So, now that I'm relying on 'ol 2 Face for daily driving purposes, issues are popping up regularly. The latest:
I had my alignment done a few months ago at a local brake/tire/suspension place that's been around for a few decades. To free the tie rod end bolts, the guy fired up the torch. Upon bringing it near my car, I commented "aren't there a lot of rubber bits up in there?" (direct quote) Then I suggested things like the CV boot, brake lines, other boots, wheel well cover thing, etc. He said "nah we do this all the time. It's the only way to free up these bolts"
So he went at it. Freed then, aligned everything. I took the car, still wasn't aligned, brought it back, they did it again, and it felt better.
So, several months later after the car sat most of the winter, my steering made creaking noises while turning at low to zero speed. Started only when turning right, and after just a few more hours of driving, it was any direction. Its like this creaking "something wants grease" sound, and I can almost feel it vibrating on the brake pedal. I looked up at my suspension, and it seems that the rubber boots around my tie rod end ball bearing looking thing is melter, and thus came off of the clip. It's entirely possible that this happened months ago, and I just hadn't noticed.
So, long story short, eff that guy. I'll be going back of course, but it's been months, so we'll see. Anyway, anyone know about these? Should I just replace the whole tie rod end, and if so, how hard is that? In the interim, I loaded it up with grease and half hose clamped it down, but it's already started creaking again.
________________________________
DDM Headlights:
I did a DDM 55W conversion, and have been pretty fantastically disappointed with the results. It's probably a combination of one headlight having a broken adjuster, so it's pointed kind of stupid, but it also seems that A: it's just not as bright as it should, and B: I can't seem to get the bulbs to sit in place happily.
The main problem: Constantly, only one bulb will fire. I can't even explain how frustrating this is, especially with the crazy loud beep warning you when one headlight is out. It seems to be switching sides, too. Sometimes one side works and the other doesn't, other times the switch sides, and sometimes it fires up first try. I can't find a pattern. It's all hooked up correctly for sure, too.
Anyone have advice on this or had similar problems? DDMs website suggests hooking them up directly to the battery, but it just irritates me. They're just supposed to WORK. bastards.
Also, anyone selling new or good condition depo ecodes, I want them. Or tell me the best place to get them at the best price.
Sorry for the long post, amigos, but I felt like telling full stories tonight.
-Rich
