-Stage 2 Upgrade (This Post)
-Carbon Cleaning
-Frankenturbo F23L Upgrade
-Hotchkis Sway Bar Upgrade
-UR Strut Tower Brace and Sway Bar Review
-Modified Fog Grilles
-Treadstone Intercooler Upgrade
-Treadstone FMIC IAT Logs
-Track Performance - 12.7 @ 106 and more logs
-Yet another track night - 12.6 @ 107
-New 034 Motor Mounts and Transmission Insert
-ECS Catch Can Install (Removed and RMA'd)
-Teaser
-Valve Seal Replacement
-Suspension and Wheel Install Post 1
-Suspension and Wheel Install Post 2
-Methanol Injection
-4-Piston Q5 Brembo BBK Install
-Bespoke Flat Bottom Steering Wheel
-B8.5 2.0T Engine Swap
-Ram-air brake ducting setup with EBC Red Stuff pads
-White letter tire stickers
-F23L Rebuild, PTP Turbo Blanket, and new HFC
-Replacing snapped front axle
Current pics:
(as of 6/16)
(as of 11/19)
Stage 2 Upgrade:
I've had my '09 A4 2.0t for about 3 months now and I have some pretty big plans for it, so figured I'll start one of these now and update it as I go. As it stands right now it's stage 2 and looks bone stock (minus the badge delete). Engine mods are probably done for the near future as I'm pretty happy with how it performs in that department, so now I'll be focusing my attention on handling and braking. More on that later, here are some pictures of the install process from my engine work so far. I also do all my own work, and although when it comes to this car I'm certainly no expert and am still learning, I'd be more than happy to answer any questions anybody has regarding the stuff I've done and have experience with.
3.0 TDI Intercooler:
Bolted right up to the stock mounts and hoses, but the diameter of the hose ports was slightly larger than stock on the new IC, so I had to really coax the old pipes on there. Lubing up the outside of the IC pipes with a tiny bit of grease helped a bit. In my opinion this IC is perfect for the level of power stage 2 provides, and anything larger isn't really necessary until you get into the larger turbos. And at 1/5 - 1/10 the cost of most aftermarket intercoolers, it's a great value.
Go Fast Bits DV+ Diverter Valve:
Got it simply to replace my stock valve as I had a hunch it wouldn't last long with the new tune, and was pleasantly surprised with its performance. Although I didn't buy it for this, it also adds a bit of sound to the turbo, which I've decided I like. I'd recommend this to anyone upgrading to stage 1 and beyond.
Eurocode High Flow Cat with DEI Titanium Heat Wrap and O2 spacer:
Funnily enough I was a little worried about getting a CEL after the HFC install, so I was kicking myself for forgetting to order a spacer. Went to take the old stock cat off and there was already a spacer on there, so I just reused it. Put about 100 miles on the car over the weekend after the install and no CEL yet. Thanks previous owner or dealership trying desperately to hide a CEL. You saved me a few bucks.
The install itself however sucked so many dicks. The turbo bolts were easy enough to get off, but the HFC to DP nuts seemed to have devolved over the years into garbled blobs of rust and contempt. They honestly weren't even nuts at this point. I realized pretty much immediately these were going to have to be cut off, and thankfully they weren't screwed into bolts, but studs which seemed to have welded themselves into the DP flange, so they would have to be drilled out as well. I was then happy to find out that these studs were made out of some kind of Skyforge-hardened steel that required about 20-30 minutes of intense drilling each to get them out. After that was all done and the studs were made into a pile of steel dust and replaced with nice new bolts and nuts, the reinstall went pretty smoothly. Another highly recommended mod for the masochistic do-it-yourselfer.
In case anyone was wondering what the difference was between the stock cat and high flow version in terms of construction, here's a side-by-side view inside both. It's pretty apparent where the performance increases come from.
Eurodyne Maestro Stage 2 ECU Tune:
Highly recommend the Maestro Suite if you're technologically-literate, have a lot of patience, and plan to tune your car more than once. If not, I highly recommend something else. Customer service is non-existent, emails are replied to within 5 minutes when inquiring about purchasing the product, and then I'm almost positive the Paypal submit button has some code linked to it that automatically adds your email address to his spam list. I've even submitted semi-detailed bug reports and got nothing. I've also found dozens of dead links all over the internet pointing to what apparently once was a thriving forum community on his website which discussed and detailed all the workings of his software for intrepid users such as myself. For whatever reason this was deleted, and there is zero official documentation on how to use any of his software.
I don't personally have anything to compare them to, but the stage 1 and stage 2 base files I've flashed so far seem to be pretty good, but I'm also under the assumption that they are not as finely-tuned as the files from a company like APR, GIAC or Revo. So if you're not fine-tuning them then it's possible you might be leaving a bit of performance on the table, although honestly probably not very much. [Edit two years later:] Disregard this, everything I've heard from people who have switched from some other tuner to Eurodyne has said how much smoother and more powerful Eurodyne is. The man who wrote these base files knew what he was doing.
Overall the software works for me and my needs, but I hesitate to recommend it to anyone even remotely squeamish about being left completely on their own to do something like this. If you're the kind of guy that likes to flash new ROMs on your rooted Android phone then this is the software for you. If you're the type that's too worried about bricking your phone, imagine yourself bricking your $20k car, do a 360 and drive away to your nearest APR dealer.
Beyond this I've done some more boring stuff like a new fuel filter, afe air filter, ECS turbo inlet hose, badge delete in the rear, new NGK Laser Platinum plugs, etc. I also have an A118-C dashcam hardwired into an accessory fuse which I can't recommend highly-enough. Under $100, 1080p and looks stealthy enough to be confused for a stock add-on. Google it, Amazon it, UPS it and install it. You'll wonder how you ever drove without it. The peace of mind it gives you knowing it'll vouch for you if you ever slam into some bozo who just blew a red light and there are zero witnesses to profess your innocence is invaluable.
After all this, it still looks Stock:
All this completely transformed the way the car feels. I did a quick stage 1 flash for a few days before I got around to installing everything, and while that was a pretty big step up, stage 2 just took it to a whole nother level. Stock, the car felt like it wanted to go fast but was holding back. Even stage 1 felt like it was leaving quite a bit on the table. First gear sucked as it took what felt like an eternity for the turbo to spool up, and then after an all-too-quick ride in the K03 turbo spike rocket ship I was left to anguish in high-RPM purgatory where I felt like I was barely accelerating anymore, but knew that upshifting early would leave me right back where I started. Second and third were decent, but still was always left wanting.
Stage 2 with these mods completely changed all that. Not only does the turbo spool up so much faster, but I feel like I actually have some power before it does so. Then second hits and I'm off for the ride, and if I can't manage to muster up the ever-increasing amount of self-restraint this car is requiring of me, third gear will have me up to 100 mph in no time at all. Not to mention the sound difference. The car just sounds so angry now. The added boost from the tune gave it a really mean growl, the HFC gave it a bit of low-end bass, and the GFB diverter valve and high-flow air filter gave it a nice high-pitched turbo whine with a subtle but very satisfying "psssh" when I let off the throttle.
I was planning on a turbo upgrade soon but honestly this will probably hold me over for quite a while. At least till next summer, or until my wastegate finally gives out. If anyone reading this is on the fence, just do it. Stage 2 will completely transform your car and life in general. The first time you mash through the gears you'll feel like a kid again, getting your first blowjob in the back of the 6th grade detention hall. You'll look to your future and think "Man, this is gonna be great."
Weekend after next I'm going to tackle a carbon cleaning. Bought two cans of BG Induction System Cleaner as recommended in this post. Anyone have any tips on cleaning fuel injectors as well? Should I just dump some of this stuff in my gas tank or would it be better to just take them out and clean them manually?
Anyway, in the not too distant future I'm planning on doing some suspension and brake upgrades. I'm leaning towards sway bars to start, and then I want to grab a big brake kit. Trying to decide between the Q5 and RS big brake kits from ECS. Want to do something with the rears too, and not spend much over $3k, so will probably go with the Q5s. Anyone with experience with either of these (or something else in that price range) I'd love to hear your thoughts. Also anyone who has done handling upgrades I'd love to hear what you think are the best bang for your buck upgrades are. I'm not too keen on lowering it with wheels just yet, really trying to keep the stock appearance, but pretty much everything else is on the table.
Lastly, here are some pics I took about a month ago:
