Page 261 of 262 FirstFirst ... 161211251259260261262 LastLast
Results 10,401 to 10,440 of 10451
  1. #10401
    Aug 12 2024
    Dallas
    Had some 15mm spacers laying around in the garage, I wanted to see how aggressive 20x9.5 35et would look like.
    I'm not a fan of these wheels and have some RS5 rotors that I'm going to replace them with.
    [IMG]https://ibb.co/BV66FFLh[/IMG]
    [IMG]https://ibb.co/pvvVkKwN[/IMG]
    [IMG]https://ibb.co/TMs3pwft[/IMG]
    [IMG]https://ibb.co/nswCCzn7[/IMG]
    [IMG]https://ibb.co/PG9k4LCN[/IMG]
  2. #10402
    Established Member Two Rings steve trac's Avatar
    Aug 21 2010
    Morristown, NJ
    Quote Originally Posted by jeff351 View Post
    Replacement pads came in so i taught my son how to change brakes
    Is this a different grey car with ceramic brakes than your post a couple weeks ago about upgrading pads?
  3. #10403
    Senior Member Two Rings jeff351's Avatar
    Dec 16 2020
    2015 Q5 Prestige TDI, 2016 RS7 Performance
    oklahoma
    Quote Originally Posted by steve trac View Post
    No, i broke one of the pads being an idiot and the second set arrived so i did the passenger side. but it was a nice day so i parked it outside and let the kid learn. we ordered some new pads for his sti and i'll let him takle those next week when they arrive from brembo
  4. #10404
    Veteran Member Four Rings m_haiser's Avatar
    Apr 24 2011
    2012 A6 Prestige, 1998 Jeep Cherokee XJ
    Central Willamette Valley
    Quote Originally Posted by Ryes7 View Post
    Mostly just used my school facilities to CNC an adapter to run the 84mm throttle body. Might be able to reproduce it if someone needed one. I do have the SOLIDWORKS and mastercam programs I wrote
    Sent from my Pixel 8 using Audizine Forum mobile app
    It's to the point where all the problems just run together in a spider web of disappointment and mush.
    -CELison
  5. #10405
    Veteran Member Three Rings Botbasher's Avatar
    Jul 26 2018
    2014 S6 "Elsa" - Mk 6 JSW - Scratch Built Lotus 7 Replica
    Humidity, NC
    Replaced what I thought was a "marginal" failed passenger motor mount. SURPRISE!!!! 100% failed and had a few unexpected things waiting for me!
    Three things that none of the DIY's mention...
    1: unless there is evidence of fluid leaking from the mount, assume there is about 500cc of hot coffee temp oily fluid residing in the mount. So when you are manipulating and rotating it, be aware that at some point, you are going to tilt it in such a way that rains hot oily fluid down on you!!
    2: that this things is oddly shaped enough that when it decides to fall out, after you cursed it for 15 minutes, it will not drop straight down, but instead, hang a left turn and smack you in the head despite your best efforts to not be under it, avoiding the aforementioned fluid!!!
    3: what an amazing improvement in throttle response this simple repair makes. The ECU/TCU are tied to the movement/acceleration in the mount and it subtly reduces power and adapts shifts to compensate for it. Riding in "S" isn't nearly as chunky and when you tell it to go it only wonders what you were waiting for!
    Definitely something I would suggest improving, either with a OEM part or one of the aftermarket versions. Your right foot will be much happier!
    I have the Drivers Mount waiting to go in and presume it's in similar condition, but that's a subframe drop and this took less than 2 hours to do!
    Cheers,
    KS
    https://youtube.com/shorts/afbm9OEfbOc?feature=share
  6. #10406
    Apr 28 2024
    ‘14 RS7 Prestige and ‘23 F150 Platinum Black Pack
    Carbondale, Colorado
    Quote Originally Posted by m_haiser View Post
    Nicely done. Checked out the other post on your other thread. Very cool! Keep up the good work
  7. #10407
    Aug 21 2010
    Morristown, NJ
    Quote Originally Posted by Botbasher View Post
    Cheers,
    KS
    haha, thanks for the heads up. What replacement did you use? OEM or aftermarket?
  8. #10408
    Junior Member Two Rings
    Mar 24 2025
    Cookeville, TN USA
    Found out that my new-to-me's S7 oil drain plug is stripped. Despite my best efforts, headed to a shop Monday (after window tint appointment) to see if they can get it out.
  9. #10409
    Senior Member Two Rings Akakios's Avatar
    Feb 05 2022
    2014 Audi S7 | 2018 Audi S4
    DE
    Quote Originally Posted by joe_momma View Post
    https://amzn.to/3FM54Wp
    If you want to try your own shot at it, these are the way to go.
    I can't recommend the regular Grip Edge Torx bits enough on this car (and any VAG car really)
    Deutsche Auto Garage - Website // YouTube // Instagram
    2014 Audi S7 (Audi Exclusive Interior)
    2018 Audi S4
  10. #10410
    Mar 11 2007
    Colorado Springs
    Leave it. Suck the oil out from the top...
    2022 Q8 S line Prestige Stock
    2012 A7Plus APR Stage II+ UC
    2012 A8L 4.2
    Still own them all...
  11. #10411
    Aug 14 2019
    Tampa
    18 S6
  12. #10412
    Aug 14 2019
    Tampa
    Quote Originally Posted by RedSox S315 View Post
    Took a little longer than I thought it would but love it.
    Very nice, but I'm partial to post #10340 ....
    18 S6
  13. #10413
    Mar 24 2025
    Cookeville, TN USA
    I tried a couple of extractors but I was just making it worse. I decided to quit before I did something stupid and make a bad situation worse lol. Worst case we just tap a new drain close to the existing one.
  14. #10414
    Senior Member Two Rings RedSox S315's Avatar
    Jul 09 2013
    Bay Area
    Quote Originally Posted by Audisthesia View Post
    Decided to copy you some more and make it all match.
    2017 S6
    2014 S4 - [SOLD]
  15. #10415
    Aug 14 2019
    Tampa
    Damn you! Now I need to mod something else.
    18 S6
  16. #10416
    Jul 26 2018
    Humidity, NC
    ECS. Got a great deal in trade for them!
    Cheers!
    KS
  17. #10417
    Mar 24 2025
    Cookeville, TN USA
    Well we got the stripped oil drain plug out and got the oil change done. I just replaced it with a standard one from AutoZone (14mmx1.50). This is an actual bolt so it won't get stripped so easily. Outside of that, oil change was as straight-forward as any other I've ever done.
  18. #10418
    Jul 26 2018
    Humidity, NC
    Kinda with you on this one... those look fantastic!!!! Link for wheel and knob??
    Cheers,
    KS
  19. #10419
    Jul 26 2018
    Humidity, NC
    Fixed my leaking oil pan seal! How annoying to find but ultimatly easy to fix. Did it on ramps in a single evening!
    Managed to get a perfect bead all the way around even working around wiring and sump parts! Even better... no more leak! Woo Hoo!!!
    Cheers,
    KS
  20. #10420
    Aug 14 2019
    Tampa
    Cheers,
    KS
    The wheel is from TT. The shifter is from A6 comp. The wheel is not going to be much use to you though because you can no longer buy the module to make all the buttons work.
    18 S6
  21. #10421
    Jul 26 2018
    Humidity, NC
    I have started playing with CANbus sniffing and a ESP-32... so this sounds like the perfect reason to dive deep on it!! I want to build a CANbus driven WMI system and that would be icing on the cake!
    Thanks for the info!
    Cheers!
    KS
  22. #10422
    Aug 14 2019
    Tampa
    Cheers!
    KS
    You'll need both CAN and LIN to make one of these wheels fully functional.
    18 S6
  23. #10423
    Established Member Two Rings NorthernGTI's Avatar
    Oct 19 2024
    C7 TDI
    Mississauga, Canada
    ToOoNiNg...
    Sadly my car already had all the cool things added prior to my ownership but it never hurts to have this.
    Sent from my SM-S916W using Audizine Forum mobile app
    2014 TDI
  24. #10424
    Feb 07 2021
    Ford F150
    Waynesboro, GA, USA
    Took care of the vibration in reverse on my 2017 A6 C7 2.0. The Tech Service Bulletin I found on this site requires loosening and retorquing of the three bolts on the flywheel. Done by Autobahn Automotive (Excellent Audi mechanic) here in Augusta in 45 minutes, then out the door. Problem solved. Will be going in for carbon cleaning in a couple of weeks. Both private Audi shops (not the dealer) use the BG three step cleaning method and verify with a borescope. I am still questioning that method. And wonder what they will see with the borescope looking through the plug holes. Neither mechanic wants to remove the intake and walnut blast. As to how that works, I don't know. Most of the chemical cleaners for intake valves are useless according to what I see on Youtube, so we will see. Will report on what happened when I get it done.
  25. #10425
    Apr 24 2011
    RS style grill
    -CELison
  26. #10426
    Apr 28 2024
    RS style grill
    Turned out great
  27. #10427
    Apr 28 2024
    What did you do with your c7 today?
    Drove down to the race track today to spectate, started hearing a large clunk at random times, thought “WTF is that?” Aired up the suspension and found this puppy under there
  28. #10428
    Apr 28 2024
  29. #10429
    Established Member Two Rings Rodrigla619's Avatar
    Mar 26 2021
    2017 Audi A6 Competition, 2011 Chevy avalanche, 2015 Audi Allroad
    Middletown, DE., USA
    Added some new forged wheels
    AWE carbon fiber intake | EPlabs stage 2 | CTS SC pulley | Merc HX, 034 trans-rear dif mounts | JXB carrier | 034 motor mounts | H&R lowering springs | APR 15mm front spacers | APR 20mm rear spacers | AWE resonated downpipe and exhaust | IE TCU tune | CAP CF diffuser | CAP CF side skirts | CAP CF front splitter | JR20 20's | MICHELIN PILOT SPORT 4S | P3 gauge | Titanium werks dress up bolts
  30. #10430
    Aug 21 2010
    Morristown, NJ
    Installed Piano Black dash trim
  31. #10431
    Jan 31 2009
    2016 RS7-P
    Competition seats retrofitted
  32. #10432
    Aug 14 2019
    Tampa
    Quote Originally Posted by Rodrigla619 View Post
    That color...... EPIC
    18 S6
  33. #10433
    Jul 26 2018
    Humidity, NC
    Quote Originally Posted by Ultracon View Post
    Many scopes can be turned 180 and look at top of the cylinder so they are likely looking to see before and after while looking back up through the valves at the carbon on the valve seats and valve stems.
    It's a descent way to tell how much crud is in your intake but I am with you in regards to the use of chemicals in trying to combat carbon build up... it's just not very effective as a way to remove build up. Possibly in prevention, but not cleaning. IMHO. Although, if anything could do it, I'd trust BG products to do it!
    Cheers,
    KS
  34. #10434
    Apr 24 2011
    Drove it to jury duty
    -CELison
  35. #10435
    Established Member Two Rings srb_brah's Avatar
    Sep 27 2024
    St. John, Indiana
    what side skirts and diffuser, assume maxton design?
    looks sharp and love the wheels!
    2017 S6 Premium Plus - Ibis White | Arras Red & Black Optics | Stage 1 IE | Borla Catback Exhaust | RocEuro CAI | 034 Trans Insert | 32K Miles
  36. #10436
    Feb 05 2022
    DE
    Badgeskins has started to offer way more Audi products and we installed a set on both our S4 and S7:
    2018 Audi S4
  37. #10437
    Mar 24 2025
    Cookeville, TN USA
    RS style grill
    Where did you source your grill? I'm looking for a replacement for my S7.
  38. #10438
    Sep 27 2024
    St. John, Indiana
    god bless this wheel setup, can you provide the link where you got to customize it?
  39. #10439
    Apr 24 2011
    Hopefully it's not against forum rules but I went through this eBay seller, they're china based but reputable in the Audi community
    https://www.ebay.com/str/stonecarbon...mis&media=COPY
    -CELison
  40. #10440
    Mar 24 2025
    Cookeville, TN USA
    Great thank you! Any issues with camera or sensor fitment?
