Results 1 to 32 of 32
    Veteran Member Four Rings BOPOH's Avatar
    Oct 08 2007
    Columbus, OH
    DIY - rear window fix
    Hi If your window in the back doesn't go up but surely goes down,then you probably have green piece broken. I did this about a year ago and it happend to me again on my second B6 audi, and i know its very commong because i had lots of people email me asking how to fix. So here is SIMPLE SEARCH thread, please add to DIY section:
    Im not responsible for any damage to your car, you are doing it on your own risk!!!
    Door panel removal is easy and can be found anywhere.
    when you take off door panel you'll see this:
    take off center plastic panel and motor, not hard but screws are soft so be careful
    I circled red the screws that hold window frame inplace, if it doesnt start moving freely i may forgat one. i did it like a year ago i think. DO NOT REMOVE DOOR LOCK SCREWS unless you are 100% that lock is stoping frame from being removed. Once you pull it out CAREFULLY it should look like this
    remember that blue pentagon looking thingy position and where cable tubes are and what color, its VERY IMPORTANT they are different colors and length, dont worry it has tight tension on it, but once you take it off you'll have alot of cable freed. when you replace it make sure there is no empty track present on that wheel.
    here is what broke on mine and how i fixed it
    i got nail made a grove in it for cable and placed it like this securing with zipties
    after that i filled it with EPOXY FOR PLASTIC on both sides and it worsk like a champ.
    Hope that helps, good luck on your project!!
    Senior Member Three Rings CRAIG1MACK's Avatar
    Mar 10 2009
    2002 Audi A4 Quattro 3.0L 6mt
    Huntsville, AL
    Re: DIY - rear window fix
    Good innovation here!
    Sep 12 2008
    South Central PA
    awesome! mine has been broken for like 6 months now. a girl slammed my door and i heard it pop
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Jun 08 2007
    Orlando, Fl
    That "green piece" is called the window regulator. It costs about $140 fom the dealer, so your fix it yourself method saved you some money
    BetaAlphaTauMember #39 GTRS Powered/Revo Tuned
    Jun 10 2008
    sf
    I assume this is informative, but man is it painful to read/comprehend.
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Quote Originally Posted by kaizr View Post
    Well, he is from Mother-Russia, so English is his second language.
    Boro, nice DIY. When I broke that same piece, I used JB-weld and it has held up fantastic ever since. That zip tie idea is great though
    -Sami-
    Veteran Member Four Rings Mark's Avatar
    1959 MGA 1600
    Chocolate Land, USA
    I did something similar to both my rear doors . . . I made a special piece in my machine shop to hold the cable nub in place and held the cable with thick copper wire instead of zip ties. Not a problem since . . .
    -Mark
    1987 5000 CS TQ 2.2T I5 - No more . . .
    2002 Denim Blue A4 1.8TQMS - RIP
    2005 Ebony Black Pearl allroad 2.7TQMT6
    Kinda stock . . . Tinted, H-Sport Sways, HP-2 Calipers, RNS-E, Bluetooth, and iPod/Sirius combined
    Got Vag-Com?
    Oct 08 2007
    Columbus, OH
    yeah sorry for my runglish, i had to do it on two of my A4s
    Oct 08 2007
    Columbus, OH
    lol do i get any +rep for my write up?
    Feb 19 2007
    Charleston, SC
    there ya go buddy!
    -Sami-
    Oct 08 2007
    Columbus, OH
    yay i got two blocks now thanks Sami!
    Jun 10 2008
    sf
    hahaha Runglish, I like that.
    What did you use to groove the nail?
    I just don't want to tear off my door then realize I don't have everything I need to get the job done.
    Jun 10 2008
    sf
    absolutegtr
    does that cable need to slide? I'm asking because if you used JB weld, or I guess since our comrade friend used epoxy, that's not going to let that slide. it looks like the goal here is to keep that cable in place in the green thinger?
    Veteran Member Three Rings j-rod's Avatar
    Sep 09 2009
    VW Toureg V8
    Dallas, TX
    Quote Originally Posted by Dan[FN]Shank210 View Post
    Did you punch her in the ovaries after?
    The Awesome™
    Web Design & Development
    www.jarodtaylor.com
    Oct 08 2007
    Columbus, OH
    Make sure that nail has huge head(flat surface) i used regular metal hand saw like this
    and yes the point is to make sure that this part of the cable DOES NOT move ANYWHERE in "window regulator"(green piece) that's why i zip-tied it and filled with epoxy
    Jun 10 2008
    sf
    hey i am doing it right now. how do i get the cable to loosen? i dunno what to take off at this point.
    Veteran Member Four Rings Turbo1A4's Avatar
    Aug 04 2008
    2002 s4 nogaro
    Jax
    quick question....did you by chance have ductape on your door at the top?
    mine did and another person i know had the same thing just worndering if it was something audi did
    211,000 miles
    ||Borla||forge dv||35%||awe||k&n||autobahn hoses||awe smic||ssac||walbro 255||
    Jun 10 2008
    sf
    ok i took out the wheel from the blue thing and now i can't get it all back togehter!!!!
    Jun 10 2008
    sf
    I did it bitches!!! Thanks for the ingenuity ruskie!
    Veteran Member Four Rings chadb2434's Avatar
    Oct 07 2008
    East Texas
    So glad this came back up. My left rear reg. has been broken for a few weeks now
    Anyone know where I can get a cheap reliable one without having to go to the dealer?
    02 A4 3.0Q6MT
    -chad
    Oct 08 2007
    Columbus, OH
    Quote Originally Posted by Turbo1A4 View Post
    yes i had samething, at first you think WTF is this ductape doing here, but then when i had to do another one on my second B6 it was there too, and not only rear but all four doors has, i think that how audi techs hold that foamy sheet while that gel hardens
    yeah its a PITA, biggest thing is that you dont skip any tracks, and tension should be really hard. Putting cable on that wheel is the last thing before you reasemble window frame. Glad you got it!
    Oct 08 2007
    Columbus, OH
    Quote Originally Posted by chadb2434 View Post
    i dont know if its the cheapEST(most parts are cheapest), but pureMS.com is damn good website, i spent over $2000 there when i did my little overhaul for my car. From them i bought my front window regulator.
    Veteran Member Three Rings Scrwedtxboy31's Avatar
    Oct 19 2008
    2004 A4 1.8TQM (6sp)
    VA
    Subscribed
    Jun 10 2008
    sf
    Yea, that blue thing was a pain in the ass. I have no idea how someone could do that on their own. I pushed the springs in as hard as possible while my friend coiled it up. Once it was wrapped and in the hole, I had to push down one wire to get it in right. Such a relief when we finally did it.
    To guy asking about getting new regulator. They are 140ish bucks. If yours isn't too bad, just do this fix.
    On my I noticed one of the clips holding it to the black thing was broken as well, but it seemed to work just fine since the other one wasn't broken and it's bolted in anyway.
    I had the duct tape too!!! I assumed someone had already been back there before...
    Aug 11 2010
    New Jersey
    does this apply to the front passenger door? thats where my issue is, and does this apply to B7 models?
    Oct 08 2007
    Columbus, OH
    no, front has weird cable system, if your cable is messed up there is no fix gotta buy replacement (purems.com) and its kinda PITA since you have to remove window frame too, but shouldn't take more than 30 minutes.
    Senior Member Three Rings rocketheavy's Avatar
    Mar 21 2008
    A4, Explorer, YZ250
    Connecticut
    I just did this today. it works perfect!
    03' 1.8T Tiptronic
    Baileys DV, 15% tints
    Ziza yellow Fogs
    Blacked out grills/trim, De Badged
    Apikol snub mount, clear corner mod
    A6 engine mounts
    Established Member Two Rings samaritano's Avatar
    Jun 05 2007
    Miami, FL
    Is there a similar fix for the driver window?
    Edgar
    Oct 08 2007
    Columbus, OH
    it is the same for both rear doors, but front doors are different things
    Veteran Member Four Rings prizmatik's Avatar
    Dec 15 2009
    Hell hole
    I had this same problem with my parents B6, we just purchased another green window glide from ebay for about $10 or so.
    Veteran Member Three Rings nihil's Avatar
    Oct 01 2007
    Too small
    N/A
    Bump for a great reference thread. I replaced the drivers side rear today, having the pics helped. Oddly enough, I too had duct tape in there. I guess Audi has learned the value of that mighty adhesive strip.
    2002 A4 1.8TQMS (sold)
    1982 MB Geländewagen 300GD
    1968 Charger R/T
    1987 Porsche 944 (sold)
    2015 Tacoma TRD/OR
    2007 4Runner
    2022 Tenere700
    2009 TW200
    Established Member Two Rings henry22's Avatar
    Feb 23 2011
    RIP 88' E28 BMW "Bert"
    Charleston
    Was hoping this was going to work for the front doors as both of mine are done. Looking like Im going to have to buy 2 new regulators.
