Results 1 to 21 of 21
    Senior Member Three Rings MBrock's Avatar
    Oct 24 2012
    Anyone Used H&R Springs To Lower A RS7?
    My 2016 RS7 will be here soon, so I've been shopping. My car will have the sport suspension and I'd like a moderate drop . I reviewed the old threads and I know some have done KW coil-overs but I'd prefer not to use them.
    The Tire Rack lists these Sport Springs fitting a 2016. Does anyone have any experience here? I'd like to know how difficult the install it is (for the shop) and does the new height require any ECU/TCU reprogramming.
    Any help would be appreciated.
    The Springs: http://www.tirerack.com/suspension/s...er+Valve+Stems
    Senior Member Two Rings vic55's Avatar
    Apr 15 2013
    The Orange County
    Thread revival! Was hoping someone had used these springs and could give feedback vs the KW HAS in regards to the drop and ride handling.
    2018 E63S Edition 1
    2017 RS7 Performance
    2017 Audi R8 V10
    2016 AMG GTS
    2012 Mercedes Benz C63 AMG Black Series
    Established Member Two Rings bobbyfali's Avatar
    Aug 14 2008
    Brampton, Ontario, Canada
    I know this is a very old thread, but does anyone have a review of their experience with the RS7/DRC & H & R lowering springs?
    08 997T/PROTOMOTIVE 63.5 VTG / E85:60-130 5.9sec(94 PUMP 6.9sec)
    16 Audi RS7: DS1 93 (Mitch Tuned) & MIRZA TCU TUNE (only mods ECU/TCU tune on 94 PUMP) 0-60:2.74, 1/4 : 10.74 @ 131.1, 60-130: 7.74
    02 996T / EPL BILLET K16 / 94Pump 60-130 7.45 (stock intercoolers) / Gone!
    Junior Member Two Rings
    Jun 27 2014
    GA
    Quote Originally Posted by bobbyfali View Post
    I have a set sitting in the attic that I want to put on. I've heard that you can do it without removing or discharging the DRC but would like some input as well.
    2016 RS-7 performance - Nardo
    2018 F-150 Raptor - Leadfoot
    1995 3000GT VR-4 - Black
    Feb 16 2019
    Minneapolis, MN
    Quote Originally Posted by GTOGSXR View Post
    I took off the OEM springs and added these from KW to the DRC - didn’t change out DRC.
    Feb 16 2019
    Minneapolis, MN
    Btw - willing to sell the OEM ones for cheap if anyone’s interested. Think they only had a few hundred miles on them since I pulled them off a new RS7 about a year ago.
    Senior Member Two Rings Serpex13's Avatar
    Jul 18 2019
    2011 GS Corvette
    Illinois
    What are the benefits of adding these springs over oem?
    Jun 11 2012
    2021 Audi SQ5 | 2019 Audi TTRS | 2004 Audi S4 (parted out) | 2000.5 Audi S4 (sold) | 2001 Audi A4 1.
    Corona, CA
    Quote Originally Posted by Serpex13 View Post
    Lowering springs lower the car making it look more aggressive.
    Established Member Two Rings Jasen's Avatar
    Jul 09 2019
    Q5
    Atlanta/ Ga
    Also looking for anyone out there who has tried the H&R sport spring set for a RS7 DRC. Not the coil overs just springs. Any feedback would be much appreciated. I like to idea of lowering car approx. 1”.
    Aug 14 2008
    Quote Originally Posted by Jasen View Post
    I would love to know as well, because once it is lowered I do t care or never plan to change the ride height again.
    Anyone ?
    Jul 09 2019
    Q5
    Atlanta/ Ga
    I ordered them today. Install is sched for 2nd of Nov. I’ll write a review once done. Price is reduced for the springs right now so not a huge investment if things go south.
    My only real concern is if my wheels will rub once lowered. ADV5.2 M.V2 21x9 I don’t know the offset (hub shows +18) but they have a more pronounced offset than factory. With DRC it says springs lower an estimated 1.2” front and .8” rears. Here are pics of wheel well gap heights stock.
    Jun 27 2014
    GA
    I have mine installed and noticed that the rear sits a little higher than the front. Did a little research and found that others with DRC on other cars (RS4 etc.) have removed a plastic spacer when installing the springs and am wondering if that is needed on the RS7 as well as I did see this spacer when installing. I also added SPC adj. control arms to adjust the camber. I am running 21x10.5 with 275/30/21 and have not noticed any rubbing but I have not driven very hard yet. The 275s do have a little stretch on them so that helps out some.
    post #985 in this thread
    https://www.audizine.com/forum/showt...=1#post8318644
    Jul 09 2019
    Q5
    Atlanta/ Ga
    Update. My modification woes continue. Car looks amazing lowered. But the 1.2” drop up front with my after market wheels is causing it to rub pretty bad on the front fenders. Removed that little screw on the inside of the wheel well which helped but still catching the fender. Taking it tomorrow to roll front fenders. Praying this fixes it or it’s back to stock setup.
    I did pull the green bump stop or spacer from rear springs. Drop was as advertised by H&R 1.2” front and .8” rear
    Image1607977412.265687.jpgImage1607977430.332359.jpgIMG_0799.jpgIMG_0797.JPGImage1607977481.865055.jpgImage1607977491.835863.jpg
    Jan 31 2009
    2016 RS7-P
    Can't tell your tire size, 275/30-21? If you're rubbing in the front you can certainly add in some negative camber.
    Jul 09 2019
    Q5
    Atlanta/ Ga
    Yes. I’m on factory size tires with the ADV1’s. Much more aggressive offset. After spring instal he did an alignment. It’s around 1.9degrees or so up front. Basically max with stock control arms. I could throw money at it and do control arms or swap to coil overs but for the money I’m thinking if rolling the fenders doesn’t work go back to stock.
    Junior Member One Ring WarEagleRS7's Avatar
    May 01 2019
    2018 GMC Sierra Denali 1500
    Salt Lake City, Utah
    Did rolling the fenders ever fix the rubbing. Current set up on my 15 RS7 275x35x20 with H&R Springs. Hate the rub on front fenders.
    Jul 09 2019
    Q5
    Atlanta/ Ga
    Quote Originally Posted by WarEagleRS7 View Post
    I didn’t roll them. Swapped to KW height adjustable springs. I would still like them rolled so I can go lower but haven’t found anyone to do it.
    Jan 16 2021
    Reno NV
    Did you have to do anything with the DRC system (i.e. drain and refill)? Or just hot swap the springs?
    Jul 09 2019
    Q5
    Atlanta/ Ga
    Quote Originally Posted by ChickenJoeMF View Post
    Just swap the springs
    Dec 16 2021
    OrangeCo/New York
    I've seen the KW instructions that seem to indicate swapping springs while maintaining hydraulic connects straight forward... is this actually the case?
    Did a similar swap on previously owned RS4 and it was tough to avoid stressing hydraulic lines.
    Jul 09 2019
    Q5
    Atlanta/ Ga
    Quote Originally Posted by Florettrs7 View Post
    https://www.kwsuspensions.com/extras...-h6881000K.pdf
    I had a shop put on H&R lowering springs initially followed by KW height adjustable springs. Neither shop removed or messed with the dynamic ride hydraulic lines (RS7) The KW instructions above show how it’s done. Just remember to remove the front springs perch if you use KW and remove the spacer on the back spring perch. I’m pretty sure I’ve posted about that and included pics in this thread or another about the headache that caused me. Good luck
