Results 1 to 9 of 9
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    Vibrations on the highway
    Alright, my car starts to shake at 60 mph+ and was looking for any suggestions on what could be causing it. Dropping my car off at the place that mounted my tires last week, and having them check the balancing. I hope that's all it is, but don't want to get boned if they lie and say it's something expensive to fix if I can figure it out with your guys help
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Veteran Member Three Rings agart's Avatar
    Mar 20 2008
    Belmont MA
    Re: Vibrations on the highway
    Are you running spacers by any chance?
    DG '02 A4 1.8TQM
    My Build Thread
    Veteran Member Four Rings B6driver's Avatar
    Sep 14 2006
    XBOX LIVE GAMER TAG: b6driver
    Eagle Rock, LA, Ca
    Quote Originally Posted by agart View Post
    it could be anywhere from clutch to spacers to misalignment. have you done anything to your suspension recently?
    2004 A4 1.8 Turbo 5 speed gone...
    2010 Candy White VW CC R-Line
    Veteran Member Four Rings T0M3K's Avatar
    Sep 14 2007
    Valley Stream, NY
    Sounds like something regarding tires. I had vibrations on the highway, and it turned out to be worn tires, new tires and balancing solved the issue. But I get lots of new problems, Ventus/Hankook are complete POS.
    Veteran Member Four Rings G Men 08's Avatar
    Feb 05 2008
    One trick pony at the time.
    Waterloo NY
    +1 on the hankook ventus (hrII?) being junk... had them on my old probe gt n they were shit... but i have the same problem.. my guess is that it is the wheels need to be balanced which i am going to have done when my snow tire come in next week or the week after
    B6 A4 3.0-sold
    C5 A6 4.2-sold
    C4 A6 2.8-sold
    B5 S4 A few mods-SOLD thankfully!!
    MKIV Golf TDI- SOLD MPG were amazing but other than that...
    C5 allroad 2.7 auto
    Veteran Member Four Rings jackyaudi's Avatar
    Jun 26 2007
    '02 A4 1.8TQS
    Montreal
    In addition to all thats mentioned, it could also be the rims. If you can let a friend drive behind you and check all the tires while you are going at that speed, then he would tell you which tire is vibrating or shaking. Assuming that the problem is one or more rims.
    For your OEM HID D1S/D2S/D3S and HID conversion [Headlights/Foglights], and Interior/Exterior LED needs, send me a PM.
    Stuff F.S: http://www.audizine.com/classifieds/...4-parts&cat=21
    Oct 19 2008
    '01 Audi TT 225, '98 Discovery
    New Hampshire
    Check the control arm bushings and tie rod ends. If the control arm bushings are worn, they usually make noise while going slowly over bumps. In extreme cases it will sounds like the front end is going to fall off. You can test the front end by jacking the car. Grab a front wheel and see if there is any play in the left/right movement, pulling the bottom/top out towards you and pushing it back in.
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Does it stop after you hit a certain speed? Mine shakes a little starting at 80 and ending at about 85.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Feb 24 2007
    Burlington, Vermont
    yeah as I figured, it was the balancing.. apparently their balance machine wasn't calibrated correctly... and threw my tires out of balance completely. All is well :D Hopefully this thread will be helpful for others, good suggestions, and thanks
    - Scott
    Das Build Thread
