Results 1 to 40 of 43
    Veteran Member Three Rings agart's Avatar
    Mar 20 2008
    Belmont MA
    My First Build - PSi Concepts 20G
    After 2 years of owning my first car, I have almost completed my first build. In addition to the turbo swap I had a bunch of little odds and ends that I wanted to do at the same time and ended up deciding to pull the engine. I figured doing each individual thing with the engine in the car would be more frustrating and time consuming than pulling the engine and having ample space to do them all at once.
    We’ll start with the mods list:
    Engine:
    PSi Concepts TD05H-20G turbo
    PSi Concepts T25 exhaust manifold
    PSi Concepts downpipe
    PSi Concepts oil lines
    Custom coolant lines
    Earl’s oil cooler with 6AN lines
    ER Comp FMIC
    ER power steering cooler
    ID 725cc injectors
    Maestro tune
    Custom 2.5”->2.25” exhaust
    Bosch Sidefire sparkplugs
    42DD stealth catch can
    Forge splitter valve set to full atmospheric(likely to change)
    Custom intake with K&N filter
    Suspension/Brakes/Drivetrain
    Bilstein PSS9
    RS4 sway bar
    SPC adjustable CAs
    WIlwood 4 piston 330mm fronts
    Stasis 310mm rear
    CM FX400 6 puck clutch and LWFW
    USP Motorsports metal clutch slave
    BBS RGRs 18x8
    034 street engine and tranny mounts
    034 snub mount
    Electronics
    Optima yellow top
    “Big 3” wiring upgrade
    Alpine INA-W900BT
    Alpine PDX 4.100
    Alpine SPX-17PRO (front)
    Alpine SPX-177R (rear)
    Podi dual setup – oil temp and boost
    Custom V1 concealed display
    Custom iPhone vent cradle
    Custom fiberglass 10” subwoofer enclosure for trunk cubby(subwoofer & amp to come soon)
    Cosmetic
    S4 bixenons
    USP doorblades
    DIY brushed aluminum trim
    I'm sure there's somthing I've forgotten but oh well... I started the engine portion of the build 2 months ago and finally got to drive it last night. Thanks to Dan @ RAI, the base tune he gave me already runs solid which was one of my biggest concerns starting this and he answered countless other questions. I wanted the car to be driveable from day 1 and last night’s test drive was flawless. Current tune is going to be at 20psi. Have never had a "fast" car and I want to get used to this power level before I up it. At that point I'll do internals and up the boost. Also, a huge thanks to my friend Emil(S4evr) for being in the garage with me every day wrenching and fabricating some parts for me. Only have iPhone pictures of the engine bay right now but some better ones are soon to come.
    Intake setup:
    Got sick of the oil temp sender being in the oil drain bolt and ended up drilling and tapping my own location for it:
    Almost ready to go back in(lines have been rearranged since):
    Cooling down after last night's test drive
    Interior. Have since put the oil temp gauge in the right pod that's empty in the pic.
    DG '02 A4 1.8TQM
    My Build Thread
    Jun 22 2009
    Dundalk, MD
    solid build
    May 24 2007
    Southern California
    nice setup.
    Kyle
    2.0L Revo GTRS Eliminator
    Jul 28 2009
    2003 A4 3.0 V6
    SL,UT
    nice
    Dec 01 2007
    Orange County, NY 10918
    very nice setup! there a bunch of us running these now. Interested to see your numbers etc.
    *suggestion - get rid of that 007 splitter. Its garbage. I had it on my car and couldnt handle the boost. Switched to a 004 and much better.
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    @skiguardusa www.skigaurd.com
    Jan 24 2008
    Pennsylvania
    It looks like you've made some great choices and did a quality installation. Very well done, especially for a first build.
    2021 GMC Sierra AT4 Diesel
    Gone but Never Forgotten:
    Instagram: bluewings460
    Mar 20 2008
    Belmont MA
    Yea I think that's going to be the route I end up going. It still needs to get dialed in but I don't see myself keeping it for too long.
    When I get the tune finalized and a couple other things squared away the plan is to get to a dyno and see what I'm putting down. I'll be sure to post up the results.
    DG '02 A4 1.8TQM
    My Build Thread
    Senior Member Two Rings JustinM's Avatar
    Sep 12 2011
    Hartselle, AL
    I really like the iphone/ipod dock! Is it stable?
    Current: 2011 Audi S4 Prestige
    Previous:
    1st. 2003 A4 Quattro 1.8T ~ Stage 1+, TT225 Injectors, H&R Springs, 19" RS6 Wheels, Ultrasport Front Lip
    2nd. 2003 A4 Quattro 1.8T Manual ~ Frankenturbo, Motoza Tuning, TT225 Injectors, Eurocode FMIC, 034 HFC, Borla Exhaust, ST Coilovers, S4 Front Brakes, RS4 Rear Sway, 19" E53 X5 Wheels
    Instagram: j_michael89
    Veteran Member Three Rings POPO's Avatar
    Feb 02 2008
    2001 Chevy Tahoe, 2005 Audi A4, RIP 2003 Audi A4
    Somerset, NJ
    Welcome to the PSI Concepts 18/20G Club
    2005 A4 2.0L Stroker- New South Vent Gauge|034 RSB|2.75" FMIC|GHL 2.5" Catback|PSi Concepts TD05H-20g|PSi Concepts Exhaust Manifold|Turbo XS EWG|Motoza tuned|
    RIP 2003 A4 1.8TQM
    Active Member One Ring Mr.Right's Avatar
    Sep 20 2008
    03 A4 01 Imola S4 01 S2000 GT35R
    Port Orange/FL
    Nice build so far. What kind of #'s are you putting done with the 20g?
    Nothing to see here people, Nothing to see here.
    Mar 20 2008
    Belmont MA
    Quote Originally Posted by 03qtro View Post
    Surprisingly it's pretty stable. Can definitely handle a spirited run I'm planning on remaking it though. I used the original vent with body filler the first time around and I think the stress to pop it in/out coupled with the temperature difference between heating and AC caused it to crack right along the joint to the plastic. Still functions fine... but doesn't look too good.
    DG '02 A4 1.8TQM
    My Build Thread
    Mar 20 2008
    Belmont MA
    Quote Originally Posted by Mr.Right View Post
    Not sure yet. I'm hoping in the 270-290 range with this tune tweaked a bit but I won't know til I get to a dyno. More worried about getting everything running right first though so it might be a little while til I get to one.
    DG '02 A4 1.8TQM
    My Build Thread
    Mar 20 2008
    Belmont MA
    Quote Originally Posted by POPO View Post
    Thanks man. Loving it already.
    DG '02 A4 1.8TQM
    My Build Thread
    Veteran Member Four Rings vhstejskal's Avatar
    Feb 01 2011
    UT
    Looks like a well planned out build; congrats... Seems like more people are moving to the PSI 20 g. Subscribed to see results.
    -Vic
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Subbed, nice build
    2019 SQ5 Prestige
    Dec 01 2007
    Quote Originally Posted by agart View Post
    I hope for more than that for you.
    MAESTRO - bigger injectors, bigger fmic.you should do better than my REVO stg3 with a knock sensor code and small ractec @283
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    Mar 20 2008
    Belmont MA
    On 20psi, you think? I mean I'd be very happy if that's true, just trying to not overhype myself haha.
    DG '02 A4 1.8TQM
    My Build Thread
    Mar 27 2005
    The Cold North
    That shouldn't be a problem. I did 300awhp on the mustang dyno at ESP in sterling MA. You should have more flow than me. They have reasonable rates and run lot of audi's if you need a quality dyno shop.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Dec 01 2007
    on 20psi? not sure. I did those numbers at 26psi.
    But i think you can do pretty good with the setup you have. I like everyone else is wondering the potential on the 20g on the 1.8t's There is 4 of us running or getting ready to run 20g's, i'm the only one with numbers and i think they sucked so, hoping the rest of you can make good numers so we can see what the MHI 20g can do.
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    Established Member Two Rings Risky Bizkit's Avatar
    Dec 06 2011
    Brisbane - Australia
    18g aint to bad either! still puts a smile on my face!
    -George
    2016 Audi RS3 8V Hatchback - Nardo Grey
    2006 Audi A4 B7 1.8T Quattro S-Line - PSi Concepts TD05-18G - Milltek Cat Back Exhaust - ER Sport FMIC - BMC CDA - Cat Delete - Custom Code - Bosch 040 - Bosch EV14 550cc - EBC RedStuff Pads + Ultimax rotors.
    Mar 20 2008
    Belmont MA
    Quote Originally Posted by EBG 18T View Post
    Good to know, that was the next thing for me to start figuring out.
    DG '02 A4 1.8TQM
    My Build Thread
    Feb 02 2008
    Somerset, NJ
    Quote Originally Posted by Risky Bizkit View Post
    Havent heard from you in a while. How are things going with thee 18g? I guess your still a happy camper!
    RIP 2003 A4 1.8TQM
    Veteran Member Four Rings Ace's Avatar
    Nov 29 2005
    Belgium
    Considering the potential of the 18G & 20G you should be able to improve on that.
    But the key is to get everything working perfectly.
    Denim Blue 2002 A4 1.8T FWD Stock 190HP(BEX Engine) Stage3
    Audi A5 2.0TFSI Coupe B8.5 EA888.3 OEM 225HP/257 ft lbs - Stage 3 623HP: Custom 4" Intake , Milltek Quad tip exhaust, Wagner Tuning Competition FMIC, Forged internals, GTX3077R Gen2 custom turbo for longitudinal, Snow performance WMI
    Mar 27 2005
    The Cold North
    Did GIAC ever release the file they worked on with Jeff for these turbos? That is the biggest problem I see for y'all is you have no solid off the shelf software to start with.
    2020 Chevy AEV ZR2
    Nov 29 2005
    Belgium
    I remember something about Maestro making a file for them also.
    Unless i am mixing it up with GIAC
    Veteran Member Four Rings mrbacardi35's Avatar
    Sep 18 2006
    Fresno/Los Angeles, CA
    Welcome to the PSI concept turbo..Very nice build sir..Just a suggestion get the FSI coils makes a whole lot from take off and not so sluggish.
    Regarding GIAC, I think Jeff is running GT30 series turbo so probably not available for 518/520 turbo.
    Mar 20 2008
    Belmont MA
    I got my first revision from Dan last night for the tune. Base map had been set at 13.5psi to make sure the injectors were set correctly and the revision has the boost turned back up because the injectors look pretty good. Should be able to reflash and go out for some logs tomorrow, if not tonight.
    DG '02 A4 1.8TQM
    My Build Thread
    Mar 20 2008
    Belmont MA
    Quote Originally Posted by mrbacardi35 View Post
    Is it a significant upgrade from the Hitachi bolt-downs? I picked those up right when I got the car as it blew a CP the first day I had it.
    DG '02 A4 1.8TQM
    My Build Thread
    Veteran Member Four Rings EErie B6's Avatar
    May 30 2008
    Honda HRX
    Penna.
    The Hitachi bolt-downs are rock solid reliable, but they do not throw a very hot spark. The FSI CPs throw a hotter spark allowing you to open your gap up to .040-.045... in the process, they are supposed to yield a little more power and better throttle response.
    Sep 18 2006
    I can't confirm but switching from Rev D to FSI was significant for me from take off. I probably didn't gain any horse, but I really like when you step on the gas the car response a lot better.
    Dec 01 2007
    think the only ones to have that file are Jeff and Kirk. Both running Gt30's. So no software/tuning yet for the 20g. J-fonz wants toDyno Tune my car and Popo's car, once all our issues are resolved.
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    Dec 06 2011
    Hah, yeah mate, been away for a while, girlfriend trouble which lead to financial dramas if you catch my drift!
    Ordered some new bits and pieces including the TFSI Coil packs, IE adapters, RS4 sway bar and a new Intake that Im guna make you wait for :-) will post once its all done.
    Congrats joining the PSi concepts crew Agart.
    -George
    Veteran Member Four Rings groundround's Avatar
    Jun 19 2009
    17 ram 1500
    Hartford CT
    Wow u are right down the street basically and never seen u! Jealous u have a garage lol
    Registered User Four Rings Doug@FrankenTurbo's Avatar
    Oct 19 2009
    Gary Fisher Sugar 2+, Trek HiFi 29er
    Portlandish
    I know this is a bit of a necromancer thread, but how many other folks are running TD05H-based turbos? Lately I've been taking a hard look at doing a bigger turbo based on its chassis.
    Veteran Member Four Rings B5nDisciple's Avatar
    Aug 23 2014
    2006 Honda Odyssey--Cannondale Caad 12--Giant Talon
    Tucson
    Quote Originally Posted by Doug@FrankenTurbo View Post
    That would be sweet!
    Then Jesus said, “Come to me, all of you who are weary and carry heavy burdens, and I will give you rest." Matthew 11:28
    Jun 27 2011
    I always have thought the TD05 turbos are pretty rad. They're cheaper/simpler than a Gt28 but still offer really solid performance. Pretty damn bulletproof too.
    Is PsiConcepts still around? I know their website is still up, but I've heard almost nothing from them or about them at all in almost 2 years...
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Aug 23 2014
    Tucson
    Yes they are alive and well. I was considering that setup as an option before shrinking my budget and going with the F21L. As a previous 50 trim DSM owner, I really like the TD05 setup. My 50 trim Talon AWD went 12.6 @ 111 on 15 psi and 91 pump lol.
    Veteran Member Four Rings DiertyEuroSpec's Avatar
    Aug 21 2009
    Fairfield County, CT
    Hell yes!! Great platform!
    2003 A4 1.8T Quattro | 18" BBS CH | KW V3 | FT F21 Mixed Flow | MOTOZA | RA4 Stage 1 w/SMFW | Milltek | Uni HFC/3'' DP Combo | 3'' TIP w/MAF | 550cc | TR1.8 FMIC | USP F/R | H-Sport F/R Sway | APR Snub | RS4 Motor Mounts | Stern Trans Mount | Skid Plate | Solid Tie Rod Ends | Short Shifter | Euro Shift Knob | VMR Boost Gauge | S4 F/R Brakes | Tyrolsport Stiffening Kit | ECS S.S. Lines | Hawk HPS Pads | 034 PCV
    Veteran Member Four Rings ZipMeUpJ's Avatar
    Nov 12 2012
    hologram R8
    boston
    as a kit??
    2012 A6 3.0T prestige | Midnight Blue Metallic | Nougat | ACC | Stock (gone)
    2003 1.8t 5spd FW(trash) Quattro swap (in progress) | audiUP snub | Depo Ecodes | Mini H1 retro | 4300k | 07k FSI coils | BKR6E | de-badged | BC Type BR | Swift Springs | BBS LM Reps 18x9.5 | 25FTG F+R | Tasteful poke
    Mar 20 2008
    Belmont MA
    Oh man, haven't updated this in a while... So here's a quick one.
    I'm no longer mafless. TT225 MAF and a tune by Daz. Runs solid at 20psi. Car is currently on stands while I put a new clutch in and rebuild the transmission. Also have new exhaust piping as my flex pipe has a hole in it and I wanted to switch to single muffler, single inlet, dual oulet. I have a terrible drone in the car that I believe is due to having no resonators and dual mufflers in the stock location.
    Cosmetically I got euro bi-xenons, front S4 seats, front USP bumper, rear S4 bumper and I wrapped my doorblades in carbon fiber. Performance wise I switched my rear Stasis brakes for S4 brakes and I got the 034 front sway bar endlinks. Got the FSI coil packs and switched to NGK plugs as well.
    I bought a spare block that I've been waiting to build but I'm not entirely sure the route I want to go, most likely a 2.0 EFR. We'll see.
    I'd definitely be interested to see other TD05H based units/kits though all I ask is a different exhaust manifold. My only gripe with the PSi one is the difficulty in installing it. Both the mounting points to the block as well as the mounting points to the turbo make it really hard to access and, even then, making sure it was secure and nothing was going to back out was a chore.
    DG '02 A4 1.8TQM
    My Build Thread
