- 01E 6 Speed Trans = B5 S4, C5 A6, Allroad (Please read note on 99 and earlier model(t-1) type 01E diffs)
- 0A3 6 Speed Trans = B6 S4
- 02X 6 Speed Trans = B6/B7 A4
- 01A 5 Speed Trans = B5/B6 A4 (Please read note on 99 and earlier models)
* For manual Trans only
NOTE: Due to the core exchange element of this product, this will be a send in your own diff to modify purchase only. We simply do not have enough cores on the shelf to support a group buy. However, once we have received your center diff, we will be able to modify and send it out same day if the package arrives to us in time. If not then it will be sent out the very next business day at the latest.
Retail pricing on JHM Center Diff: $350 plus shipping
Group Buy pricing:
- 5(+) units sold = $25 off
- 10(+) units sold = $50 off
- 15(+) units sold = $75 off
- 20(+) units sold = $100 off
Group Buy Members:
1. theredcaron
2. Tarmac(01E)(PAID)
3. dylanbike1
4. sholitz(01A)
5. jettin123
6. RallyeG(01E)
7. downhillracer
8. HotSauce
9. racing_fan(OA3)(PAID)(local install)
10. alwaysaudi(0A3)(PAID)
11. Satummoo(01A)
12. pafable(02X)(PAID)
13. doctorheine
14. lunamarA4(02X)(PAID)
15. AudiOso(0A3)(PAID)
16. downhillracer(01A)
17. fernank1987(02X)
18. turbonick(0A3)
19. Max(01E)
20. 034 Customer(01E)(PAID)(local install)
21. tbomb80(02X)(PAID)
22. 617 Bones(01A)(PAID)
23. WRC_4kqt(01E)(PAID)
24. D.K(0A3)
25. noznab(0A3)
26. twiztids4(01E)(PAID)
27. lunamarA4(02X)(PAID)
28. AUDIocee(0A3)(PAID)
29. mikekehler(PAID)
30.
More information about the JHM 4:1 Center diff upgrade:
Web page: http://www.jhmotorsports.com/shop/ca...0fea030989309c
The factory torsen center differential in the S4 and A4 provides a 2:1 torque distribution between front and rear. What does this mean? This enables the end of the car that still has traction (most of the time the rear) to deliver double the torque to the tires with traction. JHM's experience has found that this closer to even distribution is best for drag racing. So this modification is not for you if you are into drag racing primarily. However for Auto Crossers, Road racers and others who prefer the twisties JHM recommends a bias ratio of 4:1. This is the same bias ratio that Audi has provided in the stock RS4 driveline.
So if you are tired of going through corners while using a lot of throttle and still getting "understeer" then this product is for you and will help you get a little more "oversteer" and allow you to drive the car a little more like a RWD car but still have the superior control of AWD.
NOTE: For 6-speed (01E) transmissions: We can only perform the FULL modification on the T2 style differentials originally equipped in 2000 and newer B5 S4s, C5 A6s, C5 Allroads and B6 A4 (3.0L only, 02-early 03). These T2 diffs have one of the following PNs on the outer case; 01E 409 751 E or 01E 409 751 F. Some of the pre 2000 diffs may be T2 diffs and have these part numbers as well. For those the full modification could be performed. If your diff is older and does not have one of these part numbers or has NO part number at all then it is most likely a T1 style diff. If you have a T1 we can only modify half of the diff due to its older design so you will not get a full 4:1 diff, it will be somewhere in between a 2:1 and 4:1. We won't know 100% for sure until we dissasemble the diff if your diff does not have one of the part numbers listed above. Some of the older diffs have been replaced over the years from other cars or due to wear so there is no other way to tell until we receive your diff and dissasemble it.
NOTE: For 5-speed (01A) transmissions: We DO NOT offer a core exchange due to a high failure rate on these diffs. We will only modify yours that you send in. Also there are 2 different diffs in the 5-speed 01A transmission, we only do the late 99.5 and up. Use this PICTURE to confirm you have the right diff to send in. CLICK HERE. These diffs are interchangeable, so if you have the older diff you can buy a newer diff from a wrecking yard to have modifed by us, then you can replace your older 2 piece unit with the modified late JHM unit.
To help make the proper selection below use this chart.
01E - 6-speed = B5 S4 (all), C5 A6 (all), C5 Allroad (all), B6 A4 6-speed (02-03 3.0l V6 only all other 6-speed A4s have the 02X) - See note above regarding older 01E diffs (pre 2000) that may not be fully modifiable.
0A3 - 6-speed = B6 S4 (all) and some 05.5 B7 S4s (note: we have seen some 05.5s with the T3 diff which is already a 4:1 and does look different than the one in the picture below. If you have that diff there is no need to send it in for modification) 02X - 6-speed = B6 A4 (04 and up) and B7 A4 (all). 01A - 5-speed = B5 A4 (99.5 and up) and B6 A4 02-04 with 5speed transmissions . NOTE: We do not modify the older A4 diffs, see picture below for more info. Also we only modify your diff and do not supply cores on these diffs due to the higher failure rate on these units.
INSTRUCTIONS: Here is a write up on how to perform the install on a B6/B7 S4. It will help with other models since the general idea is the same. Check it out **> HERE
NOTE: It is common with this mod to notice a slight chatter when making u-turns at low speeds. This is due to the modification to make it bias differently under power and at high speeds. Normal daily driving it is not noticeable.
Please email or reply to this thread if you are interested in joining this GB.
Due to our high call volume, Please email [email protected] with any questions about this GB.
