Results 1 to 15 of 15
    Veteran Member Two Rings
    Mar 02 2004
    2001 Audi A4 Avant
    Upstate NY
    Opinions on Coilover Suspension for Avants.
    What is your experience or understanding of buying coilovers for an Avant due to the heavier rearend? Should we have a higher spring rate in the back or just set the height a bit higher?
    I am looking for advise on our unique Avant situation and what people are happy with. This is for my A4 of course.
    Current:
    2001 Audi A4 Avant, Stage 3 (17 years, 120K)
    Sold:
    1999 Audi A6 Avant, Worn (3 years, 134K)
    1996 Audi A6 Avant (5 years, 155K)
    *(Owned, Odometer)
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Re: Opinions on Coilover Suspension for Avants.
    They work fine. I've run corner balanced KW V1 coilovers at various heights and they were fine. Plenty of track time too.
    I'm now running Shine Racing suspension with 400 lb. springs and Bilstein HD struts that may or may not be custom valved. It rides better, handles better, and sits high enough to get through the winter.
    Jim
    I Do Werk.
    Mar 09 2004
    nw michigan.
    Jim
    I Do Werk.
    Mar 02 2004
    2001 Audi A4 Avant
    Upstate NY
    Thanks. I am thinking of getting the GT Coilovers.
    Current:
    Sold:
    *(Owned, Odometer)
    Registered Member Two Rings
    Jan 06 2008
    langhorne, pa
    i am running H&R avant SPECIFIC coils.
    I am very happy with them, and for the price, you cant beat them
    www.blowneuroz.com
    www.radusadirect.com <-the BEST place for wheel bolts
    Veteran Member Four Rings sliverwagon's Avatar
    Feb 06 2005
    EAI Bareknuckle
    Shawnee on Delaware
    I had Koni's on my B6 avant and loved them
    Veteran Member Four Rings jbrentd's Avatar
    Oct 31 2005
    '13 allroad, '91 Coupe Quattro, '64 Corvette, '93 Corvette, '21 Bronco
    Tulsa, OK
    No complaints here from my streetsports.
    1991 Coupe Quattro - Project Car
    2013 allroad - My DD
    2011 A3 S-Line - Son's DD
    SOLD - 2007 A6 4.2L // 2001 Pelican A4 Avant // 1996 A4
    Feb 12 2004
    ‘23 RS5 Sportback '20 Q8 S-Line
    I have Stasis SS on my B7 and they are pretty damn low without the ability to go much higher in the rear. it seems to be a common issue on the koni/stasis even with the stasis spacer. I am actually going to look into adding more spacers in the rear.
    with that said, I love them. Great ride for the street and not as aggressive as some.
    Dec 02 2007
    I love mine, wouldnt change a thing
    Feb 06 2005
    EAI Bareknuckle
    Shawnee on Delaware
    Picture with the konis and 18in Oettingers
    Veteran Member Four Rings twinsnailsS4's Avatar
    Richard Henry Dana Jr.
    After a bunch of research when I made my purchase and after reflecting a bit, I think your decision should be driven by what your plans are and what you're willing to spend for that goal. If your plan is strictly aesthetic, you should be fine with any set of c/o's unless there is a specific avant model. If you plan serious track time, the real expensive set ups (e.g., Stasis ms kit) will allow you the ability to play with height and spring rates.
    Assuming you're more in the former department, check out the Vogtland GT kit from Startup. The kit was actually based/tested on Startup's B5 S4 avant. You may also want to shoot them an email for their feedback. Either way, suspension was one of those mods that made a huge difference (akin to the "chip").
    Current: B5 S4 Avant, F10 M5 (comp pkg), 14' Tundra (4x4), Lexus CT200h, BMW S1KRR
    Past: W212 E63, C6 A6 Avant, B5 and B7 S4 Sedans, FD RX7, a Civic Hybrid and 2 Beaters
    Established Member Two Rings Spirare's Avatar
    Jul 08 2008
    Upstate NY
    Mr. Greyhound Guy!!
    Fancy meeting you here...
    You would cry, you would scream
    If you knew half the things I've seen
    Please please just do as I say
    repent and leave you evil ways
    Mar 09 2004
    nw michigan.
    FWIW, I tracked the car extensively for a couple years. Ran it with the balanced coilovers and with stock sport suspension. Both setups had H-Sport bars. Stock suspension was on street tires, coilovers were done with the same street tires and also with r-comp and track pads. Unless you're going to run the sticky tires with aggressive pads it just doesn't matter. The car was a couple seconds quicker on the coilovers but just as much fun without them. The bars were necessary with the stock sport but not with the coilovers.
    Jim
    I Do Werk.
    Mar 02 2004
    2001 Audi A4 Avant
    Upstate NY
    Quote Originally Posted by Spirare View Post
    Mr. Greyhound Guy!!
    LOL, this is where I talk to my Avant peeps.
    Current:
    Sold:
    *(Owned, Odometer)
    Veteran Member Four Rings EuroA4's Avatar
    Feb 12 2004
    PA-NJ
    Quote Originally Posted by mr rolleyes View Post
    DITTO!
