Results 1 to 40 of 50
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    *** NEW : 2.5" Turbo inlet silicone hose for 3" MAF - INTRO OF $180US SHIPPED ***
    Turbo Inlet Hose, 2.5" Silicone, Longitudinal 1.8T w/ TT225 MAF
    Designed as a high performance replacement for the longitudinal 1.8T with GTRS/GT2871R Eliminator turbo, and 2.75" ID TT225/VR6 MAF housing. Constructed from high quality, automotive grade silicone using 4-layers of reinforced nylon - this hose will not collapse under extreme vacuum.
    The intake hose is 3" at the MAF and 2.5" at the turbo inlet, and features provisions for all factory DV, PCV, vacuum lines. Perfect fit with the TT225 MAF housing inside the factory airbox, or any aftermarket air intake.
    This hose, along with the 2.5" compressor inlet upgrade, is crucial when attempting to make over 240WHP.
    2.5" compressor inlet adapter for the GTRS/GT2871R turbo kits sold separately .
    Similar products sell on the market for OVER $300US.
    INTRO PRICE = 180US SHIPPED in the lower 48 for the first 15 people.
    (add 38US for the GTRS adapter)
    Sep 28 2006
    Lexington
    Re: *** NEW : 2.5" Turbo inlet silicone hose for 3" MAF - INTRO OF $180US SHIPPED ***
    Have it for a 98 a4?
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    K04 | GIAC PC-16 | FMIC | 3" Neuspeed Exhaust | ATP Test Pipe | Raceland Coilovers | N75 Race | Forge 007 | K&N | VDO Boost Gauge | A8 BBK | Rear Fog Light Mod
    07 A4 3.2LQ - K&N
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    ^^it isn't specific to your year.. But your turbo setup.
    Sep 28 2006
    Lexington
    Well I'm just running K03 right now. Don't know if that would work
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    07 A4 3.2LQ - K&N
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    It is most likely designed to use on the elim kits that need to run a 3" maf for the Uni tuning. Basically like the one Neuspeed offers, but that one only fits a stock maf.
    Feb 26 2006
    Earth
    These wont work on stock K03's or stock MAF's.
    Veteran Member Three Rings beejohn's Avatar
    Jan 24 2005
    Pennsylvania
    damn i already have a neuspeed pipe and adapter otherwise i'd be all over this. looks like a good product bump for a good seller
    --beejohn
    2001 A4 1.8TQMS
    Sep 11 2007
    Dirty Jersey
    looks nice, I can see one in my future
    Nine [O_O] Eight Tuning
    custom work, fabrication, bumper shaving, fender rolling, plastic & fiberglass fabrication and repair
    Turbo charged and lowered for better grocery getting :screwy:
    Feb 26 2006
    Earth
    Thanks everyone :)
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    looks like a good product.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Feb 26 2006
    Earth
    All PM's replied to.
    If you do not get a reply in a timely fashion and want an ASAP response simply call me & I will try my best to help you out.
    Apr 22 2007
    Riverbank, Ca
    At what point does the stock MAF become a restriction?
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by andyrew View Post
    The MAF readings are maxed out if you're using a stock housing with a GT28 or larger turbo.
    It also is a restriction at 210+ WHP.
    Jul 07 2004
    socal
    Quote Originally Posted by Laszlo@034 View Post
    Which means it can be maxed out with a K04 or even a well tuned K03.
    Apr 22 2007
    Riverbank, Ca
    Mike a KO3 getting into 200+whp? show me...
    Also, I'm going to need proof that a larger MAF will show an increase in HP on a gt28.
    Jul 07 2004
    socal
    That would be my custom tuned K03 that ran 14.29 at 97 mph on 104 octane. I was able to hit 215 g/s on a stock maf with that setup and is about the same numbers the J31 file hits on the stock maf.
    Apr 22 2007
    Riverbank, Ca
    Is that a KO3S or KO3? What boost pressure where you using to get 50HP more than the GIAC file?
    Jul 07 2004
    socal
    Just the stock turbo that came stock on my 2000. Ran 20psi. I actually still have that chip some where here at the house.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    034 again with a product needed for the market.
    I don't have an elim. turbo, but thanks for not forgetting about us B5 owners
    Apr 22 2007
    Riverbank, Ca
    Impressed.
    O34 Motorsports, I'll be joining the Feb 7th dyno day, and if you want to test your hose and a 3" maf on my stage 3 kit (with all the bells and whistles) as a before and after, Give me a buzz.
    Sep 17 2005
    Fremont, California
    The gain isn't merely from a larger MAF; it's from being able to properly map the ECU in high boost/RPM, where the element would be maxed out in a stock sized housing.
    A MAF element is just a 0-5V output... The ECU then does some simple math depending on how the MAF scaling is calibrated, and turns that 0-5V signal into g/s. Here's a quick generalization of why you need a larger housing for BT setups (the boost/RPM numbers are not hard data, just examples):
    With stock housing and a GT28RS - 20 PSI+ from 4000 RPM onward - the ECU will see a 5V signal from the MAF. It won't know that more air is entering the motor at higher RPM and/or boost, and cannot compensate with proper fueling.
    By using a larger (2.75") housing, you lessen airflow over the element, and therefore won't max out the 0-5V signal. So, at 4,000 RPM and 20 PSI, the ECU will see 3.9V, and at 6500 RPM and 20 PSI, the ECU will see 4.6V. Therefore, fueling can be scaled accordingly.
    It is especially important not to max out the MAF sensor on the early cars that don't have a wideband. They have nothing but the MAF to go off of.
    Sep 17 2005
    Fremont, California
    Impressed.
    The gain isn't just from the MAF, it's from the combination of tuning and the correct MAF setup.
    Now maybe we could grab a Uni ECU and the correct MAF housing for your car, and then do a before and after.
    Apr 22 2007
    Riverbank, Ca
    Feel free to use my car as a test if you'd like. PM me if you'd like.
    If not thats fine with me.
    Apr 06 2008
    Brandon, FL
    i really want one of those hoses, but im not going bt for at least another 6mo. have you determined what the final cost of the hose will be after the opening sale?
    Current whip:
    RIP:
    Jul 07 2004
    socal
    It retails for $195 + $38 for the elim adapt0r on the 034 web site.
    http://www.034motorsport.com/product...ducts_id=18594
    Feb 26 2006
    Earth
    All PM's replied to
    Senior Member Three Rings eurotecknik's Avatar
    Feb 23 2008
    06 A4, 09 A5
    Chicago Бъл
    Any news on this? still going?
    01 A4 1.8T Quattro Manual - SOLD
    90 Audi 90 Quattro Manual - SOLD
    03 A4 1.8T Quattro Manual - SOLD
    B5 S4 Daily Driver - SOLD
    Current:
    06 A4 Quattro Auto
    Feb 26 2006
    Earth
    All Pm's replied to....
    Veteran Member Four Rings audiFUEGO's Avatar
    Jul 17 2007
    2001.5 A4 1.8t QM
    Boca Raton, FL
    wow nice to see this finally available...
    I wish you guys had made this a year ago... would have saved me some headache.
    Feb 26 2006
    Earth
    Quote Originally Posted by audiFUEGO View Post
    Alot more products in the pipeline for saving headaches.Look out for a Stage I to Stage V turbo kit thread tomorrow/monday.
    Veteran Member Four Rings Kyle H's Avatar
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Quote Originally Posted by Issam@034 View Post
    awesome.
    "Einstein: Any man who can drive safely while kissing a pretty girl
    is simply not giving the kiss the attention it deserves. "
    because racecar.
    Feb 26 2006
    Earth
    All taken with a Nikon D80 :)
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    I knew I liked 034 for a reason.... you're nikon guys! duhh.
    haha, seriously though, I'm excited to see what you guys put together for turbo kits.
    because racecar.
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Monday is coming to an end and I don't see an announcement from 034....
    because racecar.
    Feb 26 2006
    Earth
    Look down ;)
    Feb 23 2008
    06 A4, 09 A5
    Chicago Бъл
    Great stuff
    Current:
    06 A4 Quattro Auto
    Feb 26 2006
    Earth
    Quote Originally Posted by eurotecknik View Post
    Great stuff
    Vas let me know when you get it!
    Feb 26 2006
    Earth
    All PM's replied to
    Thanks for the awesome support everyone.We are working on some new pieces for 2009 that will really make you salivate
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    Does this free up a little more room for the elims than what ATP offers? only problem with the ATP one and my 3" maf is that the filter is very crammed in and is hitting the body. was going to order a hks filter, but they are spendy. This is about the same price, but it looks like i could save more room this way and possible put the cover on the back of my passenger side headlight again.
    Past (in order): Hibiscus Red B5 A4 ,2003 Audi RS6, B6 s4, UrQuattro, Urs4, Nogaro sport B5 S4 avant, Silver stg 3 B5 s4, 2010 A6 Avant prestige
    Present: Casablance White stg 3 B5 S4 avant, 2002 Audi S6
    Veteran Member Four Rings jbrentd's Avatar
    Oct 31 2005
    '13 allroad, '91 Coupe Quattro, '64 Corvette, '93 Corvette, '21 Bronco
    Tulsa, OK
    Would this work for the k04 with 3" maf (hammer file)?
    1991 Coupe Quattro - Project Car
    2013 allroad - My DD
    2011 A3 S-Line - Son's DD
    SOLD - 2007 A6 4.2L // 2001 Pelican A4 Avant // 1996 A4
