So my rear passenger side window goes down. Does not ever go back up though, using the driver's button panel or the actual window button from the rear passenger side door panel.
I do however, hear the motor work itself "up" per say, but the glass itself does not follow. I would like to assume the window has just fallen off the guide and I don't need to do a regulator or motor replacement. *cross fingers* because I can hear inside the door what sounds like everything is working still.
I stumbled upon this thread from 2008:
http://www.audizine.com/forum/showth...or-Replacement
Would this be a feasible DIY to follow? Would I be able to figure out how to put the window back on its track using this, or am I over confidenced in thinking its this easy?
Anyone have this problem before and can provide any help?
Is there another DIY out there you guys can point me in the direction of?
I'd rather not let the stealership look at it. And I'm getting tired of leaving work with my window up. Driving home to find my window has fallen all the way down. And I have to use my hands to manually slide the window up before I lock and leave the car.
Thank you in advance,
Shaun.
