Page 5 of 15 FirstFirst ... 34567 ... LastLast
Results 161 to 200 of 599
  1. #161
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Re: The B7 A4 Dyno Thread
    Quote Originally Posted by drumnjuny View Post
    aaaand thats why i'll be going to carz for my next dyno
    I just want every one to go there so we have comparable data.
    Sent from my porcelain throne.
    2021 Audi S4, P34 Intake
  2. #162
    Veteran Member Four Rings seal66's Avatar
    Aug 05 2011
    2008 Audi A4, 2015 Audi A3
    CO
    ya. it would be good to have that. they are good guys and know what they are doing. I just wanted to see where my car sits in terms of running wise so.
    2008 Audi A4 2.0T
    320awhp/420awtq...E85---UnitedMotorsports Tuned
    2015 A3 8v P-Stock
    2003 A4 Avant 3L-sold
  3. #163
    Veteran Member Four Rings derrek's Avatar
    Jul 23 2010
    arizona
    What kind of dyno are most of you using? I'm thing about getting my car dyno'd but I want to use a dyno that I can compare my numbers with everyone else's.
  4. #164
    Dec 03 2008
    2018 SQ5
    I think Carz has a windyn super flo or some shit like that.
  5. #165
    Aug 05 2011
    CO
    Carz uses a
    SuperFlow 880 AWD AutoDyn
    2008 Audi A4 2.0T
    2015 A3 8v P-Stock
  6. #166
    Established Member Two Rings RoccityRider's Avatar
    Apr 04 2011
    Rochester, NY
    Hey Everyone,
    I just picked up a 2008 "S Line" 2.0T Q6mt about a month ago and wanted to post my initial dyno results. I did two runs in stock and two runs in APR stage 1 93oct, all runs were in fourth gear. I noticed that my torque is higher than most of the other cars in this thread. I am attributing this to me running snow tires when I did my pulls (though the dyno operator said this would not change the results on a Mustang Dyno). I will hopefully be going stage II in the next two weeks whenever I can find time to get the car on a lift.
    Here are some quick pictures of the car:
    And here is the 93oct vs stock dyno reading:
    08 A4 2.0T S Line | APR Stg 2 93 | 034 Turbo Inlet Pipe |APR Test Pipe | DTM Rear Bumper | RS4 Rear Sway Bar
  7. #167
    Aug 05 2011
    CO
    mhm. that is high. I am pretty sure though most dyno shops run a 3rd gear pull. I am not sure how much it would change the numbers between a 3rd and 4th gear pull though. Power to ya if it is running that good man. clean btw
    2008 Audi A4 2.0T
    2015 A3 8v P-Stock
  8. #168
    Veteran Member Four Rings Firefox250's Avatar
    Nov 17 2009
    BT B7 A4 Sedan Quattro & B7 A4 Avant Titanium 2.0T Quattro
    Aurora, Colorado
    Quote Originally Posted by RoccityRider View Post
    Holy cow you made more torque than any of the stage 2+ cars! If you have the funds could you find another shop with a dyno before you go stage 2? I'm honestly doubting my own dyno and plan on getting another one done too, because I've been told the operators of the dyno can inflate numbers. I'm assuming on this data sheet run #1 is stock and #2 is with the APR chip? Either way I'm jelly of your dyno run
    Tuned by UNITEDMOTORSPORT
    HTA3073 Build page
    Bluewaters Performance blog on my build
  9. #169
    Veteran Member Four Rings ericpaulyoung's Avatar
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Great runs. Thanks for posting.
    Eric
    Epy
  10. #170
    Sep 27 2008
    Phoenix
    Your stock numbers are right around the same output as a stock B7 so your dyno looks like it is from the crank. A stock B7 has 200 hp and 207 lbs of torque.
  11. #171
    Dec 03 2008
    2018 SQ5
    Yeah, that has to be crank readings. there is no way a stock A4 will come close to 200 WHP. You'll be lucky to reach 170 WHP stock.
  12. #172
    Apr 04 2011
    Rochester, NY
    These are non corrected, at the wheels numbers, on a Dyno that many people have proven to be accurate. I spent some time tonight, talking with my long time friend and local ARP dealer; John@Roc-Euro. Our best guess is that the high numbers are due to me running narrower lighter snow tires. This poses a dilemma, as there is currently 6" of snow on the ground and I won't be swapping them out anytime soon.
    There is one other shop in the area that has a mustang AWD dyno, but I feel it will read the same high numbers due to the lightweight tires. The only way I can recreate the test is to wait for spring when I put my summer tires back on, to eliminate that huge variable. The higher numbers also may be attributed to it being 20* outside and about 60* inside the shop today with near zero humidity. Come mid the late March I will redo this run, and do a stage II pull on summer tires. If the numbers are still high, I will go to the other shop for comparison. I am still debating if I want to do a snow tire stage II pull just for fun.
    Anyway, thanks for all the feed back. I am liking this forum more than the B6 forum already.
    Andrew
  13. #173
    Senior Member Three Rings olethalb's Avatar
    Feb 22 2013
    london ish
    first mapping session on my dtm 2.0t fsi quattro when i converted it to k04 - have since gone hybrid k04 but o printout :(
  14. #174
    Active Member Two Rings Golfedd's Avatar
    Nov 19 2012
    UK
    Dirty Diesel warning... 2.7T V6 Diesel Went with the hope of 230-240bhp and 400-430ftlb
    Stock: 177bhp and 280ftlb
    Mods: Pre-Cat Deleted and DPF deleted + Bobby-Singh Custom Map
    Results: 265bhp and 442lbft
  15. #175
    Registered User Four Rings
    Apr 25 2012
    Rochester NY
    Wow, 88awhp from a tdi? That's impressive. Guess they left a lot of room on the table. Nice work!
  16. #176
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    440TQ!!!! WTF? where is the sign up sheet for that?
  17. #177
    Feb 06 2009
    328d, Tacoma
    Woodland Park, Colorado
    In Europe, where you actually have a selection of power plants... 2-3 diesels 2-3 gas. While we got to choose between the 2.0 and 3.2....
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
  18. #178
    Feb 22 2013
    london ish
    Yesterdays remap / dyno run - crank figures
    Better turbo and morecmapping coming soon
  19. #179
    Senior Member Three Rings ultraleggera a4's Avatar
    Feb 27 2012
    Aurora, Colorado
    Cool Dyno Day was Successful.
    Next I'm doing all my fueling components and dyno it again. I'm aiming for 270whp on stock k03.
    If you call bullsh*t you can find out for yourself if it really puts down the power. I will post dyno sheet tomorrow.
    239whp / 284wtq dyno proven (uncorrected)~270whp/305wtq with new goodies dyno results will be coming soon
    Stock K03
  20. #180
    Dec 03 2008
    2018 SQ5
    Quote Originally Posted by ultraleggera a4 View Post
    Hard not to call bull shit on that one. Haha. But good luck to you! You'll have to be fwd and run nitrous. Lol.
  21. #181
    Veteran Member Four Rings LoKisSpYdR's Avatar
    Jun 26 2012
    Brilliant Red B7 A4 2.0T Titanium quattro Tip - 2015 Q7 PP
    Reading, PA Area
    Seriously!!! Why does Aui think that there is no market for TDi quattro in NA? I'd love to put down those numbers and still get the mpg they get. My whole reason for not getting an S4 (same reason I got rid of my C5 A6 4.2 & C5 S6), the mpg sucks horribly.
    B6 A4 1.8T Dolphin Gray qM
    4L Q7 3.0T Glacier White PP
  22. #182
    Nov 17 2009
    Aurora, Colorado
    If you can pull it off on two different dynos with 91 octane. You must have one helleva tune and boost adjustment. What are your engine modification?
    HTA3073 Build page
  23. #183
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    not calling bullshit...... just laughing, really, really hard. why wouldn't you just wait to post the actual dyno, instead of giving us the announcement 12hrs before? now you're gonna look silly when you fall 20fwhp (i can only assume you don't mean on a quattro) short.
    people who act / put down results usually don't announce it first. they just do it... why make threats when you can just throw down instead? we don't need the introduction / pre-game haha. i guess you will find out for yourself whether it puts down the power, we all know the k03 has no air to make such numbers - upgrade the fueling components all you want!
  24. #184
    Feb 27 2012
    Aurora, Colorado
    Dont Worry im about to download the video.
    https://plus.google.com/photos/10620...22348986851711
    and yes its front wheel drive, but no nitrous and also has the sh*tty CVT transmission.
    oh yeah, my car also was heat soaked due to no fan with hood closed on all three runs and ambient temp of 84F. probably lost 1-3 ponies due to that.
    Stock K03
  25. #185
    Feb 27 2012
    Aurora, Colorado
    FIREFOX250 I'd rather not give away my secrets but my motor is built like yours but i have 9:1 not 9:5. and yes my tune is not commercial like the usually tunes.
    Stock K03
  26. #186
    Feb 27 2012
    Aurora, Colorado
    oh but it does if you have the worlds best tuner and over $8k in parts invested
    Stock K03
  27. #187
    Nov 17 2009
    Aurora, Colorado
    https://www.facebook.com/photo.php?f...type=1&theater
    Links are not working. That's pretty good numbers for a FWD and CVT transmission . After investing 8k in fueling and building your engine, I would of thought you would swapped out the transmission at least.
    HTA3073 Build page
  28. #188
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    or turbo... can we safely assume that's coming next?
  29. #189
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Can't see the numbers, facebook says content isn't available. But 270fwhp is quite the feat, even if you did hit 270fwhp, it wouldnt really matter, it would be just a massive spike, the k03 doesn't flow for enough for 270, you're just going to see the dyno shoot up and sharply decline. Go buy a k04 or gt28.
  30. #190
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    haha seems like he's proudly made 268 or something very close to 270 i would be proud also but i guarantee that is not a safe tune, you can blow a stock motor at 25 psi which i guarantee will throw a rod through your shit
    but i still need to see the dyno lol.
  31. #191
    Feb 25 2011
    Seacoast NH
    links don't work.
    never link to FB.
  32. #192
    Feb 27 2012
    Aurora, Colorado
    Quote Originally Posted by Firefox250 View Post
    new links fixed
    Stock K03
  33. #193
    Feb 27 2012
    Aurora, Colorado
    Next im doing all fueling components dyno again, then turbo
    Stock K03
  34. #194
    Feb 27 2012
    Aurora, Colorado
    no spike and it is smooth as it can be
    Stock K03
  35. #195
    Feb 27 2012
    Aurora, Colorado
    motor is not stock, and the sheets are posted
    Stock K03
  36. #196
    Jun 26 2012
    Reading, PA Area
    Never mind.
  37. #197
    Dec 03 2008
    2018 SQ5
    So, 238 whp and 283 wtq? Is that correct? I believe those numbers. Good numbers too. Did we decide if this is awd or fwd? I think you could make a little more torque, but it's doubtful you can get the hp any higher.
  38. #198
    Feb 27 2012
    Aurora, Colorado
    Correct and as mentioned before its FWD CVT more power loss than manual FWD also torque will increase with fueling. I will hopefully hit 250whp with hpfp, rs4 lpfp controller, and s3 injectors with a retune.
    Stock K03
  39. #199
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    like i said u can revamp your fueling as much as you want, K03 doesn't have air for 270 wheel, not even fwhp.
    so is this the part where we all say "we called bullshit" and "we were right"??
  40. #200
    Feb 27 2012
    Aurora, Colorado
    Listen be more optimistic for our platform, there is a way and I'm going to show you, I dont want to reveal everything but along with the fueling, I'm getting an APR machined head.
    Stock K03
