Results 1 to 28 of 28
    Mar 20 2012
    2012 Audi Q5 2.0t
    portland or
    will I hate life on 20s?
    So im hating how bad the stock 18s look. Im looking at some 20x8.5 et25 but worried it will ride too rough? I drive about 1500-2000 miles a month.
    Thoughts?
    2012 Q5 2.0T
    2010 A6 3.0T
    2004 A4 Avant 6spd 1.8T (SOLD)
    1998 A4 quattro (SOLD AND MISSED)
    2006 Suzuki sv650
    Established Member Two Rings Blockburner's Avatar
    Aug 16 2015
    boston
    The et is crazy but 20s ride good. I have some vossens for sale.
    Jul 17 2011
    Sin City, USA
    As blockburner said, that offset is crazy. Are you lowered? If you are, you will be pushing tire into sheetmetal as these wheels will cause the tires to poke out past the fender line. Plus, it is not the size of the wheel that dictates how rough the ride is going to be, it is the tire (specifically the aspect ratio) that will determine ride quality. What size tires are you looking at running?
    '09 C6.5 A6
    Feb 25 2016
    San Antonio, TX
    I have 20's on my A5, set of OEM RS5 wheels with a slightly higher tread rating than the stock Pirelli tires. Only problem with 20s if you don't check your tire pressure regularly, a pot hole can seriously eat your tire/rim. The ride isnt as smooth as a 18 with a wider tire side wall, but then again I don't zoom through sh***y roads anyway.
    How are your road conditions?
    I have some great deals on Vorsteiner FF's if you are interested.
    Mar 20 2012
    2012 Audi Q5 2.0t
    portland or
    I thought et25 would be good since the wheels are only 8.5? but I could do et35 if thats better. for tires I want to stay stock rolling diameter so it looks like that would be a 255/30/20
    2012 Q5 2.0T
    2010 A6 3.0T
    2006 Suzuki sv650
    Feb 06 2013
    CA
    Quote Originally Posted by seanentrust View Post
    If you have good roads, 20s will be ok, but like everyone else here has said...ET25 is a bad idea. I'd stick with 30, at most. Also, the ride WILL BE HARSH, since you'll have less rubber to provide any cushioning.
    Veteran Member Three Rings cal3thousand's Avatar
    Feb 19 2013
    2006%20Audi%20A8L%3B%201994%20Volvo%20850%20Turbo
    All good info so far.
    What I would say is that it also depends on your tolerance for bumps and feeling the road imperfections. Then, you also have to think about how heavy that wheel and tire will end up being. You are adding unsprung rotational weight to your ride, unless you get some very light 20s.
    Also remember that there is a middle ground between 18s and 20s. It's pretty hard to tell 19s from 20s at a glance since we are talking rim diameter and not real lip diameter, so some 19s may look as large as some 20s.
    Danton Black: 2009 Audi C6.5 A6 Sedan (Quattro, 3.0T, Prestige)
    I miss my Avant, longing for a 2011 3.0T
    Dead:
    Griselda, aka Grizzy: 2007 Audi C6 A6 Avant (Quattro, S-Line)
    Just some small cosmetic mods while getting to Stage 0
    Veteran Member Three Rings callaghan.'s Avatar
    Apr 08 2009
    DO IT.
    20'S Fit so nicely on C6's. I'm running 20x10 et40 all the way around. Just a slight roll in the rear and i get no rubbing...also have no wheel gap. I road trip all the northeast with a wife and baby and it's a smooth ride.
    avantlife.
    Feb 15 2016
    Salt Lake City, UT
    I have a question about putting 20's on mine.
    I have the 2010 A6 Prestige with sports package. As of now I have 19 - 8.5 et 48 with 20mm spacers that came stock with car. Will I be able to lose the 20mm spacers and be OK?
    Thanks
    Veteran Member Four Rings jbrentd's Avatar
    Oct 31 2005
    '13 allroad, '91 Coupe Quattro, '64 Corvette, '93 Corvette, '21 Bronco
    Tulsa, OK
    I loved the looks of the 20s (20x9 et35) on my C6, but the roads on may daily commute were not kinds to them. I think I had them for about 9 months and had to replace two tires and repair a cracked rim.
    1991 Coupe Quattro - Project Car
    2013 allroad - My DD
    2011 A3 S-Line - Son's DD
    SOLD - 2007 A6 4.2L // 2001 Pelican A4 Avant // 1996 A4
    Veteran Member Four Rings ichi d's Avatar
    May 10 2013
    Toronto,ON
    I'm upgrading to 20x9 et37 this summer and will be using 245/35/20 tires for the extra depth in sidewall. My old setup was 19x9 et52 Tt-rs peelers with 255/35/19 tires. Giving that I'm still going to run the same 35 series tire I think the ride should be close to the same as my 19s. Maybe even a bit softer because I went with Dws06 this vs pss.
    C7 S6 / AWE Touring / -14mm / EuroTails /
    Jul 17 2011
    Sin City, USA
    Quote Originally Posted by ichi d View Post
    Actually, the 245/35/20 wil be thinner sidewall than the 255/35/19. The "35" is the aspect ratio of the sidewall comparded to the width of the tire calculated as a percentage. So 35% of 255 is greater thatn 35% of 245.
    '09 C6.5 A6
    May 10 2013
    Toronto,ON
    Yes you are right sin. What I meant was the 35 is a higher profile then a 30 series tire so I was hopping it will help with the pot holes around my town so I don't end up cracking a rim. Now all I hope is I don't get any rubbing issues.
    Mar 28 2016
    2006 Maserati Coupe GT, 2004 Ram 2500 Diesel, 2012 VW Turbo Beetle, 2014 Yamaha FJR1300
    On my truck I went from 20's back down to 18's because the ride was so bad. The S6 with black optics pkg comes with 20's which was a big concern. Factory settings and the air suspension are a big help. The car rides great on them so I don't see any concerns at this point. Taking a 1500 mile sub 19 hour trip through the high desert in a week and I will report black after some hard fast miles.
    Apr 21 2005
    Alpharetta, GA
    You will be perfectly fine with 20x8.5 et25...I ran 20x9.5 et35 with my Carlssons (which is 2mm more aggressive) and now run 20x10 et20 with my AGs (which is 23mm more aggressive).
    Throw some 235/35 on there and you will have a nice flush stance.
    Instagram: @riegeltheaters
    2001.5 VW Passat 1.8T | Rest in Pieces
    2002 Audi allroad 2.7T | Sold
    2010 Audi Q5 3.2 S-Line | Sold
    2006 Audi A6 4.2 S-Line | Sold
    2007 Audi A3 3.2 S-Line | Sold
    2008 Audi RS4 | Current
    2008 Mercedes G55 AMG | Current
    Mar 20 2012
    2012 Audi Q5 2.0t
    portland or
    if I want to run 255/30/20 am i better off running et35 instead of et25?
    2012 Q5 2.0T
    2010 A6 3.0T
    2006 Suzuki sv650
    Feb 06 2013
    CA
    IMHO, yes, since at +25, you will probably need to roll your fenders to ensure you don't shred your tires.
    May 10 2013
    Toronto,ON
    so at et37 with 245 i should be safe? i am lowered with 1 finger gap.
    Apr 21 2005
    Alpharetta, GA
    Any reason for wanting to run that tire? Is your goal a wider contact patch or a large sidewall? 235/35 is more than wide enough for an 8.5'' wheel and will give you a large sidewall (read: more comfortable ride) than a 255/30.
    However to answer your question, yes you would probably be better with an et35 that should have no risk of rubbing and if needed you can always throw a small spacer on there to dial in the stance a little bit.
    - - - Updated - - -
    You're fine. Nothing to worry about.
    Mar 20 2012
    2012 Audi Q5 2.0t
    portland or
    Quote Originally Posted by rollininstyle04 View Post
    - - - Updated - - -
    I want to run at least a 245, which is the stock width I'm running now, I'm not interested in running a narrower than stock tire. if i run a 245/35/20 thats 4% difference in stock, a 245/30/20 is the closest to stock
    2012 Q5 2.0T
    2010 A6 3.0T
    2006 Suzuki sv650
    Apr 21 2005
    Alpharetta, GA
    That's fair. Stick with the 255/30 and et35 then to avoid any potential rubbing issues without having to roll or modify anything.
    May 10 2013
    Toronto,ON
    my stock tires are 255/35/19 and moving to 245/35/20 puts me at a 2.7% difference. i think you will be find if you decided to go 245/35/20.
    Senior Member Three Rings SindreVjohnsen's Avatar
    Dec 21 2014
    Norway
    Always had 20s on my cars :) You can feel the road but if ur paying atension and avoiding pit holes etc you will be fine.
    Even had 20s as winter on my old car. That wasnt that nice :P
    -Artic White Avant, 2.7 quattro
    - Audi A6 Avant , Shadow Line , ABT kit. (sold)
    Apr 08 2009
    Quote Originally Posted by jbrentd View Post
    Jesus, what kind of wheels and tires were they? I have 20x10's on 255/35 and drive all over the northeast, including the notoriously horrible NYC roads, without issues.
    avantlife.
    Oct 31 2005
    Tulsa, OK
    Quote Originally Posted by callaghan. View Post
    They were 20" Peeler repros on 255/30 Falkens (iirc). I guess I didn't pay close enough attention to the potholes. They are a little harder to react to and do more damage when they are coming at you at 70 mph.
    Jun 02 2015
    2011 A6 Avant
    Ste-Marthe-sur-le-Lac, QC
    I went with OEM 20x9 ET37 on 255/30R20 Toyo Proxes 4 Plus, been on the car about 6 weeks now. Besides paying a little more attention to potholes, I wouldn't complain about them.
    Mar 20 2012
    2012 Audi Q5 2.0t
    portland or
    decided to go with 19s but undecided on peelers or rotors?
    2012 Q5 2.0T
    2010 A6 3.0T
    2006 Suzuki sv650
