Page 1 of 10 123 ... LastLast
Results 1 to 40 of 382
    Veteran Member Four Rings BlkdoutS4's Avatar
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    BlkdoutA4's RS6-R Build Thread
    Well I guess I'll start a build thread...
    Story so far:
    I've had my 2001.5 Silver S4 for about 3 years now.. bought it bone stock with 95k miles on it. By 110k miles it was full stage 3, with a custom tune from JHM, running meth, put down just over 400whp on 034's dyno. A few months ago I started having some smoking issues during decel along with some oil burning. Tried a bunch of fixes to no avail, most likely culprit was the valve stem seals leaking. So I decided to pull the motor. Started a few weeks ago (first motor pull), and I have another car to drive so I just took my time. As of last Sunday, the motor is out and I have started to break down the motor.
    Turbos have been selected and paid for... should be here within a few weeks and they aren't 605s.
    Engine size: 2.7L
    Rods: Stock
    Pistons: Stock
    Heads: 2.7 w/new guides, new valve stem seals, valve job
    Cams: Stock
    Valvetrain: Stock
    Intake Valves: Stock
    Exhaust Valves Stainless Supertech
    Intake Manifold: Stock, 034 Phenolic Spacers
    Intake: RS4 Airbox, RS4 accordian, K&N panel filter
    Y-Pipe: Stock
    Throttle Body: Stock, 034 TBB
    Diverter Valves: 034Motorsport
    Turbo kit: JHM RS6-R
    MAF: 90mm
    Fuel Rails: Stock
    Fuel Pump: Bosch 044
    Spark Plugs: NGK BK7RE
    Coil Packs: 034 2.0T conversion kit
    Injectors: Custom Bosch 650cc EV14s
    Tune: JHM
    Water/Meth Injection: VAST
    Clutch: VAST Stage 3
    Intercooler(s): JHM FMIC
    Mounts: 034 snub, 034 Track Density motor and Street Density tranny
    Exhaust Manifolds: Stock
    Downpipes: 034 3" downpipes w/ high flow cats
    Exhaust: APR stealth
    Coil-overs: ST
    Wheels: 18X8 B6 S4 Avus'
    Tires: 225/40/18 Hankook Ventus V12
    Front Brakes: 330mm 6 Pot Brembos off Touareg, MB rotors, SS lines, Hawk HPS pads
    Rear Brakes: 300mm B7 S4 rotors, 034 bracket, SS lines, Hawk HPS pads
    Miscellaneous: VAST/ARD 2.2" Polished Bi-pipes, JHM Short shifter + weighted knob, Red oCarbon interior trim, Momo EVO RS GT seats, Euro rear bumper, Podi boost gauge, LC-1 Wideband, powdercoated valve covers
    The car before the motor pull began:
    Momo seats:
    ST coilovers:
    Garage:
    Motor pull:
    Mom's BF helping me out
    Me:
    Old K04s (25k miles):
    '01.5 Silver B5 S4 - Follow my build here: http://www.audizine.com/forum/showth...4-Build-Thread
    Senior Member Four Rings witwer4444's Avatar
    Dec 13 2008
    01 Nogaro S4
    Around
    Wanna sell your K04's?
    Call Me Dave.
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    Have to wait until Tuesday to get the head bolt tool from the local Snap-On guy, then the heads will be pulled.
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    Quote Originally Posted by witwer4444 View Post
    Yes, they will need to be rebuilt. They are not blown and had no issues when pulled but there is some shaft play and I would not put them back in without a rebuild. I have someone local that has dibs on them but send me over an offer and if it falls through we can work something out.
    Dec 13 2008
    01 Nogaro S4
    Around
    PM'd with questions
    Call Me Dave.
    Senior Member Three Rings protocol_droid's Avatar
    Nov 20 2009
    socal
    Nice doing it yourself. Are those momo's the older reclineable versions? name? Can't tell from the pic.
    01.5 B5 S4 Nogaro Avant 6MT Sport ll EPL STG3
    01 B5 A4 Silver Avant
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    Quote Originally Posted by protocol_droid View Post
    No, they are fixed back. I believe they are called Momo Evo RS GTs... weigh about 30 lbs each.
    Senior Member Four Rings Austonwerner4's Avatar
    Feb 01 2011
    00 Silver S4, 04 Campy Touareg V8, 03 Grey Passat
    WI
    I want your rear bumper
    Single Turbo on it's Way
    New Member One Ring
    Nov 27 2011
    Tooele, Utah
    what sick looking car
    Veteran Member Three Rings Matt Danger's Avatar
    Jun 04 2007
    B5 S4
    ROC NY
    What led you to think your valve seals were leaking?
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    Quote Originally Posted by Matt Danger View Post
    I had whitish-clear smoke only during decel or cruising down hills, and was burning more oil than usual. No smoke under boost, no turbo whine, no loss of power. Pressure tested and found no leaks, no codes, replaced spider hose with no change, compression test checked out fine. Talked with a few different mechanics and a few knowledgeable people within the B5 S4 community and only thing we could come up with was leaky valve stem seals.
    If it turns out that that isn't what was going on, oh well...
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    Anyone wanna sell me a set of Tial s605's? Thought i'd throw it out there before I buy a new set from 034...
    Senior Member Three Rings dubzackvr6's Avatar
    Oct 18 2010
    B5 S4, 03 W8 6spd Variant
    SLC
    Looks like he's picking the motor up by himself.
    Veteran Member Four Rings S-Power's Avatar
    Jan 11 2008
    034 Stage 3
    CA- San Jose
    Bryan did you tape up everything and number it? Hahaha That's what I did worked out pretty well for me!
    Dino.R
    034 Stage 3
    TEAM EuroProjektz
    Jan 11 2008
    034 Stage 3
    CA- San Jose
    Dino.R
    034 Stage 3
    TEAM EuroProjektz
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    Quote Originally Posted by S-Power View Post
    Ya most of the stuff is taped and numbered.
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    Heads are off the car:
    Not exactly sure what I'm looking for or how to tell the condition of them... anyone wanna chime in?
    Stage 3 Forum Advertiser Four Rings Max@034's Avatar
    Jan 13 2009
    Fremont, CA
    Looking good Brian!
    You won't really be able to inspect the valve stem seals with the valvetrain installed, but a leakdown test on the head will show an issue.
    You can rotate the cam till you can see up a valve stem and try to see if there is evidence of oil burning. However its probably unlikely more then a few of them were leaking, if that.
    Make sure you take your heads somewhere that is familiar with 5v heads.
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    Quote Originally Posted by Max@034 View Post
    Any suggests Max?
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    Anyone know the best place to buy new valve stem seals?
    Senior Member Three Rings 2380S4's Avatar
    Jul 16 2008
    07 DTM S4, 01 S4, 08 328XI & 90 Turbo Grand Prix
    Living The Dream!!!
    Pm max at 034. He can most likely help you out.
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    Quote Originally Posted by 2380S4 View Post
    Max and I are friends, I did call him earlier just waitin' to hear back. He's probably on his lunch break right now
    Jul 16 2008
    Living The Dream!!!
    Sweet deal then. Max has helped me on many parts for my build and he's extremely knowledgable.
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    What are people paying to have their heads rebuilt? The machine shop told me my heads need new valve stem seals, guides, 2 intake valves and all 12 exhaust valves.. the quote was around $1500... ouch!
    Jul 16 2008
    Living The Dream!!!
    That's not horrible, depends on parts being used.
    I spent $200 on just having valves on brand new heads lapped. On top of the cost of a full 2.8 head build with super tech.
    Jan 13 2009
    Fremont, CA
    I still think you should get some upgraded exhaust valves, but from a financial standpoint, grabbing some 2.8 heads or that motor you found might be your best bet. But with 605's, it would be nice to rev to 7000rpm or higher without worry of your old hollow exhaust valves busting.
    Veteran Member Four Rings MikeyB3's Avatar
    May 16 2008
    Wow, your pistons look just as bad as mine did!
    As far as head building, 1500 seems a little low, but I guess it depends on how far they're building... Mine was way more than that. Then again, I had a P&P done and had them completely rebuilt.
    Did you decide on which turbos you're going with?
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    I think I am gonna go with the SS Supertech exhaust valves with the Black Nitride coating.
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    Quote Originally Posted by MikeyB3 View Post
    The $1500 would include disassembly, valve job, all new valve stem seals, all new guides, (12) new exhaust valves and (2) new intake valves, reassembly.
    As far as turbos, I really would like to go Tial 605, just not sure if funds will permit.
    May 16 2008
    Quote Originally Posted by BlkdoutA4 View Post
    I dont know parts/labor rates, but I'd say if that's where you're headed, sounds about right.
    Are you doing rods? If funds are right, do what you plan to do. But if you're a little low, I've ridden in/driven an RS6 car without rods, and on a moderately conservative tune. She's quick, man. Feels stockish in drivability, but way more push.
    Veteran Member Three Rings michael66899's Avatar
    Oct 26 2006
    5 B5 S4's
    WA
    That's a very competitive price for all of that, I'd say go for it but get the supertech exhaust valves.
    -Girodisc-J-Fonz-BW EFR-Fikse-AMD-034-Ringer Racing-Group 2-WWU Formula SAE
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    Quote Originally Posted by michael66899 View Post
    That's the plan, thanks for the response.
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    what about head bolts... is it best to stick with OEM or are Victor Reinz ok to run? the VR ones are about half the price...
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    bump, anyone have any info on Victor Reinz head bolts? I need to order some soon...
    Jul 16 2008
    Living The Dream!!!
    No haven't used those. Went with arp head bolt set from 034 on my gt build.
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    Just placed the order for new guides, valve stem seals, and the Stainless Supertech exhaust valves.
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    Anyone got a stock S4 airbox laying around that they don't need anymore?? PM me..
    Oct 18 2010
    SLC
    No RS4 intake?
    Senior Member Three Rings DanS4's Avatar
    Oct 03 2008
    01.5 Audi S4, 00 golf Tdi
    Reading, PA
    pm sent
    01.5 S4 ; 00 2 door golf TDi 320k
    VAST tuned k04s, piggies, ASP exhaust, FMIC, Tracksports, DTS, ...
    http://www.socals4.com/
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    Quote Originally Posted by dubzackvr6 View Post
    No RS4 intake?
    I'll probably end up running a stock airbox with 034 85mm MAF and 034 silicon accordian. The RS4 intake stuff I have is setup to be used with a 90mm MAF
