avatar
    Jun 19 2015
    Boston
    Quote Originally Posted by shonseb View Post
    Finally! Man, that's awesome. Been getting so discouraged by the BT posts on here lately. This restores my hope in our platform.
    B8 A4 - Eurodyne-tuned F23L - 12.6 @ 107 on 93
  25. #2425
    Sep 17 2006
    That looks awesome. But when I get to the point of built internals I’m building one of these for less than what I have put into my current AR:
    past: B6 S4, B5 A4
  26. #2426
    Veteran Member Three Rings B8_Dude97's Avatar
    Sep 05 2016
    Antioch, California
    The s4 guys better look out. Couple more bt builds and we're looking pretty good.
    This is the same turbo apr ran a 12.2 with and this guy ran a 11.7 with fueling upgrades
    ...they said it would never happen....
  27. #2427
    Veteran Member Four Rings Zach L's Avatar
    Feb 23 2010
    Austin, TX
    Quote Originally Posted by lettuce View Post
    As expected, that horsepower required the Bosch GM Ecotec injectors, an upgraded Autotech HPFP, and even then he's running a multi-port water/meth system with a custom controller. Everything continues pointing to the fueling system (and the tuning to support the upgraded components) as being the major single obstacle to overcome on this platform. I think think we can get 370-420 awhp from the factory system max. I don't think it was mentioned in that thread, so I inquired about who did the tuning.
    That said, the experience from builds like that A5 and other VW TSI engine builds is starting to provide some real clarity on what works. That's a good thing!
    Daily Driver: B8 A4 quattro 6MT, Aruba Blue on Black, Premium Plus, Sport Package, Bang & Olufsen
    Current Projects: 2006 Cayman S 6MT • 2006 VW GTI 2.0T 6MT • 1997 VW Golf • 1982 VW Rabbit Diesel • 1972 VW Bay Window Bus
  28. #2428
    Mar 11 2016
    Orange County CA
    "That's A LOT of money Al !! Maybe it's time we re-think our decision making paradigm?"
  29. #2429
    Jan 15 2014
    Boston, MA
    Quote Originally Posted by Zach L View Post
    420whp on the stock fueling is a pipe dream on the B8 2.0
    B9 Allroad
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
  30. #2430
    Feb 23 2010
    Austin, TX
    Just for clarity, I'm talking about with a true big turbo; not a K04. Initially, yeah it's a pipe dream even with the bigger turbo, but with time I think it'll happen.
    That's how it happened for the Mk6 TSI. There were GTI making more than 370whp on stock fueling about 6 years ago. Then over the years with tuning revisions, 420whp on stock fueling hardware. That's with 93 octane and no water/meth. That's been the case for more than 2 years now.
    The B8 stock fueling system is just as capable as the Mk6 GTI. Our current problem is there's not enough people pushing the limits, and now that the aftermarket injectors are becoming more common I assume people on our B8 platform will just jump to using those rather than really pushing the factory fueling system to its true limit.
  31. #2431
    Nov 20 2016
    Even 300whp seems to be a pipe dream on the K04 on pump gas. lol
  32. #2432
    Feb 08 2017
    Quebec
    Quote Originally Posted by Spawne32 View Post
    I know right
  33. #2433
    Sep 25 2016
    Fairfax,VA
    I think that's possible on 93 , but not on a mustang Dyno lol
    B8.5+E85=
  34. #2434
    Feb 23 2010
    Austin, TX
    More info on that Big Turbo A5, related to K04 discussion:
    Quote Originally Posted by wlcr View Post
    Quote Originally Posted by RockJGC View Post
    Nice....but how's the turbo lag? I'd imagine it's got almost all of it's power in the upper rpm's, no?
    Here is the graph, I have more than enough torque at 3k rpm. After K04 I don't feel much difference in spool.
    Nice build. Who did the tuning?
    Thanks)
    All software (ECU and TCU) by AGPMotorsport. It's a Russian company specialized in custom tuning.
  35. #2435
    Aug 17 2015
    California
    When does everyone's K04 spool up?
    Maybe crossing 20 psi is a good measuring point. Can you hit this around 2500 rpm, or is it more like 3000 rpm?
  36. #2436
    Mar 11 2016
    Orange County CA
    That graph doesn't have Tq And HP cross at 5250 rpm. Is the Hp - Nm relationship different?
  37. #2437
    Veteran Member Three Rings Brandon K.'s Avatar
    Apr 17 2016
    2017 Golf R, 2018 Q7 3.0T, 1991 Saab 900T
    Vancouver WA
    Can someone please explain to me why they need to cross at 5250 rpm? I know a good amount about cars (been my hobby for 25 years) and have an engineering degree and I have only read this information about it crossing at 5250 on this board. I don’t understand why/how I have never heard of this before.
    Thanks
  38. #2438
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Quote Originally Posted by brandon k. View Post
    can someone please explain to me why they need to cross at 5250 rpm? I know a good amount about cars (been my hobby for 25 years) and have an engineering degree and i have only read this information about it crossing at 5250 on this board. I don’t understand why/how i have never heard of this before.
    Thanks
    sent from my iphone using audizine
    hp = (tq*rpm)/5252
    HP is just a measurement of torque over time
  39. #2439
    Aug 31 2011
    Lathrop
    NM is a higher number than TQ so it will cross sooner.
  40. #2440
    Jun 19 2015
    Boston
    Quote Originally Posted by Brandon K. View Post
    Thanks
    Where did you buy your engineering degree from?
    Joking
